Paradiso Posted October 20, 2008 Share Posted October 20, 2008 Thanks. It doesn't make sense to me that you'd need thread sealer on the diff. I have copper washers in the garage (Alfa oil pan bolt uses them) so if they're the same size I'll use a new one, otherwise I'll just reuse the one that's on there. Link to comment Share on other sites More sharing options...
JoeFromPA Posted October 20, 2008 Share Posted October 20, 2008 I just tightened my trans bolt to 50 lb/ft and called it a day. Haven't done the diff yet....searching for a suitable, cheap pump. Joe Link to comment Share on other sites More sharing options...
Paradiso Posted October 20, 2008 Share Posted October 20, 2008 I have something like this: http://www.kctools.com.au/images/TOOLS/slides/10295%20OIL%20SYRINGE.jpg Just suck the oil in and shoot it into the diff. Link to comment Share on other sites More sharing options...
fishbone Posted October 20, 2008 Share Posted October 20, 2008 Wow, that looks just like the pump I use when my digestive system ... you know what, I'm not going to finish that thought. Link to comment Share on other sites More sharing options...
Inigo Montoya Posted October 22, 2008 Author Share Posted October 22, 2008 Turkey baster!! really any auto parts stores should have something that will work Link to comment Share on other sites More sharing options...
JoeFromPA Posted October 23, 2008 Share Posted October 23, 2008 I bought a pump....$8 or so. Looks cheap as hell. I'll make sure it works prior to draining the rear diff. I've got 1.5 quarts of 75w110 leftover. I'm thinking I'll do a full drain this time and save an extra .7 quarts for 20-30k from now....drain some out and top it off with fresh. Joe Link to comment Share on other sites More sharing options...
rtbrjason Posted October 25, 2008 Share Posted October 25, 2008 Has anyone used mobil 1 synthetic ATF fluid in their 5/6mt? I've always used this in previous manual transmissions but am unsure if this is okay for the 6mt. Link to comment Share on other sites More sharing options...
NatesGr8 Posted October 28, 2008 Share Posted October 28, 2008 Has anyone used mobil 1 synthetic ATF fluid in their 5/6mt? I've always used this in previous manual transmissions but am unsure if this is okay for the 6mt. I just used it on my 5 mt, been doing well for the last 2 weeks/1000 miles. Nate edit...woops didn't see you said ATF fluid, i used the recommended gear oil, the mobil 1 synthetic version Link to comment Share on other sites More sharing options...
fishbone Posted October 28, 2008 Share Posted October 28, 2008 Why would one put ATF in a MT? Link to comment Share on other sites More sharing options...
NatesGr8 Posted October 28, 2008 Share Posted October 28, 2008 yeah that doesn't make sense to me either. Link to comment Share on other sites More sharing options...
Deaks2 Posted October 28, 2008 Share Posted October 28, 2008 I went with semi-synth since some ppl on NASIOC said that full-synth was too slippy for proper functioning of the synchro's... Link to comment Share on other sites More sharing options...
fishbone Posted October 29, 2008 Share Posted October 29, 2008 yeah that doesn't make sense to me either. Well I started writing a dissertation on why you should stick to the OEM recommendations for AT and then noticed he's got a manual. WTF Link to comment Share on other sites More sharing options...
RustyShackleford Posted November 8, 2008 Share Posted November 8, 2008 The 5MT listed as having 3.7qt capacity but in reality mine took only about 3.3qt to be at FULL. I only found that after I poured about 3.5qts in gear box ... I had a similar experience yesterday, after I put in roughly 3-3/4 quarts and found it considerably above "full" on the dipstick. One wonders if the inaccuracy is in the dipstick calibration or in the 3.7qt capacity spec; seems equally likely ... unless a significant volume of old oil remained in the tranny, but I warmed the car up, parked it on level ground, and let it drain at least 30min (while I struggled with the rear diff'al plugs). Link to comment Share on other sites More sharing options...
SubOperator Posted November 10, 2008 Share Posted November 10, 2008 Check this thread I posted about surface level and tranny dipstick readings: http://legacygt.com/forums/showthread.php?t=99542 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
RustyShackleford Posted November 10, 2008 Share Posted November 10, 2008 Interesting - about the dipstick level being very sensitive to car levelness.I parked on a slight incline (front of car higher) by a few inches and indeedfound that the level was then only about 1/4" above "full" (it was maybe 1/2"when I thought it was parked level). Oh well, I take solace in the advice thatit's not a pressurized case and slight overfill should not risk seals. Link to comment Share on other sites More sharing options...
macarpiem Posted November 15, 2008 Share Posted November 15, 2008 You are the man!!! thanks for the good threads!! really helpfull.awesome. Do your own!!!!! Peace. Link to comment Share on other sites More sharing options...
RayC Posted November 26, 2008 Share Posted November 26, 2008 I just changed the fluids on my 5MT, the rear diff oil looked almost new in my car and smelled just like gear oil. Same for the front diff / tranny. Note to all doing this: When i filled my front i just used some extra silicone hose and inserted the nipple of the quart bottle and squeezed. This works but you have to go fairly slow as mine backed up and i succeeded in placing quite a bit of gear oil on the concrete. Thanks for the how to. This was very easy, except for cleaning up the mess i made myself. edit: oh, and to those questioning ATF in a manual trans - many new manuals (hell, many OLD manuals) take Dextron ATF as their fluid. Link to comment Share on other sites More sharing options...
generalbacardi Posted December 20, 2008 Share Posted December 20, 2008 Note to all doing this: When i filled my front i just used some extra silicone hose and inserted the nipple of the quart bottle and squeezed. This works but you have to go fairly slow as mine backed up and i succeeded in placing quite a bit of gear oil on the concrete. Thanks for the how to. This was very easy, except for cleaning up the mess i made myself. I just did that with a short length of hose since it's all I had and I the hose came off the bottle into the dipstick hole! :eek: I'm going to get one of those flexi parts grabbers at the auto store and hope I can fish it out. I can still see it in the hole. F^%$#%^$#%$#%#!!!!!! Link to comment Share on other sites More sharing options...
987687 Posted December 21, 2008 Share Posted December 21, 2008 I don't need to change my tranny oil, it leaks, so I just top it off every week... Gonna get that fixed. Link to comment Share on other sites More sharing options...
Kelvrick Posted December 21, 2008 Share Posted December 21, 2008 Very nice writeup, too bad I've already done mine for 30k mile service. btw I got my torx t70 at autozone. Sweet, had a hell of a time trying to find one until I called Autozone. Guy didn't think he had em but went to check and found 1. Was 3.99, so cheaper then ebay in the end. My Outback Link to comment Share on other sites More sharing options...
rkl303 Posted December 22, 2008 Share Posted December 22, 2008 only thing i didn't like was it was a 3/8" as that thing is stuck on there hard and unfortunatley I lost my 1/2" version but I am sure that probably isn't going to be the weakest link. Link to comment Share on other sites More sharing options...
RustyShackleford Posted December 22, 2008 Share Posted December 22, 2008 A 1/2" to 3/8" adapter is a nice addition to any tool kit. Ask Father Christmas ... Link to comment Share on other sites More sharing options...
bradlgt21 Posted December 23, 2008 Share Posted December 23, 2008 Can we sticky this thing maybe move it to the walkthroughs and permanantly sticky it. This walkthrough is awesome. Took care of all my questions with the process. Link to comment Share on other sites More sharing options...
Inigo Montoya Posted December 24, 2008 Author Share Posted December 24, 2008 I put a link there when I first created the thread, just didn't want to go back an copy and paste everything. Link to comment Share on other sites More sharing options...
Mundi78 Posted December 29, 2008 Share Posted December 29, 2008 Which 5MT and Diff oil I should use in 05 LGT ?? Mobile1 Valvoline RedLine Royal Purple Link to comment Share on other sites More sharing options...
