HansGT Posted June 12, 2006 Share Posted June 12, 2006 Ok guys...sorry for the questions if they have already been answered in the prior 50 pages I've noticed my fan running more recently and seems to be louder. Now I don't know if it's just because were entering warmer weather and I'm not used to it or what. Anyway, AP stg 1 since october, no issues. Turn the car on...fine, no fan. Once car gets a bit warm...a few minutes fan come on (normal) but it seems to run and run and run. I didn't notice it running like this before. I did notice that my coolent was low, but I filled it the other week. What gives? Fan relay? Doubt it's ECU related now...anyone? Thermostat? Should I be driving? Link to comment Share on other sites More sharing options...
HansGT Posted June 12, 2006 Share Posted June 12, 2006 I read some more. wow, a lot of people have this issue....why are so many so lucky? seems everyone that has it go away has to do a new ECU (22611AJ17D)? Is this an '06 model ECU or '05? has anyone had success with just the relays? Link to comment Share on other sites More sharing options...
OCDetails Posted June 12, 2006 Share Posted June 12, 2006 this is the post with my invoice scanned. Take that to your dealership and tell them to do the same thing. They can call my dealership if they have an issue. Nate Wade has apparantly done this for more than one LGT. They seemed pretty familiar with the problem. _________________________________________ “Cleanliness becomes more important as godliness becomes more unlikely.” O C D E T A I L S . C O M OCDETAILS BLOG Link to comment Share on other sites More sharing options...
HansGT Posted June 12, 2006 Share Posted June 12, 2006 Thanks OCdetails. wonder why it happens now at 17K??? Link to comment Share on other sites More sharing options...
HansGT Posted June 12, 2006 Share Posted June 12, 2006 anyone know if the version "D" ECU (or ECM whatever its called) works with the AP v1.10 maps? Link to comment Share on other sites More sharing options...
scatman Posted June 13, 2006 Share Posted June 13, 2006 I know it works for the v1.15...or whatever the latest map is. However I must add that after the fan fix my AP "did not recognize" the new "D" ECU. I had to send it to COBB to have the AP re-set, for lack of a better word. I got the impression from COBB that they were not aware of the fan problem on these cars and that I simply messed up the divorcing process some how. Now I could have, mind you, but I followed the process to the letter. Regardless, AP and new ECU are happy together. Link to comment Share on other sites More sharing options...
jdanhires Posted June 13, 2006 Share Posted June 13, 2006 Just got the LGT back from the dealership. They replaced the ECU with a 'D' revision, and the cooling fan issue has gone bye bye, at least for now. Just sent my AP back to Cobb to have the firmware upgraded. I spoke with Justin, and they seem to be aware of the problem. John Link to comment Share on other sites More sharing options...
HansGT Posted June 13, 2006 Share Posted June 13, 2006 Ok,Tested my car yesterday. Maybe I don't have the problem or its early stages? Take a look..... Before leaving work I let the car idle for 5 minutes....no fan (75 degrees outside). Also, turned AC on and off three times. Drove out to the stop light (7min)....no fan. 16mins.....stop light after being in beltway traffic 20-65mph....fan on....temp normal halfway mark. Seems normal to me that the fan would come on. 10min. Cool down while in Walmart. Start up...no fan...temp at halfway mark. 3min....stop light...fan on. 6min....home....park....fan on. Hmmmm, I may not have the problem I thought? What does everyone think? It just seems louder or something....maybe I'm nutts or the car is trying to make me nutts. Link to comment Share on other sites More sharing options...
HansGT Posted June 13, 2006 Share Posted June 13, 2006 Another test... 65 degrees....1 min idle...no fan. 15min to work...speeds 10-65mph. Pull into work...NO FAN! WTF?! Link to comment Share on other sites More sharing options...
Throttlejockey Posted June 15, 2006 Author Share Posted June 15, 2006 If you had the problem it would come on and stay on from the time you start the car until you turn it off. Link to comment Share on other sites More sharing options...
HansGT Posted June 16, 2006 Share Posted June 16, 2006 yep, i don't have the problem. seems to be ok. Link to comment Share on other sites More sharing options...
outahere Posted July 13, 2006 Share Posted July 13, 2006 Have noticed that my fan is becoming hyperactive, turning on well before the engine has fully warmed up, and taking forever to shut down. Surprising that Subaru still does not have a definite, permanent fix for this defect. Link to comment Share on other sites More sharing options...
malimx6 Posted July 17, 2006 Share Posted July 17, 2006 well, I'm concerned right now. When I start my car, fan is off (normal). As soon as it turns on, it stays on untill I shut the car off. Leave a car for like 1/2 -1 hr and start the car, same story. No fan, then as soon as it turns on it stays on until I shut the car off. I think I have the same problem, just reacts differently. Maybe in couple of weeks it'll start doing it like the rest of you guys. And yes, it gets really loud + I don't use A/C that much, only on highway. Link to comment Share on other sites More sharing options...
legandrex Posted July 19, 2006 Share Posted July 19, 2006 I had problem and got a new ECU installed. Now it acts weird when A/C is on. Loud fan noise happens right away when I turn on A/C and goes away in a few seconds. Seems like it cycles on and off every several minutes. It's hard to tell what it does while driving because I can't feel or hear it, but it never acted like this with original ECU. At least it doesn't continually stay on. Anybody else experience this. Link to comment Share on other sites More sharing options...
Leonardo Posted July 19, 2006 Share Posted July 19, 2006 Another way to know you have the problem is if you do a Datalog, you'll notice on the bottom half (switches and sensors) the two fans. You'll see the AC one go on and of ( 0 - 1 ) and the other (main) will be on full blast but show off ( 0 ) on the display. So, it's on and the ECU don't show it. Link to comment Share on other sites More sharing options...
mblazder Posted July 19, 2006 Share Posted July 19, 2006 They replaced my ecu and fan relay and now the car is running great. I discovered that none of my other keys work which i verified on this forum and am surprised the dealership didn't inform me of. I already switched back to my TDC protune on the AP, if i take it to the dealership can they still make my other keys work or do i need to flash it back to stock? Link to comment Share on other sites More sharing options...
Leonardo Posted July 19, 2006 Share Posted July 19, 2006 they can program the key's in. If anything, use the Married Stock realtime map so they feel the car as stock if they move it in the lot. Link to comment Share on other sites More sharing options...
mkalbarc Posted July 20, 2006 Share Posted July 20, 2006 Yup, they only reprogrammed one of my keys as well. I have not reloaded the AP yet because I'm taking the car back Monday to get the other keys taken care of as well as some motor mounts replaced. The car has been running like a champ though and no more fan issue since the replaced ecm and relays. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted July 21, 2006 Share Posted July 21, 2006 Link to comment Share on other sites More sharing options...
bgsntth Posted July 24, 2006 Share Posted July 24, 2006 Thanks guys! Took my car in this morning for the re-diagnosis, and thanks to OCD's work-order, they knew where to look for the fix. So, they ordered the relays and Series D by 9:30am. Best part is Marin now has a loaner program. So instead of having to deal with the "kids" at Enterprise, I have an '06 OB for the next couple of days. Link to comment Share on other sites More sharing options...
SuperhawkLGT Posted July 24, 2006 Share Posted July 24, 2006 Dropped mine off and got this. They wouldn't listen and have do their own diagnosis. Link to comment Share on other sites More sharing options...
scoobyGTlover Posted July 26, 2006 Share Posted July 26, 2006 Took my 05LGT in today to fix the stuck on cooling fan and a sill plate that came loose.When I started the car to leave I noticed the mechanic had left the a/c on and sure enough the cooling fan came on even though the temp gauge showed that the car was still cold.Back I went inside to say the problem was not fixed.The mechanic who worked on my car was surprised that it was not fixed and after talking to I think the service manager the mechanic was informed that Subaru Canada had sent out a email stating to also change the ecu along with the relay.Luckily they had another ecu instock to replace mine which was ordered for another customer who was not going to be in for a few days and they could get another one by that time.So all is good so far .What I learned is the relay screws up the ecu so only replacing the relay is not going to work as the ecu is screw from the first relay and has to be replaced. Link to comment Share on other sites More sharing options...
TSiWRX Posted August 3, 2006 Share Posted August 3, 2006 UPDATE: http://legacygt.com/forums/warranty-issues-problems/40207-cooling-fan-relay-tsb.html#post702068 <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
LegGTLT Posted August 3, 2006 Share Posted August 3, 2006 Scccccchhhhhwwwweeeeettt! Please PM joeleodee For All Site Questions. He is the acting Admin and can resolve anything related to LegacyGT.com Link to comment Share on other sites More sharing options...
Leonardo Posted August 5, 2006 Share Posted August 5, 2006 Fiiiiiiiiiiiiinaly! Link to comment Share on other sites More sharing options...
