fredrik94087 Posted November 20, 2014 Author Share Posted November 20, 2014 im going up 2 more psi I think I will need to be prepared with an upgraded fuel pump has anyone tested the waters on this and know which pump will bolt in? Ejection seat is mandatory...good luck! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Perscitus Posted November 24, 2014 Share Posted November 24, 2014 Some 'blast from the past' (circa 2008 and 2014 update) inspiration for all of our H6 brethren... ItalianLegacy I'm looking mainly at you boy! Then again, who am I fooling? You don't need any further inspiration. The beast is coming along very nicely. http://forums.nasioc.com/forums/showthread.php?t=1437246 http://forums.nasioc.com/forums/showpost.php?p=20928237&postcount=22 Link to comment Share on other sites More sharing options...
KFCConspiracy Posted November 26, 2014 Share Posted November 26, 2014 As soon as they say they're available I'm ordering... I have arranged install and a dunno tuNE already. Link to comment Share on other sites More sharing options...
Perscitus Posted November 28, 2014 Share Posted November 28, 2014 Cold and semi-warm start video of the headers/header-back exhaust: Warm start and some revving @ 2:06. Plus nstg8r's brake flasher mod toward the end of each section (when I applied the brake). Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 1, 2014 Author Share Posted December 1, 2014 Some 'blast from the past' (circa 2008 and 2014 update) inspiration for all of our H6 brethren... ItalianLegacy I'm looking mainly at you boy! Then again, who am I fooling? You don't need any further inspiration. The beast is coming along very nicely. http://forums.nasioc.com/forums/showthread.php?t=1437246 http://forums.nasioc.com/forums/showpost.php?p=20928237&postcount=22 I wish I could get a better intake manifold with a larger TB...wish!!! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 3, 2014 Author Share Posted December 3, 2014 Just imagine if there was a 3" inlet direct bolt on DBW throttle body... If you had a better intake manifold with a larger TB is in the works, I would send a deposit right now! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Perscitus Posted December 4, 2014 Share Posted December 4, 2014 My oh my! Such a tease.... http://shop.amrperformance.com/AMR-Performance-teams-up-with-Raptor-Superchargers_b_11.html Link to comment Share on other sites More sharing options...
nstg8r Posted December 4, 2014 Share Posted December 4, 2014 My oh my! Such a tease.... http://shop.amrperformance.com/AMR-Performance-teams-up-with-Raptor-Superchargers_b_11.html 3 years, almost 60K miles on my car and one of my mufflers is only a year old due to the accident... Dunno if I could afford it all anyway. Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 5, 2014 Author Share Posted December 5, 2014 (edited) My oh my! Such a tease.... http://shop.amrperformance.com/AMR-Performance-teams-up-with-Raptor-Superchargers_b_11.html Yikes!!! Do I even dare? Will it hold up to constant beating around the track? Okay, okay, slow down Fredrik. Headers and a tune next year, try to lighten up that Piggy a little, and call it a day! Edit: Okay, mmmmmaybe you can look into a lowered final drive ratio. Second Edit: off-topic. I checked my oil today (3,000 miles), and I haven't lost a single drop. I will be changing at 5,000 miles. I will let you guys know then. Edited December 5, 2014 by fredrik94087 "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
nadracer Posted December 8, 2014 Share Posted December 8, 2014 (edited) The EZ30 and the EZ36 are very similar and the EZ30D from the early 2000 model H6 has an aluminum intake manifold. If one of those can be picked from a junker there is a high possibility it'll fit. Then you could possibly get them port matched; EZ30D manifold and the EZ36 throttle body. If you had a better intake manifold with a larger TB is in the works, I would send a deposit right now! Edited December 8, 2014 by nadracer Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 8, 2014 Author Share Posted December 8, 2014 The EZ30 and the EZ36 are very similar and the EZ30D from the early 2000 model H6 has an aluminum intake manifold. If one of those can be picked from a junker there is a high possibility it'll fit. Then you could possibly get them port matched; EZ30D manifold and the EZ36 throttle body. Thanks but in the end I'd want a larger TB. Highly doubtful that I would find one easily, but I will keep an eye out. I fear it may need to be extrude honed just to match the size of the plastic one we have now. I cant imagine it having larger runners mated to a smaller engine. And the heat is another factor. I would love a manifold TB combo made for the 3.6. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
stevenc1703 Posted December 12, 2014 Share Posted December 12, 2014 Raptor Superchargers for Subaru's 10 hours ago · With some kind of finality - the Ez30 and EZ36 headers will arrive in Aust on Dec 22, however we arent sure we will get them until the first week of Jan Will keep everyone posted So a little delay but that's cool I'll be a little more financially ready then. Link to comment Share on other sites More sharing options...
SleeperWagon Posted December 14, 2014 Share Posted December 14, 2014 Anybody know if a 6 speed swap has been done on a 3.6r yet? Link to comment Share on other sites More sharing options...
stevenc1703 Posted December 14, 2014 Share Posted December 14, 2014 Anybody know if a 6 speed swap has been done on a 3.6r yet? None that I know of but there might be a 3.6r 6 speed build out there, just not in a 5th gen. Link to comment Share on other sites More sharing options...
Perscitus Posted December 14, 2014 Share Posted December 14, 2014 The tranny bolts right up supposedly. PnP, sans the 5EAT wiring harness and TCU disable. Go back a page for a link to NASIOC EZ36D swaps into previous-gen STIs. They used 6MTs and turbo'ed the H6s. AMR has done a good bunch of these swaps too, for DD and race/auto-x customers. Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 15, 2014 Author Share Posted December 15, 2014 Anybody know if a 6 speed swap has been done on a 3.6r yet? Don't get me started!!! As Perscitus said, it does bolt up. New Zealand has a 2.5GT with a 5EAT. A=B (6-speed // 2.5GT), B=C (2.5GT // 5EAT), so A=C (6-speed swaps with 5EAT) "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted December 15, 2014 Share Posted December 15, 2014 Don't get me started!!! As Perscitus said, it does bolt up. New Zealand has a 2.5GT with a 5EAT. A=B (6-speed // 2.5GT), B=C (2.5GT // 5EAT), so A=C (6-speed swaps with 5EAT) E-tuning a guy in Australia with a 2010 LGT with the 5eat. Tuned him last year (stage 1) is now going stage 2. Many more parameters to play with in ECUFlash versus the usdm 3.6R, aside from the turbo related parameters. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
Perscitus Posted December 15, 2014 Share Posted December 15, 2014 E-tuning a guy in Australia with a 2010 LGT with the 5eat. Tuned him last year (stage 1) is now going stage 2. Many more parameters to play with in ECUFlash versus the usdm 3.6R, aside from the turbo related parameters.Very interesting, thanks for sharing. How much btq or wtq did it put down at Stage 1? Will be great to know what the 5EAT here sees as he goes Stage 2 too. Link to comment Share on other sites More sharing options...
McDowell Performance Tunin Posted December 18, 2014 Share Posted December 18, 2014 I'll have to dig up some old data logs and see what I can find. His car has a Cobb catted down pipe now. For stage 1, he already had the racer-x tmic. www.facebook.com/mcdowelltuning [sIGPIC][/sIGPIC] Click Here for Stage1, Stage2 and Stage3 Tuning and eTuning Info Link to comment Share on other sites More sharing options...
Aeterna Posted December 20, 2014 Share Posted December 20, 2014 Ok so im really wanting to hear the power plant we have under our hoods. Buuut i definitely dont want to listen to a drone for 30k miles a year. So does anyone know of any ABE that can be had for a healthy exhaust note? If i have to get raptor headers then you gotta do what you gotta do i suppose. Link to comment Share on other sites More sharing options...
Perscitus Posted December 20, 2014 Share Posted December 20, 2014 If you're thinking ABE, pickup something from Nameless Performance or perhaps Magnaflow/Borla mufflers. You shouldn't introduce any excess drone with an ABE alone. You'd need to change the mid-pipe/y-pipe or other components to do that on the 3.6R, especially in terms of ID and overall length. But, in case the ABE proves too much at certain RPMs (especially those loved by the EZ36D+5EAT combo), then either add a Vibrant resonator upstream (as far up as you can) or consider a helmholtz resonator j-pipe (see Fredrik's build). Both will mellow things down a good order of dBs. PS - If ARK ever offered an ABE for the 3.6R, I'd vote ARK GRIP hands down... Link to comment Share on other sites More sharing options...
Aeterna Posted December 21, 2014 Share Posted December 21, 2014 (edited) Awesome thanks this would fit aye? http://www.arkperformance.com/ProductDetails.asp?ProductCode=SM1302-0210G Edited December 21, 2014 by Aeterna Link to comment Share on other sites More sharing options...
Tradewind Posted December 22, 2014 Share Posted December 22, 2014 Raptor - SS Headers be ready for shipping in 2 weeks to any 3.6 owner wanting them Merry Xmas to all Link to comment Share on other sites More sharing options...
fredrik94087 Posted December 23, 2014 Author Share Posted December 23, 2014 Raptor - SS Headers be ready for shipping in 2 weeks to any 3.6 owner wanting them Merry Xmas to all If I dood it, I get a whoopin'. I really want a set for next track season. Sponsor? It will be after April. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
ItalianLegacy Posted January 17, 2015 Share Posted January 17, 2015 has anyone ever run a compression test on their 3.6R that can post their results? Link to comment Share on other sites More sharing options...
