N.Y.X. Posted August 20, 2013 Share Posted August 20, 2013 Username: N.Y.X. Year: 2008 Make: Subaru Model: Outback XT Trim: Limited Color: Newport Blue Pearl Miles: 89K miles as of 4/2015 Purchased: 4/2015 Mods Engine/Performance: Perrin Catted Downpipe w/ Tig Welded Wideband Bung Perrin EL (fixed by Perrin) Headers Fast Motorsports Retrofitted LGT Catback Grimmspeed Uppipe Grimmspeed Catback adapter Grimmspeed Gaskets Grimmspeed EBCS JMP 9 Blade Billet Ball Bearing 16G Turbo Custom Stainless Braided Turbo Oil Feed/AVCS Lines Grimmspeed TMIC KSTech Air Intake w/ Heat Shield (not installed) ID1000CC Injectors DW65C Forge Motorsports BPV Killer b Oil Pickup and Baffe Mishimoto Turbo Inlet (Red) Perrin Pitch Stop Mount (Red) Cryotune Performance Dyno Tune 91 Oct. Brakes/Suspension 04 STI Brembo F/R Calipers 04 STI Brembo F/R Rotors KNS STI Conversion E-Brake Shoes KNS Rear Brembo Brackets Stoptech F/R SS Brake Lines Yokohama YK580 235/40/R18 Rota Gravel 18x8.5 BCBR LGT Height Coilovers Whiteline Rear Control Arm Bushing KCA399 Whiteline Roll Center Steer Kit KCA313 Whiteline Front LCA Inner Bushing Set W53353 Whiteline Front Sway Bar BSF30Z Whiteline Rear Sway Bar BSR39Z Beatrush Rear Strut Bar OEM LGT Lateral Link Assemblies 2-OEM LGT Rear Control Arms Moog Front and Rear Sway Links Interior: Kartboy STS w/ Bushings TWM Performance Weighted Knob Redline Goods Shift/Ebrake Boots and Armrest Cover USDM STI Pedal Set USDM 4th Gen STI Steering Wheel/Airbag Weathertech Black Floor Mats OEM Rear Cargo Mat Rear Cargo Awning, Net and Tailgate Finisher Exterior: Custom Grille Custom Halo Headlights Halo Fog Lights Grimmspeed Red Alternator Cover JDM BP5 Face Lift Taillights JDM Facelift Rear Gate Garnish w/ LED Fog Light (Not Installed) Redline Goods Hood Strut Kit 20% Window Tint Yellow Fog Light Tint Electrical/Lighting: Sunpro Electrical Oil Temp & Boost Gauges AEM A/F Gauge Mishimoto Sandwhich Adapter Custom 2 Gauge Cubby Pod (A/F & Oil Temp) Universal Swivel Gauge Mount (Boost) Morimoto H7, 35W, 5500K HID's w/ Anti Flicker Resistor Optima Red Top Battery Maintenance: Subaru Blue Oil Filters Schaeffer's 9000 5W40 Motul 300 Gear 75W90 Rear Diff @ 90k Schaeffer's SCH-293 75W90 Front Diff @ 90k OEM Oil Cooler Seal @ 90k Gates Timing kit w/ Subaru OEM Waterpump/Gasket/Thermostat @ 92k Gates AC and Serpentine Belt @ 92k 2-New OCV's Part #: 10921AA080 @ 92k Southbend Stage 3 Daily Clutch, OEM Flywheel, Bearing, Fork, Boot, Clips @ 96k 2-New Front CV Shafts @ 92k 4-NGK Iridium LFR7AIX @ 96k Stoptech F/R Brake Pads @ 94k http://i1063.photobucket.com/albums/t503/childreth13/10995556_10100427159196506_3541582807534182593_n_zpsco72gouz.jpg http://i1063.photobucket.com/albums/t503/childreth13/14650081_10100729207349586_7065696213256640909_n_zpskmbgwtbt.jpg OBXT Build starts on post #125 http://legacygt.com/forums/showthread.php/n-y-x-build-sold-lgt-08-obxt-stage-3-212787p4.html Link to comment Share on other sites More sharing options...
wurkenman Posted August 21, 2013 Share Posted August 21, 2013 All sounds good except that Mobile 1. Get that out as soon as possible. These cars do NOT like that oil. If you woke up today, you have another chance to do it right. Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 21, 2013 Author Share Posted August 21, 2013 Gotcha, that came from the place I got it from. I will change it out next time around!! SOLD 4/2015 Year: 2006 Make: Subaru Model: Legacy GT Trim: Limited Color: Obsidian Black Pearl Miles: 80K miles as of 8/15/13 Purchased: 7/2/13 Mods Engine/Performance: Stage 2 Cryotuned on 91oct SPT Intake Perrin Catted Downpipe w/ Tig Welded Wideband Bung Perin Uppipe Perrin EL (fixed by Perrin) Headers Grimmspeed Gaskets Custom CBE (Going to add 2 universal skunk2 mufflers and custom mid and y pipe) CUSCO Front Strut Tower Bar Cobb STS STI Boost Pill Brakes/Suspension Front Centric Premium Rotors @ 83k Rear Centric Premium Rotors @ 83k Stoptech Street Pads F/R @ 83k Yokohama YK580 215/45/R17 Rota Gravel 18x8.5 (Summer Set) Interior: All Weather Floor Mats Exterior: Window Tint Black DEPO Headlights Plastidipped Grill Plastidipped Rims Thule 480XT Roof Rack Electrical/Lighting: 6000K HID Headlights Maintenance: IP&T Oil Line Puralator One Oil Filter Rotella T6 5w40 Autocraft Gold Battery @ 80k NGK SILFRA6A @ 81k Motul 300 Gear 75W90 Rear Diff @ 81k Red Line Lightweight Shockproof/Motul 300 Cocktail @ 81k Timing Belt Replaced with Gates Kit, Subaru waterpump, gasket, thermostat @ 83k Both Front hubs Replaced w/ Moog 513220 @ 87k Stage 3 Collection: Grimmspeed EBCS (acquired, not installed) BNR 16G (acquired, not installed) Grimmspeed TMIC (acquired) DW850CC Injectors (not acquired) DW65C (acquired) Perrin Turbo Inlet (not acquired) Turkeylord Blue Tee replacement (not acquired) Boost, Oil Temp Gauges (not acquired) 2-New OCV's (not acquired) Stage 3 Cryotune 91oct (once I acquire then install everything I will limp over to Dave's for a stage 3 tune) Photos: http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130707_104533_672_zpsb1f47de7.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164922_647_zps5c0903c4.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165007_092_zpscdbf56e0.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164938_917_zpsbd076e19.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164948_771_zpsadcd7df0.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_164914_752_zpsa5878156.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165116_117_zps0b312e7a.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165103_969_zpsddc3fa19.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130703_165606_369_zps67a0341d.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130819_185140_030_zpsc5cd0fa7.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130808_142616_875_zps50e28305.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130812_202023_483_zpsf032d97e.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130808_175139_384_zps8c6e0a5e.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 21, 2013 Author Share Posted August 21, 2013 Based off this statement, do a lot of people run 5W50? I see a lot of posts where people run 0W40... 5W30 is pretty thin when hot. Too find out what's best for our (EU) turbocharged Subaru engines, here in Holland we had an engineer of Kendall Oil taken oil samples from 150+ car's. (This fellow also works on the best oil for top-fuel dragsters) The samples where taken to the Kendall labaratories for analysis, and checked on everything you can imagine. So traces of metals from all engineparts, but also dilution with gas, sand, etc. According to the engineer turbocharged performance engines like our's should not use rather thin oil, cause the engine's produce pretty high torque at relatively low rpm's. An other item is, they can also run relatively high top rpm's. These fact's plus outcome of the oilreport, the conclusion was: All 0W.. and ..W30 samples contained more metal parts than average. The range 5W40, 10W40, and 5W50 came out best, with 5W50 as the absolute winner. According to this engineer, most car manufacturers prescribe thinner oils, cause of the cold start. In practice most people do not take the time for the engine oil to reach working temperature. Premature wear out could be an item then. 5W50 provides a healthy cold start, and a good lubrification on high temperatures. And this little gem was underneath... http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1293170&page=all Link to comment Share on other sites More sharing options...
stuck686 Posted August 21, 2013 Share Posted August 21, 2013 rotella t6 5w-40 fool. menards has it Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 21, 2013 Author Share Posted August 21, 2013 We don't have them here:/ I'll look around! How about Royal Purple? Link to comment Share on other sites More sharing options...
Cone_Killer Posted August 21, 2013 Share Posted August 21, 2013 Go to Walmart. Buy 2 gallons Rotella T-6 (blue jug) $21.xx each. Link to comment Share on other sites More sharing options...
Cone_Killer Posted August 21, 2013 Share Posted August 21, 2013 ^ I said 2 gallons because its cheaper just to buy a gallon vs. 1 additional quart every change. Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 21, 2013 Author Share Posted August 21, 2013 Excellent!! Thanks for the help, it's much appreciated!! Link to comment Share on other sites More sharing options...
tocinoman25 Posted August 22, 2013 Share Posted August 22, 2013 The mod bug bites again...i had my car stock for 3 1/2 years and collected parts from msprank group buys, etc...and so glad that i started to mod...it sure is a fun car! Had to install my parts this spring cuz next year is the big wedding...but i am saving for a turbo upgrade and supporting mods... Enjoy the car and let the modding begin! Ive been running shell rotella T6 for the last year and its good stuff...if it werent for these forums..i wouldve just used conventional 5w 30 Are you installing parts yourself? I hosted install days in my garage =) Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
N.Y.X. Posted August 22, 2013 Author Share Posted August 22, 2013 I've been building my Xterra for the last 3 years and it just became too much for a daily driver. So that's why I picked up the subie. I plan on installing all the parts myself as I do all the work on my vehicles and in the chance I can't do it, odds are one of my local buddies can. I also host local mod days, trail runs, shooting/camping weekends, etc. I like to get together with other mod enthusiasts! Here's my trail rig, I'm actually installing an ARB locker as we speak!! http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130720_140326_750_zps413f65ed.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130821_210659_020_zpsaf688857.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 3, 2013 Author Share Posted September 3, 2013 Wanting to change out my fluids in both diffs and the 5MT but seem to be getting mixed signals. I would like to swap all the fluids (including the oil w/ T6) and change the spark plugs before I go for my tune... What do some of you local guys prefer? Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 3, 2013 Author Share Posted September 3, 2013 Scored a set of "fixed" Perrin EL headers!!! Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted September 5, 2013 I Donated Share Posted September 5, 2013 put OEM plugs in when you swap those. Otherwise looks good, and swap the cusco front strut tower bar from "performance" to "ballast adding". Because of the front strut tower setup in these cars that does literally nothing for your performance except add weight to the front end. The front tower strut mounts are welded to the firewall and are braced by that already. Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 5, 2013 Author Share Posted September 5, 2013 I did not know that, thank you!! IK you said you run Red Line 75w90ns... but did you have any shifting problems before hand, or was it pretty much the same from changing the fluid... Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted September 5, 2013 I Donated Share Posted September 5, 2013 I didn't notice a difference. done it twice now with the redline, Once when I first got the car (99,000 miles) because I didn't know when it was last done and once a couple months ago (132,000 miles). I went with it because that's what was in the pictoral method to changing the fluids that you posted in the other day. I might try the cocktail next time just for chits and giggles. Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 6, 2013 Author Share Posted September 6, 2013 Sooooo ended up by going with BAC5.2's cocktail; returned the valvoline and ordered up 3 qts of Red Line Lightweight Shockproof and 2 qts of Motul 300 Gear 75W90. Figured I would order another and do the rear diff at the same time! $90 with free Prime 2-day shipping from amazon, not too bad! I will post an update with my results:) Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted September 6, 2013 I Donated Share Posted September 6, 2013 Sounds good! Also just so you know the stock intake is good up to about 350whp in these cars. You probably won't see any improvement in performance from the spt intake but you will notice more of a sound from the intake. Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 6, 2013 Author Share Posted September 6, 2013 That's what I read but it was free from a guy who wanted to trade for the stock stuff, so I figured why the hell not;) Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 6, 2013 Author Share Posted September 6, 2013 So ordered up the Red-Line Lightweight Shookproof, few qts of motul 300 gear (for MT cocktail and rear diff) through Amazon. Got a couple puralator one filters, 4 replacement spark plugs, and a smoked plate cover for the rear from advanced auto with a $50 off $125 promo code picked up in store (ignore the royal purple, that's for my xterra). Just have to swing by walmart after work and pick up a couple gallons of Rotella T6! I'll be a happy camper!! http://i1063.photobucket.com/albums/t503/childreth13/Untitled_zps2b7c955c.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 7, 2013 Author Share Posted September 7, 2013 Plugs... http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130907_094505_801_zps8d2c0298.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130907_094516_568_zps4a3b9f5c.jpg Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted September 7, 2013 I Donated Share Posted September 7, 2013 Wow, way past time on those. Get a proper tune asap Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 8, 2013 Author Share Posted September 8, 2013 I can't wait! But still putting together some of the final pieces of the puzzle. Fluids and all the pre-tune/scheduled maintenance will be done by the end of this week. But I still need my grimmspeed headers gasket to arrive and my "fixed" EL headers! Oh and the custom y-pipe to be welded up. Then it will be time to get road tuned! Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 10, 2013 Author Share Posted September 10, 2013 Drained and filled the 5MT with the Shockproof and Motul 300 cocktail; noticeably smoother in every gear and feels like new. Took the crunch out of 4th all together. Thanks for the help everyone! How some of my oil arrived:/ http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130909_170828_195_zps75460fec.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130909_191258_904_zpsbf233090.jpg Panning for gold;) http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130909_184326_368_zpsebd84b46.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 13, 2013 Author Share Posted September 13, 2013 Ordered the last 2 gaskets I needed; a pair of header gaskets from Grimmspeed and a new OEM Subaru donut;) Link to comment Share on other sites More sharing options...
