lookslikeanevo Posted April 13, 2006 Share Posted April 13, 2006 i like the new upgrades, 6mt, vcd, but i really dont like the blue, it really clashes with the exterior color, i like the red that the 06's had, red leather=secks. as much as i would want to trade up, i think i would wait until 08 Current:MY05 SWP wagon - 253/290 UP, AEM CAI, Invidia Q300, tuned@yimisport OLD: MY06 GRP - 274/314 Link to comment Share on other sites More sharing options...
vet Posted April 13, 2006 Share Posted April 13, 2006 Does the entire line get the Torsen rear diff or just the specB? Link to comment Share on other sites More sharing options...
Two-Five Sti-L Posted April 13, 2006 Share Posted April 13, 2006 The 08' model may come w/more power, but most likely it will be UGLIFIED with the Impreza/Tribeca treatment. Personally I'd rather have a nicer looking/slower car than an ugly beast. Plus you can always do something about the HP issues. Link to comment Share on other sites More sharing options...
The B4 Posted April 13, 2006 Share Posted April 13, 2006 http://vocuspr.vocus.com/vocuspr30/Temp/Sites/2624/e903d2bc0fbc45baa2077b125c881cbf/07_Legacy_spec.B_FrontSeat.jpg They updated the gauges. I don't know if I like them or not.... The car seems to have a more Euro-look though... I guess I like it! It has a little MPG meter, just like the older Euro cars (like old BMWs and Benzs).. Hahaha.. That's not MPG that's a torque meter [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
KA81 Posted April 13, 2006 Share Posted April 13, 2006 i know it's still early but im curious as to what the ECU tune options there will be, if it's possible at all and is the 6 speed an improvement or is it just for show? something about longer/shorter gears got me all confused ...lol Link to comment Share on other sites More sharing options...
The B4 Posted April 13, 2006 Share Posted April 13, 2006 i know it's still early but im curious as to what the ECU tune options there will be, if it's possible at all and is the 6 speed an improvement or is it just for show? something about longer/shorter gears got me all confused ...lol If it's the same as the STI you will have: 1) to shift more 2) High RPMS at highway cruising speed 3) added weight from the heavier trans I had my friend's STI on Sunday. if the Spec B is geared the same... it will be a disappointment for those wanting fuel economy. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted April 13, 2006 Share Posted April 13, 2006 Fuel economy? What the hell is that? Link to comment Share on other sites More sharing options...
The B4 Posted April 13, 2006 Share Posted April 13, 2006 The one feature that I actually think is "blah" is the SI-Drive. Really, all it does is change the sensitivity of the Throttle position sensor. In Sport mode, it acts just like the current GTs, in Sport Sharp mode, it acts like an STI which can be had with a TDC protune map if you have an AP. In "Intelligent" mode, it softens the curve. It's NOT like getting an AP because it doesn't actually increase the performance of the engine, just the response to input. I wonder if this feature will still work with an AP, or if it will even make the AP less compatible Not true... The SI-Drive controls the electronic throttle system’s response and fuel and ignition curves to modify engine torque characteristics, changing the performance character of the car in each mode... It does shift points, throttle control, AND actual engine management. If Cobb can crack it... this will be AWESOME for map switches. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
kanoswrx Posted April 13, 2006 Share Posted April 13, 2006 Well with a Manual Tranny I don't really see the point of "SI" you can control pretty much all of that with your right hand and your right foot. I have driven both a STI and of course my LGT, the STI tranny is nice. I would very much like to drive the new spec b and see how the power/handling are different with the new lsd and vdc. But the 5 speed on the lgt is also really nice, so I am not going to cry over it. Not true... It does shift points, throttle control, AND actual engine management. If Cobb can crack it... this will be AWESOME for map switches. Link to comment Share on other sites More sharing options...
Jon in CT Posted April 13, 2006 Share Posted April 13, 2006 If it's the same as the STI you will have: 1) to shift more 2) High RPMS at highway cruising speed 3) added weight from the heavier trans I had my friend's STI on Sunday. if the Spec B is geared the same... it will be a disappointment for those wanting fuel economy.The 2007 spec.B does weigh 115 lbs more than the 2006 version. However, we still don't know gear ratios or EPA fuel economy numbers. The ECO button is said to improve fuel economy by up to 10% over the 2006 version. Link to comment Share on other sites More sharing options...
axis008 Posted April 13, 2006 Share Posted April 13, 2006 That's not MPG that's a torque meter While I don't want to argue with you, it looks like "MPG" when zoomed in. Not going to rule out torque, though, of course.. -ben Link to comment Share on other sites More sharing options...
Ken S Posted April 13, 2006 Share Posted April 13, 2006 So, anyone know how VDC works with the viscous coupling? I thought it needed VTD to work the way it was designed (ie. change torque split before applying brakes independently). Ken Link to comment Share on other sites More sharing options...
Ken S Posted April 13, 2006 Share Posted April 13, 2006 Also noted on the spec sheet "6-speed manual (modified from Impreza® WRX® STI®) ". What's been modified? Ken Link to comment Share on other sites More sharing options...
Two-Five Sti-L Posted April 13, 2006 Share Posted April 13, 2006 ^^ Its stated to have different gear ratios tuned specific to the L. Link to comment Share on other sites More sharing options...
axis008 Posted April 13, 2006 Share Posted April 13, 2006 ^^ Its stated to have different gear ratios tuned specific to the L. What he said ^. Also, the STis now have carbon-plated double-cone syncs on 4th through 6th gears. I don't think the spec.B will get that. -ben Link to comment Share on other sites More sharing options...
redline76 Posted April 13, 2006 Share Posted April 13, 2006 You can't please every one all the time. FWIW, I think many of the complaints on this board about the C/G Legacy have been addressed in this car; it remains to be seen how much carries over to the Ltd trim line. It's nice, but at the price point of the C/G Spec B I'm not sure it's the value leader anymore over the competition like the '05 was when it first came out. Looking at the March sales figures, I guess I understand why they dropped the 5spd wagon, and why there's a rumor SOA might drop the wagon entirely: Only 411 wagons sold out of a total of 7642 Legacies (5%!). Bummer nonetheless. Link to comment Share on other sites More sharing options...
psucaptainkickass Posted April 13, 2006 Share Posted April 13, 2006 Ok, so how much HP/TQ do I tell people my LGT comes with?? 250/250, or the <cringe> lower numbers. Also, are COBB's dyno charts for stage 1, 2, SAE corrected? I don't have them in front of me, sometimes they note that on the dyno graph. I am Stage 1, soon stage 2 so it really doesn't matter. Link to comment Share on other sites More sharing options...
Jon in CT Posted April 13, 2006 Share Posted April 13, 2006 Looking at the March sales figures, I guess I understand why they dropped the 5spd wagon, and why there's a rumor SOA might drop the wagon entirely: Only 411 wagons sold out of a total of 7642 Legacies (5%!). Bummer nonetheless.You're not too good with numbers. Subaru sold 2,219 non-Outback Legacy cars last month and about a third of them (~737) were wagons. http://i2.tinypic.com/sxljpf.jpg Link to comment Share on other sites More sharing options...
The B4 Posted April 13, 2006 Share Posted April 13, 2006 While I don't want to argue with you, it looks like "MPG" when zoomed in. Not going to rule out torque, though, of course.. I was looking at something totally different... my bad. [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
gfxdave99 Posted April 13, 2006 Share Posted April 13, 2006 what im trying to figure out is what that little display is on the bottom of the tach If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
gfxdave99 Posted April 13, 2006 Share Posted April 13, 2006 what im trying to figure out is what that little display is on the bottom of the tach if you go to www.subaru.com they have flash animations on the 07 lgt and the 07 sti http://www.subaru.com/sub/misc/2007/spec.B/index.html in the flash animation it shows you that its just a cute lil chart looking thing that shows you what mode your knob is in.. Also it still has heated seats but with the joy knob taking over that space i wonder where the controls for them are i cant see them on the new stereo or anywhere else.. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
gfxdave99 Posted April 13, 2006 Share Posted April 13, 2006 Not to post whore but i also just noticed that it comes with memory seat for the driver, about (*@&@(* time. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
Tommyh Posted April 13, 2006 Share Posted April 13, 2006 Not to post whore but i also just noticed that it comes with memory seat for the driver, about (*@&@(* time. ...I really do not understand the point of this. I could possibly see the use of it if two or more people of vastly different sizes switch off driving the same car very often, but who does that? Martin Luther - "Who loves not women, wine and song remains a fool his whole life long." EL4NFZT7 Link to comment Share on other sites More sharing options...
gfxdave99 Posted April 13, 2006 Share Posted April 13, 2006 ...I really do not understand the point of this. I could possibly see the use of it if two or more people of vastly different sizes switch off driving the same car very often, but who does that? Because seat position is also preference, not simply dictated by size and body shape for one. Good for husband/wife But why i really wish i had it, was every time i take my car to the dealer, or anywhere where somebody else drives the car (parking in the city etc) they ALWAYS *@& with the seat and then i spend 10 minutes tyring to get it back to the way i had it. If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
SWP-LegacyGT Posted April 13, 2006 Share Posted April 13, 2006 +1 for heated seats button. Link to comment Share on other sites More sharing options...
