SBT Posted May 9, 2013 Share Posted May 9, 2013 Thanks. 85K, female driven (I think). Package came out to $2.6K and comes with OEM FW, clutch, PP, fork, trans mount, diff cradle, DP bracket. Missing shifter and slave cylinder though . My "to buy' list includes: a. shifter assembly b. slave cylinder c. wagon 4EAT driveshaft (Outback ok?) d. spec B axles e. DCCD controller (probably just get a manual version) Anything else you could think of? Not sure if the starter is the same or not, but I see them included a lot of times with a 6MT conversion "package" - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Waxiboy Posted May 9, 2013 Share Posted May 9, 2013 I read somewhere that the starter is the same. Link to comment Share on other sites More sharing options...
Guest Posted May 9, 2013 Share Posted May 9, 2013 Starter is the same. Link to comment Share on other sites More sharing options...
frank_ster Posted May 9, 2013 Share Posted May 9, 2013 same as 5mt not the same as At 4 eat or 5 eat Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted May 9, 2013 Moderators Share Posted May 9, 2013 I was at MachV the other day and they had an 09 STI 6 speed transmission sitting in the shop with $2700 OBO on it in case anyone here is interested. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Waxiboy Posted May 9, 2013 Share Posted May 9, 2013 I was at MachV the other day and they had an 09 STI 6 speed transmission sitting in the shop with $2700 OBO on it in case anyone here is interested. That is my transmission and diff Link to comment Share on other sites More sharing options...
SBT Posted May 9, 2013 Share Posted May 9, 2013 So are we in agreement to merge all three of these threads into one super-sticky? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 10, 2013 Share Posted May 10, 2013 Yes... EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
SBT Posted May 10, 2013 Share Posted May 10, 2013 Looking for the original contributor's input...but thanks! - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
BoozeRS05 Posted May 10, 2013 Share Posted May 10, 2013 EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted May 10, 2013 Author Share Posted May 10, 2013 So are we in agreement to merge all three of these threads into one super-sticky? Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Waxiboy Posted May 13, 2013 Share Posted May 13, 2013 Can you guys post photos of where you put your DCCD controllers? I have only seen Hammer Down's manual controller. Just trying to get ideas. Thanks. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 13, 2013 Share Posted May 13, 2013 I don't have any pics but swapping transmissions on the 25th so I can take some then. Mine is below the radio but on top of airbag (?) module. May be the same place as hammers Can't remember. Anyway that is a good spot. As it is close to wires going down the hole to the transmission and also close for the g-force sensor that has to be in the center of car under the console. Link to comment Share on other sites More sharing options...
Waxiboy Posted May 13, 2013 Share Posted May 13, 2013 Sorry, I meant the switches. I don't think 2 switches will fit by the e-brake handle. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 13, 2013 Share Posted May 13, 2013 (edited) Yes they will!!!!! Ill post a pic here in a bit You just have to take the console out and look at the underside of this area. There are some things on the underside but just enough space to put them there. I measured a dozen times and then cut the holes with a dremel after covering the area with duct tape. Pulled tape off and they snapped right into place Edited May 15, 2013 by Scooby2.5 Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 15, 2013 Share Posted May 15, 2013 Update^ Link to comment Share on other sites More sharing options...
Waxiboy Posted May 15, 2013 Share Posted May 15, 2013 Thx man! With regards to driveshaft, Legacy or Outback does not matter as long as it is 4EAT wagon right? Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 15, 2013 Share Posted May 15, 2013 I have an Outback XT and used a 4EAT driveshaft out of a legacy 2.5i Link to comment Share on other sites More sharing options...
Waxiboy Posted May 15, 2013 Share Posted May 15, 2013 Are the slave cylinders the same for all years? Link to comment Share on other sites More sharing options...
ama0787 Posted May 15, 2013 Share Posted May 15, 2013 Any chance you have the dimensions for the holes that need cut? Thanks, Anthony Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 16, 2013 Share Posted May 16, 2013 (edited) I measured the back side of the STI switches, and maybe even traced around them with a pencil and then cut. If you do it right they snap right in the holes. Just be careful where you cut the holes. Make sure you look at the back of the console first as there is stuff back there. They barely fit and you have to be precise. Good luck! Edited May 16, 2013 by Scooby2.5 Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 16, 2013 Share Posted May 16, 2013 Are the slave cylinders the same for all years? See NSFW 6 speed thread, OP http://legacygt.com/forums/showthread.php/nsfws-6mt-swap-thread-143520.html Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 16, 2013 Share Posted May 16, 2013 Anyone that has done the 6 speed swap and maybe a clutchmasters clutch have to adjust the pedal under the dash after the swap? Link to comment Share on other sites More sharing options...
ama0787 Posted May 16, 2013 Share Posted May 16, 2013 Thanks for the advice Anthony Link to comment Share on other sites More sharing options...
Scooby2.5 Posted May 16, 2013 Share Posted May 16, 2013 No Problem Link to comment Share on other sites More sharing options...
