dynamic80 Posted March 9, 2006 Share Posted March 9, 2006 I was also planning to change both my 5EAT and rear dif. Any particular brandnames I should be looking for, for auto trannies. Also is there a write-up for it. This is my 1st subie and do not want to mess anything up, especially dealing with Honda's back then... Flame on! Link to comment Share on other sites More sharing options...
mccorry Posted March 9, 2006 Share Posted March 9, 2006 I'm going with Secialty Formulation's MTL-R (actually designed for transaxles w/hypoid differential) and their HDS-5 in the rear diff. I swapped in the MTL-R into the transmission 2 nights ago. I have approx. 200 miles on the new oil and I don't notice any improvements over the stock fluid thus far. Actually it is almost exactly the same feel..... Link to comment Share on other sites More sharing options...
gfxdave99 Posted March 9, 2006 Share Posted March 9, 2006 Is it possible to change too soon? i only have 10k on but would like to swap anyway would it be harmful? If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
tundwgn Posted March 9, 2006 Share Posted March 9, 2006 Is it possible to change too soon? i only have 10k on but would like to swap anyway would it be harmful? Just like engine's, gearbox's (break-in) as well. I just changed mine to MOBIL 1 Synthetic 75/90W. With only 5900 miles my gear oil looked fair, I could see sparkles in the sunlight, which indicates to me that the gear oil was tainted with (gear). Nothing bad, just observation. I still need to change over the front diff oil. Does anyone know what size the torx drain plug is for the front, it looks pretty big?? Thanks Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 9, 2006 Share Posted March 9, 2006 Doesn't the trans feed the front diff? Link to comment Share on other sites More sharing options...
2Simpletons Posted March 10, 2006 Author Share Posted March 10, 2006 It's a T70 TORX...do a google search...I got mine on eBay. And yes, the trans does feed the front diff. Link to comment Share on other sites More sharing options...
tundwgn Posted March 10, 2006 Share Posted March 10, 2006 Doesn't the trans feed the front diff? See Page 11-35 in book. Front diff gear oil level, totally different sump than auto transmission sump. Requires API CLASSIFICATION GL-5. Auto transmission fluid is different type of fluid than a gear lube. Link to comment Share on other sites More sharing options...
mccorry Posted March 10, 2006 Share Posted March 10, 2006 MT = same oil sump for front diff and gearbox.... AT = separate sumps for front diff and valvebody.... Link to comment Share on other sites More sharing options...
AWDxBOOST Posted March 30, 2006 Share Posted March 30, 2006 okay...so is it cool to use NS in the rear diff? no one answered that Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 31, 2006 Share Posted March 31, 2006 See Page 11-35 in book. Front diff gear oil level, totally different sump than auto transmission sump. Requires API CLASSIFICATION GL-5. Auto transmission fluid is different type of fluid than a gear lube. Maybe I'm confused- my WRX had a manual trans and the front diff was fed by the trans. Link to comment Share on other sites More sharing options...
mccorry Posted March 31, 2006 Share Posted March 31, 2006 You are right, Jedi.... he is talking about an AT car.... Link to comment Share on other sites More sharing options...
outahere Posted April 3, 2006 Share Posted April 3, 2006 NS has Non-Slip additives that slow down the synchros and help them grab better - apparantly this is what our Subarus tranny's need. I guess guys have used various types of syn fluid and blown sychros out...kinda scary. Not quite correct. The NS gear oil from Redline has no limited slip additives. The standard gear oil (75W90) from Redline does contain limited slip additive, and is not generally recommended for synchronized transmissions. Link to comment Share on other sites More sharing options...
AWDxBOOST Posted April 3, 2006 Share Posted April 3, 2006 No, don't use the redline NS in the rear diff actually xenonk just told me otherwise... Link to comment Share on other sites More sharing options...
Th3Franz Posted April 3, 2006 Share Posted April 3, 2006 I think I have NS in my rear diff.. don't think it matters. It's viscous, so it just needs a fluid of the right weight. -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
outahere Posted April 3, 2006 Share Posted April 3, 2006 okay...so is it cool to use NS in the rear diff? no one answered that In the LGT rear diff you can use the Redline NS or non-NS. In the 5MT trans use the NS version. Link to comment Share on other sites More sharing options...
The_Condor Posted April 3, 2006 Share Posted April 3, 2006 I've used 75/90 NS in my 2.5RS and it worked well for a while. Then after about 10k miles or so the 1st gear grinds started to come back. You 02+03 WRX owners should know exactly what I'm talking about. If I were to do it again I'd use redline MT90 instead which is what I'll use in my GT when the time comes. I think the NS doesn't provide enough friction for those synchros and nothing sucks more than 1st gear grinds or grinds while quickly shifting. From reviews I've read the MT90 works better than the NS... my 2 cents Link to comment Share on other sites More sharing options...
edmundu Posted April 3, 2006 Share Posted April 3, 2006 I've used 75/90 NS in my 2.5RS and it worked well for a while. Then after about 10k miles or so the 1st gear grinds started to come back. You 02+03 WRX owners should know exactly what I'm talking about. If I were to do it again I'd use redline MT90 instead which is what I'll use in my GT when the time comes. I think the NS doesn't provide enough friction for those synchros and nothing sucks more than 1st gear grinds or grinds while quickly shifting. From reviews I've read the MT90 works better than the NS... my 2 cents So long as you are aware that Subaru calls for a GL5 spec fluid, which the MT90 is not. It's a GL4, which means it has about half of the required EP/AW additives. There are 2 Co's I know of with oil's specifically designed for hypoid transaxles like ours, Specialty Formulations Inc. & Silkolene. I'm running the SF MTL-R oil & love it! Link to comment Share on other sites More sharing options...
Vimy101 Posted July 28, 2006 Share Posted July 28, 2006 Fascinating thread. I'm going to be switching to full synthetic fluids throughout the car over time so thanks to all for your thoughts. It there a transmission filter on the MT that needs to be changed out? Link to comment Share on other sites More sharing options...
deneb Posted July 28, 2006 Share Posted July 28, 2006 It there a transmission filter on the MT that needs to be changed out? Nope. Link to comment Share on other sites More sharing options...
derffred Posted September 8, 2006 Share Posted September 8, 2006 okay... no one said the QUANTITY of oil... i wanna go to the store now to get some gear oil but i don't know how much to buy lol Link to comment Share on other sites More sharing options...
caramall2 Posted September 9, 2006 Share Posted September 9, 2006 "Search" function is your friend. http://legacygt.com/forums/showthread.php?t=35674&highlight=fluid+quantities Link to comment Share on other sites More sharing options...
derffred Posted September 22, 2006 Share Posted September 22, 2006 just to let everyone know.. i used Pennzoil GL-5 75-90 gear oil anndddd it feels the same as stock... maybe even a bit worse lol.. driving is fine, but at an idle, changing gears (just playin around) it's all ratchety.. i checked my fluid level and it's okay Link to comment Share on other sites More sharing options...
JuxtaGT Posted October 11, 2006 Share Posted October 11, 2006 I've been using the SF MTL-R stuff for 15k miles now. Something is wrong, I have speed & power sensitive whine from the transmission (5mt). Going to switch to the redline stuff and see if it goes away. Has not affected fuel mileage or drivabilty, but I"m concerned, transmission problems are EXPENSIVE. Car is at 33k miles total now. Link to comment Share on other sites More sharing options...
itsme Posted October 12, 2006 Share Posted October 12, 2006 When I had my WRX we would add a quart of GM syncromesh fluid. I made WRX trannies shift much better and easier to get into 1st. Would that make our car shift better? Racer X FMIC for '05-'09 LGTs, '08+ WRX and '10+ LGT,'14+ FXT, and '15+ WRX TMIC Racerxengineering.com Link to comment Share on other sites More sharing options...
klnyc Posted December 5, 2006 Share Posted December 5, 2006 What brand of gear oil does Subaru use? Whats the closest to OEM brand? Sorry about the noobie q's Link to comment Share on other sites More sharing options...
