Brakes: How to buy brake upgrades?
Xenonk
I decided to put this FAQ together to help people decide how about going upgrading brakes as well as helping people fimilar how to buy brakes to fit for their needs. Not everyone need 16" rotors front and rear and still complain about how they can't stop better than stock.
Q: How does one stop the fastest/shortest?
A: It really starts with the tires. Brakes are one thing, but the main concern is about how the tires grip the road to stop.
Q: Tires? What? I thought we were talking about brakes?
A: Tires are the only thing that keeps the car in contact with the road, you are relying on 4 little patches of rubber to keep a 3000+ lbs car on the road. So yes, tires do make a difference. For example, if both cars had super awesome brakes, but one car had rubber soft slick tires while the other car had just bare rims, which one would stop faster? It's obvious that the tire will get into better grip (friction) with the road than the bare rim. It's hard for bare metal to dig into the concrete. If you dont believe me on the matter that tires dont make a difference, ask race car drivers why they have to use racing slicks.
Q: Ok, so tires are upgraded, now what?
A: Hopefully, the tires you chose helps you narrow down what kind of brakes you should look into. I have broken down the three common tires you will find and 3 kinds of brake upgrades you can get along with the car.
Tire A, Daily driving: This is the kind of tire that would be on your car most of the year and winter driving is possible since it could very well be an all-season tire.
Tire B, Spirited driving, Autocrossing for Street Touring: This is the kind of tire that is more dedicated for street use in the summer or possibly an autocross street touring race setup. The tire is fairly soft and the potential for harder braking is possible (also less chance for the ABS to come on).
Tire C, Race and Race-practice driving: This is where your tire is barely DOT-approved and street legal, the tires barely last more than 5,000 to 10,000 miles conservatively for street driving or only 100 miles for race use. These types of tires are sticky.
Brake Upgrade A, conservative driving: This is the setup you are looking for that you expect to keep on your car for a while unless the brake pads run low. The key things to upgrade are better brake fluid, better brake pads. The driving habit is mild and delicate braking, long drags, and low speed stops (think slow daily driving). Look for a brake pad that has a high coeffiecent of friction (for that quick bite) and low operating temperature (so that winter or cold brakes will still work).
Brake Upgrade B, spirited driving: This setup is something that might need some higher performance pads, better rotors to help prevent brake failure or poor performance. Things to look for are stainless steel brake lines, better brake fluid, slotted/cross-drilled rotors, larger or higher operating temperature brake pads.
Brake Upgrade C, hard driving: This setup is to help you get the most out of your brakes without worrying about overheating/overworking your brakes. This setup is usually for racing use only since the brakes (and tires) need to warm up first before they work properly. Things to look for are racing brake fluid, bigger rotors with slots or crossing/drilling, racing brake pads, stainless steel lines, bigger calipers that can handle larger brake pads. All these parts help you keep the brakes work in the higher braking temperature ranges. Overheated brakes are just as bad as having no brakes at all.
Q: Are slotted and cross-drilled rotors needed?
A: Slots are useful to a point when you are looking for a way to prevent glazing of the brake pads. Glazing of the pads happen when you overheat the brake pads (either too hard on the brakes and not big enough of a rotor to dissapate the heat fast enough thus makes the pad material harden and it starts to lose its frictional properties. Cross Drilled really has no real use now as brake technology has advanced.. it does have an appealing look to them, but as for today, you dont need them as they serve next to nil on purpose. Specifically on the Legacy (GT or 2.5i) the brakes are fairly well using just the stock rotors. The weight of the rotors (mass) is pretty heavy.. more mass also helps in heat capacity, so the more mass you have for the rotors, the more repeative braking that you can do. Big Brake Kits do benefit from this very reason, but a few other brake tests has shown that the thickness of the plates and the overall thickness of the rotor proved to be more of a useful design than just the overall diameter of the rotor [Motor Trend did the study about 2 to 3 years ago I believe]. Blank rotors are fine and does the job, especially for a daily driver that doesnt need that heat capacity.
Q: So what kind of brake pads out there?
A: There are a lot of brake pads out there, things to take consider are the three main attributes that usually 2 attributes are offered in a braking pad:
-Dusting/Noise (how much they make your bling rims dirty)
-Temperature (the range of temperature of which the pad works)
-Friction (how well the pad has the initial bite and feel to the rotor)
It's very hard to find a brake pad that can be awesome in all 3 attributes. Street pads will have great low noise/dusting, good friction bite, and typical low temperature range. Performance pads will have good friction, good temperature range, and typical medium dusting. Race Pads have great temperature range, good friction, and lousy dusting (very dirty).
Q: What temperature is right for me?
A: If you are looking for daily driving and expect to drive through a winter season, look for a brake pad that can operate in low or freezing temperatures. If you are looking for autocross and very light track days, look for above freezing to 800 F temperature ranges. Very rare that a daily driven or street driven car hit temperatures of 1000 F unless you are that crazy to hold the brakes down at near full force while driving at 40 mph for 15 mins. Racing brake pads start near the 150F to 1500F+ range (so somehow the driver needs to warm up the brakes before actually using them).
Q: How do I pick a good brake fluid?
A: The thing is to look for the HIGHEST WET BOILING POINT (as brake fluids do soak up moisture in the air and causing the fluid to fail and feel mushy). Change your brake fluid at least once a year or every 15,000 miles for the best pedal feel. ATE Super Blue fluid is probably the best "bang for the buck" at $15/bottle for a full flush. Always use a fresh bottle, dont use a bottle that has been open for more than a month as it has probably soaked up dirt and other moisture in the air that would make the fluid ineffective.
Q: What about stainless steel lines?
A: Usually designed for better pedal feel for less pedal brake travel and less flex in the lines. It's an upgrade that is really up to the owner as stock lines offer enough PSI of fluid for the caliper to clamp with enough force. Unless you are upgrading your master cylinder and larger calipers, upgraded stainless steel brake lines with higher PSI rating is not neccessary
Q: What about big brake kits?
A: Big brake kits are used to make use of the tires' grip potential and dissapate heat faster. It's not neccessary for a street car to run with larger brakes unless you run the Autobahn or something and have the tires run them. Also, check the brake pads that the brake kits come with. There's no sense in getting bigger brakes (more weight) if the brake pads are lousy "performance" pads that can overheat and glaze.
If there are any other questions, I'll will answer them on a case-by-case basis from here on out.
Keefe
  • Replies 168
  • Created
  • Last Reply
Top Posters In This Topic
Nice writeup. Just noticed this statement...
That's probably true of the LGT, and maybe that's the point. But my Hyundai Elantra, for example, came with 10.1" rotors which I upgraded to the 11" Tiburon OEM brakes after I upgraded the wheels. The larger rotors, calipers, and pads do provide a larger heat capacity but more importantly the leverage is improved. The result is a dramatic improvement in stopping power at the expense of some added unsprung & rotational mass and a lighter wallet. So it definitely depends on the car whether it justifies an upgrade to a big brake kit.
Carbon Ceramics = expensive, and they have a very short lifespan.. they are also lighter in weight and can deal with a high operating heat range, but once they cool down from that high, that's the end of their life cycle. Eventhough Porsche offers them on their Production cars, it's a very costly option to have (think in the range of $20k to $35k for a set, front and rear and matching brake pads and calipers). On the street, they will work like any brakes, nothing special.. the real potential is when they are driven hard and that there's no fading that occurs during the operation of high heat.
Keefe
Keefe
I disagree on several points.
Cross drilled rotors WILL crack if driven on the track. Bad idea. I've never seen a set of cross drilled rotors not crack, but then most track cars don't used cross drilled rotor because they crack.
Stainless lines are probably one of the best bang for buck upgrades for a track day. Above 8/10th brakeing effort, your pedal will be linear. With rubber lines, your pedal will require esponentially more force to stop at the same rate as with stainless lines. They do not require uprating your master cylinder or calipers to have an effect.
For fluid, I alternate between ATE Super blue and ATE gold. The color change makes it easy to tell when you've changed out fluid.
SS lines will also have much better modulation and pedal feal then rubber lines, but only at or near threshold.
The caution with SS lines is that dirt can work their way between the braid and the hose under it, causing abrasion and potential failure. This will be a slow process and requires periodic inspection of the lines for weeping. Not a big deal if you pay attention to them.
If you are tracking your car, you should be doing a brake job before and after to change pads. This is a good time to do this.
The other caveate is that SS lines are often not DOT approved, which can cause issues if you get into an accident due to brake failure. As long as the lines have not failed, there shouldn't be an issue, but forwarned is forwarned. Personally, I am willing to take the microscopic risk for the benefits SS lines bring.
Oh, my suggestion on the fluid is not in dispute with the orginal post. I'm making the suggestion to make it easier to bleed brakes.
I would like to say there is basically two types of performance driving. One is driving for qualifying/sprint-race speeds (pushing 10/10ths or even more so to get the fastest time and disregarding the parts on the car for damages because at the end of qualifying or a short sprint race, you'll replace them anyways for the next race). Expect to see a lot of cracked rotors and the such at these kind of speeds. The second type of performance driving is known as the race speeds (pushing the car to the limit that will outlast the other drivers and their cars, this is very common when it comes down to enduro races). Slotted and Cross-drilled rotors are made for a reason still. 24-hour and 12-hour races have a meaning of how to stay in the race with precision and conservative driving at the highest level. Sure, cross-drilled rotors do crack, but for track practice and learning the lines and conserving your brakes to last for the day isn't. http://www.racingbrake.com has made some of the better racing rotors I have dealt with (over Baer, Project Mu, and even Brembo rotors). Not all rotors are designed the same way, as some of the brake rotor's veins for cooling go a long way and number of holes also add up to the structural integrity (or lack of) about the rotor.
I have been on the losing side of a 3-hour enduro as my team lost the race in their class (leading 2nd place when the front full blank rotors and race pads finally glazed up at 2 hours and 58 mins, of which we did an attack starting from 4th place at the last 10 laps which made them overheat). The driver lost all braking power on the 2nd to final lap and buried the car into turn 1's tirewall at http://www.virclub.com
Keefe
Keefe
Well, I'm late in this, but some points on blank vs. slitted vs. cross-drilled rotors.
For the street, blanks are more than adequete. They simply don't look too cool, which is why there is a large amount of slitted/cross-drilled rotors on street cars.
For the track, slitted rotors make the most sense in terms of circuit performance, especially over longer periods.
Which leads us to cross-drilled. There are two types of cross-drilled - ones that are actually, physically drilled, and ones that are cast with the drill holes in place (Porsche rotors). The cast-hole rotors are fairly sturdy. And expensive. At the track, rotors are like bags of chips while watching the superbowl - expect to replace them regularly. So if you are serious about your track braking, balance your needs vs. replacement costs.
Cross-drilled rotors cracking: All rotors have the possibility of cracking, cross-drilled (non-cast) are simply the most prone to it. Yet you can easily make a cross-drilled rotor last longer without cracking than even a blank rotor. The main failure point for rotors is not on the track itself, but after you leave the track. Most people go 100% (or more, at least for them) on the track up to the last second, pull off, stop the car, set the e-brake and let those expensive rotors cool off rapidly. <crack!> What really does it is the brake pads - the rotors are exposed to air everywhere but the pads, and when you let it cool off from Extra Crispy to Slightly cool with most of the rotor cooling off *much* faster than the section of the rotor under the pads, the difference in temperature will make *any* rotor brittle quickly.
If you want your rotors to last after track racing, either take one or two really slow, easy cool-off laps before you pull off (if you have that choice), or try to slowly roll around somewhere to let the brakes cool off more gradually and evenly.
Porsche owners with those expensive ceramic rotors have had some fairly expensive replacement bills (think half the cost of WRX or more...) after relatively low mileage on those rotors because they do just that - pull in and stop. Even Porsche thought they would know better...
Cheers,
Paul Hansen
http://www.avoturboworld.com
http://www.e-bacs.com
Paul - yup right on. Forgot to talk about the whole cast vs. drilled. thanks
IMHO, cross-holed (I'll be generic) just isn't worth the hassle or expense. It's a total PITA to do cirlces in the parking lot waiting to cool the brakes down.
  • 4 weeks later...
I had cross drilled rotors f/r on my 98 camaro Z-28, ran about 25,000-30,000 miles on them, and they weren't easy miles. I liked to run that car at high speeds out in the open, as well as on the back roads, lots of hard braking from speeds ranging up to 160 mph, to lower speeds of 30-40, and i did lots of hard braking, hard excel, hard braking..ect...never had a problem with brake fade, and i never cracked any of the rotors. It all depends on what you are going to be doing. If you are going to be braking hard a lot from higher speeds, or lower speeds, the added saftey of slotted or cross drilled rotors is probably worth the extra expense, since life is priceless and it can save one. If you are a normal driver who obeys all posted speed laws, a normal rotor will be just fine for you. IMHO
  • 4 months later...
Hi,
I recently visited LegacyGT forum and noticed you have been actively giving advice to members with your in depth experience and knowledge, which has received my attention and respect as it hard to find nowadays in various medias or web forums.
Since your posting generates some good discussions about drilling / slotting again just like anywhere else, I would invite all the members to view our comparison on different disc surface finishes.
http://www.racingbrake.com/main/two_piece_compare.asp.
The rotor cracking is caused primarily due to poor casting quality or more precisely - Microstructure, this makes the rotor more prone to deformation (warping or cracking) under heat. Thermal fatigue makes the rotor loses it's strength, not because of the drilling. Jerami1981's experience should well support my statement.
Anyone, especially racers, should be aware that a well performed rotor shall be made available from ground up i.e. good material (casting and heat treatment) which is more resistant to heat and better designs that will drain heat faster and keep the disc cool, rather than centering around "drilling" or "slotting" which although can change the performance to some extent, would not principally change the physical property that dictates how a rotor performs. See http://www.racingbrake.com/main/rotor_is_important.asp which was in response to Mazda 3 forum discussion about aftermarket rotor. http://www.mazda3forums.com/index.php?topic=24716.0
Our rotors are built from our experience and know-how. See our patent pending designs http://www.racingbrake.com/main/technology.asp. All designs are simple to understand and work. For example WRX enthusiasts love our rotors, while other manufacturers /suppliers including OE keep warping, why? it's is because our patent pending design of reinforced rib that makes the difference:
http://www.racingbrake.com/images/legacygt.jpg
http://www.racingbrake.com/images/legacygt1.jpg
Best Regards
  • 1 month later...
yes, provided that you probably need to cut off the brake dust shield, retain the caliper bracket, and have wheels that can clear the calipers. Just remember that the bolt pattern for the Legacy is 5x100, so that means a 2005 STi rotor would not work on this car. Also check for thicknesses of the rotor when you start to mismatch the rotors and calipers.
I am not sure of what the specs are for the 2006 WRXs (other than it being fitted with OEM Subaru 4-pistons/2-pistons with probably the same OEM dimensions as OEM 2005 rotors).
But the question that I should ask you is: "What IS your braking problem?"
Keefe
the brakes are horrible.. pedal is too squishy and if i need to stop on a dime, im in trouble. other than the constant rotor warping and the horrible ebrake that doesnt grab... the brakes are just not strong enough for the power of the car stock, let alone stage 2! so i was curious about the new WRX brakes, i know they are nicer than the previous years, and since they only have 17'' wheels, i figured they might do the trick, after market big brake kits are soo expensive... Or in your opinion, should i just throw on a NEW set of OEM rotors and put upgraded pads on and call it a day?
I track my car and I dont have these issues (and I stop from 120 mph down to 40 mph every 1 min or so during a 30 min sessions 6 times during a weekend = 3 hours of hard driving). Are you locking up the brakes? It's possible that you already boiled your OEM brake fluid (which explains the squishy brakes). You should look into better tires to help raise the level of grip. If you have the ABS kicking in, that means you are locking up the brakes, and the tires are to blame from this point on. Previous years of the WRX brakes are smaller, so that's something you don't want.
You should upgrade your brake pads.. it's also possible that you have glazed your pads or left a lot of the OEM brake pad deposits (aka dust) on the rotors to cause it to shake. Warping comes from the heat and cool-down process. Be light on the pedal pressure, you don't need to slam on the brakes (as there is a LOT of clamping force from the stock calipers). From what I am understanding from what you are typing, it sounds like majority of the people on these boards that complain about the brakes are getting me think of their driving habits. A proper smooth braking technique will save you from not just life-threatening situations, but you can prolong your brakes more.
I am currently over 32,000 miles on the stock rotors (over 1000 miles of road track, and over 100 miles of autocrossing).. I only upgraded my pads at 10,000 miles because I wore out my stock pads from driving hard on a daily basis. I also upgraded my fluid as well so that it doesnt boil over at the track days. The rotors have never been turned/resurfaced. I have no shakes, pulsating, or warp rotors from the braking that I do.
Keefe
How about a recommendation on upgraded pads for street use? Cobb?
I left this open for everyone to make up their own choice of which company to go with.. but here is the range specs that you should be looking for:
Operating Temperature : 0 degrees F and up (some are 32 degrees F). Look for a wide range if you can. I believe the Carbotech Bobcats are 32F to 750F.
Coeff. of Friction: Look for something high, something above 0.38 and up. I believe Carbotech Bobcats have something high as 0.45 and up. Stock is about 0.28 to 0.32... this number represents the amount of initial bite you will feel.. this number will also relate to how much heat you can build up to warp your brakes IF you are the type that ride on the brakes on your daily commute. Change your braking habits and you won't have warping rotors
Brake Dust/Noise: I am leaving this up to everyone to decide.. some are noisy, some are quiet.. some are really dusty, while some are dust-free.
Keefe
Keefe,
Which endless pads did you go with? Are you still enjoying them? I remember that it was the pad with the lower coeff. of friction. (relative to the other pad, not stock) I am planning to gradually assemble my braking suplies over the winter and I wanted to try something beside Bobcats. (though I liked those a lot for the street)
Ted
:spin:
  • 2 months later...
I have had good success on hard-driven street cars with PBR/Axxis Ceramic pads, no noise, good bite, good wear characteristics, but dusty (I don't really care about that though, if the pads perform, I can wash the wheels). On my WRX I ran these with stock OE rotors, Stoptech SS lines and ATE Type 200 Dot 4 High Temp fluid. NEVER faded brakes, even on spirited canyon runs through the Gold Country and Feather River area of California.
Keefe,
Ted
Endless SS-M.. I rather have less bite and more heat capacity all while having NO DUST and NO NOISE :D I happen to like smoother modulation on the brakes (better pedal feel and modulation than a hard initial bite, especially for just street driving.. and it doesnt hurt for me to drag out the brakes some if I have a loaded car). SS-Ms have lasted me about 30,000 miles with track days and autox days.. so if I didnt do all of that, it should have lasted me about 50,000 miles or so..
Keefe
  • 3 weeks later...
