Brakes: How to buy brake upgrades?
Xenonk
  • Replies 168
  • Created
  • Last Reply
Top Posters In This Topic
My stock wheels fit over my APracing BBK.
But Like you said in a previous post:
"In all honesty the size and clamping force of the OEM calipers are more then enough is you have decent pads.
Better calipers will help out in the feel department due to better rigidity.....And looks.....it makes you feel good"
And I totally agree with what I said earlier. But for me, going to a BBK (I wanted a few things the OEM caliper/rotor combo couldn't do) was done w/ keeping the OEM wheels for winter. The AP BBK does that with room to spare.
What do they offer that is different? Just curious
-caliper rigidity = much better brake feel
-caliper weight = lost 7 pounds of unsprung weight
-better heat dissipation = on street pads I can brake 18 times in a row from 90 mph w/ NO fade at all (all stops back-to-back after a WOT run)
-larger rotors
-two-piece rotors = 3 lbs less unsprung weight (some weigh even less), better thermal expansion, less heat transfered to bearings
-better selection of pads and rotors depending on needs
see my thread about them:
http://www.legacygt.com/forums/showthread.php?t=61183
Edited by LittleBlueGT
  • 5 months later...
I'm up for new brake pads, calipers in front (passenger side binding) and rotors.
I have to keep my budget in mind these days. currently running Hawk HPS on stock rotors. my commute is 30miles one way, flat out. 8 traffic lights, off rush hour driving. Never in stop and go.
debating staying stock when i replace; and if so would stainless steel lines and fluid be a sufficient upgrade or not worth it?
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
SS lines wont make a HUGE difference.
If you need to replace the caliper anyways you have a couple options. One is to rebuild (under $20 in parts and maybe 1 hour labor).
Or we have our Wilwood Performance Brake Kit. New calipers, rotors, pads and lines. This would totally change your brake feel.
A cheaper option might be to try a more aggressive street pad like a Carbotech Bobcat.
Free Sonax Cleaner Deal
http://www.brakeswap.com
Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol...
Great service. No bumping required :icon_tong!
  • 2 months later...
This is a really amazing and informative thread. Xenonk, I appreciate your holistic approach to the topic of stopping. Like a lot of other people I get carried away sometimes when looking at aftermarket parts and forget what the real goal is. In my case, it's just stopping my car during daily driving, sometimes more spirited than others.
So I bought my LGT used with 35000 miles on it. I'm at 65k now and the steering wheel shakes when I press the brakes hard. This happened before, stopped and now it's back. I'm thinking it's a warped rotor but I need to inspect to be sure. So, question; if I were to replace the front rotors and/or pads only, is that problematic? Do the rears need to be done at the same time?
Possibly uneven pad deposits from the OEM pads. Switch to a different pad compound and see if it goes away.
What I would do is get a good set of pads that are non-OEM (Akebono, Hawk HPS, etc...), then before putting them on, have your front rotors turned. If they have a lot of metal left, this should result in a nice, flat, rotor. Then follow the instructions with the pads for the "nbedding process and you'll be all set.
I had warping issues in Europe, where 125 mph to 60 mph slow downs will heat op the rotors a bit. I had a Volvo V70, and I warped the OEM brembo rotors after only 10,000 miles. Once I replaced them with Power Stop rotors, and matching pads, all was well. Just my experience.
I ended up going into a brake shop and having them check out the pads and rotors. I feel confident in changing them but not in evaluating them... so they said the rotors and pads are shot. I guess this makes sense because I've had the rotors resurfaced before. I don't know how the previous owner drove the car but considering what I've had to have done to it (new strut, bent rim, etc) I don't think he was a mellow driver. Anyhow, I think I'm going to go ahead and have the rotors replaced with something of equal to or greater quality to the OEM rotors and then put some upgraded pads on, like the Hawk HPS pads. The guy at the brake shop was pretty adamant that the OEM brake setup on the LGT is more than sufficient which seems to jive with what I've seen in this thread.
For normal to spirited driving, the OEM pads should be just fine. As long as you are putting new pads/rotors, you may as well have them flush your brake fluid and give you new. That will help pedal feel a lot.
aside from the stock pads, the rotors are plenty good as they are.. the way I see it, the only way you would want better rotors is if you do a lot of braking that overheats the pads, at that point, you might as well get better pads if you use the brakes that much.
Keefe
  • 1 month later...
Hey Keefe, lots of great info here. However, I do a lot of spirited driving going to work. I am opposite to traffic both ways (to and fro work). I also drive in Washington DC a lot where breaks are heavily involved. What category would I fall into, based on your chart?
BTW, I saw your car on Georgia Avenue last week, heading towards Olney! Is that where you reside? I also saw your car parked at the Advanced Auto Parts off of 355. I took several pictures of your car, if that is OK with you! :)
Also, one more question, how about suspension? How would that affect things in terms of braking distance? Would it be safe to say that the stiffer your car/suspension is, the more you travel in braking distance due to lesser tire grip? I remember having this conversation a long time ago while I was active at Summit Point Raceway. But I forgot what the verdict was and have lost a lot of my knowledge due to a rusty brain! :lol: Any insight?
Edited by HarryN
Keefe, I am taking your recommendation and getting some Toyo R1R's in 225/40/18 to put on my 18" spec.b stockers. Before I get back out to the track I also need to get my brake situation taken care of.
On my previous hpde event, after about the second lap of each session, the car would start to shake violently when braking. There was no pulsating in the pedal, it was mostly felt in the steering wheel, but it shook the car enough for the instructor to be concerned. We checked for flat spots in the tires, checked air pressure, checked the lug nut torque, and everything looked fine. When I came back from lunch, he had someone check over my car and said that it is cause by a soft spot in the rotor and it not heating up uniformly. I took the car to the dealer to have the rotor replaced but they only resurfaced it (there was some very slight warping) and said SOA will not allow them to replace the rotor. They told me the rotors are not designed to withhold track conditions and even if they replaced it, the problem would return (I know this is total bs).
Since the problem is not fixed, I am looking at what I should do. I know I need lines, pads and fluid at the least, and I probably want some slotted front rotors, but they need to clear the stockers. I am also considering the wilwood kit with 4-pot front calipers, slotted front and rear rotors, front and rear lines and hp+ pads all around, but I would rather not spend that much if it isn't necessary.
My current pads have about 75% life remaining after 8500 miles and 1 track day, and the tires have enough life left in them for probably another 2 track days. With my bad rotor I was letting off the throttle around 120 and coasting down the rest of the straight getting on the brakes early and braking early and light on all the other turns because it was tough fighting the vibrations. This really took a lot of the fun out of things. Any recommendations? I will need to order brakes and tires very shortly, my next track day is 3 weeks from today. I've also gone stage 2 since my last day out which means I will have even more speed to shrub off.
make sure you bed the pads properly. My stock rotors lasted over 40,000 miles with a number of autox and probably 8 lapping days total. I upgraded to some DBA 4000 rotors and they have held up well. I could do without the slots, but no big deal having them. I am still on stock calipers and they are fine unless you really want to improve the brake feel with wilwoods or a BBK. I've been stage 2 for the last 15k miles or so and did an event last fall on Carbotech XP8 with the DBA's and they were great. I would recommend XP8 or Hawk HP+ for track use at the least
Stock pads?
:spin:
since we are doing fairly the same commute, I dont see myself using the brakes all that much even in stop and go traffic (since I'm not hard on the accelerator to speed up fast just to hit the brakes in another 5 seconds). I'm usually light on the brakes on stop and go traffic.
I run around town on all sorts of pads, from ceramics to track pads between weekends at the track (too lazy to change them out again for the following weekend if I know I'll be out on track soon). Overall, any street performance pad will do, but if you see yourself driving like i do and do hard late threshold braking going into the decel lanes of the off/on-ramps, then I suggest using a little bit higher bite and a bit higher temperature range (probably something that is along the lines of Carbotech Bobcats or higher). Most of the time in the DC area, we dont drive around much in the hills either. The only thing with going with a higher temperature range is that you may need to change out the pads to something colder when winter comes around (unless you are comfortable with warming up your brakes with a few good drags before you head out as you pull out of your driveway on the cold winter days).
In terms of suspension, it depends on your set up and how much weigh transfer and suspension travel you are dealing with. On the grand scheme of things, head dive is probably the least of your concerns if you are doing an emergency brake stop because someone brake-checked you or that you came up on heavy 495 traffic, you have other things to worry about at that point.
It would be safer to say that the stiffer (this is a very gray area actually because there's a difference between the term "stiff" and the term "compliant" or "controlled" shocks depends on the roads than your tires) can lead to a larger emphasis of what your tires can do, but not always the case. Take for example if you had stiff shocks on a smooth surface, your tires will be in contact of the road all the time. This is assuming that your front shocks and springs are stiff enough to prevent head-dive which allows the rear tires of the car to help slow you down. It is correct that 90% of cars built have the front brakes to be the brute of the force (unless you drive a Porsche 911 or some other Rear Engine Rear Drive car). If your car's suspension was going to do an endo or a stoppie like a motorcycle would, then it's obvious that your rear tires will have little or no effect in helping you slow down, overall, you are only using 70~80% of the braking potential of your car. Even in Motorcycle Safety Classes the instructors spend time teaching the students to use front and rear brakes together to get maximum stopping distance. So backing up, if the road is not smooth, then this causes some problems. As I mentioned before, shocks play a big role in how well the car can stop and non-compliant shocks will make braking distances longer because they are spending too much time in the air or off the ground from the previous bounce or bump and not enough time pushing back down onto the ground to keep the tires back on the pavement. Sure, you can have stiff shocks, but you also need for them to be compliant or matched with the road surface. A fast reacting shock will help (think rebound, or the force of which the shocks pushes back down to extend the shock back to touch the ground) keep the tire down on the ground. What makes a suspension "stiff" is actually how the bound or compression portion of the shock reacts.. and there are two functions of the compression: fast speed and slow speed (rate of which the shock compresses). Fast would be considered how quick the suspension reacts to hitting a pot hole or how quick it can absorb a bump like a 2x4 on the road while a slow speed compression would be the rolling action of the car through a turn or how you are slowly adding the pressure on as you crest over a hill or hitting up a banked turn. So if the car's fast speed compression and fast speed rebound are lousy, then it's going to be obvious that whatever contact that you can make with the tire on the road will determine how well you are going to stop based on how much contact time you have with the road and the tire's grip levels. The "stiffness" really comes from the slow speed bound and rebound actions of the shocks. Hope that all makes sense.
Back to the basics, so long as the tires are on the ground and that you are using threshold braking, the tires will do their job to slow you down. If the car is so stiff [and suspension is not compliant] that the tires are leaving off the ground, then it's obvious that you dont need brakes, rather you need air brakes or some kind of parachute to slow you down.
I actually reside not too far from Andrewtech in Gaithersburg area, but I drive everywhere north of DC.
Keefe
Stock rotors are fine.. if anything, you got a "hot spot" (not exactly a soft spot) where you burned and overheated the pads onto the rotor and caused a significant difference in thickness of the rotor. Usually that's a sign of the rotors overheating and that initial slam of the brake pedal eventually wore it to where you got a lot of melted pad material or that you ended up smacking that exact same location of the rotor at every brake entry zone. Either case, that's an indication to work on your braking input as a driver as well. Overall, stock rotors hold up just fine for track days. It's the pads that you need to worry about that you are not glazing them and melting them onto the rotors and causing a hot spot or a pad imprint on them. Spotty pad material will do that to a rotor and that's probably why the shop re-surfaced them.
You could look around for some slotted rotors but that still won't solve your problem if you overheat the rotors again. The slots could prevent the pads from burning onto the rotor, but the slots WILL eat up your pads quicker, it's something for you to consider. I used to track the blanks all the time and they did well, they just got really hot so I had to use higher temp pads and looked at changing up my driving habits and also looked into brake ducts.
The biggest thing you need is to get new fluid, some new stock/oem-sized rotors and higher temp brake pads as there are enough out there to choose from. I AM NOT DOING A PRODUCT PLACEMENT NOR DOING ANY ADVERTISEMENT OF PARTICULAR VENDORS/SPONSORS by saying this: Brakeswap or Racecomp Engineering probably has a better solution of what you may need to run with your R1Rs and your situation since they have slotted, blanks, and other rotors that would fit your budget than what I would recommend (Magnetic1 has a M3 E36 that he races often at the track, so he knows exactly what you need and Racecomp Engineering have a long history in racing and instructing HDPE as well.. we all came from the same background starting as HPDE students like yourself, so you can learn from our experiences). Call them up to see what pads that will work for you. I would lean towards something along the lines of at least getting new front rotors and front pair of track pads something like Carbotech XP12 or higher (since you have stage 2) and Carbotech XP8 or higher [or match them all aroundif you want] and you are also running on R1Rs and you wont have the response from an r-compound tire, so your braking zones will be longer than an r-compound tire which means you will be on the brakes longer which in turns feeds out more heat. Get some new fluid in the lines (as Im pretty sureu if you glazed your pads from the last time, you probably boiled your old brake fluid too). The SS lines are not neccessary, but just a nice thing to have if you want better pedal feel, but it's not going to make you a better in braking exercises.
swap out your stock pads before your track day and swap them back in after your track weekend is over. Stock pads were never meant to do track days.. heck they aren't even good enough for even autocross events. They are only good for the joe shmoe that's trying to get to work at the speed limit with only him driving on the road on a cold weather rainy day while driving grandma home (to keep things quiet).
Keefe
i would go higher since I drive faster :lol::p
just kidding buddy.
Keefe
  • 1 year later...
hi,
after 53000km i'm planning to upgrade my front brake discs to cross-drilled zimmerman sport.but wondered if it's ok to replace the front stock brake disks and leave the rear stock discs?
it's ok, but if you are street driving, you dont need the cross-drilled or even slotted brakes.. you are better off just driving around with full blanks as they dont eat up your pads as quickly.
either case, you should just check your rotor thicknesses regardless, if you need to get rear ones because they are getting too thin, then you should get them replaced anyways.
Keefe
