Nightmaresmk Posted May 4, 2015 Share Posted May 4, 2015 Question after two years on my setup. i have run into an issue that several have posted questions on but no real answer. When driving at little to no throttle "flat road cruise on" my car starts hunting for afr. bouncing between 11.4to 16.8 you can feel the car jerking. AFR under load and idle are fine. Vacuum is stable -19psi to -20psi. Ive replaced parts with oem Subaru like 02 sensors and coils. Only thing i have changed since the original tune is the elh a couple months ago. Link to comment Share on other sites More sharing options...
762x39 Posted May 10, 2015 Share Posted May 10, 2015 Bren Tuning: What are you charging for stage 2 dyno tuning? Link to comment Share on other sites More sharing options...
Streetlegal Posted May 13, 2015 Share Posted May 13, 2015 Figure I'll join the party. Would be an e-tune since I'm in WI. I'm planning on doing this in two steps so if you could let me know if it makes sense/would work, that would be awesome. Or if you have any suggestions. Currently I have: -invidia Catless DP, Avo Mid/Y, nameless axlebacks -stock turbo and fueling -perrin after MAF tube -GFB Hybrid 50/50 BOV -air pump delete I am wanting to go E85 since it's all over the place by me and will be easier to make power. Would like to have an E85 map and a 93 map. Eventual goal is 400awhp/400awtq or somewhere around there. Part one plans: -ID1000s -DW300 -FMS FMIC (already have this) -GS EBCS -figure out some intake that will work with the FMIC Drive around with that for awhile while I get the rest of the parts together: -NA intake manifold -TGV deletes -Parallel fuel rail conversion -UEL headers or ported manifolds and GS crosspipe (have the cross pipe and spare manifolds to port) -Rotated up pipe with corresponding exhaust -not sure on the turbo yet. Was looking at a GTX3076 but thinking that might be more than I need. So I wanted to pick your brain and see what your thoughts were. Pricing on the e-tune too if possible trying to figure out my options. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 14, 2015 Share Posted May 14, 2015 Any dyno tune is $500 unless he has a special. stg 1/2/3 doesn't matter. StreetLegal you will want a wideband LC1 or AEM so you can monitor afr and a flex fuel sensor if your running e85. also with e85 you want a 10 micron filter before the fuel rails that you can open and clean every couple months. e85 is a dirty sticky fuel. Link to comment Share on other sites More sharing options...
jasejase Posted May 14, 2015 Share Posted May 14, 2015 Most tuners quote based more or less on the mods you have Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 15, 2015 Share Posted May 15, 2015 His prices are listed thankfully. My belief is Stage 0,1,2 road tune. stage 3,4,insane dyno tune with road tune cleanup. Link to comment Share on other sites More sharing options...
Streetlegal Posted May 19, 2015 Share Posted May 19, 2015 Any dyno tune is $500 unless he has a special. stg 1/2/3 doesn't matter. StreetLegal you will want a wideband LC1 or AEM so you can monitor afr and a flex fuel sensor if your running e85. also with e85 you want a 10 micron filter before the fuel rails that you can open and clean every couple months. e85 is a dirty sticky fuel. Oops forgot to list the wideband. I have an MTX-L in my trans am and really like it. Was planning on doing the same one. Didn't know you needed a flex fuel sensor or the filter. Haven't seen anyone else list that stuff. This also wouldn't be a dyno tune. It would be an e-tune since I am in WI Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 20, 2015 Share Posted May 20, 2015 Yeah e85 is actually e70-to e85 and it varies from month to month station to station so a sensor for ethanol content is a must imo. the filter is a must as well. e85 is not as widely used so sediment is normal unfortunately and it also breaks down quicker than gas. Link to comment Share on other sites More sharing options...
Streetlegal Posted May 21, 2015 Share Posted May 21, 2015 Yeah e85 is actually e70-to e85 and it varies from month to month station to station so a sensor for ethanol content is a must imo. the filter is a must as well. e85 is not as widely used so sediment is normal unfortunately and it also breaks down quicker than gas. Ah ok. Well I'll wait for them to respond. I'll most likely be going through them Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 22, 2015 Share Posted May 22, 2015 I would email him Bren is very good and very popular so that means he's extremely busy lol Link to comment Share on other sites More sharing options...
Streetlegal Posted May 22, 2015 Share Posted May 22, 2015 I would email him Bren is very good and very popular so that means he's extremely busy lol I guess that would be the smart thing to do Link to comment Share on other sites More sharing options...
Cobbtuned Posted June 20, 2015 Share Posted June 20, 2015 I need a tuner in Sacramento Sent from my SM-N910P using Tapatalk Link to comment Share on other sites More sharing options...
Nightmaresmk Posted June 23, 2015 Share Posted June 23, 2015 He's backed up and Buried happens when your good at what you do. email or call him. Link to comment Share on other sites More sharing options...
510Finn Posted August 8, 2015 Share Posted August 8, 2015 I need a tuner in Sacramento Sent from my SM-N910P using Tapatalk You have a PM. [emoji4] Sent from my ASUS_Z00AD using Tapatalk 08 Spec B details Link to comment Share on other sites More sharing options...
Ellesedil Posted August 21, 2015 Share Posted August 21, 2015 I'm hoping there's a good resource for this somewhere already, but I've been unable to find one so far. Is there a good guide to introduce those new to Accessports and ECU modifications (clarification: I'm not looking to modify anything myself)? Specifically, I'd like to understand what's going on in the engine, what things/gauges I should be monitoring, and what exactly do those gauges mean as far as the engine is concerned? Link to comment Share on other sites More sharing options...
rebourne Posted September 16, 2015 Share Posted September 16, 2015 man, this is a good thread. pic thread build thread Link to comment Share on other sites More sharing options...
Jimmy78 Posted December 28, 2015 Share Posted December 28, 2015 i am currently rebuilding my spec b motor. wondering if i should go stock block new or forged internals. want to do a vf52 injectors and pump turbo back maybe uel tomei headers and a ewg. any suggestions or input would be appreciated. and as far as a first start up or break in tune. need ap or no. thanks Link to comment Share on other sites More sharing options...
Jimmy78 Posted December 28, 2015 Share Posted December 28, 2015 also air pump delete. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
NastyLGT Posted March 4, 2017 Share Posted March 4, 2017 Got an e-tune through you guys about 8 months ago...been running great. Had it out today and during 2ng and 3rd gear pulls, the knock feedback jumps to -4.xx then all the way to -8.xx....obviously a reading that high isn't good. I've read that anywhere up to about -3 is acceptable. How do I fix or remedy this issue? Stays at zero during normal driving even under moderate boost. But as soon as I mash the throttle, the knock feedback jumps.... Link to comment Share on other sites More sharing options...
Dujo Posted March 6, 2017 Share Posted March 6, 2017 You may want to email BrenTuning directly. There hasn't been a post in this thread in a year and a half. It may not be seen for a while. Good luck! Link to comment Share on other sites More sharing options...
Blayzin212 Posted September 12, 2018 Share Posted September 12, 2018 Hi guys, new to this...forum that is. I have a question, what tactrix cable do I need in order to flash my 06 lgt with ecuflash from USB? Link to comment Share on other sites More sharing options...
