Inigo Montoya Posted December 29, 2008 Author Share Posted December 29, 2008 Which 5MT and Diff oil I should use in 05 LGT ?? Mobile1 Valvoline RedLine Royal Purple I used Redline for my fluid changes, however there has been discussions about both the options of mobile 1 and royal purple, as well as the subaru syncro-s (that only comes in large amounts though) I am happy with my decision. Link to comment Share on other sites More sharing options...
RustyShackleford Posted December 29, 2008 Share Posted December 29, 2008 Which 5MT and Diff oil I should use in 05 LGT ?? Mobile1 Valvoline RedLine Royal Purple Rumor has it the factory fill is Valvoline (dino). Link to comment Share on other sites More sharing options...
SubOperator Posted December 31, 2008 Share Posted December 31, 2008 I used RedLine. No problems so far (knocking on the wood) after ~10K. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 2, 2009 Share Posted February 2, 2009 Question: Is it safe/possible to disconnect the ATF return line and route it into a drain pan, then turn the car on and pour fresh ATF into my 5EAT until it comes out clean? I have my girlfriend to watch the level of expelled transmission fluid so that I can match the incoming volume of ATF. If so, would I need to plug the disconnected return line? TIA! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
devobuzz Posted February 2, 2009 Share Posted February 2, 2009 I would think this is kinda dangerous. I put a new engine in a car once and I forgot to connect the tranny lines to the radiator. I idled the car about a min or less, so some tranny fluid was pumped out before I had noticed. I didn't look like much fluid. Topped it off thinking it was OK. Tried to put it in gear and nothing. Couldn't move the car. Had to get a new tranny. Don't know what happened if I blew the tranny fluid pump or what. Be careful!! Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 10, 2009 Share Posted February 10, 2009 I would think this is kinda dangerous. I put a new engine in a car once and I forgot to connect the tranny lines to the radiator. I idled the car about a min or less, so some tranny fluid was pumped out before I had noticed. I didn't look like much fluid. Topped it off thinking it was OK. Tried to put it in gear and nothing. Couldn't move the car. Had to get a new tranny. Don't know what happened if I blew the tranny fluid pump or what. Be careful!! Your post was the reason I did it the normal way instead. What's an extra gallon or 2 of fluid worth if you don't have a working transmission to put it into? Does anyone know the size of the 5EAT ATF plug (is it for instance the same M20x1.5 plug specification as the engine, though it requires the different socket)? Thanks! [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
fishbone Posted February 11, 2009 Share Posted February 11, 2009 ^ How did you go about changing it, did you drain, refill, then drain again and refill? Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted February 11, 2009 Share Posted February 11, 2009 ^ How did you go about changing it, did you drain, refill, then drain again and refill? Yes. I recommend driving around between each, as my ATF did not mix well between the first and second fluid change when I just idled for 5 minutes. I just wanted it done quick, wasn't thinking. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
fishbone Posted February 11, 2009 Share Posted February 11, 2009 ^It's a spendy endeavor as the OEM ATF isn't cheap, but in the end it's cheaper than a flush which generally only the dealer is willing to do if you request OEM ATF. Link to comment Share on other sites More sharing options...
JoeFromPA Posted February 11, 2009 Share Posted February 11, 2009 Question: Is it safe/possible to disconnect the ATF return line and route it into a drain pan, then turn the car on and pour fresh ATF into my 5EAT until it comes out clean? I have my girlfriend to watch the level of expelled transmission fluid so that I can match the incoming volume of ATF. If so, would I need to plug the disconnected return line? TIA! I did this in my 95 volvo 850 turbo. I used, I think, 4 1 gallon containers and drained about 1 quart each time. I made sure that I had added 4 quarts every time a gallon container was full. So it never ran lower than 1 quart low. Worked like a charm. Except I didn't re-connect the line properly. 3 days later, the line disconnected and spewed ALL the transmission fluid out into the engine bay while I was doing 40mph on a back road with no pull off area. I slipped it really well for about 1 mile..... God bless volvo. Transmission worked just fine when I re-added some crappy fluid Joe Link to comment Share on other sites More sharing options...
iahtnoob Posted March 2, 2009 Share Posted March 2, 2009 help me out here, i'm a little confused. Does the manual Legacy have a front differential? and does an automatic Legacy have a front differential to change its' fluids? Link to comment Share on other sites More sharing options...
Inigo Montoya Posted March 2, 2009 Author Share Posted March 2, 2009 On the manual transmission the front diff is fed with the tranny fluid, not sure on the automatics. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 3, 2009 Share Posted March 3, 2009 help me out here, i'm a little confused. Does the manual Legacy have a front differential? and does an automatic Legacy have a front differential to change its' fluids? Both have a front differential. On the MT, the tranny and front dif share the same fluid. On the 5EAT, the tranny and front dif are separate. They each have their own dipstick/fill tube (front dif on passenger side, trans on driver side) and drain plug with different socket fitting for each. Front dif uses T70torx. Tranny uses hex bit. Front dif uses same fluid as rear dif. Tranny uses... you know. Hope that's everything you're wondering [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted March 3, 2009 Share Posted March 3, 2009 There really should be a 5EAT fluid change walkthrough, but there's no way I'm doing that picture taking at least until it gets warmer. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
iahtnoob Posted March 3, 2009 Share Posted March 3, 2009 thanks climberd, maybe i'll have the patience to do the pictures!!! Link to comment Share on other sites More sharing options...
DukeTrout Posted April 5, 2009 Share Posted April 5, 2009 The transmission dipstick/fill tube on the 6mt looks different and is located lower and farther than the one on the 5MT. See pic. It is nicely labelled "gear oil." Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
pathfin9 Posted April 5, 2009 Share Posted April 5, 2009 Also, on the 6MT, there are 2 drain plugs. WHen I first did it, i only did one, and i was like, there is no way that is 4.3 quarts....then i found that there was 2nd drain plug, and the rest came out. -John Link to comment Share on other sites More sharing options...
DukeTrout Posted April 5, 2009 Share Posted April 5, 2009 Weird. I got a nice solid gallon out of the single drain, and refilled exactly 4.2q. Then again, I dropped the front down and lifted the back, and the forward tilt encouraged quite a bit of flow. Maybe the second drain is for when they have the car up on a lift and tilting isn't an option? Ich bin echt viel netter, wenn ich nuechtern bin. Echt! Link to comment Share on other sites More sharing options...
pathfin9 Posted April 5, 2009 Share Posted April 5, 2009 Yeah, I had it up so it wasnt tilted. I got the most from opening the pan plug, which makes sense now that I think about it. -John Weird. I got a nice solid gallon out of the single drain, and refilled exactly 4.2q. Then again, I dropped the front down and lifted the back, and the forward tilt encouraged quite a bit of flow. Maybe the second drain is for when they have the car up on a lift and tilting isn't an option? Link to comment Share on other sites More sharing options...
Vitulla Posted April 11, 2009 Share Posted April 11, 2009 Here I am struggling trying to get the top rear diff plug out...LOL 1:15am and tugging at it. Im worried that me forcing is gonna break something... Any tips on how to get it out without breaking anything? Thanks appreciate the help! Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 11, 2009 Share Posted April 11, 2009 Spray it with PB Blaster or Liquid Wrench or whatever, then let it sit for a bit. If no go, heat gun or some light torch action might help. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
RustyShackleford Posted April 11, 2009 Share Posted April 11, 2009 Here I am struggling trying to get the top rear diff plug out...LOL 1:15am and tugging at it. Im worried that me forcing is gonna break something... The differential and plug are pretty stern stuff. I think the thing most likely to break is your hand, when the wrench slips off - or the wrench itself if it is crap. Any tips on how to get it out without breaking anything? Thanks appreciate the help! I've heard of jacking up the car a little, wedging the end of the wrench against the ground, and then lowering the car so the weight of the car pushes on the wrench. Or maybe take it to a garage and get them to use an air wrench to undo it (and then put it back in loosely to drive home). Link to comment Share on other sites More sharing options...
r-willy Posted April 11, 2009 Share Posted April 11, 2009 Great thread here -- I'm inspired! Word of warning though: It's possible to over-tighten the diff drain plug (probably fill plug as well), which might be the best reason to use torque numbers for reference. Steel plugs and alloy diff cover make for the potential of cracking the cover, which I have seen. Use a little self-restraint when you're cranking on 'em, especially if you're using a 1/2" drive. Link to comment Share on other sites More sharing options...
Vitulla Posted April 11, 2009 Share Posted April 11, 2009 Thanks for the great tips. I have 1 more question. I sort of gave up on the rear diff, I forced all afternoon, various ways and nothing seems to work. I'll get a shop to loosen it or just change it completely. When i recovered the left over tranny fluid in the front, I left with approximately 2.5 quarts...is that normal? I filled it with 3.7L...any risk if I put just a little more? Thanks guys, forum is great! Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted April 12, 2009 Share Posted April 12, 2009 Thanks for the great tips. I have 1 more question. I sort of gave up on the rear diff, I forced all afternoon, various ways and nothing seems to work. I'll get a shop to loosen it or just change it completely. When i recovered the left over tranny fluid in the front, I left with approximately 2.5 quarts...is that normal? I filled it with 3.7L...any risk if I put just a little more? Thanks guys, forum is great! 5MT, 6MT or 5EAT? [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
