foxrider28 Posted April 20, 2016 Share Posted April 20, 2016 Here's a better example. http://www.veloster.org/forum/attachments/hyundai-veloster-exterior-lighting/3726-how-much-veloster-headlamp-should-i-go-kdm-lhdvsrhd.jpg Link to comment Share on other sites More sharing options...
testa422 Posted April 20, 2016 Share Posted April 20, 2016 ^ perfect example! Link to comment Share on other sites More sharing options...
Timothy.B Posted April 20, 2016 Share Posted April 20, 2016 Huh, never knew that! Timothy.B's 2011 LEGACY 3.6R Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted May 10, 2016 Author Share Posted May 10, 2016 Recommendations for a clutch kit? Or should I just hit up Subaru for OEM? Someone also sugested the tsk3 kit, which originally I thought was a clutch kit but turned out to be a throw out bearing? I think. Link to comment Share on other sites More sharing options...
GTEASER Posted May 10, 2016 Share Posted May 10, 2016 Recommendations for a clutch kit? Or should I just hit up Subaru for OEM? Someone also sugested the tsk3 kit, which originally I thought was a clutch kit but turned out to be a throw out bearing? I think. Since you have a 2.5i, just stick with a stock clutch. The TSK3 is a snout sleeve and TOB, get it. Also do the clutch damper delete, you'll get a lot more miles out of the new clutch AND enjoy the engagement and feel more. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted May 10, 2016 Author Share Posted May 10, 2016 Since you have a 2.5i, just stick with a stock clutch. The TSK3 is a snout sleeve and TOB, get it. Also do the clutch damper delete, you'll get a lot more miles out of the new clutch AND enjoy the engagement and feel more. Cool, only things I need to order is the disc complete and cover complete? http://uploads.tapatalk-cdn.com/20160510/3d31d31387a5a16effc99cba0d4ae8a1.jpg Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
GTEASER Posted May 10, 2016 Share Posted May 10, 2016 You need a new pilot bearing. http://parts.subaru.com/p/Subaru_2010_Legacy25L-6MT-4WD/BALL-BEARING/49287234/806212020.html I would get 6 new clutch cover bolts. http://parts.subaru.com/p/Subaru_2010_Legacy25L-6MT-4WD/BOLT-AND-WASHER-ASSEMBLY/49286397/800508310.html And 8 new flywheel bolts http://parts.subaru.com/p/Subaru_2010_Legacy25L-6MT-4WD/BOLT/49286490/800610740.html You can probably just have your flywheel resurfaced. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted May 23, 2016 Author Share Posted May 23, 2016 As a donor strut housing, is there any other year/model besides 2010-2014 Legacy that I can use? Say if I were to hit a junk yard. Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
ripstik Posted May 23, 2016 Share Posted May 23, 2016 As a donor strut housing, is there any other year/model besides 2010-2014 Legacy that I can use? Say if I were to hit a junk yard. Sent from my LG-ls990 using Tapatalk same year outback maybe. I know the strut itself is longer but is the housing the same? Link to comment Share on other sites More sharing options...
GTEASER Posted May 23, 2016 Share Posted May 23, 2016 same year outback maybe. I know the strut itself is longer but is the housing the same? No ripstik! Where do you get this stuff sometimes? The spring perch is mounted higher on the strut tube on the Outback units, that is why they are higher....duh! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
GTEASER Posted May 23, 2016 Share Posted May 23, 2016 As a donor strut housing, is there any other year/model besides 2010-2014 Legacy that I can use? Say if I were to hit a junk yard. Sent from my LG-ls990 using Tapatalk As far as we know at this time, there are not any other struts that will work for us. You need 2010-2014 Legacy donors. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted June 18, 2016 Author Share Posted June 18, 2016 I have a lot of maintenance to do with my leggy. This week I plan to change the tranny fluid. Recommended gear oil? I was thinking Motul. Do I need anything besides the oil? Filter? Going to Google how to do it, but just wanted everyone's experiences. Pretty straightforward to do? Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
Shadow_419 Posted June 18, 2016 Share Posted June 18, 2016 Pretty easy to drain and fill the transmission. Just need a T70 torx for the drain bolt. I put the car back down off the jack stands to get the transmission level and get everything out. Lots of folks use the Motul or the Subaru stuff. I used Amsoil severe gear 75w90. Seems good so far, but it's only been about 6k miles. Link to comment Share on other sites More sharing options...
Zee199969 Posted June 19, 2016 Share Posted June 19, 2016 I'm running the Motul gear oil. Shifting is smooth as butter My "Build" Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted June 19, 2016 Author Share Posted June 19, 2016 Nice . Looks like I need to get one of those pumps to get the oil in the rear diff Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
Shadow_419 Posted June 19, 2016 Share Posted June 19, 2016 I just popped a grommet out in the spare tire well. Used a hose and funnel to fill. Same hose and funnel to fill the transmission as well Link to comment Share on other sites More sharing options...
cww516 Posted June 19, 2016 Share Posted June 19, 2016 If you have a second person to help you, you can fish the tube up to them around the wheel and have them hold the bottle next to the car. Link to comment Share on other sites More sharing options...
BBPeik Posted June 19, 2016 Share Posted June 19, 2016 I had a crunchy second gear. Ever since I switched to Motul the crunch is gone. I would recommend it for sure. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted June 23, 2016 Author Share Posted June 23, 2016 Hmm.. Actually.. I just checked my tranny fluid and its still clear. So I shouldn't be in a rush to change it? Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted June 23, 2016 Share Posted June 23, 2016 Hmm.. Actually.. I just checked my tranny fluid and its still clear. So I shouldn't be in a rush to change it? Sent from my LG-ls990 using Tapatalk How many miles since the last time it was changed? My "Build" Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted June 23, 2016 Author Share Posted June 23, 2016 How many miles since the last time it was changed? That's the issue, I bought the car at 90k, from a subie dealer, and they didn't have prior records... So I was assuming they did nothing, since I changed my spark plugs and they looked like they were in there for ages. Sent from my LG-ls990 using Tapatalk Link to comment Share on other sites More sharing options...
Shadow_419 Posted June 23, 2016 Share Posted June 23, 2016 It very well may be good for a while longer, but when you change it you'll know when it's due. What I'm saying is if money is a little tight it won't be the end of the world to wait a little. I changed mine at 113k and had no idea when it had been done either. The $60-70 on good synthetic gear oil is going to last you for a good amount of time, and protect your drivetrain. Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted August 26, 2016 Author Share Posted August 26, 2016 So, anyone else here with a 2.5i and dual muffler exhaust? Mine just fell off.. Sent from my SM-N930P using Tapatalk Link to comment Share on other sites More sharing options...
Cup_of_Joe Posted August 26, 2016 Author Share Posted August 26, 2016 When I bought the car used, it came with the dual muffler from the last owner. It looks like the one they added on fell off at where they made it a Y pipe. I don't go fast over any bumps, not lowered yet, or hit any pot holes. But looking at it, maybe the subframe or control arm might of been hitting it every so often. Sent from my SM-N930P using Tapatalk Link to comment Share on other sites More sharing options...
foxrider28 Posted August 26, 2016 Share Posted August 26, 2016 If I'm not mistaken you can use the GT/3.6 mid pipe back setup just have to add the hanger for the passenger side muffler which in your case should already be there. Link to comment Share on other sites More sharing options...
