HAMMER DOWN Posted March 30, 2013 Share Posted March 30, 2013 Yes, but I like to jump to 40. Do too, I drive my GT like a rental car:rolleyes: with shifts above 6k. Remember my & G|F's oil history. She ran 0W-30 SSO & Ea15k13 oil filter stock location for over 150k. And I did too, didn't move to the duel remote filter sysytem until 73k. I would like this SSO in 40 weight, that all. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
jasejase Posted March 30, 2013 Share Posted March 30, 2013 Totally forgot to grab an oil sample for my OA when i did my oil change a couple weeks back. She's never burned a drop on Motul (knock on wood), and that's all she's ever ran with... Curious to see the OA however. Link to comment Share on other sites More sharing options...
Tooslick Posted March 31, 2013 Share Posted March 31, 2013 Just to experiment, I ran the Amsoil 0w-40, "4 Stroke Oil" (product code AFF), for 10,000 miles in my 1.8L/225 Hp, Audi TT Quattro. It worked as well as any other Amsoil product I've tried. I did a baseline test first to look at the physical/chemical properties. This oil has lots of ZDDP & boron, a TBN of 10.5, VI of 184 and NOACK volatility of only 7.3% (check out the spec sheet). One thing that surprised me is that this stuff is pretty shear stable, which is unusual for a wide range multi grade (0w-40, 5w-50, etc). This oil uses an older API, SL/CF chemistry that allows for higher additive levels than SM or SN. I can recommend the Amsoil 0w-40 in HiPo automotive gas engines, based on the actual testing I've done. TS Link to comment Share on other sites More sharing options...
Tooslick Posted March 31, 2013 Share Posted March 31, 2013 According to Amsoil Tech Services, the HTHS viscosity of their 0w-40 is 3.9 Cp @ 150C. For comparison the 0w-30 is only 3.1 Cp. So that's approx 25% thicker.... TS Link to comment Share on other sites More sharing options...
rapture Posted March 31, 2013 Share Posted March 31, 2013 Rotella t6 Every 3000 mi amsoil or motul if i got the extra$ 5/40 Link to comment Share on other sites More sharing options...
Brett Posted March 31, 2013 Share Posted March 31, 2013 i had to go el cheapo and buy mobil 1. so far, so good. i usually get motul. i would like to try liqui-moly. has anyone used that? Link to comment Share on other sites More sharing options...
Tooslick Posted April 1, 2013 Share Posted April 1, 2013 All the German oils including Liqui-moly, Fuchs and Pentosin are very good products, which are sometimes used as the factory fill in various European vehicles. TS Link to comment Share on other sites More sharing options...
Brett Posted April 1, 2013 Share Posted April 1, 2013 i've only seen liqui-moly, not the other two. it was at New German Performance, go figure Link to comment Share on other sites More sharing options...
TheBlubaru Posted April 1, 2013 Share Posted April 1, 2013 I have been using Amsoil European Car Formula 5w40 every 3k. God created turbo lag to give V8s a chance Link to comment Share on other sites More sharing options...
Max Capacity Posted April 1, 2013 Share Posted April 1, 2013 I have been using Amsoil European Car Formula 5w40 every 3k. WOW, that's not long at all. I'm at just over 5000 miles on it in the wagon. I'll go another 1000 then change it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
05LGTLtd Posted April 1, 2013 Share Posted April 1, 2013 Just changed from PennzUltra 10w30 and a wix filter to: Castrol Edge 0w-40 with Subaru *AA160 black filter. Edge is on sale at AAP this month, 5qts with Fram Ultra filter. Didn't need any subaru filters so I got an oversized filter for my riding mower instead. Yes, I'm putting a Fram Ultra on my lawn tractor... lol. All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
buffalo legacy Posted April 1, 2013 Share Posted April 1, 2013 Valveoline synthetic/ wix filter/ every 3000 miles Link to comment Share on other sites More sharing options...
Captain Ned Posted April 1, 2013 Share Posted April 1, 2013 GC and around 6K miles. 88K on a 2010 LGT; it spends most of its time punching holes in the air on the interstate so I could probably go longer, but I'm too old & lazy to pull off the tray to take a sample. When GC finally disappears, it'll be M1 0W-40 Euro Formula. Finally ran out of AA100 Tokyo Rokis; still waiting for a consensus on the best non-Fram replacement. The upright Forester filter is intriguing, as is the Tokyo Roki for the RX-8. Link to comment Share on other sites More sharing options...
Tooslick Posted April 2, 2013 Share Posted April 2, 2013 I run the Amsoil Ea15k12 or Ea15k20 (the larger filter) oil filters on my 2.5L Subaru's. However, they're too expensive to be changed every 3000 miles. These use a very low restriction, full synthetic, wire backed "nano fiber" media that also has very high dirt holding capacity. I've cut them open after 15k-20k of use and they hold up fine. TS Link to comment Share on other sites More sharing options...
SCHM1AN Posted April 2, 2013 Share Posted April 2, 2013 I just got done using an Amsoil Ea15k12 filter for the past 15,500 mi. I can cut it open for you guys if you want to see Link to comment Share on other sites More sharing options...
bluesubie Posted April 3, 2013 Share Posted April 3, 2013 Just changed from PennzUltra 10w30 and a wix filter to: Castrol Edge 0w-40 with Subaru *AA160 black filter. Edge is on sale at AAP this month, 5qts with Fram Ultra filter. Didn't need any subaru filters so I got an oversized filter for my riding mower instead. Yes, I'm putting a Fram Ultra on my lawn tractor... lol. AAP's web site says that BC v2 isn't eligible for promotional discounts or special offers. Is it different in the store or does it just depend on the person ringing up your purchase? -Dennis Link to comment Share on other sites More sharing options...
05LGTLtd Posted April 3, 2013 Share Posted April 3, 2013 rang up at my local AAP for 29.99 five quarts and FramUltra filter... That was on monday AM. http://shop.advanceautoparts.com/wcsstore/CVWEB/Attachment/staticbusinesscontent/image/apr-2013-flexi.pdf Ad doesn't state any specific weights, just edge... ??? Napa has their synthetic on sale for 3.49/qt. Would be a good choice to run in a NA subie for 5-7k. 10w-30 should be fine in a turbo if your stock or stage 1/2 for 3-4k. All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
bluesubie Posted April 3, 2013 Share Posted April 3, 2013 Maybe it's a web only thing. This item is not eligible for promotional discounts, coupons or special offers. Click here."] Click here. -Dennis Link to comment Share on other sites More sharing options...
05LGTLtd Posted April 3, 2013 Share Posted April 3, 2013 That statement is on every oil listed on the site. I just keeps people from using multiple discounts on oil, like $25 off $100 etc. The sale flyer price will be good in store. All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
theflystyle Posted April 3, 2013 Share Posted April 3, 2013 castrol 5w-30 with purolator pure one (Then mahle oc500 when I finish the PPOs) Link to comment Share on other sites More sharing options...
awwrxwgn Posted April 9, 2013 Share Posted April 9, 2013 Rotella T6 with subaru filter/crush ring Link to comment Share on other sites More sharing options...
05LGTLtd Posted April 15, 2013 Share Posted April 15, 2013 Napa analysis came back on the last oci of Pennzoil Platinum 10w-30. http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2973091#Post2973091 All I need now is a hill holder and a center passing light... Link to comment Share on other sites More sharing options...
Tooslick Posted April 15, 2013 Share Posted April 15, 2013 That looks like the chemical signature of the Pennzoil Ultra??? Results look very good. I recommend 10w-30 synthetics for turbo applications partially because they're the most shear stable of the SAE grades. If this testing was by a lab other than Blackstone, you can run the TBN down to 25% of its baseline value. If its a Blackstone Labs TBN result, you can go down to 20% of the baseline. (I like to be somewhat conservative in the interest of maintaining excellent deposit control). TS Link to comment Share on other sites More sharing options...
solidkevlar Posted April 17, 2013 Share Posted April 17, 2013 t6 /suby filter/ every 3k . for 25,000 since rebuild, lots of 5.5k runs, still no oil consumption Link to comment Share on other sites More sharing options...
generaljoe67 Posted April 18, 2013 Share Posted April 18, 2013 AMSOIL Signature Series and AMSOIL filter every four thousand even though it should go longer. Banjo filter bolt removed Link to comment Share on other sites More sharing options...
