JermTheElf Posted June 26, 2013 Share Posted June 26, 2013 I had good luck with that.. Mine was 9.0025 OEM. I set it to 12 after installing 750cc injectors. It's been within a few tenths of correct after 4 fill-ups now which is good enough for me. Awesome thanks for the info Link to comment Share on other sites More sharing options...
BrenTuning Posted June 26, 2013 Author Share Posted June 26, 2013 JermTheElf, message sent Link to comment Share on other sites More sharing options...
Connor Posted June 30, 2013 Share Posted June 30, 2013 In your experience what is the most reliable stage 2 setup? Of course catless uppipe and catted or catless downpipe. Do you find a boost controller helps? What else is a good idea for stage 2? Also, do you prefer the AVO or Perrin TMIC? Link to comment Share on other sites More sharing options...
BrenTuning Posted July 1, 2013 Author Share Posted July 1, 2013 In your experience what is the most reliable stage 2 setup? Of course catless uppipe and catted or catless downpipe. Do you find a boost controller helps? What else is a good idea for stage 2? Also, do you prefer the AVO or Perrin TMIC? As stated the catless up pipe and downpipe of choice. Stock boost controllers are fine for a basic stage 2 setup. Either BP mod your TMIC or run an aftermarket intercooler. Both Perrin and AVO perform about the same. Adding a fuel pump helps as well as these cars aren't new anymore and the factory pump could be a little tired. Link to comment Share on other sites More sharing options...
WaspGT Posted July 5, 2013 Share Posted July 5, 2013 Bren, I'm working on installing a few parts now so i can finally take a trip to your shop. I'll be running a JMT 20G, CNT DP, Grimmspeed UP & CP, K&N Typhoon intake, and a CNT CBE. I need to know what size injectors i'll need, and what to get for a fuel pump. I've been told that the DW65C is the pump i need... and to go for 620cc or higher for injectors? What do you recommend for moderate power? I'm looking for safe & reliable power. LGT has 142k, dont need to grenade it just yet. Also i was told to ask you about the FMS TMIC. I was told that you believe in them and that it'll do what i need it to. Does the FMS TMIC for an 08+ fit the LGT too? Last but not least what kind of whp should i expect? (I always run 93 at the pump.) Thanks in advance Link to comment Share on other sites More sharing options...
BrenTuning Posted July 5, 2013 Author Share Posted July 5, 2013 FMS tmics work, not as nice as the ProcessWest they copy but they work. DW740cc injectors and DW65c pump. Hard to guess on power numbers, some of those ebay turbos really under perform. Link to comment Share on other sites More sharing options...
WaspGT Posted July 5, 2013 Share Posted July 5, 2013 Understood... just can't see spending over a G on something as ridiculous as an AVO on DD street car. Stock turbos got play all around... time for an upgrade. $400 was a great deal for a 20G with a warranty:). Do i buy an FMS TMIC for a late model WRX and make it fit? Are they the same as LGT? Link to comment Share on other sites More sharing options...
BrenTuning Posted July 5, 2013 Author Share Posted July 5, 2013 Same Link to comment Share on other sites More sharing options...
09Pegasus Posted July 13, 2013 Share Posted July 13, 2013 Hey Bren, I've been running a Sgt2 AP OTS tune for a little over a year now. I have a CNT catless DP, Borla CBE, and a Perrin TMIC. As of now my car will backfire when shifting, and it jerks a little when spooling. How is the best way to go about getting an Etune from you guys, price, and how long for a revision? Link to comment Share on other sites More sharing options...
ashwinearl Posted July 14, 2013 Share Posted July 14, 2013 Could you explain the process for creating logging files. Specifically, what do you perform a pull in a specific gear. What rpm to start what rpm to end. Can you give an indication of what speeds are necessary to obtain a good log file? Link to comment Share on other sites More sharing options...
ashwinearl Posted July 14, 2013 Share Posted July 14, 2013 2005 Legacy GT 5MT wagon stock. Goals: fun daily driver, fuel efficiency, drivability, reliability. What is the best bang for the buck combination of up pipe, downpipe and other recommended parts for a stage 2 combined with an access port and Bren Tune that you are comfortable recommending. Link to comment Share on other sites More sharing options...
BrenTuning Posted July 15, 2013 Author Share Posted July 15, 2013 Hey Bren, I've been running a Sgt2 AP OTS tune for a little over a year now. I have a CNT catless DP, Borla CBE, and a Perrin TMIC. As of now my car will backfire when shifting, and it jerks a little when spooling. How is the best way to go about getting an Etune from you guys, price, and how long for a revision? I'll send you a PM in a minute Could you explain the process for creating logging files. Specifically, what do you perform a pull in a specific gear. What rpm to start what rpm to end. Can you give an indication of what speeds are necessary to obtain a good log file? When an etune is purchased we send you a detailed .pdf describing exactly what we are looking for in datalogs. Link to comment Share on other sites More sharing options...
WaspGT Posted July 18, 2013 Share Posted July 18, 2013 FMS tmics work, not as nice as the ProcessWest they copy but they work. DW740cc injectors and DW65c pump. Hard to guess on power numbers, some of those ebay turbos really under perform. Bought an FMS TMIC and decided to go with a Kinugawa TD06 20G. I got the JMT 20G in the mail and there was so much play in the shaft it was ridiculous. It must have been off by several thousandths. What garbage! I also bought a 3 port Grimmspeed Boost Solenoid. Can i put that in now before the tune, or will it F with the Cobb tune? I thought it was just supposed to regulate the boost consistancy and eliminate the creep. Link to comment Share on other sites More sharing options...
BrenTuning Posted July 18, 2013 Author Share Posted July 18, 2013 Install it at the dyno. It's a completely different style boost controller than stock. Link to comment Share on other sites More sharing options...
WaspGT Posted July 27, 2013 Share Posted July 27, 2013 Could a Forge BPV cause an engine light to come on; ie: misfire on cylinder 2? Link to comment Share on other sites More sharing options...
SCASEYS Posted July 27, 2013 Share Posted July 27, 2013 http://www.forgemotorsport.com/content.asp?inc=product&cat=0007&product=FMDVTUN you can swap to the yellow spring now I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
prodrifterx Posted July 27, 2013 Share Posted July 27, 2013 Could a Forge BPV cause an engine light to come on; ie: misfire on cylinder 2? Wouldn't a bpv issue cause issues throughout rather than only one cylinder. Link to comment Share on other sites More sharing options...
BrenTuning Posted July 29, 2013 Author Share Posted July 29, 2013 Could a Forge BPV cause an engine light to come on; ie: misfire on cylinder 2? No. Go through and check everything, ie pressure test, check plugs, coil packs, injectors. Link to comment Share on other sites More sharing options...
RallyMachine Posted August 6, 2013 Share Posted August 6, 2013 Hey Bren, was tuned for Borla headers plus TBE etc. The headers just cracked and I was wondering if the tune would be affected if I change header brands. Link to comment Share on other sites More sharing options...
BrenTuning Posted August 7, 2013 Author Share Posted August 7, 2013 Different brands have different spool characteristics. Without going with the same header, it will possibly be off. Link to comment Share on other sites More sharing options...
RallyMachine Posted August 20, 2013 Share Posted August 20, 2013 So I ended up changing from the Borla header and Perrin Big Tube UP to the Maddad header/UP combo and did a Perrin turbo inlet at the same time. I don't have any knock, but from a crappy log I did it looks like my spool is crazy slow...vf52 hits 0psi at 2400rpm but doesnt reach peak untill 4000+. I'm guessing that this is a tuning issue, specifically WGDCs. Is that correct? Edit: This is with the stock BCS Link to comment Share on other sites More sharing options...
BrenTuning Posted August 20, 2013 Author Share Posted August 20, 2013 Could be that or a preturbo exhaust leak. Link to comment Share on other sites More sharing options...
RallyMachine Posted August 20, 2013 Share Posted August 20, 2013 Are Turbo Dynamics values of 15 unusually high? That's what I was seeing from spool until I hit target boost way late... Is it possible that I need to have my wastegate arm adjusted? Link to comment Share on other sites More sharing options...
BrenTuning Posted August 20, 2013 Author Share Posted August 20, 2013 That situation is highly uncommon. We would suggest having a tuner / shop locate the problem and isolate it to be tuning or mechanical. Link to comment Share on other sites More sharing options...
rtbrjason Posted August 20, 2013 Share Posted August 20, 2013 Are Turbo Dynamics values of 15 unusually high? That's what I was seeing from spool until I hit target boost way late... Is it possible that I need to have my wastegate arm adjusted? Maybe you're using a MickeyD tune? He uses that strategy where it ramps to 15 until peak boost then tapers to 5-10 as you approach redline.. I'm sure others do that as well. Link to comment Share on other sites More sharing options...
