boxkita Posted February 24, 2015 Author Share Posted February 24, 2015 I can get these at a very good price but you will have to PM me if you want to buy one. For example I can get the 06-07 WRX-STI system in both Silver or Black, with or without the thermostat, for a lot less than the MSRP you see on the Mishimoto website. That's true for all Mishimoto products, not just the oil coolers. No guarantees on fitment since I've never installed this exact setup. Wish I had known about your discount before I bought my radiator. Oh well. Looks like I'll be doing this, as soon as I figure out a mounting location. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
AMileHighLGT Posted February 24, 2015 Share Posted February 24, 2015 Couldn't you ditch using the sandwich adapter and tap into the main galley plugs on the top of the block? Link to comment Share on other sites More sharing options...
boxkita Posted February 24, 2015 Author Share Posted February 24, 2015 Like the 5th & 6th gens do? I guess so, however, when the intake manifold is in place along with the accessories, there is not much room. Unless I remember wrong? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Gex Posted February 24, 2015 Share Posted February 24, 2015 So with the 2psi pressure loss on the Mishimoto external oil cooler, would it be prudent to install the sti 11mm oil pump along with it? Link to comment Share on other sites More sharing options...
boxkita Posted February 25, 2015 Author Share Posted February 25, 2015 Looking at my invoices, it doesn't say whether I have a 10 or 11mm oil pump. I thought I was getting an 11, however, don't remember. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
SBT Posted February 25, 2015 Share Posted February 25, 2015 P/n? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
kzr750r1 Posted February 25, 2015 Share Posted February 25, 2015 15010AA360 is the 11mm Link to comment Share on other sites More sharing options...
AMileHighLGT Posted February 25, 2015 Share Posted February 25, 2015 Like the 5th & 6th gens do? I guess so, however, when the intake manifold is in place along with the accessories, there is not much room. Unless I remember wrong? I have not eye spied a 5/6 gen in person so I could not say. You're right, there's not much room there with the turbo inlet, I think it could be done. I'm sure some phenolic spacers for added room would be a good idea. Link to comment Share on other sites More sharing options...
boxkita Posted February 25, 2015 Author Share Posted February 25, 2015 I have not eye spied a 5/6 gen in person so I could not say. You're right, there's not much room there with the turbo inlet, I think it could be done. I'm sure some phenolic spacers for added room would be a good idea. If I was going to that much work, I'd move the oil filter on top, too. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted February 25, 2015 Moderators Share Posted February 25, 2015 So why are you considering adding an oil cooler again? Are you selling this thing or what? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
boxman Posted February 25, 2015 Share Posted February 25, 2015 left side is MaxCapacity @ 153k on dino oil middle is boxkita @ 30k on dino oil right is AMileHigh @ 108k on mystery oil When did your engine catch on fire? Wasn't that the passenger side? Link to comment Share on other sites More sharing options...
boxkita Posted February 25, 2015 Author Share Posted February 25, 2015 When did your engine catch on fire? Wasn't that the passenger side? previous engine & previous heads. And like all other drama in my life, it was more cellphone snap rather than youtube. Fire was out in 2 secs. On top of which, it was the other side that caught fire. These are rebuilt STI heads Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Sgt.Gator Posted February 25, 2015 Share Posted February 25, 2015 So with the 2psi pressure loss on the Mishimoto external oil cooler, would it be prudent to install the sti 11mm oil pump along with it? I have plenty of oil pressure although I can't swear it didn't get the higher pressure pump when they added the FP18g in 2007. My gut says they did not, it has the stock EJ255 pump. I haven't really looked into the 10mm vs 11mm debate. Do you have to do any fabricating or mods to go 11mm? I suppose a thread search will take me to an endless argument ? Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
Chris GTO TT Posted February 25, 2015 Share Posted February 25, 2015 On a street car I'd leave the oil to coolant heat exchanger in place even if you go with an external air to oil cooler with a thermostat simply to ensure your oil comes to temp sooner. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
MrTris Posted February 28, 2015 Share Posted February 28, 2015 I have plenty of oil pressure although I can't swear it didn't get the higher pressure pump when they added the FP18g in 2007. My gut says they did not, it has the stock EJ255 pump. I haven't really looked into the 10mm vs 11mm debate. Do you have to do any fabricating or mods to go 11mm? I suppose a thread search will take me to an endless argument ? The biggest concern is cavitation. On your racecar, I wouldn't go higher without good reason, like auxiliary oiling system components that would create a large pressure drop, as it probably spends more time at high RPMs than a streetcar. The risk of cavitation is higher in the upper range than in normal cruising speeds. Link to comment Share on other sites More sharing options...
Thetoad Posted February 28, 2015 Share Posted February 28, 2015 Just bear with me please.... Many years ago when I was a youngster if you can believe that .. I honestly still remember a jingle.....here it Goes... "Never pick up a stranger.......lDont Put Your Car In ..Danger....Nows the time.....The Right Time to Change Her........Change To Prestone ANTI ..FREEZE.. Don't know about the Radiator,,,,,but I do know about the ...Freeze.... Link to comment Share on other sites More sharing options...
MrTris Posted February 28, 2015 Share Posted February 28, 2015 Just bear with me please.... Many years ago when I was a youngster if you can believe that .. I honestly still remember a jingle.....here it Goes... "Never pick up a stranger.......lDont Put Your Car In ..Danger....Nows the time.....The Right Time to Change Her........Change To Prestone ANTI ..FREEZE.. Don't know about the Radiator,,,,,but I do know about the ...Freeze.... ?????????????,,,,,,,,,,???????????? Link to comment Share on other sites More sharing options...
boxkita Posted February 28, 2015 Author Share Posted February 28, 2015 I used to think he does that for post count. Now its moved into another of the quirks I enjoy about lgt.com. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted February 28, 2015 Author Share Posted February 28, 2015 11mm is plug and play for 10mm. Looking at my invoice it just says oil pump. So probably 10mm. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
SBT Posted February 28, 2015 Share Posted February 28, 2015 P/N would identify it for sure. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted February 28, 2015 Share Posted February 28, 2015 Is it a cast or stamped impeller? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
boxkita Posted February 28, 2015 Author Share Posted February 28, 2015 Is it a cast or stamped impeller? It may depend on who did the upgrade. I think it has do with boring the shaft and using a bigger piston. At least pics i saw when looking at this a couple of years ago. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
SBT Posted February 28, 2015 Share Posted February 28, 2015 NM - you're talking Oil Pump and I'm thinking Water Pump. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
boxkita Posted March 2, 2015 Author Share Posted March 2, 2015 At long last, the driver side head is off. Head looks good, except for the baked on oilly carbon gunk. Block looks fine. Pistons are covered in baked on oilly carbon gunk, plus coolant fluid drops. Cylnder walls don't show much scoring, however, the boring marks are not visible either. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
boxkita Posted March 2, 2015 Author Share Posted March 2, 2015 Found the leak, too. driver side, front piston, exhaust side of piston between water jacket & piston wall. There is no matching marks on head. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
