Brett_dub Posted October 15, 2017 Share Posted October 15, 2017 I installed the bushing today but had some trouble. Incase anybody is in a rush and expects it to go as smoothly as I did, here's how it can turn into a few hours. After removing the cover and cotter pin, I find the inner brass portion of the stock bushing had rusted itself solid to the center pin. I had to pry the washer off, then the rubber, so I could use a micro torch to heat the brass portion. Needle nose vice grips twisted it off after a few minutes of heating it. Then I used a Dremel and sand paper to clean the base of the pin so the new bushing could sit flush. It took a few tries to get enough clearance to reinstall the cotter pin. It was worth the headache though as it does feel a lot more secure going into gear. Now to get rid of the side to side play when I'm in gear Link to comment Share on other sites More sharing options...
brandon.mol Posted October 15, 2017 Share Posted October 15, 2017 I don't think there is any way to get rid of that, since that's the play in the shifter in the cabin. Maybe the '15+ wrx shifter helps.... Enablers with said shifter will chime in. Link to comment Share on other sites More sharing options...
DrD123 Posted October 16, 2017 Share Posted October 16, 2017 the OEM Legacy short shifter and the 15+ WRX short shifter both have stronger springs Link to comment Share on other sites More sharing options...
Brett_dub Posted October 16, 2017 Share Posted October 16, 2017 I was hoping this would do it. http://legacygt.com/forums/showthread.php/perrin-2015-wrx-shift-stop-230892.html?p=4935651 Link to comment Share on other sites More sharing options...
Falcor Posted October 16, 2017 Share Posted October 16, 2017 the OEM Legacy short shifter and the 15+ WRX short shifter both have stronger springs So, why don't we just figure out what stronger springs are needed and swap them out? Much cheaper than a whole new shifter. Link to comment Share on other sites More sharing options...
Sarang Posted October 17, 2017 Share Posted October 17, 2017 If you do that, and I benefit from it, I'll buy you a beer if you're ever in Phoenix. Link to comment Share on other sites More sharing options...
FLlegacy Posted October 17, 2017 Share Posted October 17, 2017 So, why don't we just figure out what stronger springs are needed and swap them out? Much cheaper than a whole new shifter. It sounds easy but adding tension won't help with solidifying the shifter. I think you need to remove all the clearance then solidify the housing somehow to really give it a sturdy solid feel. Link to comment Share on other sites More sharing options...
DrD123 Posted October 17, 2017 Share Posted October 17, 2017 I was hoping this would do it. http://legacygt.com/forums/showthread.php/perrin-2015-wrx-shift-stop-230892.html?p=4935651 that helps with the being able to move the shifter way past where you need to in order to go into 1st/2nd. It's a stop - it doesn't impact spring tension. Link to comment Share on other sites More sharing options...
Brett_dub Posted October 17, 2017 Share Posted October 17, 2017 Now to get rid of the side to side play when I'm in gear Im actually not too sure what the spring tension is... Link to comment Share on other sites More sharing options...
Falcor Posted March 5, 2018 Share Posted March 5, 2018 Here are links to before and after install: Before - After - Link to comment Share on other sites More sharing options...
covertrussian Posted March 5, 2018 Share Posted March 5, 2018 You're before video is the same as after one, would love to see the before! 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
creep_nu Posted March 5, 2018 Share Posted March 5, 2018 you can check in his uploaded videos (click on his name). he's also got some videos from the shifter stop. Link to comment Share on other sites More sharing options...
covertrussian Posted March 5, 2018 Share Posted March 5, 2018 you can check in his uploaded videos (click on his name). he's also got some videos from the shifter stop. Relevant username , I didn't feel like creeping on his youtube user just yet 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
Falcor Posted March 5, 2018 Share Posted March 5, 2018 You're before video is the same as after one, would love to see the before! Oops, fixed. Link to comment Share on other sites More sharing options...
