cryo Posted April 12, 2016 Share Posted April 12, 2016 Wow, Bummer for sure. Keep me updated. Dave [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
RckyMtnGT Posted April 13, 2016 Share Posted April 13, 2016 Wow, thats a big downer! Best of luck getting back on the road. Link to comment Share on other sites More sharing options...
N.Y.X. Posted April 13, 2016 Author Share Posted April 13, 2016 Thanks guys, things seem to be getting a little strange, slight deformation on the exhaust side blades, intake blades are perfect, zero shaft play. http://i1063.photobucket.com/albums/t503/childreth13/20160412_191154_zpsutnthn0d.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160412_193430_zpsp9zli3f7.jpg Link to comment Share on other sites More sharing options...
Nightmaresmk Posted April 14, 2016 Share Posted April 14, 2016 Your shaft broke or twisted it's a old turbo. unfortunately it is what it is. just replace it. Keep your filter line like i suggested on FB. Unless you find debris in the oil or in the filter don't worry about it and get a new turbo. Link to comment Share on other sites More sharing options...
N.Y.X. Posted April 14, 2016 Author Share Posted April 14, 2016 That's the thing, it's not an old turbo, it's got less than 1500 miles on it when it went out. Anyway, I ordered a 40 micron filter from XRP to replace the 10 micron filter that comes in the IP&T kit. Now just debating whether to stick with the 16g or upgrade to the 18g.... Link to comment Share on other sites More sharing options...
Nightmaresmk Posted April 14, 2016 Share Posted April 14, 2016 18G and you must have had a defect. as i said i have been running the IPT filter for years with over 80k miles with out issue. i went from v1 to V2 and then put it on my 18g Link to comment Share on other sites More sharing options...
N.Y.X. Posted April 25, 2016 Author Share Posted April 25, 2016 Welp Brian at BNR has the turbo, wants me to get a sandwich adapter and a new oil line running from it? Who in the hell makes that kit? Then he tells me I need a 50 micron filter for the IP&T kit, I told him I ordered the 40 and he said "oh that's ok then." Then he stated "someone used the wrong clip on the actuator and it's binding up, so that was likely the wastegate issue." Dave only added that clip after the adjustment, so it wasn't working right with the correct clip either. Then he said the turbine had touched the housing on both intake and exhaust and could have been a bad bearing from the beginning... Then he said to pretty much pull the OCV's and avcs line to confirm proper function and pretty much get a compression test cause it could be my engine that caused it. I explained again the the VF46 I pulled was flawless, no play, filters clear, old lady driven and maintained at the dealer etc, so how would I all of a sudden have a engine issue? So from the sounds of it the original turbo was bad right out the box, but now I have to go spend all this extra time and money to fix something that was bad to begin with just to confirm it? WTF. Not really sure what to do at this point... Link to comment Share on other sites More sharing options...
N.Y.X. Posted May 22, 2016 Author Share Posted May 22, 2016 Added the killer b pickup and oil baffe as well as completed the timing service and added a mishimoto sandwich adapter. http://i1063.photobucket.com/albums/t503/childreth13/20160521_095852_zpsa3ekoxoc.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160519_202509_zps9jaclgo7.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160520_153158_zpsftcrseb3.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160521_113529_zpsy94ptsrx.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160521_105638_zpsswtvqkxj.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160521_113259_zpsu62exlvk.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160521_105504_zpsiqqjkimr.jpg Link to comment Share on other sites More sharing options...
Rhitter Posted May 22, 2016 Share Posted May 22, 2016 How hard was the timing belt / water pump replacement? My pump is only a year old, but already leaking and I think I need to pull it off and put another on. Any tips? My OBXT build Link to comment Share on other sites More sharing options...
N.Y.X. Posted May 23, 2016 Author Share Posted May 23, 2016 This was my first time doing timing, luckily I have a good friend who confirmed I properly set everything up via video. I used "Meaty's Timing Change" on NASIOC and that was helpful. A couple of tricks: ~To reinstall crank pulley, clean mating surfaces well, put some clean oil on there with your finger and it will slide on with ease. ~Do not put oil on the crankshaft bolt, just dry torque to 100ft/lbs ~Make sure you get all the bolts off water pump, you need to remove this small rubber gasket to keep debris out and put it on your new pump before install. ~Water pump comes out by gently prying on the left side where the above rubber seal is. That's all I can think of at the moment. Link to comment Share on other sites More sharing options...
rion84 Posted May 29, 2016 Share Posted May 29, 2016 Good upgrade. The lot was clean but love the color of the obxt Link to comment Share on other sites More sharing options...
N.Y.X. Posted June 2, 2016 Author Share Posted June 2, 2016 So over the last 2 weeks after my turbo failure I have done the following: ~KB Oil Pickup and Baffle ~OEM Timing Replacement ~Flushed Rad Fluid and Burped System ~Added new custom 16g (will have thread and more details later on when I have broken her in) ~Flushed oil system with new filter and crap 5w30 for 15 minutes while looking for any leaks, issues ~Oil change with new OEM filter and Schaeffers 5w40 ~Installed AEM UEGO Gauge, idling at 14.5-14.8 ~Made custom oil feed line from here: http://shopping.kinugawaturbo.com/turboaccessories.aspx http://i1063.photobucket.com/albums/t503/childreth13/13315267_10100644935690666_5294314176036184176_n_zpszph7lw5f.jpg http://i1063.photobucket.com/albums/t503/childreth13/13307344_10100644935650746_2489767995498095065_n_zpssewr72ai.jpg http://i1063.photobucket.com/albums/t503/childreth13/13327506_10100644935710626_4208637446961207476_n_zpsqpisr573.jpg Link to comment Share on other sites More sharing options...
rebourne Posted June 2, 2016 Share Posted June 2, 2016 Glad your getting back on the horse! pic thread build thread Link to comment Share on other sites More sharing options...
GEE-OTTO Posted June 2, 2016 Share Posted June 2, 2016 I had that same plug in my 09 LGT! Hope the repairs/replacements yield a happier car, when you pulled the OCV/S was there any signs of debris? Or in the inline filter? I ask only to add to my knowledge base of "what to check if..." Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 30, 2016 Author Share Posted July 30, 2016 There wasn't anything in line, the failure was a 100% due to a bad turbo, more specifically a chinese manufactured center housing, a bend shaft to correct too large of manufacturing constraints, etc. Over 500 miles on the new JMP turbo break in and I have no issues what so ever. But he rebuilt it from scratch pratically. I do plan on writing a good review on my experiences, oil feed lines, filters, etc after my dyno appointment and next oil change. Had to move my dyno appointment with Cryo back to 8/5 so I could get my turbo inlet installed. Next up new brake pads all the way around and a couple engine grounds. http://i1063.photobucket.com/albums/t503/childreth13/13646940_10100681238858826_738278211_o_zpsb9sgiqqw.jpg http://i1063.photobucket.com/albums/t503/childreth13/13639593_10100681238883776_1837835254_o_zpsf5ecjxku.jpg Link to comment Share on other sites More sharing options...
runningbird Posted August 1, 2016 Share Posted August 1, 2016 did you need to take off or loosen the intake to get your new inlet on? Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 1, 2016 Author Share Posted August 1, 2016 I did not. Link to comment Share on other sites More sharing options...
runningbird Posted August 7, 2016 Share Posted August 7, 2016 how did the tune turn out? Link to comment Share on other sites More sharing options...
jam007 Posted August 7, 2016 Share Posted August 7, 2016 I love these OBXT projects Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 8, 2016 Author Share Posted August 8, 2016 Ok, so a little update, having some quirky tuning issues building boost. We could also smell a small exhaust leak, thinking my up pipe may be cracked, again.... Anyways, picked up a used Fast Motorsports catback exhaust that should help with the restriction along with a KS Tech air intake. I will go through and inspect, retorque the exhaust to spec from the headers back. Possibly replace the uppipe n the process. Old Tune: 286WHP/318WTQ http://i1063.photobucket.com/albums/t503/childreth13/20151120_090138_zpsyhzrjdgf.jpg New Tune: 303WHP/314WTQ http://i1063.photobucket.com/albums/t503/childreth13/20160805_202431_zps7z25atlg.jpg I think there's more power there, just need to get it dialed in. http://i1063.photobucket.com/albums/t503/childreth13/IMG_20160805_102112_zpsazlupmi2.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20160805_122907_zpsv8lx7dss.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160807_121808_zpsgscnaldv.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160807_121825_zpsjnkuzohz.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160807_121836_zpslqmal324.jpg http://i1063.photobucket.com/albums/t503/childreth13/20160807_123346_zpsii3qma15.jpg Link to comment Share on other sites More sharing options...
Flinkly Posted August 8, 2016 Share Posted August 8, 2016 no under-hood heatshield? * Build Thread * 26.53 MPG - 12 month Average * Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 8, 2016 Author Share Posted August 8, 2016 It doesn't fit with the GS Splitter and didn't want to cut it up. Link to comment Share on other sites More sharing options...
cryo Posted August 10, 2016 Share Posted August 10, 2016 On the upside this is the first standard 16G/vf52/vf48 LGT I can remember hitting over 300hp on our dyno on 91oct. That's no small feat, just gotta figure out where the restriction is and why such late boost. We checked wastegate preload, we are maxed from a tuning aspect to build boost so it lies deeper. [sIGPIC][/sIGPIC] Providing unmatched customer service and a Premium level of Dyno/E-tuning to the Community cryotuneperformance@yahoo.com facebook.com/cryotuneperformance. Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 11, 2016 Author Share Posted August 11, 2016 On the upside this is the first standard 16G/vf52/vf48 LGT I can remember hitting over 300hp on our dyno on 91oct. That's no small feat, just gotta figure out where the restriction is and why such late boost. We checked wastegate preload, we are maxed from a tuning aspect to build boost so it lies deeper. KS Tech intake on the way, with heat shield and going over to the exhaust shop Friday morning to see what the retro fit will cost on my catback. After that I will inspect my uppipe to see if it cracked... AGAIN as I had it re tig welded last year before the stage 3 tune. Either way I'm pleased and look forward to see if that helps open her up and combat the restriction issues. I think she could reach 320whp. Link to comment Share on other sites More sharing options...
WRX USA Posted August 11, 2016 Share Posted August 11, 2016 It doesn't fit with the GS Splitter and didn't want to cut it up. The trimming is really minor and I don't think anyone would really notice if you ever switched back to all OEM, if you ever sell. Link to comment Share on other sites More sharing options...
