JayInVA Posted August 1, 2014 Share Posted August 1, 2014 My LF wheel bearing is making noise. Ordered a pair of DA bearings off of Amazon for $65 shipped. Amazon.com: Detroit Axle: Front Wheel Hub Bearing Assembly 513220 - 5 Lug with ABS (Pair of 2): Automotive Installed yet? How are they? Link to comment Share on other sites More sharing options...
Dispatch20 Posted August 6, 2014 Share Posted August 6, 2014 Definitely interested in hearing more about these. Link to comment Share on other sites More sharing options...
Quack Posted August 9, 2014 Share Posted August 9, 2014 Installed both front bearings. Everything works fine, no issues. Link to comment Share on other sites More sharing options...
theflystyle Posted August 9, 2014 Share Posted August 9, 2014 Would have been interesting if someone changed both fronts and used OEM on one corner and the DA one on the other Link to comment Share on other sites More sharing options...
cmpequeno Posted August 9, 2014 Share Posted August 9, 2014 I got the cheapest one from rockauto and like someone else posted when i turn on CC the car pulsates. Installation was rough so I'm not sure if the assembly is the problem or something else. Need to find time to do it myself among other things Sent from my H866C using Tapatalk 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted August 9, 2014 Share Posted August 9, 2014 Did you not read this thread before you bought those... Buy the DA, and send those things back. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
cmpequeno Posted August 9, 2014 Share Posted August 9, 2014 No i didnt, my mistake Sent from my H866C using Tapatalk 2 Link to comment Share on other sites More sharing options...
Quack Posted August 12, 2014 Share Posted August 12, 2014 Have about 500miles on them since I had them installed on Saturday, and no issues. With my work schedule, I should have over 1000 miles on them by this coming Sunday. For reference, my 2009 will be 5 years old at the end of August, and have 169k miles on it as of today. I took delivery of it with 10miles on the odometer. Link to comment Share on other sites More sharing options...
MrTris Posted August 12, 2014 Share Posted August 12, 2014 My LF wheel bearing is making noise. Ordered a pair of DA bearings off of Amazon for $65 shipped. Amazon.com: Detroit Axle: Front Wheel Hub Bearing Assembly 513220 - 5 Lug with ABS (Pair of 2): Automotive Your link is expired/bad, but, if it's the Detroit Axle 513220, could you go place a review and include that you've had success with them on a Fourth Gen Subaru Legacy (05-09)? Amazon will take care of the rest when others are searching for new wheel bearings, but the review will definitely help - Still going OK? Link to comment Share on other sites More sharing options...
Quack Posted August 12, 2014 Share Posted August 12, 2014 Link still works for me. Everything is a OK. Link to comment Share on other sites More sharing options...
MrTris Posted August 13, 2014 Share Posted August 13, 2014 So the DA 513220s -- for just front, or front AND rear? Link to comment Share on other sites More sharing options...
Quack Posted August 13, 2014 Share Posted August 13, 2014 For just the front. Didn't do the rears Link to comment Share on other sites More sharing options...
JayInVA Posted August 13, 2014 Share Posted August 13, 2014 So the DA 513220s -- for just front, or front AND rear? 513220 = Fronts 512293 = Rears Link to comment Share on other sites More sharing options...
Shello007 Posted August 19, 2014 Share Posted August 19, 2014 Just ordered the front pair. $65. Shipped. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 19, 2014 Share Posted August 19, 2014 So you just order directly from them, that's awesome. http://detroitaxle.com/?s=Part%20Finder&pfs=true&pf_nonce=8c51b1c262&vy=2005&vmk=41&vm=591&pt=410 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Shello007 Posted August 19, 2014 Share Posted August 19, 2014 No.. Sorry, should have mentioned.. Amazon.. Which was cheaper than ordering directly from DA. Sent from my SCH-I535 using Tapatalk Link to comment Share on other sites More sharing options...
JBear Posted August 19, 2014 Share Posted August 19, 2014 I never would have thought to get them on Amazon. Which is odd because I get like, everything on Amazon. Even if I don't, I at least look. Hm. Link to comment Share on other sites More sharing options...
forced compression Posted August 19, 2014 Share Posted August 19, 2014 purchased rear pair off eBay with 2 year warrantee! so far so good, installed both in under 1.5 hour best $68 shipped Link to comment Share on other sites More sharing options...
Industry Posted August 26, 2014 Share Posted August 26, 2014 Any tips on getting this God damn hub out of the spindle? Link to comment Share on other sites More sharing options...
boxman Posted August 26, 2014 Share Posted August 26, 2014 6" 3 arm gear puller. Link to comment Share on other sites More sharing options...
Quack Posted August 26, 2014 Share Posted August 26, 2014 Air hammer Link to comment Share on other sites More sharing options...
D-VO Posted August 26, 2014 Share Posted August 26, 2014 Air hammer Definitely helps. Link to comment Share on other sites More sharing options...
Industry Posted August 26, 2014 Share Posted August 26, 2014 Mount from outside, push on axle? Link to comment Share on other sites More sharing options...
boxman Posted August 26, 2014 Share Posted August 26, 2014 yep Link to comment Share on other sites More sharing options...
Quack Posted August 26, 2014 Share Posted August 26, 2014 With the air hammer, use it on the side of the hub to rotate it. Hit it around where the bolts thread onto the hub. I noticed that the hub I pre-soaked with Kroil came off easier that the other side. The side that didn't have Kroil took a larger/better air hammer Link to comment Share on other sites More sharing options...
