Anyone Interested in An Aftermarket Exhaust
Are you interested in a aftermarket exhaust?
200 members have voted
  1. 1. Are you interested in a aftermarket exhaust?
  • Replies 326
I dispute your assertion of "all." For ordinary street use, maybe.
Such as this discussion. No reason for a dual exhaust on Subaru's, it's added for appearance. And it looks nice, gives the car a more symmetrical appearance especially with the cutout so obvious on the single exhaust model.
No reason for a dual exhaust on Subaru's ...
Your original assertion was "all dual exhausts" ... not limited to street-driven Subaru Legacys.
Edited by ammcinnis
^ last car was a Prius. Knows everything about ICE exhaust systems.
Tits mcgee
Also the stock muffler to mid pipe uses a circle O ring style gasket so the stock flanges are made to adapt that type of gasket. The nameless exhaust uses a standard 2 bolt gasket.
Using the donut (circle O ring) gasket on the cat-side, which should be ~2.5", and then placing the mouth of the Nameless flat-flange over the donut gasket should enable you to get a good, leak-free fit. Several have used this approach when dealing with flat-flange to donut-flange connections on our Subarus.
So I would like to start off by saying I don't care about anyone's argument about duel exhaust, its my car and i do what i want to it, i don't care what you think or about your two cents. I do what I do and i don't mind helping like mined people do the same thing. So if your against duel exhaust just back out of this thread now, if your are into the idea and have been following my post here's some info.
The Nameless tips don't work (very well) with the stock 2.5 exhaust on my 2015. the gaskets are different and the flange bolts don't line up. Since I've got a fifth gen 3.6 mid pipe things are looking up. took off my stock mid pipe today and installed the 3.6 with zero issue. Flanges matched up perfect, hangers all match and the nameless axle backs work as intended with the 3.6 exhaust. the 3.6 mid pipe from the resonator back is a bigger pipe but no fitment issues. another good find i found was on the passenger side where there are not hangers welded in, it is easy to see where they go because there is metal that is formed for them (see picture) Until I get the hangers and weld them in I'm going to make a block off for the passenger side exhaust for now once i'm done with the block off I will give it to whomever for free if they would like to do the same set up as I.
Gasket difference
http://i.imgur.com/zO1bMrh.jpg
Hanger points on passenger side
http://i.imgur.com/Y2RUEPl.jpg
http://i.imgur.com/ijVNY2u.jpg
http://i.imgur.com/i8GMG7e.jpg
http://i.imgur.com/QR2yfhb.jpg
http://i.imgur.com/23greY2.jpg
http://i.imgur.com/Cvrz73W.jpg
http://i.imgur.com/HSvnaxT.jpg
http://i.imgur.com/QPEWlk6.jpg
http://i.imgur.com/dIy8UDg.jpg
Very informative. It's your Legacy and it's great your making it your own. Keep the information coming, you might be the first but this thread will be reference for years to come. 🔨🔨🔨
Laughing at Oneself and with Other is good for the Soul😆
Nice work jyjellu!!! Glad you got some good results. It looks like the Nameless tips need to be extended outward by an inch or two to be more flush with the rear bumper valance.
yeah 2 1/8" will make it flush. I will have to cut off the hanger on the axle back then add the 2 1/8" and weld the hanger back on
thanks man I hope this helps so more people.
Wow that kinda sucks that the mufflers aren't flush with the rear valance. Hopefully when I get mine I don't run into that issue but looks like I more than likely will.
We shall see; still waiting on and update on the build process of my exhaust I ordered.
Follow me on Instagram @CT2015Legacy
  • 3 weeks later...
Well I tested out the Nameless Axleback and the flanges are about 1/2 inch short where the bold location is http://tapatalk.imageshack.com/v2/15/03/17/1e37ffa0045f3367aac2219c80eb1251.jpg
I've reached out to Nameless but haven't gotten any response as of yet.
Edited by CT2015Legacy
I'm in San Diego and I've emailed one of the Old School Subie exhaust makers and hopefully I can get a test fit for the 3.6R..
That would be awesome! I still haven't heard back from Nameless; going to give them a call back later today when I'm back in CT or sometime tomorrow.
Spoke to Nameless today and looks like the outgoing models Axleback will not fit out cars.
They will be eventually developing something/making adjustments as they have a vehicle available however they weren't able to tell me when. I should here back tomorrow and will try to get more info which I will share with everyone.
Didn't really want the cat out of the bag just yet...But they are a Great Company No After market rattle cans for me.. I only work with the Best.. My experience in Mods and doing Import Shows help out a Great Deal.
No worries; I'll patiently wait 😁
http://i.imgur.com/G9uyNCB.jpg
http://i.imgur.com/Ks2vU8Y.jpg
http://i.imgur.com/BARHpy4.jpg
http://i.imgur.com/vf8pplv.jpg
http://i.imgur.com/tRm9QJm.jpg
http://i.imgur.com/uq1y9mt.jpg
http://i.imgur.com/Cvfjviw.jpg
http://i.imgur.com/zoHZRMx.jpg
http://i.imgur.com/kZqwgnc.jpg
http://i.imgur.com/BCBWLnB.jpg
http://i.imgur.com/tpVJRzh.jpg
cut the tip off, added about 7 inches to to each pipe, welded the tip and bracket back on. used 1/2" rod from Nameless to weld to the body. The tips stick out to the furthers point on the bumper (the body line)
So guessing this is the nameless exhaust custom modified correct?
Only reason I ask is because the current systems for previous generations don't fit the 3.6 (I tried and the flanges are to small to thread the bolts).
