NSFW Posted January 12, 2012 Share Posted January 12, 2012 Poor man's water injection. A little hydrolock never hurt anything. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted January 12, 2012 Share Posted January 12, 2012 speaking of water injection, I had an idea for cleaning out the engine from time to time in the way water injection does, except a different way pour a quart of windshield washer fluid into the FMIC core. It's so low, water will only get drawn up and into the engine little by little over time. Anyone see any issue with this staggering work of pure heartbreaking genius? OP could do this [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
NSFW Posted January 12, 2012 Share Posted January 12, 2012 I'd be worried that it would mostly not get picked up, until randomly sloshing into the motor all at once. Better to tee the BOV actuator line into the WWF reservoir, and trickle it in Sea-foam style. Or better yet, none of the above. Link to comment Share on other sites More sharing options...
sumfoo1 Posted January 12, 2012 Share Posted January 12, 2012 I'm a moron ok, so the map is aimed at being efficient at higher prs. Well, be has done well for themselves in the diesel market so that should be no surprise. However efficiency is just the percentage of power going to compressing the air vs total power going to the air. The remainder is heat. However, the less total power going to the air is significantly less at lower pressure ratios, so it will still flow the sr amount of air, at lower prs, it will just heat it up a similar amount. Still not an ideal turbo for low prs, just makes more sence then it doesn't work at low pressure. You could put a baffle on the inlet/outlet to protect from sloshing, it would be gone pretty quickly due to evaporative cooling effects. Also anyone know what the lowest elevation 1/4 mile drag strip is ? I know "no problem" is 12-15 ft Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted January 12, 2012 Share Posted January 12, 2012 Better to tee the BOV actuator line into the WWF reservoir, and trickle it in Sea-foam style. Perfect! done, going to do that on all my cars. Will post if I damage an engine, but to be realistic it's not going to hurt a damn thing; it will only do what the sprayer kits inadvertently do, clean everything Or better yet, none of the above. Where is your sense of adventure Sorry for the OT, though OP could totally do this (while off boost) [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
monkiboym Posted January 19, 2012 Share Posted January 19, 2012 jdmchizad, can you post some photos of the relocation that you were able to complete without rerouting of the lines in order to create room for the turbo? just finished building the motor on my 08 wrx and now installing my EFR and full-race ts kit next but know i got some fitting hurdles ahead.... thanks! Link to comment Share on other sites More sharing options...
Hops Posted January 19, 2012 Author Share Posted January 19, 2012 I'll try to get some soon! Still working on lines and fittings... Buy my cars! Link to comment Share on other sites More sharing options...
monkiboym Posted February 1, 2012 Share Posted February 1, 2012 I'll try to get some soon! Still working on lines and fittings... hi sir, still no luck with photos of the relocation? also, just to have a timeline so i don't have to keep checking here, when are you expecting to have this wrapped up and tuned? Link to comment Share on other sites More sharing options...
gutt-spec-B Posted February 1, 2012 Share Posted February 1, 2012 subscribed Link to comment Share on other sites More sharing options...
Hops Posted February 1, 2012 Author Share Posted February 1, 2012 Sorry guys... Ski season! Next week I'll be back in it. Buy my cars! Link to comment Share on other sites More sharing options...
doccrowley Posted February 1, 2012 Share Posted February 1, 2012 Our snow is pitiful. Finish the car before the snow arrives, 3rd week of Feb. Link to comment Share on other sites More sharing options...
mwiener2 Posted February 1, 2012 Share Posted February 1, 2012 3rd week of Feb? How about tomorrow... My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
doccrowley Posted February 2, 2012 Share Posted February 2, 2012 2-4" is just dust on crust at this point. Really bleak snow conditions at this point. http://forecast.weather.gov/MapClick.php?site=slc&textField1=40.58194&textField2=-111.65444&zone=1 Link to comment Share on other sites More sharing options...
Hops Posted February 2, 2012 Author Share Posted February 2, 2012 New wastegate actuator bracket http://i111.photobucket.com/albums/n121/JDMChizad/9bb93348.jpg Relocated ABS. Still need to make a bracket and figure out where to mount the power steering and coolant reservoirs. http://i111.photobucket.com/albums/n121/JDMChizad/b6d2307f.jpg Buy my cars! Link to comment Share on other sites More sharing options...
Ohitsspencer Posted February 2, 2012 Share Posted February 2, 2012 Woohoo! Progression! Link to comment Share on other sites More sharing options...
jfg22557 Posted February 2, 2012 Share Posted February 2, 2012 Iwg:icon_cry: needs twin vta tials Link to comment Share on other sites More sharing options...
mwiener2 Posted February 2, 2012 Share Posted February 2, 2012 TS IWG is half the point of an EFR My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Mortal2None Posted February 13, 2012 Share Posted February 13, 2012 The NASIOC thread of an EFR install is in the process of tuning and the initial results look promising: http://forums.nasioc.com/forums/showthread.php?t=2041557 Link to comment Share on other sites More sharing options...
mwiener2 Posted February 13, 2012 Share Posted February 13, 2012 Initial results don't look better than a standard 30r... Also, that guy is making it way, way over complicated. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Mortal2None Posted February 15, 2012 Share Posted February 15, 2012 35r? Link to comment Share on other sites More sharing options...
Mortal2None Posted February 15, 2012 Share Posted February 15, 2012 And yes. They're not sticking to the K.I.S.S. principle there. Link to comment Share on other sites More sharing options...
Hops Posted February 15, 2012 Author Share Posted February 15, 2012 Finally got some time off work, got a killer powder skiing day, and picked up some fittings and fuel lines. Back to work! Buy my cars! Link to comment Share on other sites More sharing options...
mwiener2 Posted February 16, 2012 Share Posted February 16, 2012 I Still have a 7064 if anyone wants it...... My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Hops Posted February 21, 2012 Author Share Posted February 21, 2012 Making progress... Fuel lines almost done, wiring harness back on, and intake manifold is coming together. Intercooler piping and intake soon. http://i111.photobucket.com/albums/n121/JDMChizad/0fee9b78.jpg Buy my cars! Link to comment Share on other sites More sharing options...
mwiener2 Posted February 21, 2012 Share Posted February 21, 2012 do you have a full build list anywhere? ~3500ASL and using E85? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
