Wangspeed Posted August 6, 2009 Share Posted August 6, 2009 FYI-The chattering that I'm referring to is not normal clutch chatter. It's a rattling noise. The car takes off totally smooth with hardly any gas. My wife can drive it without stalling, or slipping too much. Warren Link to comment Share on other sites More sharing options...
JoeFromPA Posted August 6, 2009 Share Posted August 6, 2009 So my question is: Is it clutch chatter? Or something else. I don't know about you, but I can usually feel clutch chatter (not just hear it) Link to comment Share on other sites More sharing options...
TSiWRX Posted August 6, 2009 Share Posted August 6, 2009 ^ Good question - I agree, I feel chatter much more than I hear it. Wangspeed - that's definitely weird, I have not yet heard anything during decel, nor any strange, non-normal-chatter noises. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
05lgt5spd Posted August 7, 2009 Share Posted August 7, 2009 can you guys running the 06 wrx flywheels veryify this is what your 06 wrx fly's looked like, i just had it rotated in prep for my act clutch install, and i want to make sure the guy sold me the correct one... sounds like there is no way around the chatter, and the oem clutch is worthless in my application. Im installing a tsk-3, hopefully it helps. thanks! Link to comment Share on other sites More sharing options...
Ridgeracer Posted August 8, 2009 Share Posted August 8, 2009 lots of noise from my spec stg2 and lwfw on decel also probably gonna go back to the stock fw if my trans ever needs to come out for some reason Is the stock dual mass FW compatible with a Spec stg2 clutch/pressure plate?? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
05lgt5spd Posted August 8, 2009 Share Posted August 8, 2009 dont think so thats why everyone buys the 06 flywheel Link to comment Share on other sites More sharing options...
Beanboy Posted August 8, 2009 Share Posted August 8, 2009 Gear rattle I'd bet. -B http://www.standardshift.com Link to comment Share on other sites More sharing options...
StoplightAssassin Posted August 8, 2009 Share Posted August 8, 2009 Is the stock dual mass FW compatible with a Spec stg2 clutch/pressure plate?? from what I remember from researching when I was in the market for a new setup... it is compatible with the stock LGT fw but it is not compatible with the WRX fw Link to comment Share on other sites More sharing options...
fonts Posted August 8, 2009 Share Posted August 8, 2009 ^ Good question - I agree, I feel chatter much more than I hear it. This. Link to comment Share on other sites More sharing options...
Vsick Posted September 10, 2009 Share Posted September 10, 2009 I just installed this yesterday also. I am also experiencing noise. Now I have two noises at the 2k-3k range. Midpipe area heat shield rattle and this new clutch related rattle? Anyways, we'll see how it sounds after 500 miles. I do like the feel of the new clutch though. Much better than the stock one. Engagement feels much more linear?, where as the original felt as if there were two engagement points. The clutch pedal is pretty heavy though, we'll see how I like it when I drive home in traffic tonight. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 10, 2009 Share Posted September 10, 2009 Now I have two noises at the 2k-3k range. Midpipe area heat shield rattle and this new clutch related rattle? . It is probably all just clutch noise, unless you had that midpipe rattle before. I took off the heatshield above my midpipe just to see if it was the problem...it was not. Link to comment Share on other sites More sharing options...
rnstein69 Posted September 10, 2009 Share Posted September 10, 2009 I also have an ACT HD clutch and 06 wrx flywheel. I have a rattle or chatter when I am in gear and coasting (off the gas). No rattle or chatter when I am on the gas. Everything feels fine though. The clutch has maybe 3k miles on it and I was sure to break it in properly. Anybody else have the same issue? Link to comment Share on other sites More sharing options...
Guest Posted September 10, 2009 Share Posted September 10, 2009 Many. Link to comment Share on other sites More sharing options...
AGR-LGT Posted September 10, 2009 Author Share Posted September 10, 2009 everyone does Link to comment Share on other sites More sharing options...
TSiWRX Posted September 10, 2009 Share Posted September 10, 2009 ^ If I'm getting the sound, it's definitely being camouflaged by my cat-back. I'm honestly not hearing anything abnormal, decel. or otherwise. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
schwinn Posted September 11, 2009 Share Posted September 11, 2009 Ditto - getting the sound too. I don't feel it, but you can hear it, particularly on decel or light-throttle. Not too loud, so I don't care... Link to comment Share on other sites More sharing options...
socalsleeper Posted September 14, 2009 Share Posted September 14, 2009 I have the ACT with the light fly wheel and I can def hear/ feel in cabin. Def on decel and under 2k RPM engine lugs down a it. But I also think I got a bad throw out bearing too. So I am going to throw a new one in soon. Plan to throw on some new rings in. So car will be on jack stand for a while. Link to comment Share on other sites More sharing options...
GTTuner Posted September 17, 2009 Share Posted September 17, 2009 Are there any HD clutches that will bolt up to the stock dual mass flywheel? Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 17, 2009 Share Posted September 17, 2009 Specs do. I have a Stg2 Spec...been holding fine for 10k miles so far...with 1 launch under my belt. Link to comment Share on other sites More sharing options...
GTTuner Posted September 17, 2009 Share Posted September 17, 2009 So no noise with the stage 2 Spec and dual mass? Link to comment Share on other sites More sharing options...
TravisS Posted September 17, 2009 Share Posted September 17, 2009 Shouldn't be, the chatter is a result of the lighter flywheel. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted September 18, 2009 Share Posted September 18, 2009 So no noise with the stage 2 Spec and dual mass? I'm running the Spec LWFW, so I don't know. I'm willing to try though if anyone wants to send me some donations. It was designed with complete OEM fitment, so I'm guessing it should be quiet. Link to comment Share on other sites More sharing options...
JoeFromPA Posted September 18, 2009 Share Posted September 18, 2009 A flywheel acts as a balancer as well as a mating surface between engine/trans. OEM fitment just means it'll be a perfect fit. It doesn't mean you can shave 1/2 the weight off the balancer and expect the system to remain in OEM-like harmony. Link to comment Share on other sites More sharing options...
05lgt5spd Posted September 18, 2009 Share Posted September 18, 2009 shoulda have used the tsk3 kit, 600 miles with the act, no chatter. Link to comment Share on other sites More sharing options...
JoeFromPA Posted September 18, 2009 Share Posted September 18, 2009 Just to confirm, you are using the WRX flywheel and not a LTW flywheel, right? Link to comment Share on other sites More sharing options...
