HellShadow70 Posted July 23, 2013 Share Posted July 23, 2013 Order the mounting bracket too unless you are handy with bending metal. I kinda wish I had it for a cleaner install. Just Pulled the trigger on the Derale 13011 and the bracket. $76.23 on Amazon.com Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted July 23, 2013 Share Posted July 23, 2013 ^^^ I can never for the life of me remember the hose ID, but yes that derale thermostat works well. Some people have trouble fitting it, but if you can install a remote oil filter, you can definitely install this. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
BlackBird97 Posted July 28, 2013 Share Posted July 28, 2013 I think i'm loosing my mind, how do you splice all the lines for adding the thermostat? I have the the cooler installed, I'm just trying to make sense of the diagram. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted July 28, 2013 Moderators Share Posted July 28, 2013 All you need is normal worm gear clamps and a couple of barbed hose couplers. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Mega Users seabass07 Posted July 28, 2013 Mega Users Share Posted July 28, 2013 Duct tape. Link to comment Share on other sites More sharing options...
HellShadow70 Posted July 28, 2013 Share Posted July 28, 2013 Did Mine Yesterday, Just like in the diagram. Installed a Derale 13011 With bracket and Tru-Cool 4454. Link to comment Share on other sites More sharing options...
HellShadow70 Posted July 28, 2013 Share Posted July 28, 2013 Update; I went back today And flipped the Derale bracket. Now It's right in the middle. I Would Like To Thank Every one in this thread for the help and knowledge. Gods Speed. Link to comment Share on other sites More sharing options...
BlackBird97 Posted July 29, 2013 Share Posted July 29, 2013 I installed mine this weekend without the bracket.. Seeing yours I think I'm going to have to pick one up. Was it hard to tap into the body of the car to mount it? Link to comment Share on other sites More sharing options...
HellShadow70 Posted July 29, 2013 Share Posted July 29, 2013 I installed mine this weekend without the bracket.. Seeing yours I think I'm going to have to pick one up. Was it hard to tap into the body of the car to mount it? not hard at all. use the 10mm bolt that holds the lines on the top of the bracket and drill a 3/16 hole on the other side. then use one of the four sheet metal screws provided. Link to comment Share on other sites More sharing options...
BlackBird97 Posted July 29, 2013 Share Posted July 29, 2013 not hard at all. use the 10mm bolt that holds the lines on the top of the bracket and drill a 3/16 hole on the other side. then use one of the four sheet metal screws provided. Awesome thanks man, is it a universal bracket for the tstat? I tried searching amazon and I couldn't find anything specific to the Derale 13011. Link to comment Share on other sites More sharing options...
HellShadow70 Posted July 29, 2013 Share Posted July 29, 2013 Awesome thanks man, is it a universal bracket for the tstat? I tried searching amazon and I couldn't find anything specific to the Derale 13011. Part# Derale 25973 Link to comment Share on other sites More sharing options...
mwm5094 Posted December 16, 2013 Share Posted December 16, 2013 OK, here you go. I spelled "FINISH" wrong, but what're you gonna do I routed my setup so that the system would act as stock under normal circumstances. The Derale thermostat was set to completely open at 180*. Basically the ATF would route normally through the radiator and then to the thermostat. If temp is high enough, some or all of the fluid will pass through the thermostat and through the external cooler before going back to the transmission. When the fluid is cold the thermostat will just turn the fluid back around and send it right back to the transmission. I wanted to include the radiator as it is because of the theory that the radiator will actually act to help cold fluid heat up a bit faster during the colder times of the year. Hope this helps! Bumping this thread. I just had a few concerns now that I have everything needed to install my 13011. Before I got the part, I pictured it in my head that the 13011 would re-route the trans fluid (thermostat closed) from one input to one output (both on the same side of the 13011) under 180 degrees and that it would "open the door" if you will above 180 making two nice channels for the fluid to flow through aka following the lines on the body of it. When I opened the box, I saw that this wasn't the case, and that the "USA" side clearly can flow right through under 180. When reading the directions, Derale wants you to interrupt both tranny lines so there is equal input and output pressure inside the 13011 in order to stop flow. I get that. My question is, following BMB's diagram, we are only interrupting the return line. Which would not cause equal pressure inside the 13011, which in my head would not make this function properly. My concern is that with the way we would run this, two things would happen. We would either starve the return line back it to the trans or since this isn't installed to the manufactures instructions (not interrupting both lines), it would still flow into the cooler and back into the trans making installing this useless. How is everyone else holding up? Am I wrong and someone can shed some light to clear this up for me? Has anyone monitored temps before and after? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 17, 2013 Share Posted December 17, 2013 I'm not sure I know exactly what you are describing, but I can describe it like this: the thermostat has two modes. Closed (cold) means the fluid In does a 180 back out. The other side does nothing, fluid sits still and waits in the cooler. Open (hot) means the fluid goes straight through one line in (side A) and out the other side (.B.), then through the cooler, then back in on Side B's other port, then out through Side A's other port. That help? Sent from my SM-N900P using Tapatalk [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
mwm5094 Posted December 17, 2013 Share Posted December 17, 2013 Closed (cold) means the fluid In does a 180 back out. The other side does nothing, fluid sits still and waits in the cooler. This right here is my only concern. Per Derale's directions, this is NOT how the thermostat operates. At least that isnt how I am interpreting it. Their words are, "How It Works: When the oil is cool the valve is in the open position, allowing oil to be applied equally to both the inlet and outlet of the cooler, preventing oil flow through the cooler. As the oil temperature approaches 180ºF the valve begins to close, forcing all of the oil to flow through the cooler and return through the valve to the source." So to me, it seems like the fluid is just at a standstill when it is cold (raising my concern of starving the trans of oil), and then when it is hot, it opens up and works just like the way you said. If you look at the thermostat not hooked up, Side A (the cold side) you can see right through. Which also raises my concern about the fluid doing a 180 and returning out side B properly when cold. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 17, 2013 Moderators Share Posted December 17, 2013 Interesting. I logged the temps briefly with my setup but honestly don't recall the numbers other than think "well, seems to be working". If you want, the guy that bought my car is local and pretty involved in the Subie community--one of the DCAWD guys. I'm sure I could put you guys in touch and you can possibly get him to log some temps and what not. AFAIK, he's been running the same setup, but who knows--maybe he changed something. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mwm5094 Posted December 17, 2013 Share Posted December 17, 2013 I may want to talk to him. I am going to install me AEM trans temp gauge on Wednesday, drive around for a few days and note the temps. Then I will install the thermostat and see if anything changes. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 17, 2013 Moderators Share Posted December 17, 2013 I may want to talk to him. I am going to install me AEM trans temp gauge on Wednesday, drive around for a few days and note the temps. Then I will install the thermostat and see if anything changes. Pretty sure they have their meets on Tuesdays at hard times, might be worth heading over there. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
mwm5094 Posted December 17, 2013 Share Posted December 17, 2013 Yeah, for sure. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 17, 2013 Moderators Share Posted December 17, 2013 PM me your email also, I'll send a quick email to include both of you and you can talk. If he's still running the same setup I would imagine it's probably working well given the timeline, but either way if there's something to be improved I'm sure he would like to know about it as well. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 17, 2013 Share Posted December 17, 2013 This right here is my only concern. Per Derale's directions, this is NOT how the thermostat operates. At least that isnt how I am interpreting it. Their words are, "How It Works: When the oil is cool the valve is in the open position, allowing oil to be applied equally to both the inlet and outlet of the cooler, preventing oil flow through the cooler. As the oil temperature approaches 180ºF the valve begins to close, forcing all of the oil to flow through the cooler and return through the valve to the source." So to me, it seems like the fluid is just at a standstill when it is cold (raising my concern of starving the trans of oil), and then when it is hot, it opens up and works just like the way you said. If you look at the thermostat not hooked up, Side A (the cold side) you can see right through. Which also raises my concern about the fluid doing a 180 and returning out side B properly when cold. Ah I see what you are saying. When the fluid is cold, the 180 back should still be open. I like the way derale plumbed their thermostat. Clever, compact. You can test it by blowing on one side, while the two opposite ends are plugged or looped. Should still have airflow. This verifies that, though not as clear as you would like: http://legacygt.com/forums/attachment.php?attachmentid=170317&stc=1&d=1387309787 This shows how it's indeed going to work fine in both modes: http://legacygt.com/forums/attachment.php?attachmentid=170318&stc=1&d=1387309787 [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
mwm5094 Posted December 17, 2013 Share Posted December 17, 2013 Exactly. I tested it with water and it worked fine. Like I said, Im going to log temps before installation and after, time will tell. Ill post results. Link to comment Share on other sites More sharing options...
mwm5094 Posted December 26, 2013 Share Posted December 26, 2013 So I got the AEM trans temp gauge in a few days ago but havent been able to drive the car until this morning. I just went to the bank and back (about a 5 mile round trip with stop lights). The highest temp I saw was 135 and that was when the car was at idle so I def think I am overcooling big time. Everytime I stopped the temp got higher and everytime I started driving (nothing over 45) the temp went down. I was actually really impressed by how fast the temps dropped, I saw it go back down to 97 within a mile. I havent been on the highway but I can only suspect with more airflow the temps would be lower. Also, the car didnt go above 2500rpm so I know the trans wasnt producing much heat either. Link to comment Share on other sites More sharing options...
SATSFYD Posted December 26, 2013 Share Posted December 26, 2013 Well that makes me want to buy one now. **There are two types of people in the world, those who build horsepower and those who buy it. Which one are you? Link to comment Share on other sites More sharing options...
mwm5094 Posted December 26, 2013 Share Posted December 26, 2013 After I take a highway cruise I'll post results of that. But yea, def seems like the thermostat needs to go in. Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 27, 2013 Share Posted December 27, 2013 Maybe while I'm doing my rebuild actually install mine "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
