mikeyan Posted October 5, 2007 Share Posted October 5, 2007 On the suggestion of several members, and to help our non-searching brothers, welcome to a hopefully condensed Turbo Upgrade Thread. Please Post the following: Year and Transmission Turbo (Please include details such as exhaust housing size, etc) Supporting Performance Mods Please include dyno charts and/or timeslips if you have them. *EDIT* Please keep this ON TOPIC. OT will be deleted and removed. SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
mikeyan Posted October 5, 2007 Author Share Posted October 5, 2007 I'll start: 2006 5eat LGT Wagon Blouch Dominator III, 8CM Exhaust housing Support Mods: TDC 816CC Injectors Perrin FMIC Aquamist HFS-5 APS EL Headers + UP Custom Fabbed Tial 38mm EWG Cobb DP (taper removed) 3" Catback to 2.5" Y Custom Exhaust http://i114.photobucket.com/albums/n268/michaelyan/Dynoz/MikeYan-Final91plusmeth-RPM.jpg Time Slips soon, other local dyno sheets coming soon! SoCal Duck Hunters Club - Unit 52 Link to comment Share on other sites More sharing options...
Hops Posted October 5, 2007 Share Posted October 5, 2007 (edited) 354/365 EFR 7064 rotated twinscroll Full-Race Manifold/Uppipe/Downpipe Stromung exhaust Custom intake (JDM Legends/Cobb Tuning) Cobb pulley Cobb prototype intercooler/custom piping T1 top feed fuel rails 1000 cc ID injectors Walbro 255 fuel pump AEM 3.5 port boost control solenoid AEM Speed Density Aeromotive fuel pressure regulatorHighest Power Graph.pdf Edited September 4, 2015 by Hops Buy my cars! Link to comment Share on other sites More sharing options...
wavewagon Posted October 5, 2007 Share Posted October 5, 2007 Great idea: Here's a link to my initial thread too with dyno graph: http://legacygt.com/forums/showthread.php?t=59879&highlight=5eat+20g Motor and Transmission Mods: FP 20g, 34mm internal wastegate, 8cm housingPerin FMICK&N CAIProdrive boost control solenoidMegan Racing CBEPDE UPCobb HFC DPPerin inletDeutchwerks 740cc injectorsWalbro pumpIPT VBTransmission cooler The install and tune went great and I am very happy with the car, 320whp/290wtq. At 4K RPM it really starts to pull and holds power all the way to redline. A completely different beast than Stage 2, very fun to drive. Jon tappered boost up to 19.5psi at 4K (to make more 5EAT friendly). Great job at Harman, thanks, Ian, Jon, and Dan! A special thanks to Boostjunkie for going the extra mile to get the Megan Racing CBE prototype on the car in time for my tune (a very nice cat-back set-up). SnoDork, thanks for the motivation and the K&N intake. Link to comment Share on other sites More sharing options...
mattg Posted October 5, 2007 Share Posted October 5, 2007 2005 LGT 5MT limited sedan FP TD06-18G 7cm Legacy fitment Perrin TMIC AEM CAI AVO pump Deatschwerks 740cc injectors Crucial P&P+coated manifolds BPM X-over pipe (soon to be wrapped) BPM flex UP (soon to be wrapped) PDE catless 3" no taper DP (soon to be wrapped) Perrin Mid & Y Cobb AP dynotuned by PDX Put down 278/274 on the PDX mustang @ 16.5 psi. I'm working on getting it tuned up into it's efficiency range, then alky in the spring. http://photos.imageevent.com/mattg/legacygt/18G.PDF I'm not sure what a stock STI puts down on this dyno, but you can see AKLGT's numbers, and farmerjohns rotated GT30 did 383/373. this was my first 18G tune on PDX old Dynapak. this was with a 7psi actuator, and we had to install a bleeder on the WG actuator line to hit 17psi. I now have the 15psi actuator. My car had a coated Megan header and no CBE for this tune. http://photos.imageevent.com/mattg/legacygt/large/18g%20dyno.JPG . . . Link to comment Share on other sites More sharing options...
redfly17 Posted October 5, 2007 Share Posted October 5, 2007 Engine: * Cobb AccessPORT * Invidia 5MT Catted DP * Vibrant Performance headers + UP ceramic coated (Blue) * UR crank pulley * Perrin Y-pipe and AVO v2 axlebacks * Perrin TMIC with alki tap * APS BOV with TDC custom tubing * CoolingMist Stage II (Vari-Cool Controller Kit) with TDC custom mounted tank * Wahlbro 255l pump TDC custom fitted * Deadbolt IHI VF40-18G * AVO 15lb Boost Actuator * NGK Iridium Spark Plugs (1 step colder) * K&N Typhoon Intake System * TDC Protuned by TDC Mike 305WHP and 335WTQ http://xc8.xanga.com/470d427208c33113739069/m81247060.jpg **NEW SETUP TO COME IN 1 WEEK** Link to comment Share on other sites More sharing options...
AKLGT Posted October 5, 2007 Share Posted October 5, 2007 Basic STI Swap: 2005 LGT 5EAT Sedan VF39 STI TMIC STI Intake Manifold Gutted OEM uppipe Custom 3" bellmouth DP SPT CBE SPT intake and heatshield Ported TGV Deletes Perrin Turbo Inlet Hose IPT Valve Body Hayden Transmission Cooler Cobb LW Crank Pulley GP Moto Coilovers Brembo Front BBK BBS STI Rims dyno numbers weren't too impressive: 238 awhp/231 wtq (86 Deg, boosting 16 psi) at PDX Tuning. these numbers ARE FROM THE RACE FUEL MIXTURE ON THE DYNO!!! all other tunes were done before during a road tune session. Obviously we know the dyno #'s are off, however, that was the best we got from my car THAT day after driving 2500 miles to PDX, spending 2 hrs in traffic in the heat from Rallitek. However, when at home, boosting 21 psi (no awd dyno here) running 12.86-12.96. Car 8458: Using the fuel mix and dyno tune race map: http://img.photobucket.com/albums/v384/trdvibe/Test%20N%20Tune%20Aug%2015%2007/Timeslip815.07.jpg Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
AKLGT Posted October 5, 2007 Share Posted October 5, 2007 ^ She keeps forgetting to add the 1/4 mile was on race gas. *edited post above* you keep neglecting the fact that the DYNO numbers are from tuning for the race map with my race gas mixture. again, the most the car would boost on the dyno was 16 psi while here it boosts at 21 psi. the car was being tuned for: 1/4 tank 90 octane + 32 oz Torco Race Fuel. 98% cycle on stock injectors and fuel. Wiggle wiggle wiggle wiggle wiggle yeah!!! Link to comment Share on other sites More sharing options...
MarcusDubya77 Posted October 5, 2007 Share Posted October 5, 2007 LGT 05 5EAT VF40/18G Hybrid IA performance tune for 91 pi$$ gas PERRIN TMIC AVO Panel Filter and BOV STi UP PDE Shorty DP Crucial MP w/ HFC XO2 Racing CBE Walbro 255 LPH fuel Pump Dynoed on a Mustang :woowoo:check out the Diamond Gray Metallic Monster!!! Link to comment Share on other sites More sharing options...
meier motor sports Posted October 5, 2007 Share Posted October 5, 2007 FIGHT!!! stock turbo. (can i play in this thread too?) cobb catless UP perrinc catless down pipe. megan racing cat back pro tuned on 93 octane and 100 octane. will post dyno later. 13.2 at the track. i can scan that to but im headed up in 2 weeks anyways so ill wait Link to comment Share on other sites More sharing options...
Boostjunkie Posted October 5, 2007 Share Posted October 5, 2007 Ok, I'll whore my dyno sheet out too 05 LGT sedan - 5MT Mod list: Shortblock: Supertech forged pistons Supertech/NPR rings Manley rods Cosworth rod and main bearing (race spec) Nitrided and micropolished stock crank Cosworth oil pump Cosworth head studs Greddy timing belt Balanced and blueprinted Heads: Ported and polished Supertech 1mm oversized valves (SS intake, Inconel exhaust) Supertech double valve springs and Ti retainers Cosworth cams (278/274) Bolt-ons: Deadbolt SZ55 turbo (7cm2 turbine housing, internal gate, 3" inlet) APS 3" turbo inlet pipe Harman Motive CAI JDM TGV deletes Perrin FMIC Perrin fuel rails Perrin EBCS PE 850 injectors Walbro fuel pump PDE uppipe Megan Racing DP Megan Racing CBE HKS BOV (fully recirculated) 91 octane pump gas. No meth. No additives. http://i6.photobucket.com/albums/y207/Pisadong/91octane_agressive.jpg I'll be back with a modded GT35R in a little over a week and hopefully quite a bit more power (500+ whp on pump + meth). Of course I do need to work out a head gasket issue too Link to comment Share on other sites More sharing options...
j255c Posted October 5, 2007 Share Posted October 5, 2007 Engine Mods: TDC Modified Inj's (816cc) TDC Walbro Pump TDC Tune WBR FMIC Blouch TD05-20g 8cm (Utilizes a Td06 Compressor Cover) Prodrive Solenoid Used STI Up-pipe Crucial Radiator Caps Crucial Racing Downpipe (2.5") Used Crucial Racing Midpipe(2.5") Stock Resonating Section (2.5") Used Welded in Perrin Y-Pipe (2.5") Used Perrin Muffler Perrin Recird BPV Used Perrin Inlet Used K&N Typhoon Intake Perrin Crank Pulley Stock Clutch 21 taper to 19 http://i67.photobucket.com/albums/h300/c0lbyj/jcolby20g.jpg 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
wukindada Posted October 5, 2007 Share Posted October 5, 2007 Perrin FMIC SZ55 "Fatboy" turbo 3" 816cc injectors AVO fuel pump AVO intake TGV deletes COBB DP(catted version) Maddad header/UP V2 GReddy EVO2 catback Crucial 160* T-stat Crucial radiator & reservoir caps Unorthodox lightweight pulleys Prodrive boost solenoid street-tuner Tuned by Scott Siegel GFB bov Turbo dynamics turbo blanket Hayden transmission cooler NGK Iridium 1 step colder plugs No dyno plots with the latest setup but according to Scott Siegel the setup is putting down just over 400whp/400ftlb @ 4200 on 93oct Have not been to the track but did log these times this past week 50-80...........3.15 60-80...........2.16 60-100.........4.82 Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
Ridgeracer Posted October 6, 2007 Share Posted October 6, 2007 AVO intake Momentum 50T w/ 2.4" inlet TDC custom FMIC TDC modded 816cc inj. Walboro FP Crucial UP Rally Perf. shorty DP Megan CBE Prodrive boost solenoid TXS BPV Protuned by Mike @ TDC Dyno'd with 93oct 320whp/342wtq http://www.legacygt.com/forums/showthread.php?t=71941 Running 21 psi peak tapering to 18 psi by redline. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
tommypenguin Posted October 17, 2007 Share Posted October 17, 2007 Subscribed and reserved. Link to comment Share on other sites More sharing options...
burnu2 Posted October 17, 2007 Share Posted October 17, 2007 2005 LGT 5MT Limited Blouch 20g 7cm upgraded WG UTEC, PE850's /w Walboro 255lph, MTS FMIC, Tial 50mm BOV, Gruppe-s headers, Perrin UP+DP Catless, Custom 3inch mandrel bent exhaust, Prodrive boost solenoid, CRY02 intercooler ring (not used on dyno), Hybrid clutch RPS pressure plate and ACT 6-puck disc, ACT flywheel, and some other stuff I can't remember. Tuned by Jermaine at TurboXS and put together by Rob at MTS, 369whp @ 22psi 342whtq 115 degree shop temp. 4th gear pulls. Baseline 364whp. Great curve to redline. (Runs REAL nice now that it's colder in MD) Best track time is a 12.4 @ 114mph, 1.7 60 foot. High 80's temp. at Capital Raceway. Full interior. Sorry no dyno or timeslip, dyno is on a thumb drive somewhere and my timeslip was probably thrown out. Plans to run soon, will edit and post a slip. Link to comment Share on other sites More sharing options...
Ray_STI Posted October 21, 2007 Share Posted October 21, 2007 I thought I'd chime in.. 2005 STI Element GT52, 3 Inch TBE (catted), APS FMIC/CAI, all the other big turbo mods.... Stock headers/up-pipe, stock clutch. EM- APv2. 400whp/402.5wtq @ 21.5 PSI of boost by 3657rpm.. Upcoming mods- CF Drive Shaft. RESERVED for 08 Legacy Spec B (whenever the APv2 for that one comes out) Link to comment Share on other sites More sharing options...
SubLo Posted October 25, 2007 Share Posted October 25, 2007 2006 Subaru Legacy GT Spec.B Engine ModsPerrin Catless Up-pipeCobb Access Port V2 - ProTuned by Mike TDC Tuning 93 Oct TuneAutospeed TBEPerrin TMICAEM CAITDC 40bb turboTDC 816cc modded injectorsTGV deletes portedWalbro 255lph fuel pumpProDrive Boost Control Solenoid.20Psi Max @3600rpm tapering to 19psi @6500Peaks: 322hp/349ft-lbs tq. Redline bumped to 7150rpmOverview Like buttah!!! Smooth and strong beyond belief down low where you won't find boost and torque on higher-end and higher power turbos! Jet Fighter sounds during operation and shutdown! Maintains stealth by looking like stock IHI VF40. Locomotive-like nearly linear acceleration (for a turbo car). Requires fuel system mods. Expen$ive as heck - hundreds more than other turbos but to me well worth it. Though, some early adopters have bought it for under $1,000!!! All this power on TMIC and no meth! I figure with meth, I'd be over 350hp and 400ft-lbs maybe. Don't think I'll ever do it though. http://www.nyccs.net/images/lgt/40bbdyno.jpg ________________________________________________ [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1980"]'05 BSM OBXT Row-your-own, W.I.P. :rolleyes:[/URL] [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1242"]'06 Shrek B # 64 - The car the wife loved to hate :( Sold...[/URL] Link to comment Share on other sites More sharing options...
Bigltfp Posted October 26, 2007 Share Posted October 26, 2007 (edited) Custom FMIC PE 850 cc inj. AVO fuel pump Blouch TD05h-20g 7cm^2 Turbo STI Mounts Full Custom TBE Short Ram intake Prodrive Boost Selenoid Mahle Forged Pistons Cobb AP with Protune Dyno Dynamics dynometer 321.7 whp, 315 wtq. Lonnie Attached Thumbnails Edited June 7, 2008 by Infamous1 Link to comment Share on other sites More sharing options...
05pearl Posted November 4, 2007 Share Posted November 4, 2007 (edited) E85 Tune Cobb DP, MP, Y Stock Cans Perrin UP/DP HKS SSQ BOV Subaru short shift AVO Fuel Pump Upgrade AVO TMIC NGK One Step Colder Plugs Deadbolt TD06H-20G Zilla DW 850cc injectors AVO Intake Snow Performance WI kit running washer fluid Labonte WI safety monitoring Defi boost gauge Momo shift knob Tuned at 5200' altitude Edited August 30, 2008 by 05pearl New Tune Link to comment Share on other sites More sharing options...
taskforcefreddy Posted March 14, 2008 Share Posted March 14, 2008 I'll throw my hat into the mix... AVO 420 AVO FMIC AVO Fuel Pump AVO Intake DW 740's Cobb UP Cobb DP Autospeed CBE ACT Street Performance Clutch Autometer Cobalt Boost Gauge Pro Tune by Jorge at P&L 328hp 335lb/ft torque Have megan racing headers going on and am contimplating the Labonte WI kit plus a new tune here shortly. Will provide new post if this happens. Link to comment Share on other sites More sharing options...
uberpollo Posted March 18, 2008 Share Posted March 18, 2008 35bb Perrin tmic Invidia catted DP STI UP Access Port Magnaflow catback K&N intake fuel pump 19.5 lbs trailing off to about 15 at redline. So smooth, so linear, always on tap. I love this setup. http://juanvergostudios.com/legacygt/35bb.jpg Link to comment Share on other sites More sharing options...
tytek Posted March 18, 2008 Share Posted March 18, 2008 2005 Subaru Legacy GT Wagon, 5spd manual Power mods: - AccessPort V1 - FP Green 3", 8cm - MTS FMIC - APS BOV - K&N Typhoon Intake - TGV Deletes - Prodrive BCS - Perrin 3" silicone inlet - DW 800cc Injectors - Walbro 255L/hr fuel pump - Ultimate Racing Uppipe w/ Tial 38mm EWG - Cobb catless downpipe - Grimmspeed x-pipe/ported manifolds - Stock catback (at dyno time - now a 3"CBE) 359whp, 359wtq Link to comment Share on other sites More sharing options...
al-gorithm Posted June 14, 2008 Share Posted June 14, 2008 2005 Legacy GT non-limited sedan, 5MT -SZ49 2.4 inlet, 8cm^2, oil and water cooled, ported wastegate, Black Xtreme Coating exhaust side, Grey Ceramic Coating compressor side, 15psi actuator rotated for more direct action -TDC FMIC -TDC Modded 816cc injectors -PLTek Walbro fuel pump -Modified stock intake straightener and MAF housing -AEM Dri-Flo intake filter -AP 3" inlet with 2.5" coupler -Prodrive BCS -1 step colder plugs -HKS SSQV -GTSpec II Headers w/velocity UP -Invidia catless DP -custom 2.5" exhaust to 2 x Flowmaster40s 350whp/356tq Link to comment Share on other sites More sharing options...
Silverstar Posted July 20, 2008 Share Posted July 20, 2008 (edited) 2005 5MT TDC 18G 8cm^2 housing - overported and polished Supporting Mods: AEM intake AVO TMIC GFB BPV 850cc DW injectors 1 step colder plugs COBB UP/DP Autospeed CBE Labonte meth injection - MAF scaled. 319whp/325tq http://i391.photobucket.com/albums/oo357/silversbr/Dyno1.jpg The red pull had the meth turned on. 315whp/344tq Edited January 19, 2009 by Silverstar Link to comment Share on other sites More sharing options...
