ItalianLegacy Posted February 4, 2015 Share Posted February 4, 2015 Thanks for your update, Italian. Is the fix as simple as a new seal and put the OEM pulley back on? And, if the seal is going to wear out, would it not wear faster with the OEM pulley? that's exactly how simple It Is ☺ Link to comment Share on other sites More sharing options...
ItalianLegacy Posted February 4, 2015 Share Posted February 4, 2015 Can it be removed and replaced without removing anything else other than the crank pulley? yes Link to comment Share on other sites More sharing options...
nstg8r Posted February 4, 2015 Share Posted February 4, 2015 that's exactly how simple It Is ☺ yes Thanks. So, other than leaking oil, there was no other damage done other than to the seal and pulley, correct? Would it make sense to just monitor it and wait for leaks instead of just swapping out everything now? I check my oil level at least twice a month, so I can just add that to my routine. Link to comment Share on other sites More sharing options...
Perscitus Posted February 4, 2015 Share Posted February 4, 2015 I will likely remove it and do a visual inspection - if its not bad or I just see faint grooves, then I will likely keep it on. Potentially use the new seal while at it. The Infiniti/Nissan forums suggest that once it starts, the oil leak is significant ~1qt/week. The accessory/serpentine belt 'helps' to distribute it and bathe the engine bay. Link to comment Share on other sites More sharing options...
Tidal Posted February 4, 2015 Share Posted February 4, 2015 It's a bummer to see this happening but I'm glad there is a cheap solution. Best of luck to all! Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 4, 2015 Author Share Posted February 4, 2015 In all fairness, just one of us has experienced this so far. More of us will chime in and keep you guys posted. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
stevenc1703 Posted February 5, 2015 Share Posted February 5, 2015 This is gonna bug me, i might have to check mine today. Thank God for a garage. Link to comment Share on other sites More sharing options...
stevenc1703 Posted February 5, 2015 Share Posted February 5, 2015 Would the introduction of boost cause an increase of crank case pressure leading to a leak? I'm not the most informed when it comes to turbos and superchargers. If my memory serves Italian just recently upped his boost a little and possibly saw the limit to boost that our engine can take. Link to comment Share on other sites More sharing options...
ItalianLegacy Posted February 5, 2015 Share Posted February 5, 2015 no because of this issue we didn't proceed with more boost. but now that it's fixed.... Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 5, 2015 Author Share Posted February 5, 2015 Stevens comment had to do with the introduction of boost...not added boost. I was wondering that too, but suppose for a moment that my car with no boost revs up in 2nd gear as Italians with boost in 3rd. That rush of revolutions building up is identical and shouldnt be a factor. If we compare apples to apples...3rd to 3rd, then you can argue the engine sees a faster build of rpms in each gear because it makes more power. This would wear things out a bit more quickly, but I dont know if it is enough. It could be a combination of things or it could be just the fact that aluminum should not interface with the seal. I doubt that everyone with this issue on the infiniti forum was boosted. I will have a look under the car this weekend. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
stevenc1703 Posted February 5, 2015 Share Posted February 5, 2015 I tried my hardest to get the pulley off but that bolt isn't moving. I see no oil leaks and i don't see any reason to risk breaking something just to see if i have a problem. Also i looked at my old pulley and i see the same marks that are on Italians prs pulley. I know the seals are good and I'm sure the wear marks are there on the prs pulley but unless you guys find something I'm not touching it. http://tapatalk.imageshack.com/v2/15/02/05/8cdaffe383d2093fd086c9ffa5ddb61c.jpg Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 5, 2015 Author Share Posted February 5, 2015 Perscitus, please give me a link to your post with the headers and dyno. I want to add it to the first page. I can find it on Google cached page but there is no post number on it, so I can't link it. I am seriously considering doing this sooner than later. I am also contemplating supercharger, but I'm trying really hard not to. Thanks! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Perscitus Posted February 5, 2015 Share Posted February 5, 2015 Pics: http://legacygt.com/forums/showpost.php?p=4959651&postcount=994 http://legacygt.com/forums/showpost.php?p=4960336&postcount=1006 Dyno Plot: http://legacygt.com/forums/showpost.php?p=4959653&postcount=995 Videos: http://legacygt.com/forums/showpost.php?p=4960065&postcount=1005 I will have more pics up soon, showing the whole exhaust setup upstream of the catback/resonator. Link to comment Share on other sites More sharing options...
Aeterna Posted February 5, 2015 Share Posted February 5, 2015 Perscitus, please give me a link to your post with the headers and dyno. I want to add it to the first page. I can find it on Google cached page but there is no post number on it, so I can't link it. I am seriously considering doing this sooner than later. I am also contemplating supercharger, but I'm trying really hard not to. Thanks! Do a Rear-Mount Twin-Turbo setup! go big or go home right? it can be called the "Suparu" Link to comment Share on other sites More sharing options...
nstg8r Posted February 5, 2015 Share Posted February 5, 2015 Also i looked at my old pulley and i see the same marks that are on Italians prs pulley. I'll take a look at my OEM pulley and see if it looks similar. Will report back later tonight or tomorrow. Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 5, 2015 Author Share Posted February 5, 2015 Thanks, Perscitus. I did a quick and dirty update on the first page. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 5, 2015 Author Share Posted February 5, 2015 I ordered the TB...I am highly doubtful, but we shall see if we can make it work. If not, I'll sell it. Wish me luck. It is going to be a long and slow process. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Perscitus Posted February 5, 2015 Share Posted February 5, 2015 (edited) I'm thinking of picking this one up and having it cleaned, port/polished by MaxBore, installed and tuned for @ AMR: http://www.ebay.com/itm/361133044034?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Edited February 5, 2015 by Perscitus Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 5, 2015 Author Share Posted February 5, 2015 I thought of the same thing but to send to stigmeier(sp). Cheers! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Perscitus Posted February 5, 2015 Share Posted February 5, 2015 Purchased! I called the seller and it looks like the donor car was a 2013 Legacy 3.6R with less than 1K miles on the ODO before being totaled. I also got a reply back from MaxBore: Hello. I can work on your TB. The total for the TB work as you want it done is $144. TB port/polish, new larger butterfly valve, shaft machining (flush with new butterfly) and a custom/resized gasket. The plenum work is if you want to remove the intake manifold and have the plenum opening machined as well, but that's not really needed in your case. No spacer work either since you don't have one. Here are some pics of TBs he's done, including some old WRXs: http://www.maxbore.com/pictures.html Link to comment Share on other sites More sharing options...
fredrik94087 Posted February 5, 2015 Author Share Posted February 5, 2015 Funny, I also asked them about the plenum when I called on Monday. I may, ahem, need a used TB from you, Perscitus. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
nstg8r Posted February 6, 2015 Share Posted February 6, 2015 http://tapatalk.imageshack.com/v2/15/02/05/8cdaffe383d2093fd086c9ffa5ddb61c.jpg My old pulley has that "polishing" where the seal was but not the grooves. Link to comment Share on other sites More sharing options...
Perscitus Posted February 6, 2015 Share Posted February 6, 2015 I'll have a look at my OEM pulley too when I get to my Storage location. Link to comment Share on other sites More sharing options...
JLGT Posted February 6, 2015 Share Posted February 6, 2015 The oem pulley will show the same lines except the difference is the strength of the metal, so no grooves on oem. The aftermarket pulleys will need to be steel sleeved. I brought up the issue with infamous on the 2.5gt pulleys and he said the metal they use is CNC machined 6061 T6 aluminum, so he stated they wouldn't need to be sleeved. I would check with the maker of the 3.6 pulley and see what they say. Link to comment Share on other sites More sharing options...
nstg8r Posted February 6, 2015 Share Posted February 6, 2015 The oem pulley will show the same lines except the difference is the strength of the metal, so no grooves on oem. The aftermarket pulleys will need to be steel sleeved. I brought up the issue with infamous on the 2.5gt pulleys and he said the metal they use is CNC machined 6061 T6 aluminum, so he stated they wouldn't need to be sleeved. I would check with the maker of the 3.6 pulley and see what they say. According to their website, the PRS pulleys are made of Duralumin. Link to comment Share on other sites More sharing options...
