MrTris Posted November 17, 2014 Share Posted November 17, 2014 I paid 200 for my 100,000 mile 04 STI cams lol. I wanted as much new as I could get though. That's where I was at, too - I think I talked him down to $150. Mine were technically fine, but, I bought a set from a local guy on NASIOC who has a heavily modded 05. The cams are identical, btw, between 05 STi and 05 LGT. The difference was that his motor was well-maintained and had the oil changed regularly, whereas mine was all kinds of burnish colored on the inside from some pretty significant neglect. A couple of runs through the parts washer at work and they looked WAY better than my original ones. Plus, I get to say I gots STi parts. Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 24, 2014 Author Share Posted December 24, 2014 Got Head studs and lube. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MrTris Posted December 24, 2014 Share Posted December 24, 2014 So, are they going to go in your butt before they go into your motor? Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 24, 2014 Author Share Posted December 24, 2014 So, are they going to go in your butt before they go into your motor? Obviously, that's why I got the lube. And I thought you were going to do it for me. Have plans changed? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted December 24, 2014 Share Posted December 24, 2014 Nice! Let me know if you need any help, I'm only 4 hrs away if you need an extra hand. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 24, 2014 Author Share Posted December 24, 2014 It's still going to be awhile before I'm ready to assemble or install. I have a lot of things to buy still. Off The top of my head, spark plugs, water pump, timing belt and pulleys, oil pump... "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2014 Share Posted December 24, 2014 It's been over a year...I hope you get this thing back together correctly. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted December 24, 2014 Share Posted December 24, 2014 My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 24, 2014 Author Share Posted December 24, 2014 It's been over a year...I hope you get this thing back together correctly. Oh i will. There's enough guides on here I'll be using too. I haven't had it apart for a year yet. I hope you made a few pots. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2014 Share Posted December 24, 2014 I just have visions of "waspy" going through my head, I hope that doesn't happen to you. Good Luck, we're here to help. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
FJuan Posted December 24, 2014 Share Posted December 24, 2014 Still cracks me up when people use Waspy's name as the new "Fail" word. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 24, 2014 Share Posted December 24, 2014 Still cracks me up when people use Waspy's name as the new "Fail" word. Yep, great minds think alike LOL 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 24, 2014 Author Share Posted December 24, 2014 Valve spring compressor and Turkeylord Blue T fitting replacement is good stuffs. http://tapatalk.imageshack.com/v2/14/12/24/41e0fc2a846b853ae6e3182e6b356963.jpg "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
FJuan Posted December 26, 2014 Share Posted December 26, 2014 When do you expect to start this rebuild? My wife's balls are delicious. Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 30, 2014 Author Share Posted December 30, 2014 Got my gasket kit from Infamous Performance and Tuning. Assembly can begin soon. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted January 5, 2015 Author Share Posted January 5, 2015 Took the old engine off the engine stand. Got the new shortblock on the stand. Cleaned all of the clutch material and grime off of the bell housing, and pulled the rear main seal out. New one is on order. Fancy nitride coated crank. ARP head studs installed. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted January 7, 2015 Author Share Posted January 7, 2015 Got my water pump and timing kit. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted January 9, 2015 Author Share Posted January 9, 2015 got my CV Boot Banding Tool for my "Bullet Proof TMIC" kit. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
RooTBeeR Posted February 1, 2015 Author Share Posted February 1, 2015 Purchases made today: Oil Cooler Oil Cooler Connector 10mm Oil Pump Spark Plugs Torque Converter Circlip Agency Power Light Weight Crank Pulley "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MrTris Posted February 2, 2015 Share Posted February 2, 2015 Purchases made today: Oil Cooler Oil Cooler Connector 10mm Oil Pump Spark Plugs Torque Converter Circlip Agency Power Light Weight Crank Pulley Remind me to show you a picture of that AP crank pulley with that raised center section where it bolts in, is snapped off. Completely. Link to comment Share on other sites More sharing options...
RooTBeeR Posted February 3, 2015 Author Share Posted February 3, 2015 Remind me to show you a picture of that AP crank pulley with that raised center section where it bolts in, is snapped off. Completely. So you saying the AP pulley is no good? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MrTris Posted February 3, 2015 Share Posted February 3, 2015 Out of all of them, you could do better for a few bucks more.. Link to comment Share on other sites More sharing options...
RooTBeeR Posted February 3, 2015 Author Share Posted February 3, 2015 well I just dont want it to physically fail or cause belt issues. I figured that since i have a fluid filled tq converter weighing quite a bit, that going with the lightest pulley wasnt going to hurt me. "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
MrTris Posted February 3, 2015 Share Posted February 3, 2015 well I just dont want it to physically fail or cause belt issues. I figured that since i have a fluid filled tq converter weighing quite a bit, that going with the lightest pulley wasnt going to hurt me. Your head was in the right place, for sure. But then again, I've been told that I'm "on my own" if I want to install a LWCP -- PIA doesn't advocate, sell, or install them. The example I saw was an Agency Power LWCP and the bolt went in on a raised portion of the pulley. That raised portion cracked and broke at all 5(?)-ish sections where it attached to the rest of the pulley. I was told that that's the reason why they don't use them. When that shit fails, your motor goes kaboom. Link to comment Share on other sites More sharing options...
Rhitter Posted February 3, 2015 Share Posted February 3, 2015 RootBeer did you ever get the Outback suspension pieces to raise your car? My OBXT build Link to comment Share on other sites More sharing options...
