Tehnation Posted March 29, 2022 Share Posted March 29, 2022 A bunch of us already have the braided ss upgrade, anyway to make it work with a a simple adapter or something? On another note, how do the bigger brakes feel? Or did I miss that part? Link to comment Share on other sites More sharing options...
mike-tracy Posted March 30, 2022 Share Posted March 30, 2022 Already have braided lines. Link to comment Share on other sites More sharing options...
Neal Cassady Posted April 3, 2022 Share Posted April 3, 2022 Have not installed them on the car with fluid running to them to test feel, however based on calculations for pedal torque, travel and BMC size, I expect the following (if you were to control for lines/fluid/pad type): OEM pedal travel is pretty long stock, so the WRX 1" or STI 1 1/16" mc are both a good upgrade with stock brakes. It's not required for the 17Z calipers, but definitely a worthwhile change, especially with a STI booster. Using the 17Z calipers & LGT rear sliding calipers, there is only about a 5% increase in pad area. Using the 17Z calipers and STI rear brembos, reduces this to about 1% (STI rear brembo has a smaller piston area), but shifts the bias forward due to increased front torque (73.9% to 75% front, OEM is 72.2%). This could be balanced by having a more aggressive rear pad, however with how nose heavy our cars are, its likely a good thing, or at least has minimal impact for 99% of drivers. The pedal travel will be about 5% longer with the 17Z calipers and OEM LGT master cylinder (15/16"). The STI master reduces travel by about 18% with the 17Z calipers, compared to stock MC/brakes. As for banjos, normally I would caution against them as there is nothing to prevent the line from rotating and loosening the banjo (Audi/VW people have leaking issues when using banjo lines instead of male flare fittings). However I took a look at my test set up, and a simple p-clamp to the upper caliper bolt could remove this risk. The OEM LGT M10x1.0 banjo bolt fits the 17Z caliper, so this could be a cheap, simple solution that avoids custom lines. Photos show an LGT OEM line and OEM banjo bolt attached to the caliper. 1 2006 Legacy GT Wagon - Regamasters, Evo X Recaros, STI 6MT, Brembo 6-Pots (in progress) @regashiii Link to comment Share on other sites More sharing options...
Ajerezcl Posted August 1, 2022 Share Posted August 1, 2022 I am looking forward to buying. Would you sell just the conversion kit? I could buy the calipers now if I find a good price Link to comment Share on other sites More sharing options...
pksystems Posted October 6, 2022 Share Posted October 6, 2022 I have a set of these calipers ready to go on my car... And a set of 2 piston mercedes rear brembos that I hope to modify for the rears. Link to comment Share on other sites More sharing options...
Cney Posted November 9, 2023 Share Posted November 9, 2023 Hey, It's been a year and I'm wondering if these brackets/conversion kit are close to release or released? 1 Link to comment Share on other sites More sharing options...
vcboi617 Posted November 10, 2023 Share Posted November 10, 2023 Same here. Hopefully they will be ready soon. Link to comment Share on other sites More sharing options...
Cney Posted November 10, 2023 Share Posted November 10, 2023 If not I'm able to have a set made in a CNC machine at my place of work if OP was willing to share the files. 1 Link to comment Share on other sites More sharing options...
wagn.ben Posted January 7 Share Posted January 7 hey Neil. any update on this project or if not would you be willing to share the files in order to continue this? You've put in alot of the hard work just needs manufacturing and would be more than happy to begin product runs if its too much of a struggle for you. ive got 17z calipers powder coated so would like to see if you are keen on sharing the files or I may have to begin designing my own adapters thanks Ben Link to comment Share on other sites More sharing options...
MM23 Posted February 4 Share Posted February 4 Hi everybody especially Neil I stumbled on on your touareg 17zr calipers swap topic while searching the internet for 3d model of touareg 17zr caliper. Great work! I am swapping those caliper on my VW Amarok Project. You probably invested a lot of time in to making 3d model of touareg calipers. But I need to ask are you willing to share 3d model, it will help me a lot with making a adapter? Thanks in advance Link to comment Share on other sites More sharing options...
Febreze Mee Posted February 11 Share Posted February 11 Going to be in the market for calipers soon, and will be holding out for a couple more months on an update here, before deciding for Cadillac Brembos. MILKRUN - Click Here Link to comment Share on other sites More sharing options...
