Andyjo Posted August 7, 2008 Share Posted August 7, 2008 Does anyone know which side is bank 2? P0021 is bank 2? I'm going to order a new valve, but don't want to order two... Link to comment Share on other sites More sharing options...
PhilT Posted August 7, 2008 Share Posted August 7, 2008 Does anyone know which side is bank 2? P0021 is bank 2? I'm going to order a new valve, but don't want to order two... It would be better to replace both at the same time IMHO, if one is failing, the other one won't be far behind. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Andyjo Posted September 3, 2008 Share Posted September 3, 2008 So i replaced both OCV's and still have the CEL.. have driven ~ 500 miles since the change out.. i guess i'll give it another oil change and hope that helps... Link to comment Share on other sites More sharing options...
Tangur Posted September 14, 2008 Share Posted September 14, 2008 I was getting the P0021 with Cobb's Stage 1, Stage 2 and now got the same thing with PDX's custom map. So seeing PhilT's misadventures and his datalogging, I decided to do the same thing. So here a run little run in which I get quite a difference between the OCV duty left and right. Am I due for new OCVs? If the car is still under warranty you think I could get them for free? (Don't know how to explain to the dealer how I knew it was the OCVs that were defective though! without telling him about the AP). If the dealer option is a no-no, can I order online or I still have to buy from the dealer?ecuExplorer 13-09-2008 20h03m05s.pdf Link to comment Share on other sites More sharing options...
PhilT Posted September 14, 2008 Share Posted September 14, 2008 Have you had any other symptoms, rough idle, stumbling at low rpm ? How many miles on the car ? You may have a hard time getting them done under warranty, depending how many mods you have done. The cheapest I found them was through Jeremy at KoP, half the price of what the dealer charges here. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Tangur Posted September 14, 2008 Share Posted September 14, 2008 No rough idle, no stumbling and around 15K on the car. Do you think it could be that? Did you take a look at the log? Thanks for getting back to me so quickly Phil. Link to comment Share on other sites More sharing options...
PhilT Posted September 14, 2008 Share Posted September 14, 2008 Most likely is the OCVs, but 15,000 is very soon for one to start acting up. When you take a log, also log the advance angle so that you can compare it to the duty cycle. You could swap them over and see if the situation reverses, then you will know for sure. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Andyjo Posted October 7, 2008 Share Posted October 7, 2008 So this might be the super-stupid check... but check to make sure the OCV's are plugged in..... I may have had this issue... =( Link to comment Share on other sites More sharing options...
puzzled Posted October 17, 2008 Share Posted October 17, 2008 Driving home today the P0021 CEL appeared for me. I am at 73.5K miles. I have not data logged the car yet to see if this is the case, but from everything I read, chances are good that I am going to have to replace the OCV's too. I took them out and cleaned them, and changed the oil and it still came back. The tip on bending the bracket worked great, but man that is a beefy bracket. Link to comment Share on other sites More sharing options...
Razor Posted June 6, 2009 Share Posted June 6, 2009 Would you ever see this code (P0021) with cylinder misfires? I'm getting the rough idle when coming back from high rpm's, but my AP is getting cylinder misfire codes as well.. Link to comment Share on other sites More sharing options...
PhilT Posted June 6, 2009 Share Posted June 6, 2009 Yes, misfires can happen due to this. Easiest way to figure out what is going on is by taking some logs. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Razor Posted June 7, 2009 Share Posted June 7, 2009 Can I log with my APv2 ? Or just watch one of the 'live tests' ? How would I do this? Link to comment Share on other sites More sharing options...
mrjk77 Posted June 28, 2009 Share Posted June 28, 2009 ahhh... ok i just threw the the P0021 code. sounds like everyone is cleaning/replacing the OCVs. CEL came on at about 60000. i cleared it with the AP and was fine for another ~1k miles. today CEL came on again with the rough idle. noob question...i tried logging with my APv2, but when i click to log, the AP says its not logging and does the AP pick up the necessary parameters anyway for this problem? Link to comment Share on other sites More sharing options...
mrjk77 Posted June 29, 2009 Share Posted June 29, 2009 update: well i took out the driver's side OCV, cleaned it, and threw it back in. let the car idle for about 10 minutes and everything seemed fine so i went out for a drive. didn't really make it 1 block until i started getting the rough idle. stalled 4-5x. threw some misfire codes to boot. just ordered two new OCVs from FredBeans (I thought they were cheap enough to warrant getting both) and they'll arrive here tomorrow. Link to comment Share on other sites More sharing options...
mrjk77 Posted June 30, 2009 Share Posted June 30, 2009 got my new OCV today. replaced the driver's side one; car runs great now...no problems at idle. if you need this part, get it at fredbeans. Link to comment Share on other sites More sharing options...
DrSpeed Posted July 16, 2009 Share Posted July 16, 2009 I was getting the P0021 with Cobb's Stage 1, Stage 2 and now got the same thing with PDX's custom map. So seeing PhilT's misadventures and his datalogging, I decided to do the same thing. So here a run little run in which I get quite a difference between the OCV duty left and right. Am I due for new OCVs? If the car is still under warranty you think I could get them for free? (Don't know how to explain to the dealer how I knew it was the OCVs that were defective though! without telling him about the AP). If the dealer option is a no-no, can I order online or I still have to buy from the dealer? Where do you guys get the cables from the OBD2 to PC? http://www.obd2cables.com/products/obd-cables/obd-ii-cables/cable-j1962m-right-angle-to-db9f-4-3-ft.html http://www.obd2cables.com/products/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/1/4/142201_700x700.jpg BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
PhilT Posted July 16, 2009 Share Posted July 16, 2009 Search on eBay for a VAG com cable, about $15 Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
F-WDC Spec B Posted July 16, 2009 Share Posted July 16, 2009 Sounds like what happened to me. Luckly i was still under warranty. They changed the sensor and im still at stage 0. and i dont plan to flash untill im ready for stage 2. Link to comment Share on other sites More sharing options...
DrSpeed Posted July 17, 2009 Share Posted July 17, 2009 The Part # for the OCV is 10921AA020 The right side OCV was a struggle to get it out past that bracket, but it did come, I think I loosened off the bracket first. Thanks for the part number.... Search on eBay for a VAG com cable, about $15 Does it matter if it's USB or Serial? Just wondered how the software is written for the ecuEXPLORER. thanks! And please forgive all my newbie questions. BANNED FROM THE TIKI FORUM. Link to comment Share on other sites More sharing options...
LGT_King Posted September 2, 2009 Share Posted September 2, 2009 Bumping this because a lot more cars are having this issue Link to comment Share on other sites More sharing options...
holter95 Posted September 25, 2009 Share Posted September 25, 2009 Had the symptoms: CEL (P0021), rough idle, hesitation at tip-in. Pulled the Bank 2 (driver side) OCV out and cleaned it with WD40 - didn't seem to work. Replaced OCV the next day ($95 from local dealer). Car runs like new, CEL never returned. Old part was noticably stickier than new. Likely the passenger side will need it in the future. Installation notes: Easy to replace - just a 10mm socket and possibly a small flathead to help with the wiring harness. You will need to pull a coolant hose off the head to get the part out, so best done when the engine is cool. A little oil will leak out of the OCV socket so make sure you wipe it up so you don't get smoking. The passenger side looks a bit tighter, so I can see where you might need to bend the bracket. Link to comment Share on other sites More sharing options...
nka Posted October 21, 2009 Share Posted October 21, 2009 How does my log look ? I'm not sur to understand if it's OK or not ? edit: I made a graphic, seems ok to me...romraiderlog_20091020_202016.pdf Link to comment Share on other sites More sharing options...
Rummy Posted November 12, 2009 Share Posted November 12, 2009 Just had my left OCV replaced at 56k miles. I hope the other one kicks it before my powertrain warranty expires. Link to comment Share on other sites More sharing options...
rawl2k6 Posted January 5, 2010 Share Posted January 5, 2010 yeah...so i'm a late bloomer and i own a 08 lgt with about 19k and i have the same problem with the CEL p0021. i can see what you guys are talking about and i want to change it but don't know what OVC means or stands for. a little help please? also is the part # the same for 08 as previous models and was that part # for fred beans? Link to comment Share on other sites More sharing options...
NatesGr8 Posted January 5, 2010 Share Posted January 5, 2010 I'm getting p0011 every time i turn my car off then back on. I can clear it and it will stay off until i restart the car. I'm at over 100K, gonna try cleaning the ocv's tonight. If that doesn't do it does anyone think i might be because i haven't changed my timing belt yet? I'm not driving the car now, and gonna order the new belt and water pump from fred beans. Link to comment Share on other sites More sharing options...
