xezus Posted June 5, 2012 Share Posted June 5, 2012 Just my input, I have successfully disassembled the maf, so I have the sensor that I can put in a drilled hole. I will need to fabricate a cover for the plug and chip board. I will post pics soon. I bought the maf at a junk yard for 5 bucks, and it works great. The guy ashed me what it was, I said, thingy for the intake, and he said 5 bucks lol. I will attempt to make a creation of tubing similar to you all, and will give all credit. Edit: I will most likely use pvc for a rough draft, to get an idea of how it's going to fit. So I will need: Pvc Dremmel maybe my stock box filter, by cutting and remolding... Maybe All in all, I will be very creative. If successful, I will post measurements and pics of the finishing product, along with links to videos of me making it. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 5, 2012 Share Posted June 5, 2012 +1 for the same username^ and dyslexia... because lamp. Link to comment Share on other sites More sharing options...
xezus Posted June 5, 2012 Share Posted June 5, 2012 Zeezus is how I pronounce it. It's my gamertag and username for practically everything I use. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted June 5, 2012 Share Posted June 5, 2012 swagon is my actually name, beat that BNR18g on 93oct Link to comment Share on other sites More sharing options...
twisty Posted June 5, 2012 Share Posted June 5, 2012 ^please dont do that its not actually a project for my subaru, but thanks for the encouragement. Link to comment Share on other sites More sharing options...
Zues Marine Posted June 5, 2012 Share Posted June 5, 2012 either way, cutting a scoop near the headlight for an intake? no... Link to comment Share on other sites More sharing options...
twisty Posted June 5, 2012 Share Posted June 5, 2012 in the legacy, there is no room at the front to do much of anything, but that doesnt hold true for all cars. and i think youre envisioning it sitting directly above the head light, which isnt correct either. take a look at a few other car models, im sure you will see plenty of space for an intake entry. dont bash me for my sense of style/ utility based on what you like or think will work. also, ive seen a couple subaru entry points that originated under the hood directly above the passenger side head light, piping to a custom box either over the head or up and next to the TB. no holes cut at all, which would be my ultimate goal anyway. Link to comment Share on other sites More sharing options...
WESTcoast Posted June 5, 2012 Share Posted June 5, 2012 either way, cutting a scoop near the headlight for an intake? no... in the legacy, there is no room at the front to do much of anything, but that doesnt hold true for all cars. and i think youre envisioning it sitting directly above the head light, which isnt correct either. take a look at a few other car models, im sure you will see plenty of space for an intake entry. dont bash me for my sense of style/ utility based on what you like or think will work. also, ive seen a couple subaru entry points that originated under the hood directly above the passenger side head light, piping to a custom box either over the head or up and next to the TB. no holes cut at all, which would be my ultimate goal anyway. Alot of peanut eye STI's take out thier drivers side highbeam and put a vent right there for the intake, my friend has it done of his track car but at the same time, it only looks good if you are going super aggressive imo. http://i393.photobucket.com/albums/pp14/ripper434/headlightInsert.jpg You can do the same on an legacy if you had the morrette headlights where you can take out the high beam and use that as a inlet for the intake. Link to comment Share on other sites More sharing options...
twisty Posted June 5, 2012 Share Posted June 5, 2012 i was thinking something along the hood line, no cutting involved. ive seen a few stock vent intakes i want to test airflow with when i have the time. its basically a collector of sorts, about 10" wide, 1' tall and angles to one side, opening up to a 3" tube for exit. pretty much perfect for what i want to do, if i can find the right one. the piping from there is the tricky part. well, its actually simple, but shedding moisture build up is the hard part. i just have to make sure i have enough air coming inside it to not have it be my choke point. i could also do something like this http://img.auctiva.com/imgdata/1/5/7/3/3/4/3/webimg/533356558_o.jpg but id hide it in the lower area, painted the same color as the bumper.that might work better, especially for water. its not going to blow water up 15" of piping if youre not doing over 150 i bet. Link to comment Share on other sites More sharing options...
twisty Posted June 5, 2012 Share Posted June 5, 2012 not sure why i worry about water so much, i live in a place that gets 342 days a year average of sunshine... Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 5, 2012 I Donated Share Posted June 5, 2012 not sure why i worry about water so much, i live in a place that gets 342 days a year average of sunshine... So what part of Phoenix are you in? -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
twisty Posted June 5, 2012 Share Posted June 5, 2012 So what part of Phoenix are you in? east-ish mesa, hehe. home of the crazies. stapely/ broadway area (little mexico, i call it. its ok tho, im half bean) Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 5, 2012 I Donated Share Posted June 5, 2012 I'm literally 3 miles away from you. Off Road SHO here on the forums doesn't live to far from us either. -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
Zues Marine Posted June 6, 2012 Share Posted June 6, 2012 dont bash me for my sense of style/ utility based on what you like or think will work. dont get butt hurt, im just saying there's not going to be a massive performance gain by doing this as opposed to putting it in the fender.. but to each his own, i dont care what you do, its your car Link to comment Share on other sites More sharing options...
twisty Posted June 6, 2012 Share Posted June 6, 2012 dont get butt hurt, im just saying there's not going to be a massive performance gain by doing this as opposed to putting it in the fender.. but to each his own, i dont care what you do, its your car if there was no chance of any gain, there wouldnt be sri or cai designs all over the world for any kind of car. there is always room for improvement over the stock set up imo. im not getting butthurt, you just come off as a dickhead sometimes. Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 6, 2012 I Donated Share Posted June 6, 2012 you just come off as a dickhead sometimes. I do too! -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
twisty Posted June 6, 2012 Share Posted June 6, 2012 so do i sometimes, no biggie. was just pointing out hehe Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 6, 2012 I Donated Share Posted June 6, 2012 dont get butt hurt, im just saying there's not going to be a massive performance gain by doing this as opposed to putting it in the fender.. but to each his own, i dont care what you do, its your car you're a dickhead sometimes trololol -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted June 7, 2012 Share Posted June 7, 2012 Time for my 2 cents! I don't have the time to go through 20 pages but I've seen most of it. Imagine your hood being open and leaving around a 1 to 2 inch gap in the front. Now fill that space with a long flat funnel like intake cowl that heads to your MAF. You'd have the challenge of redesigning your hood latch and making this intake out of something so it won't melt on your rad. It's too early now but I'll sit down and do some math later on. I just like this idea because my OCD kicked in and I wouldn't want these beautiful cars to be asymmetrical. I also took the idea from the Bussard Ramjet which is the best vehicle concept for near light speed travel. Geek powers deactivate! Link to comment Share on other sites More sharing options...
twisty Posted June 7, 2012 Share Posted June 7, 2012 Time for my 2 cents! I don't have the time to go through 20 pages but I've seen most of it. Imagine your hood being open and leaving around a 1 to 2 inch gap in the front. Now fill that space with a long flat funnel like intake cowl that heads to your MAF. You'd have the challenge of redesigning your hood latch and making this intake out of something so it won't melt on your rad. yeah, that has crossed my mind as well. i dont mind the asymmetrical idea at all, i thrive on chaos. i also like to make changes to my car based on looks sometimes, but not at the cost of performance. even if it were a wash on performance upgrade, id likely do it if i thought it looked good to me. Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted June 7, 2012 Share Posted June 7, 2012 How much extra power would we get if the alternator weren't being strained? Hypothetically you could install a braking system that goes along with the conventional brakes that generates electricity while stopping the car. If you could wire it correctly couldn't you recharge the battery and relieve some strain from the alternator? Also I promise I know how grammar works. The comma on my keyboard doesn't work Link to comment Share on other sites More sharing options...
I Donated broknindarkagain Posted June 7, 2012 I Donated Share Posted June 7, 2012 How much extra power would we get if the alternator weren't being strained? Hypothetically you could install a braking system that goes along with the conventional brakes that generates electricity while stopping the car. If you could wire it correctly couldn't you recharge the battery and relieve some strain from the alternator? Also I promise I know how grammar works. The comma on my keyboard doesn't work They do this on newer hybrid cars...but it just simply does not provide enough electricity to recharge the batteries. Not to mention....what about long highway drives -broknindarkagain My Current Project - Click Here COME AND TAKE IT "The only thing necessary for the triumph of evil is for good men to do nothing." Link to comment Share on other sites More sharing options...
SomethingWittyAsAUsername Posted June 7, 2012 Share Posted June 7, 2012 I'm a physics student so I see everything in terms of energy and I see it wasted everywhere with everything. The more efficient something could be made the faster it technically could be. Everybody wins! Link to comment Share on other sites More sharing options...
TexasLegacy2.5GT Posted June 7, 2012 Share Posted June 7, 2012 dont get butt hurt, im just saying there's not going to be a massive performance gain by doing this as opposed to putting it in the fender.. but to each his own, i dont care what you do, its your car ^^^Anyone that uses "butt hurt" to describe a feeling is just a queer! Sorry, it's just too too much. Grow up. Link to comment Share on other sites More sharing options...
joelwatts Posted June 7, 2012 Share Posted June 7, 2012 regenerative braking is a supplement to conventional charging. on hybrid and ev's they will use any energy spent to regenerate a charge of electricity. in the brakes case, heat. so by that theory, any source of heat could be used to recharge the battery. body heat (although minor in the electrical sense of the word) is an enormous source of energy. a ton of the energy expended by the body is done through heat. if you were to wear a heat inductive material suit and have it wired through a bridge w/ diodes, you could use your selve to partially relieve the strain on the alternator. however, alternators produce far more electricity than is generally needed. that is why they have voltage regulators, to dial that back. voltage is only the amount of force the electricity has. current output is what strains the alternator and charges the battery. since alternators are in series ckts, the amount of voltage can be regulated w/ the current output varying. if you were to wire your self in series, the amount of current would be so low that the energy it took to convert your body heat into electricity would supersede the amount being produced. but if you found a more energy efficient way to convert heat to current then you'ld be in business. I'm a native of South Carolina. I am a dying breed. Link to comment Share on other sites More sharing options...
