N.Y.X. Posted May 27, 2015 Author Share Posted May 27, 2015 Ordered 1/2" saggy butt spacers with GEO metro rear studs. Link to comment Share on other sites More sharing options...
N.Y.X. Posted May 31, 2015 Author Share Posted May 31, 2015 Finished up the Whiteline suspension bits and the KB bushings... Need to order some end links for F/R. http://i1063.photobucket.com/albums/t503/childreth13/Hoops_zps7czggbhn.png http://i1063.photobucket.com/albums/t503/childreth13/WL_zps8lqe7f8v.png http://i1063.photobucket.com/albums/t503/childreth13/AL2_zpsydxquczy.png http://i1063.photobucket.com/albums/t503/childreth13/WL1_zpshux82dzq.png http://i1063.photobucket.com/albums/t503/childreth13/WL2_zpseag9r6gz.png http://i1063.photobucket.com/albums/t503/childreth13/WL3_zpsdk7fddp7.jpg Link to comment Share on other sites More sharing options...
Kevin622 Posted May 31, 2015 Share Posted May 31, 2015 Looks good! I just installed my whiteline ball joints + tie rod ends. Also did both shifter bushings i love it! Link to comment Share on other sites More sharing options...
rebourne Posted June 1, 2015 Share Posted June 1, 2015 Hey N.Y.X., What do you think about adding a link to when the OBXT action starts to the post #1 edit? I'm still trying to find it (handicapped by phone browsing), gave up and posted this. #subscribed pic thread build thread Link to comment Share on other sites More sharing options...
N.Y.X. Posted June 1, 2015 Author Share Posted June 1, 2015 Sounds good man, will do! Post #125. Link to comment Share on other sites More sharing options...
N.Y.X. Posted June 14, 2015 Author Share Posted June 14, 2015 Added 1/2" saggy butt spacers. http://i1063.photobucket.com/albums/t503/childreth13/11429854_10100467970086156_1905754714328391786_n_zpsisjxcihv.jpg Finally got her aligned, not the best, but still working with it a bit. http://i1063.photobucket.com/albums/t503/childreth13/20150611_072046_zpszzgazfjr.jpg Changed the front diff fluid with some schaeffer's 75w90... http://i1063.photobucket.com/albums/t503/childreth13/11401444_10100471071795306_2263559684609930598_n_zpsyvrzlrda.jpg Installed the V2 Turbo Oil Feed Line IP&T Kit http://i1063.photobucket.com/albums/t503/childreth13/20150613_102659_zpsbpurekmw.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150613_104426_zpsajcqmbw8.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150613_112958_zpsatlih4ms.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted June 14, 2015 Author Share Posted June 14, 2015 Ordered new Gates serpentine and AC belts along with MOOG front and rear sway bar links. Link to comment Share on other sites More sharing options...
N.Y.X. Posted June 20, 2015 Author Share Posted June 20, 2015 Fronts... http://i1063.photobucket.com/albums/t503/childreth13/20150618_181420_zpskzgfz2mz.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150618_181432_zpsbwy5zwiv.jpg Rears... http://i1063.photobucket.com/albums/t503/childreth13/20150618_191901_zpsfeyk3s3k.jpg Belts... http://i1063.photobucket.com/albums/t503/childreth13/20150618_184915_zpsjpp7hhyy.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150618_184814_zpslp9f1ubv.jpg Link to comment Share on other sites More sharing options...
LatentWagen Posted June 24, 2015 Share Posted June 24, 2015 Nice progress NYX; looks like you were just in time with the belt. How are you liking the new suspension setup? LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 6, 2015 Author Share Posted July 6, 2015 I am still playing with the settings, so far about 7-9 "clicks" from soft is where it seems to be most comfortable. But for coils for less than $1k they are awesome!!! Wanted to add a little subtle touch on the headlights matching the wheels, but they came out ok. Need to re-do one as for some reason it's not sitting right. But once I do the lens maybe I will like them more. Also need to remove the clear protective material. http://i1063.photobucket.com/albums/t503/childreth13/20150704_155235_zpsrjbcq3of.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150705_145433_zpsnw14vg0q.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150704_155241_zpsvc8pe1ru.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150705_145441_zpsaa1mojw4.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150704_163405_zpshpq4lzxt.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150704_173355_zpsmonx4xbo.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150704_173417_zpsodvc8mdg.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150704_174539_zpswogijpxy.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150704_184534_zpseae5rt64.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150704_200601_zpswlpnfmzh.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150705_112713_zpslplfiqiq.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150705_121927_zps9hatj4iy.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150705_122419_zpsoggs7lgy.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150705_132129_zpsnlcbgn1g.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150705_135430_zpsf9wijw44.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 9, 2015 Author Share Posted July 9, 2015 Ordered electrical sunpro A/F, Oil Temp and Boost gauges long with their 2 gauge flat plate mount I am going to try and retro fit into the cubby. Plan is to run A/F and Oil Temp in the cubby and got a universal swivel mount to mount to the vent for the boost gauge. Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 11, 2015 Author Share Posted July 11, 2015 Added a 5500k kit from the retrofitsource. I had to trim the back of the bulb connectors so the back can just barely catch and screw in to seal the unit. I am happy for the 5 year warranty but not happy about trimming them to fit. http://i1063.photobucket.com/albums/t503/childreth13/20150711_105957_zpssoaorcai.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150711_162817_zpsnqjet4vq.jpg Also made a cubby pod out of a $9 mount. I do plan on wrapping it in carbon fiber vinyl. http://i1063.photobucket.com/albums/t503/childreth13/20150711_170333_zpsxgwhogn9.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150711_170055_zpsjlrttgqw.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150711_172846_zpsudhmw9lc.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150711_172853_zpswev0zd6l.jpg http://i1063.photobucket.com/albums/t503/childreth13/11698514_10100485500684696_636578844035653078_n_zpslh5skdbl.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 13, 2015 Author Share Posted July 13, 2015 Was able to vacuum, clean, leather conditioner, armor all and wash her today. 1st time I have been able to go through and detail the interior since purchase in May. Peeled the clear covers off the headlights in preparation for the 3m restoration and just that makes the custom lights look better. Some instagramers.... http://i1063.photobucket.com/albums/t503/childreth13/11745474_10100485710060106_1252099845258638295_n_zps4h3fx6bt.jpg http://i1063.photobucket.com/albums/t503/childreth13/11201178_10100485713383446_5060661445419869813_n_zpsykdbnrfh.jpg http://i1063.photobucket.com/albums/t503/childreth13/11745787_10100485716043116_5386559678373700763_n_zpsr9x0h81l.jpg And the regular shots.... http://i1063.photobucket.com/albums/t503/childreth13/20150712_162828_zps0a0sg7zw.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_170058_zpsvxbzvpra.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_174712_zpscxyqdokl.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_174741_zpst4uefgva.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20150712_174813_zpstup7nrrk.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_175159_zpsgja5ktdt.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_175203_zpsezq5sljs.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_175220_zpsahjzqreq.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_175237_zpslem2k7uj.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20150712_175328_zps4jhovr2p.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_175505_zpsqdagc4go.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150712_175604_zpsbgr2em5l.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 14, 2015 Author Share Posted July 14, 2015 Gauges came in... http://i1063.photobucket.com/albums/t503/childreth13/20150713_183703_zpsqtkpesay.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 14, 2015 Author Share Posted July 14, 2015 http://i1063.photobucket.com/albums/t503/childreth13/20150713_200211_zpsslhkgoyn.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150713_200217_zpsu0j2xyo9.jpg Link to comment Share on other sites More sharing options...
Nightmaresmk Posted July 14, 2015 Share Posted July 14, 2015 Toss that A/F gauage its complete waste of space. Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 14, 2015 Author Share Posted July 14, 2015 I plan to test them all to the ECU numbers and report back. I know they are cheap, but they are "the best" of the cheap world and have been around forever. I will at some point add "real" gauges but didn't want to spend $500+ on the real deal... I do like to test things to see my outcome, sometimes reading through pages and pages of others personal experiences just turns into white noise.... Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 14, 2015 Author Share Posted July 14, 2015 Here's the trimming on the retrofit source's HID's. Covered them in liquid electrical tape. http://i1063.photobucket.com/albums/t503/childreth13/20150713_202926_zpsaewpi4w9.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150713_202933_zpsimmukja0.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 19, 2015 Author Share Posted July 19, 2015 Polished up the portions that were not covered in the 3m protector to make them match up better. http://i1063.photobucket.com/albums/t503/childreth13/20150718_193146_zpsq2r0wpey.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150718_193941_zps4e1mvkpk.jpg Gauges... http://i1063.photobucket.com/albums/t503/childreth13/20150719_125107_zpsccxv8mnv.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150719_150506_zps2eshi4rz.jpg http://i1063.photobucket.com/albums/t503/childreth13/20150719_150536_zps24jkbf9k.jpg Link to comment Share on other sites More sharing options...
Nightmaresmk Posted July 20, 2015 Share Posted July 20, 2015 Sunpro works for most gauges not pretty but they work. the afr gauge is a narrow band which is fine for a carb not so much our cars. Link to comment Share on other sites More sharing options...
N.Y.X. Posted July 20, 2015 Author Share Posted July 20, 2015 Ohhh ok, gotcha. I will have to do some more research then. Thanks! Link to comment Share on other sites More sharing options...
Nightmaresmk Posted July 21, 2015 Share Posted July 21, 2015 Yeah modern cars use a wideband AFR gauge. I have had innovative and aem both worked great. Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 28, 2015 Author Share Posted October 28, 2015 Haven't posted up in awhile, figured I would give you all a little update. Disappointed with the OBXT brakes and pricing what the LGT setup would cost I figured I may as well go straight for the brembo setup. So I got a set of 5x100 Brembo STI Rotors along with matching gold front and rear calipers and rear hubs/spindles for the ebrake. Re doing my headlights this weekend, going to repaint the insides black, add a 100MM angel eye as well as some DRL's to give them more of a custom look. Plan on scheduling a tune soon, but I have never attempted fuel injector swap before, so I may just pay to have them installed along with the timing service. Not 100% sure yet. Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 29, 2015 Author Share Posted October 29, 2015 Also picked up those used Nameless rear muffler deletes from the FS section. Here are some pics of the brembo's. Need to install: Front Brembo Rotors and CalipersRear Brembo Rotors, Calipers, OEM hubs and spindlesNameless Rear Muffler DeletesBNR 16GGS EBCSPerrin Catted DPPerrin EL HeaderGS TMICID1000CCDW65CForge Motorsports BOV http://i1063.photobucket.com/albums/t503/childreth13/2736_zps1ovwwtsi.jpeg http://i1063.photobucket.com/albums/t503/childreth13/2734_zpsgd8yezlz.jpeg http://i1063.photobucket.com/albums/t503/childreth13/2728_zpsh1ap77ih.jpeg Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 30, 2015 Author Share Posted October 30, 2015 Started on the retrofit, paint, grille, etc. http://i1063.photobucket.com/albums/t503/childreth13/20151029_182405_zpsnj9myjuq.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151029_223331_zpsxzt0ayfy.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_114153_zpspvxtqjz1.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_122446_zps0zkin2y8.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_122431_zpskgdrbnjz.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_153841_zpsvj3bfyka.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_100821_zps4ceiz17a.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_103446_zpseuehxvga.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_105350_zpsnsfhz0sw.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_153807_zpsah1wrbwy.jpg http://i1063.photobucket.com/albums/t503/childreth13/20151030_153826_zpscjqhimcg.jpg Link to comment Share on other sites More sharing options...
