Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 What kind of leak, fuel or air? I have Deatschwerks 17U-07-1000-4 injectors. https://www.deatschwerks.com/17u-07-1000-4 They came with a card, no idea where it is. I think it only had the flow rate though. Link to comment Share on other sites More sharing options...
Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 My fuel pressure seems high, gauge was reading around 60 psi when idling, and when it was about to die it dropped down to around 40 Link to comment Share on other sites More sharing options...
rhino6303 Posted August 18, 2020 Share Posted August 18, 2020 What kind of leak, fuel or air? I have Deatschwerks 17U-07-1000-4 injectors. https://www.deatschwerks.com/17u-07-1000-4 They came with a card, no idea where it is. I think it only had the flow rate though.Air. You'd know if you have a fuel leak. My fuel pressure seems high, gauge was reading around 60 psi when idling, and when it was about to die it dropped down to around 40What does your FPR install look like? When you did your top feed conversion, did you use the fuel rail mounted FPR or a different setup? Link to comment Share on other sites More sharing options...
Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 (edited) I have an 07+ fuel rail mixed with 05 fuel rail, didn't use the fuel rail mounted fpr. I have an sti fpr on the return line and gauge on the other line. The setup worked prior to rebuild. https://legacygt.com/forums/showpost.php?p=5982271&postcount=370 Edited August 18, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 60psi is around where oem fpr's max out. Maybe I need an aftermarket fpr to get higher fuel pressure. Seems like I need higher pressure. Link to comment Share on other sites More sharing options...
Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 I have some cheap fpr boxing around somewhere, can go up to 150 psi. Maybe I will try it out tomorrow see if that changes anything. Link to comment Share on other sites More sharing options...
rhino6303 Posted August 18, 2020 Share Posted August 18, 2020 At idle your fuel pressure should be around 38 psi with the vacuum line connected and 43 psi with the line disconnected. Link to comment Share on other sites More sharing options...
Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 That's for stock setup, might not be the case anymore. Guys on nasioc have been modding their fprs by banging the top to raise the fuel pressure. Why do people use aftermarket fprs if not for more fuel pressure? Link to comment Share on other sites More sharing options...
rhino6303 Posted August 18, 2020 Share Posted August 18, 2020 That's for stock setup, might not be the case anymore. Guys on nasioc have been modding their fprs by banging the top to raise the fuel pressure. Why do people use aftermarket fprs if not for more fuel pressure?More fuel pressure at idle isn't better though. People used to mod the fpr because they were running high boost and needed more pressure to stay 1:1 for boost and fuel. When you did your fuel pump wiring, did you keep the FPCM wired in so you still have 33, 66 and 100 for the duty cycle? I'm sending a PM too. Link to comment Share on other sites More sharing options...
Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 I just wired it according to the post underdog made. https://legacygt.com/forums/showthread.php/fpcm-wiring-upgrade-relay-staying-switched-w-key-off-242295.html which is an upgrade from https://legacygt.com/forums/showthread.php/upgrading-your-fuel-pump-wiring-4th-gen-213570.html Link to comment Share on other sites More sharing options...
Tehnation Posted August 18, 2020 Author Share Posted August 18, 2020 I really don't think I have a leak. Ive been chasing leaks in this car since I bought it, I have memorised the entire vacuum system. I bought the smoker because if its a leak its gotta be really small. Exhaust system is tight and right as well. I've pulled this car apart dozens of times. So I have considered all the usual things. It has to be something stupid.... Link to comment Share on other sites More sharing options...
Tehnation Posted August 24, 2020 Author Share Posted August 24, 2020 IT LIVES!!! Just took it on the road!! Drives good except for the clutch sorta sticking to the floor for some reason. This EFI tuner is pretty damn good, he had my fuel trims etc. dialed on the 1st map he sent. 2nd map fixed the issue with finding idle. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 26, 2020 Share Posted August 26, 2020 Good to hear. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 26, 2020 Author Share Posted August 26, 2020 Actually, the clutch is working fine now... not having that issue anymore. Link to comment Share on other sites More sharing options...
Tehnation Posted August 26, 2020 Author Share Posted August 26, 2020 I love these stage 3 cams..... I can drive around in second gear and get up to 60mph with room to spare and I'm only running 7psi of boost atm. This is exactly what I wanted, band was moved to the right. Can't wait to get it on the dyno... gotta get these cylinder rings seated asap... only done like 35 miles so far, another 965 to go! Link to comment Share on other sites More sharing options...
Tehnation Posted August 26, 2020 Author Share Posted August 26, 2020 (edited) I totally forgot about 93 pricing swings.... I need to start paying attention to gas prices again. I paid like 3.30 a gal to fill up at the close gas station, the expensive one. Drove down the block and it was like 2.97. Normally for 87 there isn't much of a difference but the 93 varies a lot from place to place. The variation and the extra add up, 3.30 is like 75 cents more than 87. Edited August 26, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Max Capacity Posted August 27, 2020 Share Posted August 27, 2020 Yeah, gas prices vary from place to place or town to town. I find that MA. has cheaper prices then CT. Though BJ's Wholesale Club has 93 for $2.44 the other day. Glad to hear the car is doing well. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 30, 2020 Author Share Posted August 30, 2020 (edited) ANDDDD THERE GOES A VALVE!! OMFG!!! motors gotta come back out.... a 3rd time....3rd times a charm right! smh...... I knew I shouldn't have cheaped out on the valvetrain.... I just knew it would come back to bite me in the ass..... what made me think valves with 120k miles on it would be good enough..... oh well.... back to the drawing board, hopefully my sb is still good. But it looks like a valve is loose and floating. This time new guides new and better valves new and better valve locks Any recommendations? I will probably just get the entire BC package otherwise. BC2960- 6° Billet Keepers / Locks for Subaru EJ205/EJ257 applications BC3600- 36.0mm Intake Valves (standard head diameter) BC3601-INC- 32.0mm INCONEL Exhaust Valves (standard head diameter) BC3960- 6.0mm INTAKE Valve Guides (Subaru EJ205, EJ257, EJ257B) BC3961- 6.0mm EXHAUST Valve Guides (Subaru EJ205, EJ257, EJ257B) god help me.... Edited August 30, 2020 by Tehnation Link to comment Share on other sites More sharing options...
Tehnation Posted August 30, 2020 Author Share Posted August 30, 2020 (edited) This train will not stop, I'm tearing it down first thing tomorrow morning. I guess now I can install that tsk3 snout kit.... #cryinginthecorner Edited August 30, 2020 by Tehnation Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted August 30, 2020 Share Posted August 30, 2020 ANDDDD THERE GOES A VALVE!! OMFG!!! motors gotta come back out.... a 3rd time....3rd times a charm right! smh...... I knew I shouldn't have cheaped out on the valvetrain.... I just knew it would come back to bite me in the ass..... what made me think valves with 120k miles on it would be good enough..... oh well.... back to the drawing board, hopefully my sb is still good. But it looks like a valve is loose and floating. This time new guides new and better valves new and better valve locks Any recommendations? I will probably just get the entire BC package otherwise. BC2960- 6° Billet Keepers / Locks for Subaru EJ205/EJ257 applications BC3600- 36.0mm Intake Valves (standard head diameter) BC3601-INC- 32.0mm INCONEL Exhaust Valves (standard head diameter) BC3960- 6.0mm INTAKE Valve Guides (Subaru EJ205, EJ257, EJ257B) BC3961- 6.0mm EXHAUST Valve Guides (Subaru EJ205, EJ257, EJ257B) god help me.... Oh dear god no. That absolutely sucks!! Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted August 30, 2020 Share Posted August 30, 2020 I have a spare short block if you end up needing some case halves or anything. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 30, 2020 Share Posted August 30, 2020 ANDDDD THERE GOES A VALVE!! OMFG!!! motors gotta come back out.... a 3rd time....3rd times a charm right! smh...... I knew I shouldn't have cheaped out on the valvetrain.... I just knew it would come back to bite me in the ass..... what made me think valves with 120k miles on it would be good enough..... oh well.... back to the drawing board, hopefully my sb is still good. But it looks like a valve is loose and floating. This time new guides new and better valves new and better valve locks Any recommendations? I will probably just get the entire BC package otherwise. BC2960- 6° Billet Keepers / Locks for Subaru EJ205/EJ257 applications BC3600- 36.0mm Intake Valves (standard head diameter) BC3601-INC- 32.0mm INCONEL Exhaust Valves (standard head diameter) BC3960- 6.0mm INTAKE Valve Guides (Subaru EJ205, EJ257, EJ257B) BC3961- 6.0mm EXHAUST Valve Guides (Subaru EJ205, EJ257, EJ257B) god help me.... Sorry to hear that, take a step back and think for a minute. The valves should have been fine. My wagon still has all the valves that came in the engine. I would guess the valve lash was off ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 No idea what happened. Was beating it on the highway and then it lost power, now its hard to start and barely runs, and has a weird squeak and some random tapping noises. Who knows whats wrong with it. First I'll inspect the timing belt, then the turbo, then pull the block. Link to comment Share on other sites More sharing options...
Tehnation Posted August 31, 2020 Author Share Posted August 31, 2020 (edited) After taking a break from it and thinking it over.... i think something happened with the timing belt, like the tensioner took a sh**. Lets pray it is something simple. If it were a valve it would start but sound like crap and change with the rpms. My motor can barely start, takes a ton of cranking, like when you have a tooth off. Dear god give me a win!!! If its the timing belt I can be up and running a lot sooner. I had a gates racing timing belt kit with the blue kevlar belt that I bought way back in the day, bought it like 5+ years ago. Edited August 31, 2020 by Tehnation Link to comment Share on other sites More sharing options...
ViscousSquirrel Posted August 31, 2020 Share Posted August 31, 2020 After taking a break from it and thinking it over.... i think something happened with the timing belt, like the tensioner took a sh**. Lets pray it is something simple. If it were a valve it would start but sound like crap and change with the rpms. My motor can barely start, takes a ton of cranking, like when you have a tooth off. Dear god give me a win!!! If its the timing belt I can be up and running a lot sooner. I had a gates racing timing belt kit with the blue kevlar belt that I bought way back in the day, bought it like 5+ years ago. Good luck! But please stop cranking it OMG! Link to comment Share on other sites More sharing options...
