Official Turbo Upgrade & Dyno Tuned Thread
Posted
On the suggestion of several members, and to help our non-searching brothers, welcome to a hopefully condensed Turbo Upgrade Thread.
Please Post the following:
Year and Transmission
Turbo (Please include details such as exhaust housing size, etc)
Supporting Performance Mods
Please include dyno charts and/or timeslips if you have them.
*EDIT* Please keep this ON TOPIC. OT will be deleted and removed.
SoCal Duck Hunters Club - Unit 52
Posted
I'll start:
2006 5eat LGT Wagon
Blouch Dominator III, 8CM Exhaust housing
Support Mods:
TDC 816CC Injectors
Perrin FMIC
Aquamist HFS-5
APS EL Headers + UP
Custom Fabbed Tial 38mm EWG
Cobb DP (taper removed)
3" Catback to 2.5" Y Custom Exhaust
http://i114.photobucket.com/albums/n268/michaelyan/Dynoz/MikeYan-Final91plusmeth-RPM.jpg
Time Slips soon, other local dyno sheets coming soon!
Posted (edited)
354/365
EFR 7064 rotated twinscroll
Full-Race Manifold/Uppipe/Downpipe
Stromung exhaust
Custom intake (JDM Legends/Cobb Tuning)
Cobb pulley
Cobb prototype intercooler/custom piping
T1 top feed fuel rails
1000 cc ID injectors
Walbro 255 fuel pump
AEM 3.5 port boost control solenoid
AEM Speed Density
Aeromotive fuel pressure regulator
Highest Power Graph.pdf
Edited by Hops
Posted
Great idea:
Here's a link to my initial thread too with dyno graph:
http://legacygt.com/forums/showthread.php?t=59879&highlight=5eat+20g
Motor and Transmission Mods:
  • FP 20g, 34mm internal wastegate, 8cm housing
  • Perin FMIC
  • K&N CAI
  • Prodrive boost control solenoid
  • Megan Racing CBE
  • PDE UP
  • Cobb HFC DP
  • Perin inlet
  • Deutchwerks 740cc injectors
  • Walbro pump
  • IPT VB
  • Transmission cooler
The install and tune went great and I am very happy with the car, 320whp/290wtq. At 4K RPM it really starts to pull and holds power all the way to redline. A completely different beast than Stage 2, very fun to drive. Jon tappered boost up to 19.5psi at 4K (to make more 5EAT friendly). Great job at Harman, thanks, Ian, Jon, and Dan! A special thanks to Boostjunkie for going the extra mile to get the Megan Racing CBE prototype on the car in time for my tune (a very nice cat-back set-up). SnoDork, thanks for the motivation and the K&N intake.
Posted
2005 LGT 5MT limited sedan
FP TD06-18G 7cm Legacy fitment
Perrin TMIC
AEM CAI
AVO pump
Deatschwerks 740cc injectors
Crucial P&P+coated manifolds
BPM X-over pipe (soon to be wrapped)
BPM flex UP (soon to be wrapped)
PDE catless 3" no taper DP (soon to be wrapped)
Perrin Mid & Y
Cobb AP dynotuned by PDX
Put down 278/274 on the PDX mustang @ 16.5 psi. I'm working on getting it tuned up into it's efficiency range, then alky in the spring.
http://photos.imageevent.com/mattg/legacygt/18G.PDF
I'm not sure what a stock STI puts down on this dyno, but you can see AKLGT's numbers, and farmerjohns rotated GT30 did 383/373.
this was my first 18G tune on PDX old Dynapak. this was with a 7psi actuator, and we had to install a bleeder on the WG actuator line to hit 17psi. I now have the 15psi actuator. My car had a coated Megan header and no CBE for this tune.
http://photos.imageevent.com/mattg/legacygt/large/18g%20dyno.JPG
Posted
Engine:
* Cobb AccessPORT
* Invidia 5MT Catted DP
* Vibrant Performance headers + UP ceramic coated (Blue)
* UR crank pulley
* Perrin Y-pipe and AVO v2 axlebacks
* Perrin TMIC with alki tap
* APS BOV with TDC custom tubing
* CoolingMist Stage II (Vari-Cool Controller Kit) with TDC custom mounted tank
* Wahlbro 255l pump TDC custom fitted
* Deadbolt IHI VF40-18G
* AVO 15lb Boost Actuator
* NGK Iridium Spark Plugs (1 step colder)
* K&N Typhoon Intake System
* TDC Protuned by TDC Mike
305WHP and 335WTQ
http://xc8.xanga.com/470d427208c33113739069/m81247060.jpg
**NEW SETUP TO COME IN 1 WEEK**
Posted
Basic STI Swap:
2005 LGT 5EAT Sedan
VF39
STI TMIC
STI Intake Manifold
Gutted OEM uppipe
Custom 3" bellmouth DP
SPT CBE
SPT intake and heatshield
Ported TGV Deletes
Perrin Turbo Inlet Hose
IPT Valve Body
Hayden Transmission Cooler
Cobb LW Crank Pulley
GP Moto Coilovers
Brembo Front BBK
BBS STI Rims
dyno numbers weren't too impressive: 238 awhp/231 wtq (86 Deg, boosting 16 psi) at PDX Tuning. these numbers ARE FROM THE RACE FUEL MIXTURE ON THE DYNO!!! all other tunes were done before during a road tune session. Obviously we know the dyno #'s are off, however, that was the best we got from my car THAT day after driving 2500 miles to PDX, spending 2 hrs in traffic in the heat from Rallitek. However, when at home, boosting 21 psi (no awd dyno here) running 12.86-12.96.
Car 8458: Using the fuel mix and dyno tune race map:
http://img.photobucket.com/albums/v384/trdvibe/Test%20N%20Tune%20Aug%2015%2007/Timeslip815.07.jpg
Wiggle wiggle wiggle wiggle wiggle yeah!!!
Posted
^ She keeps forgetting to add the 1/4 mile was on race gas.
*edited post above*
you keep neglecting the fact that the DYNO numbers are from tuning for the race map with my race gas mixture. again, the most the car would boost on the dyno was 16 psi while here it boosts at 21 psi. the car was being tuned for: 1/4 tank 90 octane + 32 oz Torco Race Fuel. 98% cycle on stock injectors and fuel.
Posted
FIGHT!!!
stock turbo. (can i play in this thread too?)
cobb catless UP
perrinc catless down pipe.
megan racing cat back
pro tuned on 93 octane and 100 octane.
will post dyno later.
13.2 at the track. i can scan that to but im headed up in 2 weeks anyways so ill wait
Posted
Ok, I'll whore my dyno sheet out too ;)
05 LGT sedan - 5MT
Mod list:
Shortblock:
Supertech forged pistons
Supertech/NPR rings
Manley rods
Cosworth rod and main bearing (race spec)
Nitrided and micropolished stock crank
Cosworth oil pump
Cosworth head studs
Greddy timing belt
Balanced and blueprinted
Heads:
Ported and polished
Supertech 1mm oversized valves (SS intake, Inconel exhaust)
Supertech double valve springs and Ti retainers
Cosworth cams (278/274)
Bolt-ons:
Deadbolt SZ55 turbo (7cm2 turbine housing, internal gate, 3" inlet)
APS 3" turbo inlet pipe
Harman Motive CAI
JDM TGV deletes
Perrin FMIC
Perrin fuel rails
Perrin EBCS
PE 850 injectors
Walbro fuel pump
PDE uppipe
Megan Racing DP
Megan Racing CBE
HKS BOV (fully recirculated)
91 octane pump gas. No meth. No additives.
http://i6.photobucket.com/albums/y207/Pisadong/91octane_agressive.jpg
I'll be back with a modded GT35R in a little over a week and hopefully quite a bit more power (500+ whp on pump + meth). Of course I do need to work out a head gasket issue too :(
Posted
Engine Mods:
TDC Modified Inj's (816cc)
TDC Walbro Pump
TDC Tune
WBR FMIC
Blouch TD05-20g 8cm (Utilizes a Td06 Compressor Cover)
Prodrive Solenoid
Used STI Up-pipe
Crucial Radiator Caps
Crucial Racing Downpipe (2.5")
Used Crucial Racing Midpipe(2.5")
Stock Resonating Section (2.5")
Used Welded in Perrin Y-Pipe (2.5")
Used Perrin Muffler
Perrin Recird BPV
Used Perrin Inlet
Used K&N Typhoon Intake
Perrin Crank Pulley
Stock Clutch
21 taper to 19
http://i67.photobucket.com/albums/h300/c0lbyj/jcolby20g.jpg
06 TB EVO IX SE stock turbo monster subaru hater :lol:
Posted
Perrin FMIC
SZ55 "Fatboy" turbo 3"
816cc injectors
AVO fuel pump
AVO intake
TGV deletes
COBB DP(catted version)
Maddad header/UP V2
GReddy EVO2 catback
Crucial 160* T-stat
Crucial radiator & reservoir caps
Unorthodox lightweight pulleys
Prodrive boost solenoid
street-tuner
Tuned by Scott Siegel
GFB bov
Turbo dynamics turbo blanket
Hayden transmission cooler
NGK Iridium 1 step colder plugs
No dyno plots with the latest setup but according to Scott Siegel the setup is putting down just over 400whp/400ftlb @ 4200 on 93oct
Have not been to the track but did log these times this past week
50-80...........3.15
60-80...........2.16
60-100.........4.82
Toyota 6EATS .........SUCK!!!!!!
  • 2 weeks later...
Posted
2005 LGT 5MT Limited
Blouch 20g 7cm upgraded WG
UTEC, PE850's /w Walboro 255lph, MTS FMIC, Tial 50mm BOV, Gruppe-s headers, Perrin UP+DP Catless, Custom 3inch mandrel bent exhaust, Prodrive boost solenoid, CRY02 intercooler ring (not used on dyno), Hybrid clutch RPS pressure plate and ACT 6-puck disc, ACT flywheel, and some other stuff I can't remember.
Tuned by Jermaine at TurboXS and put together by Rob at MTS, 369whp @ 22psi 342whtq 115 degree shop temp. 4th gear pulls. Baseline 364whp. Great curve to redline. (Runs REAL nice now that it's colder in MD)
Best track time is a 12.4 @ 114mph, 1.7 60 foot. High 80's temp. at Capital Raceway. Full interior.
Sorry no dyno or timeslip, dyno is on a thumb drive somewhere and my timeslip was probably thrown out. Plans to run soon, will edit and post a slip.
Posted
I thought I'd chime in..
2005 STI
Element GT52, 3 Inch TBE (catted), APS FMIC/CAI, all the other big turbo mods....
Stock headers/up-pipe, stock clutch.
EM- APv2.
400whp/402.5wtq @ 21.5 PSI of boost by 3657rpm..
Upcoming mods- CF Drive Shaft.
RESERVED for 08 Legacy Spec B (whenever the APv2 for that one comes out)
Posted
2006 Subaru Legacy GT Spec.B
Engine Mods
  • Perrin Catless Up-pipe
  • Cobb Access Port V2 - ProTuned by Mike TDC Tuning :p
  • 93 Oct Tune
  • Autospeed TBE
  • Perrin TMIC
  • AEM CAI
  • TDC 40bb turbo
  • TDC 816cc modded injectors
  • TGV deletes ported
  • Walbro 255lph fuel pump
  • ProDrive Boost Control Solenoid.
  • 20Psi Max @3600rpm tapering to 19psi @6500
  • Peaks: 322hp/349ft-lbs tq. :)
  • Redline bumped to 7150rpm
Overview
Like buttah!!! :wub: Smooth and strong beyond belief down low where you won't find boost and torque on higher-end and higher power turbos! Jet Fighter sounds during operation and shutdown! Maintains stealth by looking like stock IHI VF40. Locomotive-like nearly linear acceleration (for a turbo car).
Requires fuel system mods. Expen$ive as heck - hundreds more than other turbos but to me well worth it. Though, some early adopters have bought it for under $1,000!!! All this power on TMIC and no meth! :rolleyes: I figure with meth, I'd be over 350hp and 400ft-lbs maybe. Don't think I'll ever do it though.
http://www.nyccs.net/images/lgt/40bbdyno.jpg
________________________________________________ [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1980"]'05 BSM OBXT Row-your-own, W.I.P. :rolleyes:[/URL] [URL="http://legacygt.com/forums/vbpicgallery.php?do=view&g=1242"]'06 Shrek B # 64 - The car the wife loved to hate :( Sold...[/URL]
Posted (edited)
Custom FMIC
PE 850 cc inj.
AVO fuel pump
Blouch TD05h-20g 7cm^2 Turbo
STI Mounts
Full Custom TBE
Short Ram intake
Prodrive Boost Selenoid
Mahle Forged Pistons
Cobb AP with Protune
Dyno Dynamics dynometer
321.7 whp, 315 wtq.
Lonnie
Attached Thumbnailsattachment.php?attachmentid=37567&stc=1&thumb=1&d=1180118461
Edited by Infamous1
  • 2 weeks later...
Posted (edited)
E85 Tune
Cobb DP, MP, Y
Stock Cans
Perrin UP/DP
HKS SSQ BOV
Subaru short shift
AVO Fuel Pump Upgrade
AVO TMIC
NGK One Step Colder Plugs
Deadbolt TD06H-20G Zilla
DW 850cc injectors
AVO Intake
Snow Performance WI kit running washer fluid
Labonte WI safety monitoring
Defi boost gauge
Momo shift knob
Tuned at 5200' altitude
Edited by 05pearl
New Tune
  • 4 months later...
Posted
I'll throw my hat into the mix...
AVO 420
AVO FMIC
AVO Fuel Pump
AVO Intake
DW 740's
Cobb UP
Cobb DP
Autospeed CBE
ACT Street Performance Clutch
Autometer Cobalt Boost Gauge
Pro Tune by Jorge at P&L
328hp 335lb/ft torque
Have megan racing headers going on and am contimplating the Labonte WI kit plus a new tune here shortly. Will provide new post if this happens.
Posted
35bb
Perrin tmic
Invidia catted DP
STI UP
Access Port
Magnaflow catback
K&N intake
fuel pump
19.5 lbs trailing off to about 15 at redline. So smooth, so linear, always on tap. I love this setup.
http://juanvergostudios.com/legacygt/35bb.jpg
Posted
2005 Subaru Legacy GT Wagon, 5spd manual
Power mods:
- AccessPort V1
- FP Green 3", 8cm
- MTS FMIC
- APS BOV
- K&N Typhoon Intake
- TGV Deletes
- Prodrive BCS
- Perrin 3" silicone inlet
- DW 800cc Injectors
- Walbro 255L/hr fuel pump
- Ultimate Racing Uppipe w/ Tial 38mm EWG
- Cobb catless downpipe
- Grimmspeed x-pipe/ported manifolds
- Stock catback (at dyno time - now a 3"CBE)
359whp, 359wtq
  • 2 months later...
Posted
2005 Legacy GT non-limited sedan, 5MT
-SZ49 2.4 inlet, 8cm^2, oil and water cooled, ported wastegate, Black Xtreme Coating exhaust side, Grey Ceramic Coating compressor side, 15psi actuator rotated for more direct action
-TDC FMIC
-TDC Modded 816cc injectors
-PLTek Walbro fuel pump
-Modified stock intake straightener and MAF housing
-AEM Dri-Flo intake filter
-AP 3" inlet with 2.5" coupler
-Prodrive BCS
-1 step colder plugs
-HKS SSQV
-GTSpec II Headers w/velocity UP
-Invidia catless DP
-custom 2.5" exhaust to 2 x Flowmaster40s
350whp/356tq
  • 1 month later...
Posted (edited)
2005 5MT
TDC 18G 8cm^2 housing - overported and polished
Supporting Mods:
AEM intake
AVO TMIC
GFB BPV
850cc DW injectors
1 step colder plugs
COBB UP/DP
Autospeed CBE
Labonte meth injection - MAF scaled.
319whp/325tq
http://i391.photobucket.com/albums/oo357/silversbr/Dyno1.jpg
The red pull had the meth turned on. 315whp/344tq
Edited by Silverstar
