BrenTuning Posted July 21, 2014 Author Share Posted July 21, 2014 from this learning view, does it seem to be normal (running on stock map) has avo panel filter and stock intake, or indicative of a leak somewhere? http://legacygt.com/forums/showpost.php?p=4876471&postcount=14 thanks in advance Wouldn't hurt to do a boost leak test. We like to see the A/F learning within 5% either direction. It's not horribly off though. Well since diamond pistons are so close I've been looking into billet pistons . Im looking to get up into the 500to 550 range . I also have a 5eat any sugestions on beef ups for it? For that range, I recommend doing rods as well. As for building the transmission, the only place that I'm aware of building the 5eat is IPT. Link to comment Share on other sites More sharing options...
shiby Posted August 11, 2014 Share Posted August 11, 2014 if a car is tuned for stage2 (uppipe, downpipe) .. and then a CBE is added, is it really necessary to have the car returned? was thinking of going this route, but would want to avoid additional expense of a retune...would it just be better to wait until have CBE also and then get tune done? Link to comment Share on other sites More sharing options...
BrenTuning Posted August 11, 2014 Author Share Posted August 11, 2014 if a car is tuned for stage2 (uppipe, downpipe) .. and then a CBE is added, is it really necessary to have the car returned? was thinking of going this route, but would want to avoid additional expense of a retune...would it just be better to wait until have CBE also and then get tune done? Catbacks do not affect the tune at that level Link to comment Share on other sites More sharing options...
Ad-dam Posted August 12, 2014 Share Posted August 12, 2014 What pistons and rods do you recommend on stock bore and stroke size. Soooo many different options . If you have part numbers that would be great. I'm ready to order parts now Link to comment Share on other sites More sharing options...
Nightmaresmk Posted August 21, 2014 Share Posted August 21, 2014 AD-dam thats a question for the engine/turbo secetion. because it depends on your goals budget ect. Link to comment Share on other sites More sharing options...
prodrifterx Posted August 21, 2014 Share Posted August 21, 2014 Question regardig duty cycle of fuel system. What's the limit of the oe fuel injectors or why won't the duty cycle of oem injectors run past 47% , fuel pump will run up to 100% pending load, and running a OTS stage 2 tune. All oem fuel system. I know it should get a proper tune, but it's been fine this far, how come it won't continue to compensate for the added air flow? Have a spt intake and avo Inlet and catless pipes. Stock header and crossover and catback. Stock tmic and so forth. Curiousity. 2006 LGT . 143k, all oe. Also any insight on what kind of latency and wp values I should be seeing? Would a larger set of injectors or high volume fuel pump make compensating for the air flow increase easier, granted tune still best bet . Link to comment Share on other sites More sharing options...
Jeffer Posted August 30, 2014 Share Posted August 30, 2014 Hey! I just got an E-Tune on 91 oct from you (very satisfied!) and was wondering if it's the same price for a second one on a different fuel type. I have access to 94 here and was wondering if it would worth it Link to comment Share on other sites More sharing options...
doobaruGT Posted September 11, 2014 Share Posted September 11, 2014 Not sure if this is crossing the line on questions related to tuning but... I'm placing a GFB TMS Response BPV on and I'm wondering what to look for when it comes to helping the flow versus inhibiting. In other words, how do I know where the "sweet spot" is? Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
jasejase Posted September 30, 2014 Share Posted September 30, 2014 I still want to get a retune. We're closing in on 3 years since my last tune. Time for a brush-up! I just wanted to get rid of my OSC plugs first. Any recs as to which plugs I should be running at my power level? Link to comment Share on other sites More sharing options...
BrenTuning Posted October 7, 2014 Author Share Posted October 7, 2014 Not sure if this is crossing the line on questions related to tuning but... I'm placing a GFB TMS Response BPV on and I'm wondering what to look for when it comes to helping the flow versus inhibiting. In other words, how do I know where the "sweet spot" is? When under full boost you do not want it opening, you'll normally hear a squeal if it is set too soft. Also when letting off the throttle after hitting full boost you do not want any compressor surge, turkey call sort of noise. I still want to get a retune. We're closing in on 3 years since my last tune. Time for a brush-up! I just wanted to get rid of my OSC plugs first. Any recs as to which plugs I should be running at my power level? OSC when you are making ~100whp over stock. So in your setup I'd recommend OSC plugs. NGKs are preferred. Link to comment Share on other sites More sharing options...
jasejase Posted October 7, 2014 Share Posted October 7, 2014 That's what I have in there. Thanks Link to comment Share on other sites More sharing options...
BrenTuning Posted October 7, 2014 Author Share Posted October 7, 2014 No problem! Link to comment Share on other sites More sharing options...
jasejase Posted October 7, 2014 Share Posted October 7, 2014 When I have time, I definitely will be coming up for a re-tune. I know I've said it twice now, but dammit, life keeps getting in the way! Link to comment Share on other sites More sharing options...
serx7 Posted October 8, 2014 Share Posted October 8, 2014 Not sure if this is crossing the line on questions related to tuning but... I'm placing a GFB TMS Response BPV on and I'm wondering what to look for when it comes to helping the flow versus inhibiting. In other words, how do I know where the "sweet spot" is? At the risk of being off the tuning topic, I installed a GFB TMS Respons BPV on my 05 OBXT last week and thought I had the spring pre-tension set properly. However, I noticed the other day that if the radiator fans kick on during idle, the BPV's piston opened slightly. An additional half turn of the hex screw on top appears to have prevented that effect. I'm currently having to run the GFB as atmospheric on a MAF tune (long story, yes I'm aware of the side effects/issues), so the opening of the piston in this manner was causing idle/idle fuel trim issues. Link to comment Share on other sites More sharing options...
ashwinearl Posted November 10, 2014 Share Posted November 10, 2014 2005 LGT Wagon 5MT -Cobb AP with OTS Map -Stock engine otherwise -89K miles (2nd owner purchased at 70k) -Have never checked banjo bolt -oil change every 3500 since purchase Goals: fun smooth daily driver. No autocross, track, etc. -Upgrade path: Invidia Up pipe Invidia down pipe Pro tune local or e-tune Question? Do you recommend upgrading the turbo at the same time as up pipe/downpipe/ tune? I am considering something small like a BNR16. Link to comment Share on other sites More sharing options...
BrenTuning Posted November 10, 2014 Author Share Posted November 10, 2014 2005 LGT Wagon 5MT -Cobb AP with OTS Map -Stock engine otherwise -89K miles (2nd owner purchased at 70k) -Have never checked banjo bolt -oil change every 3500 since purchase Goals: fun smooth daily driver. No autocross, track, etc. -Upgrade path: Invidia Up pipe Invidia down pipe Pro tune local or e-tune Question? Do you recommend upgrading the turbo at the same time as up pipe/downpipe/ tune? I am considering something small like a BNR16. Upgrading from the VF40 is always a good thing reliability wise. Seeing how low your mileage is you should still have some life in the VF40. EVO316Gs and VF52s are great replacement choices. Link to comment Share on other sites More sharing options...
Mike07LGT Posted February 9, 2015 Share Posted February 9, 2015 Hey Bren, you e-tuned my car about a year ago when I had a pretty restrictive catted downpipe that was on the car when I bought it. I just installed a catless downpipe and wanted to know if this would change anything with my previous tune, like quicker spool or overboost issues I could come across. Thanks for any info you can provide! 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
LmilnerGT Posted April 28, 2015 Share Posted April 28, 2015 Can you please recommend a proven clutch setup for 350hp/350tq power range with the WRX SMFW? Highly prefer chatter-free. Link to comment Share on other sites More sharing options...
Turkeylord Posted April 29, 2015 Share Posted April 29, 2015 What's the best way to "de-tune" a map for break-in? I've tried halfing the DAM table, zeroing out the WGDC table... I tried importing stock WGDC table values, but that was pretty ineffective and led to boost cut the other night. Should I mess with boost targets? Lots of options, just wondering what's the best way. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted April 30, 2015 Share Posted April 30, 2015 Use SI Drive and switch to Intelligent mode 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
boxkita Posted April 30, 2015 Share Posted April 30, 2015 Read your initial statement. And ignoring part of it... I have a tune that I like from a local tuner. However, in the course of replacing the HG, I've made just enough tweaks (740 to 850 injectors, tgv deletes, bigger radiator, etc) that an adjustment to part of the tune is necessary. Is this something you'd be willing to do? Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
BrenTuning Posted April 30, 2015 Author Share Posted April 30, 2015 Can you please recommend a proven clutch setup for 350hp/350tq power range with the WRX SMFW? Highly prefer chatter-free. Exedy Stage 1 What's the best way to "de-tune" a map for break-in? I've tried halfing the DAM table, zeroing out the WGDC table... I tried importing stock WGDC table values, but that was pretty ineffective and led to boost cut the other night. Should I mess with boost targets? Lots of options, just wondering what's the best way. Zero out the WGDC, essentially shutting off your boost controller. Then knowing the proper scaling for your injectors (if aftermarket) Read your initial statement. And ignoring part of it... I have a tune that I like from a local tuner. However, in the course of replacing the HG, I've made just enough tweaks (740 to 850 injectors, tgv deletes, bigger radiator, etc) that an adjustment to part of the tune is necessary. Is this something you'd be willing to do? If you have an AccessPort we can send you a basemap for a MAF setups. Neil@BrenTuning Link to comment Share on other sites More sharing options...
762x39 Posted May 3, 2015 Share Posted May 3, 2015 Is it completely safe to run the Cobb OTS Stage 2 93 map with these modifications: Grimmspeed uppipe, Invidia Downpipe, Grimmspeed Top mount intercooler, and Hexmods valvebody modification? I would like to hold off on a pro tune until I go stage 3 as I'll need a tune for the new turbo anyway. I'm from upstate NY and am planning on having my car tuned at Bren tuning. Do you think it is possible to have the new turbo installed and tune the car all in one day? I will be installing the injectors and pump. Link to comment Share on other sites More sharing options...
Nightmaresmk Posted May 4, 2015 Share Posted May 4, 2015 U can't install injectors without a tune. All the stage two parts are fine with cobb ots map just know a protune is nothing like the ots maps. May car has blipped 25psi due to a dp divider issue. ie divider is holding the wastegate closed and my tune by bren is the only reason it didn't blow. Link to comment Share on other sites More sharing options...
BrenTuning Posted May 4, 2015 Author Share Posted May 4, 2015 Is it completely safe to run the Cobb OTS Stage 2 93 map with these modifications: Grimmspeed uppipe, Invidia Downpipe, Grimmspeed Top mount intercooler, and Hexmods valvebody modification? I would like to hold off on a pro tune until I go stage 3 as I'll need a tune for the new turbo anyway. I'm from upstate NY and am planning on having my car tuned at Bren tuning. Do you think it is possible to have the new turbo installed and tune the car all in one day? I will be installing the injectors and pump. We can send you a basemap for your AP to get you here when you install your turbo/fuel system. Your current list should be fine on the OTS mapping. Neil@BrenTuning Link to comment Share on other sites More sharing options...
