DJMajickMan Posted April 14, 2014 Share Posted April 14, 2014 Shweeeet, thanks! The AB portion are the parts I'd actually like to keep, but it's all welded :/ Sounds like you're both right, and it'll be cheaper/easier just to get a new setup. Better yet....more money in your pocket might be to sell the existing working unit in tact vs praying to make it work. In other wards put it for sale Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 17, 2014 Author Share Posted April 17, 2014 I logged using EcuTek and sent to William (Delicious Tuning). This may take a while and I'm not sure if I have provided the correct parameters nor useful logs. I'll let you know when I know. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 23, 2014 Author Share Posted April 23, 2014 Quick feedback on two items before my senses get dull and I can't tell anymore. 1. DBA rotors and Hawk street pads with Goodridge brake lines: I got everything installed except for rear rotors a week ago. Within a few days, I could tell that the fronts had more grip. If I were to put a number on it, I'd say 20 to 30%. The rear with OEM rotors and Hawk pads were not holding enough. I could feed the weight of the car leaning forward. A few days ago, the rear DBA rotors were installed. Now, there is a very "slight" brake bias toward the rear compared to OEM. It feels great. Front and rear brakes feel firmer and hold better with NO noise. 2. Front Kartboy endlinks and whiteline 26mm polyurethane bushings. Initial feel of wheel pushing back against the car on hard corners. Front got firmed up. The bit of slight klunking over bumps at low speeds is almost all gone or non-existent. Not sure which of the two helped, but it's a lot better. Two issues. 1. Kartboy front endlinks would not mate up with 3.6R bar. I had to use several whiteline endlink spacers, and I needed longer bolts...maybe 3/4" longer. 2. Whiteline no longer makes a 26mm FSB service kit. And, there are none in stock in several places I checked. I took the bushings from a Whiteline LGT 26mm FSB. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
ItalianLegacy Posted April 25, 2014 Share Posted April 25, 2014 Raptor just emailed me asking if I would test fit the headers on our 3.6. I said YES! Link to comment Share on other sites More sharing options...
Tidal Posted April 25, 2014 Share Posted April 25, 2014 Raptor just emailed me asking if I would test fit the headers on our 3.6. I said YES! Blaze on brutha Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 25, 2014 Author Share Posted April 25, 2014 Funny. I checked my email today and there was one from raptor asking if I want to order headers for their next build cycle. I think Italian got the better offer. Or, he made them an offer they couldn't refuse. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
GTEASER Posted April 25, 2014 Share Posted April 25, 2014 Damned Italians!! They alway beat the rest of us to some good pussy. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
ncfree Posted April 25, 2014 Share Posted April 25, 2014 Funny. I checked my email today and there was one from raptor asking if I want to order headers for their next build cycle. I think Italian got the better offer. Or, he made them an offer they couldn't refuse. Ask then if you could also be one of the test fitters for them and that you know their secrets.. Blackmail should work right? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 25, 2014 Author Share Posted April 25, 2014 Ask then if you could also be one of the test fitters for them and that you know their secrets.. Blackmail should work right? Sent from my iPhone using Tapatalk I'll try it with a Chicago accent "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 28, 2014 Author Share Posted April 28, 2014 Baby steps...I just flashed my ECU with first map from Rob at AMR. I will create a new set of logs and we shall iterate. It all seemed so hard and complicated at first, but he patiently walked me through it. I will hopefully have some numbers in a week or two. Cheers! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
DJMajickMan Posted April 28, 2014 Share Posted April 28, 2014 Baby steps...I just flashed my ECU with first map from Rob at AMR. I will create a new set of logs and we shall iterate. It all seemed so hard and complicated at first, but he patiently walked me through it. I will hopefully have some numbers in a week or two. Cheers! So does this mean you can provide step by step instructions for the rest of us 3.6 owners Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 28, 2014 Author Share Posted April 28, 2014 So does this mean you can provide step by step instructions for the rest of us 3.6 owners Sure...piece of cake when you've done it once. Like most things in life. There is a youtube video by some tuner for a Nissan GT-R, but my GUI was a little different than his. By the way, this is an e-tune. For a lot of us, this may be the way we have to go as EcuTek programmers are not always in our area. When all is said and done, I'll make a vid and post it with a link on the first page...a few weeks away. Cheers! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Tidal Posted April 28, 2014 Share Posted April 28, 2014 Are you using the Tactrix Openport or something else? Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 28, 2014 Author Share Posted April 28, 2014 Are you using the Tactrix Openport or something else? Not sure...it is straight from EcuTek "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
DJMajickMan Posted April 28, 2014 Share Posted April 28, 2014 Not sure...it is straight from EcuTek how much was that? Link to comment Share on other sites More sharing options...
KFCConspiracy Posted April 28, 2014 Share Posted April 28, 2014 Funny. I checked my email today and there was one from raptor asking if I want to order headers for their next build cycle. I think Italian got the better offer. Or, he made them an offer they couldn't refuse. An interesting offer none-the-less. What's their site btw? My Google-fu seems to be weak on this one. Link to comment Share on other sites More sharing options...
DJMajickMan Posted April 28, 2014 Share Posted April 28, 2014 An interesting offer none-the-less. What's their site btw? My Google-fu seems to be weak on this one. http://www.raptorsc.com.au/models.php?id=6 Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 28, 2014 Author Share Posted April 28, 2014 how much was that? I don't remember off-hand. I bought cable, license and tune together. You should be able to get specific pricing from a tuner. "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
nstg8r Posted April 28, 2014 Share Posted April 28, 2014 So, you did an opensource tune using the ecutek cable? Link to comment Share on other sites More sharing options...
fredrik94087 Posted April 28, 2014 Author Share Posted April 28, 2014 So, you did an opensource tune using the ecutek cable? Not opensource. I contacted Rob at AMR. He is an EcuTek tuner. Everything is from and related to EcuTek. Going on dyno tomorrow morning for pull logs, hp/tq gains/losses, and AF numbers (for comparison to ECU). Cheers! Edit: Very stoked! "It's within spec" - SOA "Depth is only shallowness viewed from the side." - Fredism "So, how much did it cost for your car to be undriveable ." - Stephen (very close friend) "You have done so much it would be stupid to go back." - Sunny of Guru Electronics 2018Q50RS | 2015WrxThread | Shrek Link to comment Share on other sites More sharing options...
Perscitus Posted April 28, 2014 Share Posted April 28, 2014 Its likely more of an Ecutek etune using their cable and protune software. A great option for anyone away from Ecutek master tuners and dyno like Fredrik mentioned above. For us Rob, since AMR and others are local... Its easier to just stop by. No need for the cable and software in this case. Link to comment Share on other sites More sharing options...
feesh Posted April 28, 2014 Share Posted April 28, 2014 Not opensource. I contacted Rob at AMR. He is an EcuTek tuner. Everything is from and related to EcuTek. Going on dyno tomorrow morning for pull logs, hp/tq gains/losses, and AF numbers (for comparison to ECU). Cheers! Edit: Very stoked! Awesome Fredrik! Can't wait for the results. I'll be next in line for a 3.6R etune after you've blazed the trail. I will have to get off my ass and get the rest of my exhaust sorted out. Link to comment Share on other sites More sharing options...
nstg8r Posted April 28, 2014 Share Posted April 28, 2014 Not opensource. I contacted Rob at AMR. He is an EcuTek tuner. Everything is from and related to EcuTek. Okay, thnx. I had read this and was a bit confused: "By the way, this is an e-tune. For a lot of us, this may be the way we have to go as EcuTek programmers are not always in our area." I get it now tho; it's an emailed Ecutek tune. Link to comment Share on other sites More sharing options...
nstg8r Posted April 28, 2014 Share Posted April 28, 2014 For us Rob, since AMR and others are local... Its easier to just stop by. No need for the cable and software in this case. Yeah, AMR is a whopping 38 minutes drive for me. But since I'm invested in the Tactrix cable and have the opensource def files, I'd still be leaning in that direction if I ever decide to get tuned. Link to comment Share on other sites More sharing options...
DJMajickMan Posted April 29, 2014 Share Posted April 29, 2014 and I have an ecotek tuner that's local(under 30 miles) but they've never touched/seen a 3.6r to tune so I'd be the first. Link to comment Share on other sites More sharing options...
