jnd121 Posted July 19, 2006 Share Posted July 19, 2006 I went to my Subaru dealer today to order the SPT intake/heat shield and the parts dealer claimed that Subaru says that it adds +43hp . Someone please verify that this is a joke. I was thinking something like a 5-10hp gain... Link to comment Share on other sites More sharing options...
mlrtime Posted July 19, 2006 Share Posted July 19, 2006 I would be surprised if you get more than 2 hp Link to comment Share on other sites More sharing options...
wukindada Posted July 19, 2006 Share Posted July 19, 2006 +43.......Def:rolleyes: So it gives you the same as a COBB AP, DP,UP & a flash to stage II... :lol: I'd see if the dealer would promise you that figure. It's been discussed before, do not install a intake not even the SPT without a proper tune;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 19, 2006 Share Posted July 19, 2006 +43.......Def:rolleyes: So it gives you the same as a COBB AP, DP,UP & a flash to stage II... :lol: I'd see if the dealer would promise you that figure. It's been discussed before, do not install a intake not even the SPT without a proper tune;) From the factory our cars run too rich. COBB and other tuners take advantage of this and get more hp by leaning out the mixture (amoung other things) slightly. I think SOA is taking advantage of this with their intake. It leans things out a bit and that gives the car more power. It is when you are something other then stock when I would be worried about tuning the SPT intake, like if you had an AP. Stock then no problmes. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
wukindada Posted July 19, 2006 Share Posted July 19, 2006 Not doubting it can be used on a "STOCK" LGT.....But 43hp...:lol: I'd be stretching if I said it would give you 15hp;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
TDC Joe Posted July 19, 2006 Share Posted July 19, 2006 That just PROVES that dealers don't know ANYTHING about ANYTHING hahaha. Ugh.. Don't bother with the SPT intake. We haven't personally tested it but another very well respected tuner has and it isn't looking very good at all. PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
wukindada Posted July 19, 2006 Share Posted July 19, 2006 Like selling a 60k STI that only puts 345 to the wheels......ESX *425*...:lol: Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
bosco Posted July 19, 2006 Share Posted July 19, 2006 ^ who might that be? bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
fazzster Posted July 19, 2006 Share Posted July 19, 2006 From the factory our cars run too rich. COBB and other tuners take advantage of this and get more hp by leaning out the mixture (amoung other things) slightly. I think SOA is taking advantage of this with their intake. It leans things out a bit and that gives the car more power. It is when you are something other then stock when I would be worried about tuning the SPT intake, like if you had an AP. Stock then no problmes. I am respectfully questioning your statement; From what I understand no matter what you do to the intake, the computer will always adjust to the proper air/fuel ratio for which it was originally programmed. It is the less restriction that gives you a little more hp and better throttle response...... Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 19, 2006 Share Posted July 19, 2006 I am respectfully questioning your statement; From what I understand no matter what you do to the intake, the computer will always adjust to the proper air/fuel ratio for which it was originally programmed. It is the less restriction that gives you a little more hp and better throttle response...... Many intakes allow more air to flow while the MAF reads less. So the computer thinks the car is only flowing 200 g/s of air (and therefore only meters that much fuel) but it is actually flowing 215 g/s, as an example. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
froggert Posted July 19, 2006 Share Posted July 19, 2006 Don't bother with the SPT intake. We haven't personally tested it but another very well respected tuner has and it isn't looking very good at all. i'll be up in new hamster next thursday for a tune with the spt. guess i'll bring my stock airbox along just in case. Link to comment Share on other sites More sharing options...
edmundu Posted July 19, 2006 Share Posted July 19, 2006 LittleBlueGT is right, many SR/CAI's mess with the MAF diameter, thereby throwing the intake calibration off. The bad thing about that as well, is the Ecu also thinks it is at a lower load, and in turn can run excessive timing... Link to comment Share on other sites More sharing options...
PhilT Posted July 19, 2006 Share Posted July 19, 2006 Many intakes allow more air to flow while the MAF reads less. So the computer thinks the car is only flowing 200 g/s of air (and therefore only meters that much fuel) but it is actually flowing 215 g/s, as an example. I respectfully agree with your statement This has been logged by quite a few people, and is well documented on this forum. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
MIKEBRAVO Posted July 19, 2006 Share Posted July 19, 2006 Many intakes allow more air to flow while the MAF reads less. So the computer thinks the car is only flowing 200 g/s of air (and therefore only meters that much fuel) but it is actually flowing 215 g/s, as an example. So does the SPT do that too? If you can afford College, you probably don't need to go. Link to comment Share on other sites More sharing options...
Opie Posted July 19, 2006 Share Posted July 19, 2006 I went to my Subaru dealer today to order the SPT intake/heat shield and the parts dealer claimed that Subaru says that it adds +43hp . Someone please verify that this is a joke. I was thinking something like a 5-10hp gain... The dealer was actually misquoting the Intake dyno info.... On a stock STI with a SPT Intake and a SPT Exhaust system was dyno'd and showed a gain of 43 HP. Buying both these items togeher is considered the SPT Power Pack and is currently only available for the STI ind WRX (WRX HP numbers were not listed?) The Legacy Power Pack...hasn't been tested due to the Bosal exhaust situation... Link to comment Share on other sites More sharing options...
SQC049 Posted July 19, 2006 Share Posted July 19, 2006 Only 43hp, I thought is was eleventybillion! Super JDM part out: http://legacygt.com/forums/showthread.php?t=65039 PM me an offer! Link to comment Share on other sites More sharing options...
bosco Posted July 19, 2006 Share Posted July 19, 2006 Many intakes allow more air to flow while the MAF reads less. So the computer thinks the car is only flowing 200 g/s of air (and therefore only meters that much fuel) but it is actually flowing 215 g/s, as an example. why would Subaru/SPT design a intake that will screw with the computer then warranty it and sell it at a dealership. if it will work on a stock car why can't it be tuned for a modded car? bosco Stay Stock Stay Happy Link to comment Share on other sites More sharing options...
Mui01 Posted July 19, 2006 Share Posted July 19, 2006 Folks, you have to be Asian to get the +43hp! If you are white you'll get +5, black +8, and for females its only +1! Didn't you folks read the Subaru dealer's manual. Link to comment Share on other sites More sharing options...
coolbluelb Posted July 19, 2006 Share Posted July 19, 2006 Only 43hp, I thought is was eleventybillion! The actual number is threve additional HP.... *** 43 additional HP... DAMN, count me in for two Link to comment Share on other sites More sharing options...
Underdog Posted July 19, 2006 Share Posted July 19, 2006 On a stock STI with a SPT Intake and a SPT Exhaust system was dyno'd and showed a gain of 43 HP. Buying both these items togeher is considered the SPT Power Pack... It comes with the SPT decal right? There's your +43! Someone should check the vacuum between the filter and compressor inlet for stock/spt/perrin/etc... This would be a good indicator of how effective these intakes really are. It would be even better if you could datalog that info somehow to see how the vacuum changes at higher rpms. Fancy graphs FTW! The Crimson Dynamo Link to comment Share on other sites More sharing options...
wukindada Posted July 19, 2006 Share Posted July 19, 2006 We shall find out how effective it really is soon....TDC will be tuning a car with one very soon;) Toyota 6EATS .........SUCK!!!!!! Link to comment Share on other sites More sharing options...
CasopoliS Posted July 19, 2006 Share Posted July 19, 2006 K&n Ftw Link to comment Share on other sites More sharing options...
TDC Joe Posted July 19, 2006 Share Posted July 19, 2006 Like I said before we already have word from another tuner, tuning this on LGT's at stage I stage II and it was all kinds of screwing up the MAF readings PM Me for all your Modification Needs! Link to comment Share on other sites More sharing options...
TSiWRX Posted July 19, 2006 Share Posted July 19, 2006 The dealer was actually misquoting the Intake dyno info.... On a stock STI with a SPT Intake and a SPT Exhaust system was dyno'd and showed a gain of 43 HP. Buying both these items togeher is considered the SPT Power Pack and is currently only available for the STI ind WRX (WRX HP numbers were not listed?) The Legacy Power Pack...hasn't been tested due to the Bosal exhaust situation.. ^ +1, with emphasis added. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
johnAWD Posted July 19, 2006 Share Posted July 19, 2006 *ROFL* ... and the parts dealer claimed that Subaru says that it adds +43hp . Link to comment Share on other sites More sharing options...
