GTEASER Posted July 22, 2016 Share Posted July 22, 2016 Good job KZR!!!! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Max Capacity Posted July 22, 2016 Share Posted July 22, 2016 Great to hear it's alive. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 23, 2016 Author Share Posted July 23, 2016 Ok that's twice now. A little smoke on startup. Yet. Startup after not a puff. I'm going to just drive the thing. Keep it under 10lb of boost and get these rings seated. Keep a close eye on fluids. Yada yada... Was watching DAM sit at 1 in town and on the freeway. It's been a min. What other monitors should I keep an eye on? Need to get the AP upgraded to V3. Link to comment Share on other sites More sharing options...
FJuan Posted July 23, 2016 Share Posted July 23, 2016 Just watch you coolant temp and oil pressure during your break in period. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 23, 2016 Author Share Posted July 23, 2016 Temp can do. Pressure is mechanical gauge inside the engine bay. I do have pressure so the gauge was a good feedback item to have. Just replaced the front endlinks and checking fluids before heading to the east bay. Will probably do and oil change later this weekend. Crack this filter open to check for Debris. Need to purge some old fuel out. Still at half a tank after placing 5 gallons of new in it. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 23, 2016 Share Posted July 23, 2016 IMO keep off the highway for the first few hundred miles so you keep the rpms from being constant...if you can. You are carrying a gallon of coolant with you for a while... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 24, 2016 Author Share Posted July 24, 2016 I'm not carrying extra coolant. Going to poke around a little once it cools off. Can smell coolant but could be just from what little I spilled on the head. That and the little ATF and gear oil spills make for an interesting potpourri. Had to barrow some spanners and tighten up the ball joint capture bolts. Forgot to tighten them down. Now the front end sounds normal. Link to comment Share on other sites More sharing options...
FJuan Posted July 24, 2016 Share Posted July 24, 2016 Sounds good, time to wash the motor and see if anything is leaking after a few days of driving. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 25, 2016 Author Share Posted July 25, 2016 Fine shimmery oil dropped out after first change. 300 miles on it. Will drop again after this tank is run through. Seems to be running fine so far. Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 27, 2016 Author Share Posted July 27, 2016 Second oil change and turbo filter cleaned out. 650 miles. Still shimmery was hoping this would clear by now. Will be changing again in the morning Thursday. By then it will have around 800 miles is on the clock. I have to drive up to El Dorado Hills and back Friday. My normal commute to San Jose is around 110 miles round trip. EDH and back is around 220 is round trip. Can't take surface streets on some of these legs. Still running well. Link to comment Share on other sites More sharing options...
FJuan Posted July 27, 2016 Share Posted July 27, 2016 I had the same shimmery oil after my rebuild. It wasn't until my 3rd oil change when I didn't see it again, around the 1,000 mile mark. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 27, 2016 Author Share Posted July 27, 2016 Ok. Makes me feel a little better. TY! Link to comment Share on other sites More sharing options...
GTEASER Posted July 27, 2016 Share Posted July 27, 2016 And just in case you're going to be doing any Blackstone reports, on both my GT when it was new, and the Fozz after the rebuilt engine, both had high levels of copper (which gave me a heart attack) on the tests for the oil that was in the car from 5k miles to 10k miles. It was within normal ranges both before and after that 10k mile oil change. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 28, 2016 Author Share Posted July 28, 2016 Thought about it but not right now. It's either going to fail soon or be good to go for a while. After another 175 mile day I'm going to drop the oil again. Need to wait for the store to open though. Need more oil. After changing the Tacoma, 3 or 4 quarts going in and out of the prelube injection, first and second Oil change, going for number 3, I'm down to 3 quarts out of two cases. Good ol Costco needs to sell Rotella instead of Mobile 1. But the chevron will work fine for break in. Link to comment Share on other sites More sharing options...
StkmltS Posted July 28, 2016 Share Posted July 28, 2016 Rotella T6 is usually competitively priced on Amazon Prime. My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
GTEASER Posted July 28, 2016 Share Posted July 28, 2016 Pretty sure Walmart has T6. I get my Castrol Edge there, best price by far. Got my last 5 quart jug for $24.xx after tax. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 28, 2016 Author Share Posted July 28, 2016 I may start using Amazon. It's about the only reason I walk into Wallyworld. Had to go pick up some Castrol at Monument this morning so I can keep dropping a pan a day. Will head through Costco today and grab another case of Chevron. Daughter hates going to Costco. Need to prep for the long trip Friday to EDH. I want another 150 mils down and change before this. Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 29, 2016 Author Share Posted July 29, 2016 Two more cases on oil in house. Need need some more filters, will pick them up Saturday. I have two left. Third change was still shimmery but after this trip to EDH will have over 1000 miles on the motor. Noticing the same boost flutter and really wish Mike would return my emails. Ordered the V3 AP. Should be here Monday. Link to comment Share on other sites More sharing options...
SBT Posted July 29, 2016 Share Posted July 29, 2016 ordered the v3 ap. Should be here monday. v3-ap002? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
kzr750r1 Posted July 29, 2016 Author Share Posted July 29, 2016 v3-ap002? Using the trade in option while I can. Will be nice to have a couple more monitors present while driving. Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 3, 2016 Author Share Posted August 3, 2016 (edited) Soon as I install the v3 and set it up, I see DAM dropped to .75 after this last tank. Never going to that station again. New I was in trouble when the pump was running slooooooowwww. Just means their filters are clogged and no telling what I put in the tank. Didn't drive today. Will be moving around this week for sure. Still need to pick up some more oil filters. On another sideways note. My mom broke down and found a 2016 Outback 2.5i Limited for a decent deal. So she bought it. Edited August 3, 2016 by kzr750r1 Link to comment Share on other sites More sharing options...
FJuan Posted August 3, 2016 Share Posted August 3, 2016 Soon as I install the v3 and set it up, I see DAM dropped to .75 after this last tank. Never going to that station again. New I was in trouble when the pump was running slooooooowwww. Just means their filters are clogged and no telling what I put in the tank. Didn't drive today. Will be moving around this week for sure. Still need to pick up some more oil filters. On another sideways note. My mom broke down and found a 2016 Outback 2.5i Limited for a decent deal. So she bought it. You may see this for a while until you get a tune, some of the parameters are off and needs to be readjusted. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
GTEASER Posted August 3, 2016 Share Posted August 3, 2016 Get a fricking tune man!!!! GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
kzr750r1 Posted August 4, 2016 Author Share Posted August 4, 2016 I'd love to have a tuner with me right now but unresponsive till yesterday. To fill out a word doc of the same information I already used to ask for support. So I'm skeptical at this point. DAM flipped back to 1.0 just as I was leaving town today. Link to comment Share on other sites More sharing options...
StkmltS Posted August 4, 2016 Share Posted August 4, 2016 What tuner are you using? My DiySB rebuild Got Misfires? Link to comment Share on other sites More sharing options...
