LosAngelesLGT Posted May 12, 2013 Share Posted May 12, 2013 I see tremendously wonderful things from Big Weiner. If you are gonna go, go all the way. I like your thinking. Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 12, 2013 Author Share Posted May 12, 2013 Right?!? Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 20, 2013 Author Share Posted May 20, 2013 I'm going to try and finish assembling my short block over the weekend. I'm just waiting on the snap on guy to send me a few of my tools back. Ill post up more pictures as I get the job done. Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 20, 2013 Author Share Posted May 20, 2013 I see tremendously wonderful things from Big Weiner. If you are gonna go, go all the way. I like your thinking. Haha I just caught the big wiener in there. Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 24, 2013 Author Share Posted May 24, 2013 Heads are fully cleaned out I'm going to try and have a fully assembled short block done over the weekend. And if I have time start to drop it into the car. It's time to let this beast breathe after over a year off Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 29, 2013 Author Share Posted May 29, 2013 http://i499.photobucket.com/albums/rr353/jmorris6689/null-24.jpg I washed it up yesterday to prep for the motor install. After a year if sitting she still cleans up nicely! Ready to have it move again, pushing it in and out of the garage was no fun. Link to comment Share on other sites More sharing options...
jmorris6689 Posted May 31, 2013 Author Share Posted May 31, 2013 I don't know if any of y'all use the rock auto web store but they have crazy cheap subaru timing kits on there and it's the nice gates kit that has the Kevlar belt. And you can buy timing components individually if you don't need a whole kit. Just thought I would share the wealth. Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 8, 2013 Author Share Posted June 8, 2013 http://i499.photobucket.com/albums/rr353/jmorris6689/null-29.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-28.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-27.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-26.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-25.jpg Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 9, 2013 Author Share Posted June 9, 2013 http://i499.photobucket.com/albums/rr353/jmorris6689/null-32.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-31.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-30.jpg Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 10, 2013 Author Share Posted June 10, 2013 Motor is coming together nicely I'm going to try and have it running late this week. Then it's on to trying to break the 11 second barrier Link to comment Share on other sites More sharing options...
Strizzy Posted June 11, 2013 Share Posted June 11, 2013 What are you doing for breaking in the new motor? My bad luck build Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 11, 2013 Author Share Posted June 11, 2013 (edited) Guess I should start composing my build sheet since she is getting close Block: ej255 701 casting Sti nitrited crank Manly H beam connecting rods Wiseco 8.5:1 forget pistons 100mm Blueprinted and balanced by myself King main and rod bearing with extra oil clearance for high boost and extra oil cuts Stock block bolts Subaru block heater Covert oil pick up Subaru oil pan Sti 11mm oil pump New water pump New timing pullies Stock crank shaft pulley New timing covers Gates Kevlar timing belt Sti intake manifold ported to match tgv's Tgv's deleted and ported to match grimmspeed spacers Grimmspeed tgv spacers ported to match ported intake on the cylinder head Stock legacy throttle body ported Grimmspeed 160 thermostat Aftermarket oil cooler mounted in stock intercooler location Heads B25 heads ported and polished exhaust ported intake Gs power division 272 cams Gs power division springs and retainers Stock valves (ran out of money for nice valves) Arp head studs Factory head gaskets One step colder spark plugs ngk platnium Factory ignition coils Fueling Dual intank deatchworks 300 lph fuel pumps 850cc deatchworks side feed injectors Stock fuel lines and rails (for now) Areomotive adjustable fuel pressure regulator Fuel swirl pot Intake and exhaust Perrin short ram intake Perrin turbo inlet Borla wrapped unequal length headers Greedy up pipe Amr cxr 550 turbo sti fitment Gfb blow off valve Avo front mount kit Invidia uncatted downpipe Manga flow cat back Misc bolt ons and gauges Grimmspeed 3port ebcs Prosport halo oil pressure gauge Innovate lm2 wideband Lamco boost gauge (factory on sti) Sport wrx pedals Open sourced tuned by myself for the moment Group n motor mounts Grimmspeed air oil separator Oil cooler mounted in stock intercooler location Driveline and suspension and brakes 05 sti 6mt transmission 07+ spec b rear axles Empi front axles 05 4eat drive shaft (looking to upgrade) 6puck act hd clutch Light weight act fly wheel R180 rear diff out of 05 sti 08 sti shifter linkage with group n bushings Sti slave cylinder Stock shocks Tein s tech lowering springs Dba 4000 front and rear rotors Hawk hp+ pads front and rear Stock rims with some fallen zeix all season tires Various other modifications eBay front lip LL bean outback wood grain steering wheel Avo grill 06 Lexus rx330 hid retrofit 06 Celcia crystal clear projectors Painted white head light housings White hella horns Tinted tail lights Carbon fiber knards Led interior lights Jazzy iPod connection Valentine one radar (a must have) Optima red top battery Probably gonna have a few edits as I remember all the parts I've compiled Edited June 21, 2013 by jmorris6689 Forgot a few parts Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 11, 2013 Author Share Posted June 11, 2013 For the break in I'm gonna run waste gate boost pressure with ams oil high zinc content oil and be pretty easy on it for 1000miles then start to use more power Link to comment Share on other sites More sharing options...
Strizzy Posted June 11, 2013 Share Posted June 11, 2013 What are you using for your fuel pump basket/holder for the twin pumps? There was one I was looking at (can't remember the name), but was worried about fueling issue with a 1/4 tank, or less, of fuel. My bad luck build Link to comment Share on other sites More sharing options...
Strizzy Posted June 11, 2013 Share Posted June 11, 2013 I'll be done with my 1500 mile break-in this week. 4250RPM rev limit with 10psi fuel cut. I varied my speeds/engine loads and engine braked as much as possible. People behind me hated me. My bad luck build Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 11, 2013 Author Share Posted June 11, 2013 I made the bracket myself I modled it after one I saw online somewhere And yeah I'll be doing tons of engine braking and not revving high at all Link to comment Share on other sites More sharing options...
Strizzy Posted June 11, 2013 Share Posted June 11, 2013 Any pics of it? My bad luck build Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 11, 2013 Author Share Posted June 11, 2013 I can see if I took any, but I put it in the tank right before the last pooped on me Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 11, 2013 Author Share Posted June 11, 2013 I don't believe I have any pictures Link to comment Share on other sites More sharing options...
Strizzy Posted June 11, 2013 Share Posted June 11, 2013 No problem. I have my fueling set up already. I was just curious as to how yours was. My bad luck build Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 11, 2013 Author Share Posted June 11, 2013 Soon as I graduate (again) and get a job I'm upgrading rails and to a/n dash10 lines to the bulk head then dash 8 for a return. Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 15, 2013 Author Share Posted June 15, 2013 So I was going to use the factory oil cooler, but it costs close to $300 so I've decided to make my own oil cooler and relocate my filter too so that the headers don't bake my oil. This should also increase my oil capacity to around 6-7 quarts with the stock oil pan and leave the oil much cooler than the stock cooler does. Ill post up pics soon as parts arrive next week. As for the rest of my motor the only thing slowing me down is waiting on parts to roll in. Link to comment Share on other sites More sharing options...
jmorris6689 Posted June 21, 2013 Author Share Posted June 21, 2013 http://i499.photobucket.com/albums/rr353/jmorris6689/null-37.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-36.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-35.jpg http://i499.photobucket.com/albums/rr353/jmorris6689/null-34.jpg Turbo and the new timing components are on. Bout to put in the cam seals, then the pullies, and put it in timing. Just moving right along, I'm finally at the point that I don't have to order any more parts. Just waiting on the oil cooler to arrive, then it's going in the car. Finally after a year and a half I'm getting close!! Link to comment Share on other sites More sharing options...
Legend Posted June 24, 2013 Share Posted June 24, 2013 Congrats on getting close. Love the pics! My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
Th3Franz Posted June 25, 2013 Share Posted June 25, 2013 Nice. My new engine will look very similar Which turbo is that? What do you think the setup will put down for power? -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
