Throttlejockey Posted August 11, 2004 Share Posted August 11, 2004 [quote name='"omarco"'][quote name='"Throttlejockey"'][quote name='omarco'][quote name='Throttlejockey']I thought it was 6 times within 15 seconds?[/quote] Probably you did the first 3 times in 6 seconds and that count?[/quote] I'm sure that's why. I'm going right now to search for the chime. Link to comment Share on other sites More sharing options...
Throttlejockey Posted August 11, 2004 Share Posted August 11, 2004 I think I found it but there's many other wires going into the unit too. It's under the panel on the drivers side. the panel is the cover above the pedals covering the steering shaft. I decided not to start unplugging connectors under there because I don't want to create another problem. Link to comment Share on other sites More sharing options...
Throttlejockey Posted August 11, 2004 Share Posted August 11, 2004 [quote name='jedimaster']There are quite a few things that the dealer can "reprogram", according to the manual. What exactly are they using to do this "reprogramming"? Is it something we can do ourselves, like turning the chirp off on the alarm?[/quote] You can use the remote to turn off the chirp on the alarm. I forget the exact sequence but it's in the manual. Link to comment Share on other sites More sharing options...
bemani Posted August 11, 2004 Share Posted August 11, 2004 Dealer needs to plug in the 'Subaru Select Monitor' computer thingie into the ODB2 port to reprogram all the stupid crap this car has. And I bet they're not trained for it and have to call Subaru tech line to do it. So if you take it in, make sure its a week day. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 11, 2004 Share Posted August 11, 2004 [quote name='Throttlejockey'][quote name='jedimaster']There are quite a few things that the dealer can "reprogram", according to the manual. What exactly are they using to do this "reprogramming"? Is it something we can do ourselves, like turning the chirp off on the alarm?[/quote] You can use the remote to turn off the chirp on the alarm. I forget the exact sequence but it's in the manual.[/quote] Thanks, I do know that- what I wanna know is what the dealer does, or uses to reprogram the features of the car. Link to comment Share on other sites More sharing options...
orpie_lightfoot Posted August 11, 2004 Share Posted August 11, 2004 I use the all the time to the car when to see if I can't figure it out. When I do, I'll Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted August 11, 2004 Share Posted August 11, 2004 [quote name='jedimaster']There are quite a few things that the dealer can "reprogram", according to the manual. What exactly are they using to do this "reprogramming"? Is it something we can do ourselves, like turning the chirp off on the alarm?[/quote] I would be very interested to know as well. All this computerized stuff, I would think someone could "hack" it, and find out how to change those little flags that say chime mode: annoying, Chime mode: mellow, or chime mode: off. Who knows what else there is, Tire Monitor mode on... metric or imperial trip computer... STi mode on (un-detunes the motor back up to 300hp/tq.) Fun fun fun... Link to comment Share on other sites More sharing options...
gtguy Posted August 11, 2004 Share Posted August 11, 2004 [quote name='IwannaSportSedan'][quote name='jedimaster']There are quite a few things that the dealer can "reprogram", according to the manual. What exactly are they using to do this "reprogramming"? Is it something we can do ourselves, like turning the chirp off on the alarm?[/quote] I would be very interested to know as well. All this computerized stuff, I would think someone could "hack" it, and find out how to change those little flags that say chime mode: annoying, Chime mode: mellow, or chime mode: off. Who knows what else there is, Tire Monitor mode on... metric or imperial trip computer... STi mode on (un-detunes the motor back up to 300hp/tq.) Fun fun fun...[/quote] The tire monitor is a mechanical system, fundamentally. I figure the STi mode on is a joke, as the STi runs more boost and a different turbo, for starters. Would but that it were so easy, however. Kevin Link to comment Share on other sites More sharing options...
orpie_lightfoot Posted August 11, 2004 Share Posted August 11, 2004 Theere is a menu for tire monitor, and MANY others I have not explored.... orpie_lightfoot Inside Curve Link to comment Share on other sites More sharing options...
wunderkind Posted August 11, 2004 Share Posted August 11, 2004 I wonder if you were to overclock the ECU, will it make the car go faster? :D Link to comment Share on other sites More sharing options...
brad21 Posted August 11, 2004 Author Share Posted August 11, 2004 Thanks for all the help on this. Unlike the USMB site the "wear your seatbelt" bashing was kept to a minimum here. I wear my seatbelt, I just don't need the reminder when running to the end of the street to get the mail etc... Link to comment Share on other sites More sharing options...
Drift Monkey Posted August 11, 2004 Share Posted August 11, 2004 [quote name='brad21']Thanks for all the help on this. Unlike the USMB site the "wear your seatbelt" bashing was kept to a minimum here. I wear my seatbelt, I just don't need the reminder when running to the end of the street to get the mail etc...[/quote] I ALWAYS buckle, even what I get mail!!!11111one11 Link to comment Share on other sites More sharing options...
Throttlejockey Posted August 11, 2004 Share Posted August 11, 2004 [quote name='jedimaster'][quote name='Throttlejockey'][quote name='jedimaster']There are quite a few things that the dealer can "reprogram", according to the manual. What exactly are they using to do this "reprogramming"? Is it something we can do ourselves, like turning the chirp off on the alarm?[/quote] You can use the remote to turn off the chirp on the alarm. I forget the exact sequence but it's in the manual.[/quote] Thanks, I do know that- what I wanna know is what the dealer does, or uses to reprogram the features of the car.[/quote] Oh, sorry, I misunderstood you. I see what you were saying now. Link to comment Share on other sites More sharing options...
mccorry Posted August 12, 2004 Share Posted August 12, 2004 Any updates on this??? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted August 12, 2004 Share Posted August 12, 2004 I wonder if a laptop could be used. Link to comment Share on other sites More sharing options...
brad21 Posted August 12, 2004 Author Share Posted August 12, 2004 I ALWAYS buckle, even what I get mail!!!11111one11[/quote] Yeah, but you're from Houston where you might have to run for your life at any given time... :P Link to comment Share on other sites More sharing options...
jman3 Posted August 12, 2004 Share Posted August 12, 2004 I recently purhased by Subaru Legacy GT. I love it. I quickly noticed the chime everyone is talking about. What I found I could do is when you initially sit in the car, latch the seatbelt. You can then unlatch the seatbelt, and as long as the car stays in park, the chime doesn't reappear. Althougth, the blinky warning light in the dashboard will still be going. This may work for ya. Good luck, jman Link to comment Share on other sites More sharing options...
WRXTom Posted August 12, 2004 Share Posted August 12, 2004 The chime also comes on if your front seat passenger unbuckles for some reason even when you're parked. My wife often has to do this since we have two small kids in the back seat. Scenario...kids fall asleep in the back but need clothing, blanket, toys, whatever adjusted and I pull over so my wife can reach back to do whatever needs doin'. I pull over, she unbuckles, chime goes off, kids wake up, peaceful silence is broken, Dad dreams of cold beer in fridge when we get home. Tom Link to comment Share on other sites More sharing options...
Drift Monkey Posted August 12, 2004 Share Posted August 12, 2004 [quote name='brad21']Yeah, but you're from Houston where you might have to run for your life at any given time... :P[/quote] Is this a funnAy? If so, please expand. Link to comment Share on other sites More sharing options...
Dr. Zevil Posted August 12, 2004 Share Posted August 12, 2004 The seatbelt chime is annoying. I want it to go away. I wear my seatbelt all the time, but the chime just has to go. Maybe an initial chiming than then silence, but the constant chiming is annoying and distracting. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 12, 2004 Share Posted August 12, 2004 SoA told me the owners manual tells you how to disable the chime. I'll get my 17 y/o son to figure it out. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it.  Engine Build - Click Here Link to comment Share on other sites More sharing options...
IwannaSportSedan Posted August 13, 2004 Share Posted August 13, 2004 Its probably something like: Turn the key from off to -run- 3 times in 20 seconds, then buckle the seatbelt 6 times in 30 seconds... Or something like that. Programming new transponder keys is similar to that. My Ranger has PATS transponder keys. Link to comment Share on other sites More sharing options...
mhelouin Posted August 13, 2004 Share Posted August 13, 2004 I've got an 05 GT 5MT and the dealer can reprogram the chime--they did on mine, anyway. Basically, the way it works--turn the car on. once the beeping starts, insert and take out the seat belt buckle 20 times quickly (like in 30 seconds). turn car off. repeat process. I know it sounds odd, but it works. All i get now when i start the car without the seatbelt plugged in is 4 or 5 chimes. Byers Subaru in Columbus Ohio (by the airport) is my dealership and they can explain it to you if I screwed it up. But it works. Best of luck. --Marc Link to comment Share on other sites More sharing options...
Throttlejockey Posted August 13, 2004 Share Posted August 13, 2004 No, it's 3 times in 6 seconds, it's in the manual. Link to comment Share on other sites More sharing options...
kenzo Posted August 13, 2004 Share Posted August 13, 2004 [quote name='Throttlejockey']No, it's 3 times in 6 seconds, it's in the manual.[/quote] That describes how the chime can be temporarily disabled - only until the car is next started. I think we're all looking for the permanent configuration change. Thanks, kenzo Link to comment Share on other sites More sharing options...
