Official jdm conversion/aftermarket body thread
  • Replies 2.6k
  • Created
  • Last Reply
Top Posters In This Topic
The bracket I was referring to was the latter one you stated, the one that actually went in the bumper near the fender. Am I correct with this list?
Newer list (Most complete retrofit):
Sedan 05-07 (Rev A-C)
JDM Bumper
Bumper Beam (or cut USDM beam)
Bumper Brackets
Shock Absorber
Fender Liners (or cut original liners)
Fog Lights (JDM brackets, DIY brackets, or entire assemblies cut out of USDM bumper.)
Sedan 08-09 (Rev D-F)
JDM Headlights (Optional: Headlight leveling switch and plugs. Plugs available at Toyota or Lexus dealer.)(Requires rewiring and soldering skills depending on which lights you want to use and because the JDM headlight wiring connectors are different from USDM.)
Fenders
Bumper
Bumper Brackets
Shock Absorber
Fender Liners
Fog Lights
Also are the USDM wiring connectors able to be soldered onto the JDM wiring? Maybe it's possible to solder the running and turn signal lights together so that they both light up and blink like USDM turn signals? I'm just spit-balling in this regard.
Edited by W.K.S.
No fogs required on the Rev.D, but everything else looks great. Nice work, that'll definitely help out both new and seasoned members of the forum.
In regards to your last question, the best thing to do is to take a battery harness and use the OEM (USDM) plugs as your means to activate the relay. The other (the wires that run to the headlights) terminals can then be modified to include the JDM plugs.
This method requires more work, but the overall result is much cleaner. You could easily permanently modify your stock wiring to work with the JDM lights. But doing this will make life difficult if you ever want or need to go back to a USDM setup.
The other part that requires thinking is the parking light and turn signal. On the JDM light they're different bulbs, but the USDM turning/parking light socket is integrated into one plug. Easiest thing to do here is to use the USDM plug as it is, but solder new wiring to the terminals where the bulb would sit. This requires a steady hand, as there is visually no space to work with. But, your parking light and turn signals would function as they would on the stock car. If you ever want to go back to a USDM setup, all you need to do is source a new turn signal/parking light socket.
Edited by Leke
+1 with HKC-speed , i bought the albero front bumper from him
smile ....
http://i174.photobucket.com/albums/w90/kaho8930/249427_10150205539309226_552309225_7494119_615770_n.jpg
http://i174.photobucket.com/albums/w90/kaho8930/250020_10150205539209226_552309225_7494116_7602142_n.jpg
http://i174.photobucket.com/albums/w90/kaho8930/UR0116_preview-1.jpg
Can he or other vendors still get this bumper?
Here it is...
Most Complete Retrofit List:
JDM Bumper
Bumper Brackets
Shock Absorber
Fenders
Bumper
Bumper Brackets
Shock Absorber
Fender Liners
From Leke on the Rev D-F headlight wiring:
For the Rev D-F lights, the best thing to do is to take a battery harness and use the OEM (USDM) plugs as your means to activate the relay. The other (the wires that run to the headlights) terminals can then be modified to include the JDM plugs.
Someone please add this to the first post!!!
Edited by W.K.S.
Any chance of getting OEM bumpers that are JDM?? Not the fancy after market ones, but the real bumpers that came with these cars in Japan.
Something a 40 year old can drive around with without getting the looks from the teeners.
http://www.sevenphotos.com/dev/spec_b_front.jpg
jdm spec b factory bumper
Just a reminder, I still have this sitting in the storeroom:
New Liberal Albero Front Bumper cover for the 08-09 Legacy wagon/sedan. Comes with mesh inserts and brackets to mount standard foglamps. $400.00 or best offer.
http://www.avoturboworld.com/media/0806_liberal_lgt04.jpg
http://liberal-aero.com/products/parts/legacy_bpbl_def/img/01k.jpg
Does not include the lip spoiler in the picture above.
Designed to look similar to the Spec B bumper in Japan.
Regards,
Paul Hansen
http://www.facebook.com/avoturboworld
