Scooby2.5 Posted December 27, 2012 Share Posted December 27, 2012 Hardly notice yea right LOL Link to comment Share on other sites More sharing options...
StoplightAssassin Posted December 27, 2012 Share Posted December 27, 2012 Hardly notice yea right LOL I'm serious. Whether I've grown so accustomed to it or I drive around it, I don't notice it. Link to comment Share on other sites More sharing options...
Justin case Posted December 27, 2012 Share Posted December 27, 2012 I'm starting to drive around it as much as I can. After 100 miles the judder is getting better at least. My other solution has been to turn up the radio a bit haha. Link to comment Share on other sites More sharing options...
TravisS Posted December 27, 2012 Share Posted December 27, 2012 I'm serious. Whether I've grown so accustomed to it or I drive around it, I don't notice it. Likewise. I've had the LWFW + ACT clutch for 90k miles now, the rattle is still there but I wouldn't even think about it if it wasn't for this thread I'm far more concerned about what sounds like the throwout/thrust bearing going bad. Link to comment Share on other sites More sharing options...
Scooby2.5 Posted December 27, 2012 Share Posted December 27, 2012 You guys are all going deaf from the noise LOL Link to comment Share on other sites More sharing options...
GT_Red Posted December 28, 2012 Share Posted December 28, 2012 I had the dealer look at mine, and they put it on a lift, and diagnosed it as the center differential inside the transmission. They did the stethoscope and had someone put it in gear while up in the air so they could pinpoint the location of the noise. Its not the flywheel as I suspected, and was bashing my choice for a long time thinking, in error, it was the flywheel. What I am wondering is, if we are all ruining our center differentials by swapping in a LWFW which may not be appropriate for turning the center diff, and could be causing premature wear and tear. As the dual mass is heavier and can spin the gears easier (i think), so I am wondering if a LWFW is a big mistake for all of us and ruining our transmissions unknowingly. Link to comment Share on other sites More sharing options...
TravisS Posted December 28, 2012 Share Posted December 28, 2012 That seems slightly unlikely if only because the noise happened immediately after install. Not to say that it couldn't potentially be bad for it in the long term, but it's certainly not the cause from the start. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted December 28, 2012 Share Posted December 28, 2012 If that's the case, I've been ruining my transmission for the last 50,000 miles and it's holding up just fine with plenty of autox abuse. Also to add, noise from a LWFW is not Subaru specific. You can check the forums for other cars and they all report noise after the installation of a LWFW. Link to comment Share on other sites More sharing options...
GT_Red Posted December 28, 2012 Share Posted December 28, 2012 My case it could be case specific. When I put in the wrx flywheel there was a slight vibration and noise, but since I drove cross country its very loud, and noticable. Gotten worse over time. Link to comment Share on other sites More sharing options...
caramall2 Posted December 31, 2012 Share Posted December 31, 2012 I have the WRX flywheel and the ACT HDSS and haven't really had any noise issues (I am having to replace it though at 25k due to slipping :-0 ) I've liked the clutch overalll though. Link to comment Share on other sites More sharing options...
SSpeed Posted November 13, 2014 Share Posted November 13, 2014 Sorry to thread bump, although I was active on this thread back then, so.... I'm finally happy to get rid of the decel noise and the engaged clutch rattle noise that this ACT had. I'm not happy with how it failed. http://www.motate.org/clutch/clutch1.jpg Link to comment Share on other sites More sharing options...
Impulse Posted November 14, 2014 Share Posted November 14, 2014 -_- bummer man.. how many miles were on it? And just so i know, any major symptoms before failure? Link to comment Share on other sites More sharing options...
SSpeed Posted November 14, 2014 Share Posted November 14, 2014 About 30k miles... The only symptoms were I would get a slight grind going in to reverse, probably from the clutch dragging. Then one day it started shifting really hard and a couple hours later, pop pop, no clutch. ACT says they will most likely warranty it even though it's 2 years old, which is cool of them. Link to comment Share on other sites More sharing options...
StoplightAssassin Posted November 16, 2014 Share Posted November 16, 2014 That's very cool of them. Spec would've hung up the phone on you and screened all your future calls. Link to comment Share on other sites More sharing options...
SleeperScoob Posted November 30, 2014 Share Posted November 30, 2014 Going to bump this thread for the hundredth time. I just installed an ACT Streetlite flywheel and Southbend Stg2 clutch, around 300 miles ago. Same issue as all that I have read with the grinding now in decel at low RPMs. Cleared my conscience a bit. I was just curious if anyone has any experience with the Southbend clutches doing this as well? I didn't see many (one guy) post about the Southbend clutch, but everyone seemed to have either ACT or Exedy. Have only had the clutch on for about 200 miles now, I hope chatter and driveability get a bit better, because so far it's rather odd. From what I've read, driveability will become better, which is relieving. Link to comment Share on other sites More sharing options...
SBT Posted November 30, 2014 Share Posted November 30, 2014 In my experience, your conscious awareness of the irritating sound and vibration diminish over time. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
700watts Posted November 30, 2014 Share Posted November 30, 2014 I have the same set up, no noise until later....and I had to install this http://www.fredbeansparts.com/subaru-legacy-gt-tranquil-tsk3-sleeve-kit.html Link to comment Share on other sites More sharing options...
SBT Posted November 30, 2014 Share Posted November 30, 2014 I had that installed when I installed the ACT HDSS CK. Still aggravated by the vibration, and clutch engagement. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
