IceWilly Posted March 1, 2018 Share Posted March 1, 2018 (edited) As requested Type: 2015/16 Premium STI wheels Size: 18 x 8.5 ET55 Tyres: 225/50R18 Would these need to run any spacers or anything, or a clean bolt up? Same offset as stock wheels on an 18 Legacy but 8.5 vs 7.5 Thanks all. These and the 2011 STI Enkei's and 2015 STi wheels shown below have been my favorite combos so far in this thread. Edited March 1, 2018 by IceWilly Link to comment Share on other sites More sharing options...
surmiser Posted March 2, 2018 Share Posted March 2, 2018 Would these need to run any spacers or anything, or a clean bolt up? As far as I know, STI wheels will cleanly bolt onto 6th gens without needing spacers, as long as you don't plan on adding big brake kits afterwards. @redvenetian on Instagram Link to comment Share on other sites More sharing options...
IcEWoLF Posted March 4, 2018 Share Posted March 4, 2018 GFG Forged FM 914 19x9 ET35 wheels with 245/40R19 Goodyear Eagle F1 Asymmetric 3 rubber. No one's posted about fitment for these specs before, so just sharing what it looks like. But it's not for everyone, because I had to roll my rear fenders all the way (including shaving and cutting) to avoid rubbing while running comfortable coilover damper settings and sane camber (just over a degree). In terms of overall rolling radius, I'm at just marginally smaller than stock, which means negligible speedo error. Question, did you wrap all the window trims black? Also i take that’s a glossy finish all around? If you wrapped it how hard was it? Did you have to take any of the trims out to do it? Link to comment Share on other sites More sharing options...
surmiser Posted March 4, 2018 Share Posted March 4, 2018 Question, did you wrap all the window trims black? Yes. Also i take that’s a glossy finish all around? Yep. If you wrapped it how hard was it? Did you have to take any of the trims out to do it? Paid to get it professionally wrapped, but hung around to watch. Trims stayed on. Didn't look terribly difficult but it required cutting the vinyl precisely with a knife. @redvenetian on Instagram Link to comment Share on other sites More sharing options...
IcEWoLF Posted March 4, 2018 Share Posted March 4, 2018 Yes. Yep. Paid to get it professionally wrapped, but hung around to watch. Trims stayed on. Didn't look terribly difficult but it required cutting the vinyl precisely with a knife. Awesome, that’s the plan for me, and plan on doing it in the next few weeks. A friend of mine will do it for me, he does window tinting and other stuff so I trust him with a trimming knife, just gotta careful around the edges. You have an amazing looking car. Link to comment Share on other sites More sharing options...
diesel4982 Posted March 25, 2018 Share Posted March 25, 2018 I don't see why not, going by the specs, and assuming your brakes are stock. I have the 4 caliper brembo brakes on a 2016 Legacy. Would the 2018 sti rims fit over those brakes? Im currently using the 2017 sti rims in 18 inch but wanted to go to the 19 inch. Link to comment Share on other sites More sharing options...
surmiser Posted March 26, 2018 Share Posted March 26, 2018 I have the 4 caliper brembo brakes on a 2016 Legacy. Would the 2018 sti rims fit over those brakes? Im currently using the 2017 sti rims in 18 inch but wanted to go to the 19 inch. I confess that I don't know. However, since you've currently got enough clearance with the 2017 STI wheels, I think there's a good chance. But at least be prepared to add thin spacers if necessary. @redvenetian on Instagram Link to comment Share on other sites More sharing options...
fullah Posted March 26, 2018 Share Posted March 26, 2018 And because I don't have any straight-on shots of the back, here's an older shot before the winglets and reverse/indicator light overlays: Are you still dropped 1.5" all around or is your car lower in these pics? I seen you mentioned about having rubbing issues and having to roll the rear lip. I'm wondering if this would be an issue with your same wheel size and offset on h&r springs on a 1.3" drop Link to comment Share on other sites More sharing options...
Pleiades 3.6R Posted March 26, 2018 Share Posted March 26, 2018 I'm wondering if this would be an issue with your same wheel size and offset on h&r springs on a 1.3" drop H&R's gave me a 1.5" drop and I'm sure they consider that within spec. Link to comment Share on other sites More sharing options...
fullah Posted March 27, 2018 Share Posted March 27, 2018 H&R's gave me a 1.5" drop and I'm sure they consider that within spec. Lmao I would actually be happier with the 1.5" drop! Everything I see says 1.3" for our car. What part number did you install? Link to comment Share on other sites More sharing options...
IcEWoLF Posted March 28, 2018 Share Posted March 28, 2018 Man I’m so jealous about some of these rims! Surmiser I was going with the Venetian red legacy but they didn’t have the 3.6R option, otherwise that would have been my color. I’m having my chrome delete redone from the shop that did my grille because the previous shop absolutely sucked and the chrome delete came or crappy. I have my appointment set for next week to get it done. It might be this summer when I get some new wheels, for now stock will do. Link to comment Share on other sites More sharing options...
surmiser Posted March 28, 2018 Share Posted March 28, 2018 Are you still dropped 1.5" all around or is your car lower in these pics? I seen you mentioned about having rubbing issues and having to roll the rear lip. I'm wondering if this would be an issue with your same wheel size and offset on h&r springs on a 1.3" drop Yes, still dropped 1.5" all around, or maybe a teeny bit lower than that after the coilover springs settled. Rear fender clearance is a real challenge with lowered 6th-gens. Even with a 1.3" drop, there might be rubbing issues because of the relatively soft stock dampers, with 19" +35 wheels and 40 profile rubber. Man I’m so jealous about some of these rims! Surmiser I was going with the Venetian red legacy but they didn’t have the 3.6R option, otherwise that would have been my color. Aww, that's a shame, not enough of us venetian red 6th-gens around! @redvenetian on Instagram Link to comment Share on other sites More sharing options...
diesel4982 Posted March 29, 2018 Share Posted March 29, 2018 Anyone have 245/50/18 tires on their car? I'm looking to get those, but don't know if there will be any issues with the stock suspension, rubbing issues..anything negative really. I currently have 245/45/18. Thanks all. Link to comment Share on other sites More sharing options...
SubieN8 Posted March 29, 2018 Share Posted March 29, 2018 (edited) Anyone have 245/50/18 tires on their car? I'm looking to get those, but don't know if there will be any issues with the stock suspension, rubbing issues..anything negative really. I currently have 245/45/18. Thanks all. I highly doubt any rubbing will occur, but you're already running an off size for the car. Check this out and it'll show you how it'll affect proportions. https://tiresize.com/calculator/ Then do some measuring of your set up and add the difference. Edited March 29, 2018 by SubieN8 Link to comment Share on other sites More sharing options...
diesel4982 Posted March 29, 2018 Share Posted March 29, 2018 I highly doubt any rubbing will occur, but you're already running an off size for the car. Check this out and it'll show you how it'll affect proportions. https://tiresize.com/calculator/ Then do some measuring of your set up and add the difference. I should clarify that I'm using the sti rims that are 18x8.5. I'm using the Michelin pilot sport as 3+ tires on 245/45/18. When replacing these tires, I would like to go to a bigger sidewall...I'd even like to get a wider tire but haven't found any. What I found was 245/50/18 which was the continental dsw.. Link to comment Share on other sites More sharing options...
IcEWoLF Posted March 29, 2018 Share Posted March 29, 2018 I should clarify that I'm using the sti rims that are 18x8.5. I'm using the Michelin pilot sport as 3+ tires on 245/45/18. When replacing these tires, I would like to go to a bigger sidewall...I'd even like to get a wider tire but haven't found any. What I found was 245/50/18 which was the continental dsw.. I am on the dws06 and they are pretty good. Link to comment Share on other sites More sharing options...
Pleiades 3.6R Posted March 31, 2018 Share Posted March 31, 2018 (edited) Lmao I would actually be happier with the 1.5" drop! Everything I see says 1.3" for our car. What part number did you install? Manufacturer Part #: 54427.2 Here's how it sits now. http://legacygt.com/forums/attachment.php?attachmentid=263378&d=1522003558 Edited March 31, 2018 by Pleiades 3.6R Link to comment Share on other sites More sharing options...
PATS4LIFE Posted March 31, 2018 Share Posted March 31, 2018 Manufacturer Part #: 54427.2 Here's how it sits now. http://legacygt.com/forums/attachment.php?attachmentid=263378&d=1522003558 Nice!!!i think I’m going to change my wheels from 17 to 18 Link to comment Share on other sites More sharing options...
DarkCloud23 Posted April 1, 2018 Share Posted April 1, 2018 Manufacturer Part #: 54427.2 Here's how it sits now. http://legacygt.com/forums/attachment.php?attachmentid=263378&d=1522003558 Looks great!!! BC Racing. Blox Racing. Whiteline. AVO Turbo. RalliTek. Gramlights Michelin. Optima. HKC-Speed. Nameless. AFE. K&N. WeatherTech. Morimoto. Solar Gard. PPF. 9H. Link to comment Share on other sites More sharing options...
IcEWoLF Posted April 3, 2018 Share Posted April 3, 2018 Figured I'd post the actual specs up here... Type: Vossen VSF1 Size: 20 x 9 ET40 Tyres: Nitto NT555 G2 245/35r20 Okay, I gotta ask, how the hell did you fit those rims in there? Do you have any rubbing problems? Also what modifications did you had to make to fit those? Link to comment Share on other sites More sharing options...
IcEWoLF Posted April 4, 2018 Share Posted April 4, 2018 I'm new to the wheel world guys, Will something like this fit properly? https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=SR023SG&wheelMake=BBS&wheelModel=SR&wheelFinish=Anthracite%20Painted&showRear=no&autoMake=Subaru&autoModel=Legacy&autoYear=2018&autoModClar=3.6R+Limited This one has offset of 50mm Size: 18x8 Mine the stock wheels are 18 x 7.5 My tires at 225/50/18 I was also considering these https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=WI15880511445TG&wheelMake=RADIUS&wheelModel=WI15&wheelFinish=Titanium%20Gunmetal&showRear=no&autoMake=Subaru&autoModel=Legacy&autoYear=2018&autoModClar=3.6R+Limited The dimension on that is 18 x 8 and 45mm offset, not sure how well that will bode with with my new tires that I got few months ago. Link to comment Share on other sites More sharing options...
Pleiades 3.6R Posted April 5, 2018 Share Posted April 5, 2018 I'm new to the wheel world guys, Will something like this fit properly? https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=SR023SG&wheelMake=BBS&wheelModel=SR&wheelFinish=Anthracite%20Painted&showRear=no&autoMake=Subaru&autoModel=Legacy&autoYear=2018&autoModClar=3.6R+Limited This one has offset of 50mm Size: 18x8 Mine the stock wheels are 18 x 7.5 My tires at 225/50/18 I was also considering these https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=WI15880511445TG&wheelMake=RADIUS&wheelModel=WI15&wheelFinish=Titanium%20Gunmetal&showRear=no&autoMake=Subaru&autoModel=Legacy&autoYear=2018&autoModClar=3.6R+Limited The dimension on that is 18 x 8 and 45mm offset, not sure how well that will bode with with my new tires that I got few months ago. No issue with either. Your tire size fits 7.5" and 8" wide rims. Link to comment Share on other sites More sharing options...
IcEWoLF Posted April 5, 2018 Share Posted April 5, 2018 No issue with either. Your tire size fits 7.5" and 8" wide rims. Okay, so I shouldn’t worry about rim offsets one being 45 and the other being 55? I heard anything over 10mm might be bad. (45mm) one Link to comment Share on other sites More sharing options...
Pleiades 3.6R Posted April 5, 2018 Share Posted April 5, 2018 Okay, so I shouldn’t worry about rim offsets one being 45 and the other being 55? I heard anything over 10mm might be bad. (45mm) one From what I understand it's no issue. The issue comes when your tires start rubbing because the offset is too far off factory specs. There's a few websites where you can plug in your current wheel and tire specs along with the new ones and it'll tell you the exactly difference and what it translates to. Someone I'm sure will correct me if I'm wrong on anything. I researched the issue a few weeks back but decided to hold off until I get the car paid off. Link to comment Share on other sites More sharing options...
Koopenfausen Posted April 9, 2018 Share Posted April 9, 2018 I know people have said that comparable offsets will fit without rubbing, but i think i'm just looking for a confidence boost before pulling the trigger lol. I have my eye on a great deal for a set of 18x8 +40 which i would put 225's on. Is that going to rub at all when the car is loaded? Link to comment Share on other sites More sharing options...
