Marvick08GT Posted May 27, 2021 Share Posted May 27, 2021 (edited) The block came back from Darton and was clearanced and assembled by Agile Auto. Mostly Cosworth parts.... Will be using my current heads using GSC parts and OEM buckets. Waiting on the parts to arrive from Full-Race: EFR 7163 vband coating/blanket Turbosmart Dual Port IWG actuator 4-port EBCS BPV block-off plate F-R up and down coated F-R ELH header for EFR kits coated I also was running out of fuel with the Dom 1.5xtr, So I am using a DW440 brushless setup with PWM controller. Fits in the factory bucket with some modifications. Includes a new pass through connector and harness all the way to the controller. Old AEM 340lph was 340lph@40psi / 260lph@75psi New DW 440lph now 440lph@40psi / 380lph@75psi Controller can also do up to 18v constant if I need more ( 620lph@40psi @ 18v ) Should be enough, I wasn't interested in a dual pump setup or replacing the factory hardlines. Edited May 29, 2021 by Marvick08GT Link to comment Share on other sites More sharing options...
Marvick08GT Posted May 27, 2021 Author Share Posted May 27, 2021 (edited) Reserved Edited June 7, 2021 by Marvick08GT Link to comment Share on other sites More sharing options...
Marvick08GT Posted May 31, 2021 Author Share Posted May 31, 2021 Thinking I want to add a FMIC, I don't like the removal of the crash bar. My tuner wants 2k to do a custom precision core and custom pipes/impact beam. I saw ETS has a kit, but it removes the impact beam. I can install a watersprayer (3/4 done) that might be enough? Tuner says will be fine with TMIC, but will heat soak after a few high boost pulls. Torn! Help! Lolz Link to comment Share on other sites More sharing options...
awfulwaffle Posted May 31, 2021 Share Posted May 31, 2021 Cobb 08-14 WRX/STI fits with tweaks and bumper mods, has a crash bar Link to comment Share on other sites More sharing options...
NoOne1223 Posted May 31, 2021 Share Posted May 31, 2021 Nice work! Link to comment Share on other sites More sharing options...
boxkita Posted June 1, 2021 Share Posted June 1, 2021 heat soak, bah! once you are 35mph, there's no soak with functional hood scoop. if yer really worried about it (waiting in line at drag strip or autox), reroute your ac to the tmic, should cool it off quickly Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 1, 2021 Author Share Posted June 1, 2021 I want to be able to keep the fog lights as well, looks like that's not possible with the Cobb. Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 1, 2021 Author Share Posted June 1, 2021 Once it gets really hot it takes a while to cool down. I just don't want to leave anything on the table. I have seen a few 500-600+ HP subarus on a tmic (GS,ETS). I figured I am in so deep, why stop now? Link to comment Share on other sites More sharing options...
boxkita Posted June 1, 2021 Share Posted June 1, 2021 seems odd to do sleeves but not closed deck testing at track showed 35mph was break even point for cooling the tmic. in autox line, 5lb bag of ice was extremely effective at cooling the tmic (discovered while dyno testing) Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 1, 2021 Author Share Posted June 1, 2021 Closed deck is to try and reinforce the factory cylinder walls. Replacing the factory sleeves with steel sleeves keeps the cylinders from flexing. Link to comment Share on other sites More sharing options...
Tehnation Posted June 1, 2021 Share Posted June 1, 2021 closed deck vs sleeves , I'd go sleeves you can keep reusing the same block and just change sleeve after the season or whenever. Can you even sleeve a CD, i've never heard of a block thats closed deck with sleeves? I always thought with the ej25 people do one or the other? Or did I just fall behind the times.....again, lol. Link to comment Share on other sites More sharing options...
boxkita Posted June 1, 2021 Share Posted June 1, 2021 Closed deck is to try and reinforce the factory cylinder walls. Replacing the factory sleeves with steel sleeves keeps the cylinders from flexing. actually closed decking controls the flexing. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted June 1, 2021 Share Posted June 1, 2021 closed deck vs sleeves , I'd go sleeves you can keep reusing the same block and just change sleeve after the season or whenever. Can you even sleeve a CD, i've never heard of a block thats closed deck with sleeves? I always thought with the ej25 people do one or the other? Or did I just fall behind the times.....again, lol. you do realize all aluminum blocks are sleeved? although the oem sleeve is called a liner. you can sleeve anything. or close deck anything. close deck tends to better for sustained high rpm while sleeving is better for high output. generalization only. once you reach a certain point, a forum is not your best source of information. there's a limit to how many times you can sleeve an engine before there's no more original material for it to bond to. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Tehnation Posted June 1, 2021 Share Posted June 1, 2021 (edited) I meant I never seen someone put aftermarket sleeves in a CD. I was talking more aftermarket sleeves not oem. CD blocks aren't meant to be modified... so you either get CD case halves or sleeve regular case halves, but I've never hear of aftermarket sleeves in a CD. Edited June 1, 2021 by Tehnation Link to comment Share on other sites More sharing options...
boxkita Posted June 1, 2021 Share Posted June 1, 2021 I meant I never seen someone put aftermarket sleeves in a CD. I was talking more aftermarket sleeves not oem. CD blocks aren't meant to be modified... so you either get CD case halves or sleeve regular case halves, but I've never hear of aftermarket sleeves in a CD. willall block is sleeved Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 1, 2021 Author Share Posted June 1, 2021 In all fairness the willall block is custom made... On a side note, ordered the Killer B water pump outlet and their new hard inlet (should have it by mid june). https://www.killerbmotorsport.net/killer-b-motorsport-extreme-flow-hard-turbo-inlet.html Link to comment Share on other sites More sharing options...
tysparks81 Posted June 1, 2021 Share Posted June 1, 2021 technically Marvick could have his sleeved block sent out to be closed decked now that it is sleeved. But he could not close deck the block then have it sleeved later. Also it would be similar to IAG's Billet Aluminum block found here. #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
Tehnation Posted June 5, 2021 Share Posted June 5, 2021 (edited) everyones so technical lol! Ok i get it, but lets be real, when you have a block thats custom made from a block of aluminum, you can adjust the design to accommodate whatever you want like the sleeves. I was more talking about average joe with regular oem case halves, not a specific one off design specially made to have the best of both worlds. For regular oem case halves, I think both aren't done because of heat issues, cause now your gonna have thicker walls and less coolant flowing, probably not a good long term operation design. But holy shit look at the thing its gorgeous but 16k.... no wonder its gold lol. Thats a down payment on a house lol Hmmm now you have me thinking, whos running a sleeved and closed deck block? I just don't see it much, but i guess it doesn't mean its not possible, now I have to start thinking about getting me a closed deck insert and sleeve for my next engine build. Edited June 5, 2021 by Tehnation Link to comment Share on other sites More sharing options...
boxkita Posted June 5, 2021 Share Posted June 5, 2021 closed deck/sleeves fall in the "i have money to burn" category for a street-driven car. By the time you're stressing the block enough to need that, you are spending money like there's no tomorrow. if you are looking for sleeved/closed deck engine owners, try a racing forum for engines that need it. nasioc for engines that don't. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted June 5, 2021 Share Posted June 5, 2021 In all fairness the willall block is custom made... On a side note, ordered the Killer B water pump outlet and their new hard inlet (should have it by mid june). https://www.killerbmotorsport.net/killer-b-motorsport-extreme-flow-hard-turbo-inlet.html post pics? I got an email about this. And have something like this in a box somewhere. Seemed gimmicky until I looked at the current state of mine (crushed). Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 5, 2021 Author Share Posted June 5, 2021 Are you referring to the water pump outlet? Link to comment Share on other sites More sharing options...
boxkita Posted June 5, 2021 Share Posted June 5, 2021 Are you referring to the water pump outlet? the other one. from the link Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 5, 2021 Author Share Posted June 5, 2021 Ohh, I don't have it yet. They are releasing stock mid June. I will definitely post pics once I have it! Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 9, 2021 Author Share Posted June 9, 2021 Update on the Killer B Inlet: pre-ordered it and they said mid-june. Called a week later they said early July. Now they are telling me mid september.. FML In other news.. TurboXS front mount is on the way! Had to be done, water sprayer helped a lot and will be moved to the FMIC. Link to comment Share on other sites More sharing options...
Marvick08GT Posted June 10, 2021 Author Share Posted June 10, 2021 Front mount arrives today, ordered a KSTech intake with heatshield to make it cold air specifically for the turboxs FMIC and the legacy body. Also found a DGM non-turbo hood at my local junkyard and bought it($100). Will pick the hood up tomorrow morning. This means I will have my Cobb with madrig carbon, full grimmspeed TMIC setup and my extended carbon scoop for sale soon! Once it is all on, I just need to get an IAT bung welded on the throttle pipe and should be good to go for now. Probably be dropping the car off in a week or 2. Link to comment Share on other sites More sharing options...
