SBT Posted October 9, 2018 Share Posted October 9, 2018 Continuing our server optimization. V2 is found in the site archives. Post up new your new replies. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted October 9, 2018 Author Share Posted October 9, 2018 Yeah puke fest indeed. The PCV hose connection is not my idea of a good seal with that connector/o ring. Last one I replaced was because I pushed on the head vent crossover inlet to hard and and ripped it, always try to at minimum tie wrap all of these connections. I'm running a hose clamp on the BOV inlet. Running my third at this point after that mishap and the first blowing out the rubber to plastic at the turbo side. I converted all of my IM vac-, water- and fuel-lines to Oetiker clamps. A much better seal and eliminates the need for zipties on all of the factory clamps/connections. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 9, 2018 Share Posted October 9, 2018 Yes and they eliminate the fitment issues having a worm gear to rotate to get into an orientation that can be reached later or buried. Was having conniption fits looking for the right clamps during the motor build. Bought way too many worm gear style and still may go back to Oetiker in the future. Issue I was running into was figuring the correct ID to fit the OD of the hoses since the free range kit is a larger OD than stock. Thought one of the kits was I picked up was Oetiker and ended up being a crush style clamp that never was used. Link to comment Share on other sites More sharing options...
lilredwagon Posted October 10, 2018 Share Posted October 10, 2018 I just used worm clamps on everything and t-bolt clamps on the ones that come off frequently. Worm clamps are fine if you're not removing them a lot, and if you need an extra seal, the Aquanet trick works. Link to comment Share on other sites More sharing options...
WRX USA Posted October 10, 2018 Share Posted October 10, 2018 I got the crank position sensor replaced so hopefully my trip back up to Portland from the Bay Area will be uneventful. It’s the only issue that I’ve had with the new motor after 12k miles. Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 10, 2018 Share Posted October 10, 2018 They do go bad. Had that happen to the ex with the step sons in the car heading over the grape vine back to norcal. Car when into limp mode. They pulled over. Called me. Luckily I left the V2 access port in the car. After instructing them how to plug it in and look at the codes. It was sending the code for the crank or cam sensor. Good thing it decided to stay stable after an ECU reset and get back to the house. Parts ordered and replaced never came back. Link to comment Share on other sites More sharing options...
WRX USA Posted October 10, 2018 Share Posted October 10, 2018 (edited) I’m fairly sure it was the original one swapped over to my new motor so 147k total on it. It was getting to the point where starts were intermittent. This morning it didn’t start so I attempted to roll start it in the driveway and ran out of hill so I reset the ECU and it started up. Also, I’ve been driving my dad’s Model S for the last couple of weeks and transitioning back to my car has been interesting. You definitely can’t zip around with an EWG like you can in the Tesla...people get mad. Edited October 10, 2018 by WRX USA Link to comment Share on other sites More sharing options...
rebourne Posted October 11, 2018 Share Posted October 11, 2018 I shouldn't be thinking thoughts like this, but does the full Q300 exhaust fit? I know I'd have to use longer hangers to clear the bumper (I am using longer ones right now anyways). pic thread build thread Link to comment Share on other sites More sharing options...
Acerguy Posted October 15, 2018 Share Posted October 15, 2018 My favorite YT auto diagnostician, Ivan at Pine Hollow Auto Diagnostics, has a new Outback-specific video today! (He has an excellent video on replacing Subaru CV boots which I've posted several times before) Link to comment Share on other sites More sharing options...
Ashchetum Posted October 15, 2018 Share Posted October 15, 2018 I am shopping coilovers > Probably going with the outback-specific BC's unless anyone else has suggestions. Link to comment Share on other sites More sharing options...
Acerguy Posted October 15, 2018 Share Posted October 15, 2018 I've been curious about the Feal "max travel" coilovers. They don't show up on their web page but I've had some conversations with them and they do make a Legacy/OB application. http://feal-suspension6.mybigcommerce.com/coilovers-max-travel-441/?sort=featured&page=1 Link to comment Share on other sites More sharing options...
WRX USA Posted October 15, 2018 Share Posted October 15, 2018 Installed all new wipers. https://www.amazon.com/dp/B005JU5VUK/ref=cm_sw_r_cp_tai_T.rXBbV2RCHMW https://www.amazon.com/dp/B001KS6FPA/ref=cm_sw_r_cp_tai_IasXBb4B78AMW https://www.amazon.com/dp/B005JU5X6M/ref=cm_sw_r_cp_tai_-asXBbG4CFMXM Link to comment Share on other sites More sharing options...
WRX USA Posted October 16, 2018 Share Posted October 16, 2018 I've been curious about the Feal "max travel" coilovers. They don't show up on their web page but I've had some conversations with them and they do make a Legacy/OB application. http://feal-suspension6.mybigcommerce.com/coilovers-max-travel-441/?sort=featured&page=1 Here are the non max-travel 441’s, http://feal-suspension6.mybigcommerce.com/feal-441-coilovers-05-09-subaru-outback-xt/, no mention of how much lower than stock they are. Link to comment Share on other sites More sharing options...
me73 Posted October 21, 2018 Share Posted October 21, 2018 Bought a 2007 head unit with auto climate on ebay. Made my own adapter harness for AUX from instructions and installed the AUX cable port next to the cig lighter in the arm rest cubby. Link to comment Share on other sites More sharing options...
bigleben Posted October 22, 2018 Share Posted October 22, 2018 Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 24, 2018 Share Posted October 24, 2018 Just Broke In... YNANSB. Received a GS AOS and considering a Fluidampr 531101 Engine Damper but so many spensives on the latter. Have an old Toyota Tacoma in the shop right now putting a new head on it. May need to wait a bit on the pulley but it's making me nervous at 210K Miles on the OD. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 25, 2018 Share Posted October 25, 2018 Confused. Is your engine toast or not? Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 25, 2018 Share Posted October 25, 2018 (edited) YNANSB was for Big Ben. Motor is working well since rebuild. Wanting to try an AOS solution after going with forged pistons. I've been having some sporadic incidents of excessive blow by causing DAM to dip to .875. Least that's my theory at this point. What was interesting is after swapping the stock IC to the GS I had one hose clamp tail touching the splitter. This may have been triggering some of the sensed knock and dipping my DAM. It hasn't come back after moving the clamps and making a slightly longer BOV hard splice hose. I was finding the clamps were not getting enough bite with the provided hard section between the GS BOV elbow and the Free Range BOV hose. Also have been warming it up a bit more before heading out on the road so it may be a combination of factors. DAM has been stable for weeks now. The GS AOS seemed to be worth an attempt for a easily reversible AOS because Cali. Now that the Toyota is back on the road I can rip into the XT and take my time. Due for Spark Plugs and some TLC. I want to get the Cobb Catted DP and 3port BC on board for a tune by the end of the year. Edited October 25, 2018 by kzr750r1 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 25, 2018 Share Posted October 25, 2018 Gotcha. After I swapped my intake hose, I began contemplating using an AOS too. I mean, it does not look like I have excessive blowby at all. But still, the idea of having a bit of oil being mixed with fuel is just not good. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 25, 2018 Share Posted October 25, 2018 Interesting comment from KillerB about AOS found here: I have my own reservations about any unit that uses 'media' as a means for separating. Any media (or baffle for that matter) is going to inhibit flow from the crankcase. This means increased crankcase pressure, which is bad! It can effect ring seal (blow-by, oil consumption and power potential). Crankcase vacuum is what you should be striving for as it has benefits with no downsides (well except for paying for an AOS). Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 25, 2018 Share Posted October 25, 2018 (edited) AOS debate and how is endless,, with PCV, without PCV, Catch Can, Return drain with and without a coolant loop. It's like the Oil Thread, there is no "right" answer for all. Preference would be to remove the intake connection all together but then there is more to revert back to stock every two years. Killer B is one way without a coolant loop. No solution for LGT. Bummer... IAG is another with a coolant loop and a huge can to displace factory wire loom and bending break hard lines for install. Nope... The above is more a mention of catch can solutions like Crawford? I don't want to manage a catch can. Nor do I have the time or energy to keep pulling more parts out and reverting to stock every two years.... GS solution seems like a decent compromise. I just hope it reduces the intake gurgle and degrading my tune. We shall see. Edited October 26, 2018 by kzr750r1 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 25, 2018 Share Posted October 25, 2018 Yeah. If I were to go that route, I would certainly consider GS too. Less maintenance and actually pretty 'easy' on the wallet. Link to comment Share on other sites More sharing options...
jkaic Posted October 26, 2018 Share Posted October 26, 2018 Decided to give 'er some TLC. Wash, clay, compound, polish, wax, all with consumer products and a harbor freight DA. Compound took the most time but i'm happy with the results. 1 Link to comment Share on other sites More sharing options...
xt2005bonbon Posted October 26, 2018 Share Posted October 26, 2018 That looks great! Which lip is this? Link to comment Share on other sites More sharing options...
kzr750r1 Posted October 26, 2018 Share Posted October 26, 2018 Nice shine. Is this your version of a winter setup? No steelies? I'm loving the monochrome paint schemes with the satin black running board detail. My car is the two tone brilliant silver with the darker silver on the plastic. If I can ever find the time and energy to repaint all of them brilliant silver. It will be done. Question to you guys is what paint can be used for the satin black that is durable? I may even start with new bumper guards since mine are pretty hacked and the rear hatch step is pretty faded from the sun. Link to comment Share on other sites More sharing options...
