Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 had to, i was right near my house, and no phone or wallet... just wanted to get it back in my driveway, so I let it sit for 5 minutes, got it started and cruised home. I initially thought it was an overheating issue, so I let it cool down for a couple hours, tried to start it and that was that. Everything is retrospect, so its not as bad as you think it is lol. Looking for a boroscope on amazon atm. I really need the sb to be fine, heads being ok would be a bonus. I'm hoping the squealing I heard is from a bearing on timing belt and not a camshaft or my turbo. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted August 31, 2020 Share Posted August 31, 2020 had to, i was right near my house, and no phone or wallet... just wanted to get it back in my driveway, so I let it sit for 5 minutes, got it started and cruised home. I initially thought it was an overheating issue, so I let it cool down for a couple hours, tried to start it and that was that. Everything is retrospect, so its not as bad as you think it is lol. Looking for a boroscope on amazon atm. I really need the sb to be fine, heads being ok would be a bonus. I'm hoping the squealing I heard is from a bearing on timing belt and not a camshaft or my turbo. I had an sti that jumped a few teeth once. After the timing was reset it fired right up so you might be ok! Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 It is the timing belt , all the marks are gone, and I have this black streak running throughout the entire thing. The tensioner bolt nut came loose and the bolt was just freely moving..... wtf happened..... Ok, So I need a new timing belt and tensioner... who makes a high quality product?? I hear gates is crap now. I just hope my valves didn't get the kiss of death.... Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 The nut came off completely .... wtf... other than that everything else looks good, Ordered a new gates blue belt. Loctite! New Belt should be here tomorrow. Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 I think the belt must have slid of onto the back part of the narrow bearing. Only place I see it can track anything black onto the belt. Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 Changing the timing belt in the engine is going to suck, I got spoiled doing it on a stand... ordered some cam adjust tools as well with the new belt https://www.amazon.com/gp/product/B07JLFKVDS/ref=ox_sc_act_title_2?smid=A1DA8RL16JPDA0&psc=1 https://www.amazon.com/gp/product/B07D4JNFT5/ref=ox_sc_act_title_1?smid=A2GLJ7X54D1BMY&psc=1 I'm not going through that nonsense again in that tight space. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted August 31, 2020 Share Posted August 31, 2020 Do your timing marks still remotely line up on the cams? Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 (edited) there are zero marks! Everything was rubbed off. oh the cam marks, the double notches , not sure they are on opposite sides. I would have to move it all somehow, but they should be close. Edited August 31, 2020 by Tehnation Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted August 31, 2020 Share Posted August 31, 2020 there are zero marks! Everything was rubbed off. The actual physical marks on the cam gears should still be visible as opposed to the paint marks. Though I guess if it’s still starting to some extent then they must be close. Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 I'm going to change the belt and see what happens! Link to comment Share on other sites More sharing options...
Max Capacity Posted August 31, 2020 Share Posted August 31, 2020 (edited) Aisin TSK004 I think is the correct part # for the timing belt most of use now day's. Or if you just need a belt, go to Advance Auto Parts and get a Dayco belt. I used that the first time back in 2008. https://legacygt.com/forums/showthread.php/replacing-timing-belt-94193.html?t=94193 post #20 Edited September 3, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
k00laid83 Posted August 31, 2020 Share Posted August 31, 2020 Aisin TSK004 I think is the correct part # for the timing belt most of use now day's. Or if you just need a belt, go to Advance Auto Parts and get a Dayco belt. I used that the first time back in 2008. https://legacygt.com/forums/showthread.php/replacing-timing-belt-94193.html?t=94193 post #9 That's the right part number. I just checked my timing belt kit label. Link to comment Share on other sites More sharing options...
rhino6303 Posted August 31, 2020 Share Posted August 31, 2020 Did you torque the tensioner correctly? Some people use loctite on that bolt. Link to comment Share on other sites More sharing options...
Tehnation Posted September 1, 2020 Author Share Posted September 1, 2020 They were both torqued correctly, no loctite though. Link to comment Share on other sites More sharing options...
Tehnation Posted September 2, 2020 Author Share Posted September 2, 2020 not out of the woods yet... some weird sound is coming from the motor, doesn't seem like a valve. I think the tensioner is shot completely and isn't giving any tension, and is hopefully bouncing up and down. So, ordered a new tensioner, an aisin tensioner. Started fine then after that seems like it went out of timing right after 1st start. If its not the tensioner, then I'm screwed and have to pull the motor. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted September 2, 2020 Share Posted September 2, 2020 Good lord Link to comment Share on other sites More sharing options...
Tehnation Posted September 5, 2020 Author Share Posted September 5, 2020 bent a exhaust valve on the passenger side. motors out, heads should be off by tomorrow, going to shop on tuesday, hopefully will get it back friday, and then motor should go back in the car next weekend. Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted September 5, 2020 Share Posted September 5, 2020 Man, you’re just not having any luck at all... Link to comment Share on other sites More sharing options...
NSFW Posted September 5, 2020 Share Posted September 5, 2020 Oof. Sorry to hear it. Link to comment Share on other sites More sharing options...
Tehnation Posted September 6, 2020 Author Share Posted September 6, 2020 I must be a masochist because I just keep coming back for more lol.... Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted September 6, 2020 Share Posted September 6, 2020 I must be a masochist because I just keep coming back for more lol.... Masochism, it’s what makes a Subaru, a Subaru. If it makes you feel any better I swore off Subaru’s somewhere in the 5-8yr ago range. (The time flies by so fast now) I’m back. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 6, 2020 Share Posted September 6, 2020 Bent valve, sorry to hear that. Is that caused by the valve lash being off ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
rhino6303 Posted September 6, 2020 Share Posted September 6, 2020 Bent valve, sorry to hear that. Is that caused by the valve lash being off ?It sounds like his tensioner failed at potentially high rpm. @Tehnation, was it both heads or just one? Link to comment Share on other sites More sharing options...
Tehnation Posted September 7, 2020 Author Share Posted September 7, 2020 (edited) Looks like just one head or cylinder rather. It was caused by the tensioner failing at high rpm like rhino said! Don't forget I have stage 3 cams, so the lift and duration are longer, so those valves are going out further longer..... not a good recipe for bad timing. Edited September 7, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted September 7, 2020 Author Share Posted September 7, 2020 (edited) Shouldn't cost much to test the valves to see which are still sealing and replace whatever valves are bent, probably like 200-400 for both heads. Biggest cost is the damn time it takes pulling this crap apart, getting a buddy over to help and putting it all back together..... so damn time consuming. It would be so convenient to be able to pull the heads without pulling the entire motor. So much work for a silly little 4 cylinder, plus it has 2 cylinder heads, 4 cams.... sheeshhhh god damn ej blocks are a pita, its like some freak v4 engine but without all the awesome power of a v8... half a v8 twice the work.. wtf Edited September 7, 2020 by Tehnation Link to comment Share on other sites More sharing options...
