N.Y.X. Posted September 15, 2013 Author Share Posted September 15, 2013 Tried to fix the headlights as much as possible from the last hack job... Did the 3m restore on the outside and used what was left on the inside of the lens after baking them. Some of the "chrome" was smeared off so I just blacked out all of it except the hi-beam shroud. Now just have to drill the holes in the bulb covers so the HID's will be sealed properly and they will at least be 2x better than what they were... http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130914_163703_525_zps36e1a551.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130914_163709_904_zps702ca503.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130914_194718_465_zps48c7d7bc.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 15, 2013 Author Share Posted September 15, 2013 Original: http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130705_121047_889_zps2a903e68.jpg After 3M headlight Resto: http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130705_125623_684_zps9563bf1f.jpg Baked, Re-Painted, Inside of Lens Buffed with remainder of 3M, Resealed: http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130917_071557_866_zps438e43c7.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130915_143814_799_zps340bf665.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 15, 2013 Author Share Posted September 15, 2013 http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130915_110337_008_zps022cada0.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130915_110446_166_zpsbf754256.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130915_115531_362_zpse8ab29e2.jpg Link to comment Share on other sites More sharing options...
solo413 Posted September 15, 2013 Share Posted September 15, 2013 Black grill looks nice, been thinking of doing mine as well, are you doing a wet sand on it for a smooth gloss black? Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 15, 2013 Author Share Posted September 15, 2013 I actually just plasti-dipped the whole thing, easy and no taping anything off! Link to comment Share on other sites More sharing options...
solo413 Posted September 15, 2013 Share Posted September 15, 2013 Nice might go that route as well! Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 15, 2013 Author Share Posted September 15, 2013 It's the best way as if you don't like it, you can just peel it off!! The trick is a lot of light layers. You want to make sure it's on thick in the end as that's the only way it peels properly. Link to comment Share on other sites More sharing options...
solo413 Posted September 15, 2013 Share Posted September 15, 2013 I didn't know that, i have not messed with the plasti-dip before Link to comment Share on other sites More sharing options...
solo413 Posted September 17, 2013 Share Posted September 17, 2013 Hey bro do you have any easy tricks for cylinder 4 plug replacement, I did pass side tonight but doing driver side tomorrow last time I did the plugs cylinder 4 was an hour of pure hell!! Lol Link to comment Share on other sites More sharing options...
N.Y.X. Posted September 17, 2013 Author Share Posted September 17, 2013 I used a "thumb" driver that worked really well with a knuckle and a spark lug socket. Seemed to be the perfect length. Mine isn't a rachet style (like the ones below) and has a much thinner grip because there is no mechanism: http://www.ebay.com/itm/New-3-pc-1-4-3-8-1-2-Palm-Thumb-Wheel-Drive-Ratchet-Set-Socket-Tool-/140862910898 [ame=http://www.amazon.com/Powerbuilt-640858-U-Joint-4-Inch-3-Piece/dp/B004QO9D9A/ref=sr_1_2?s=hi&ie=UTF8&qid=1379386530&sr=1-2&keywords=3%2F8+drive+joint]Powerbuilt 640858 U-Joint 1/4-Inch, 3/8-Inch, 1/2-Inch Drive Set, 3-Piece - Amazon.com[/ame] Link to comment Share on other sites More sharing options...
solo413 Posted September 17, 2013 Share Posted September 17, 2013 Thanks I'm c if I can get one tomorrow on my way home from work to do drivers side Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 2, 2013 Author Share Posted October 2, 2013 Dropping by SubaPerformance after work for them to weld in a wideband bung in my DP, installing everything Sat/Sun and going to get roadtuned by Cryo on tuesday!!! http://i1063.photobucket.com/albums/t503/childreth13/IMG_20130930_180426_127_zpsfe0606a8.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 4, 2013 Author Share Posted October 4, 2013 Boo http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131003_195940_007_zpsf5adf8a3.jpg Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 4, 2013 Author Share Posted October 4, 2013 Before my accident, this is what I was on the way to pick up... http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131004_165404_804_zpsceefdecb.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131004_165411_573_zpsfbc6b87c.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131004_165421_702_zpsbf4600e7.jpg Link to comment Share on other sites More sharing options...
Arielgt93 Posted October 4, 2013 Share Posted October 4, 2013 What?!!! What happened? Link to comment Share on other sites More sharing options...
solo413 Posted October 5, 2013 Share Posted October 5, 2013 That really sucks, hope u ok bro Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 5, 2013 Author Share Posted October 5, 2013 What?!!! What happened? That really sucks, hope u ok bro Thanks guys, I'm ok; some guy just didn't yield to me when I had the right of way. I slammed on the brakes and he punched it and just connected with his rear driver side wheel at probably under 30mph. I hope it all works out ok; but I'm still installing everything this weekend and getting tuned tuesday!! Link to comment Share on other sites More sharing options...
solo413 Posted October 5, 2013 Share Posted October 5, 2013 Thanks guys, I'm ok; some guy just didn't yield to me when I had the right of way. I slammed on the brakes and he punched it and just connected with his rear driver side wheel at probably under 30mph. I hope it all works out ok; but I'm still installing everything this weekend and getting tuned tuesday!! Glad u good bro! Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 6, 2013 Author Share Posted October 6, 2013 Man that stock uppipe is bullsh*t!!! http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131005_152219_099_zpsa2f4fa28.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131005_152241_835_zps7653c45e.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131006_111850_526_zps00e40a9e.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131006_111838_520_zps3f4c90a1.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131006_111906_377_zpse080fc87.jpg Link to comment Share on other sites More sharing options...
masta jer Posted October 6, 2013 Share Posted October 6, 2013 correct me if I'm wrong but i read on this site that the Perrin EL Headers "does not retain the boxer rumble" sound to our cars... This is the only reason I personally am thinking of steering away from it. Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 6, 2013 Author Share Posted October 6, 2013 That's correct. But it would not be the "boxer" sound that you're referring too, it would be the "unequal length header" sound. Porsche also uses a boxer engine and they don't have the sound you're referring to. For me it's about performance, not sound. Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 11, 2013 Author Share Posted October 11, 2013 Just got cryotuned!!! Couldn't be happier with my 91oct Stage 2!! Feels great! Link to comment Share on other sites More sharing options...
tocinoman25 Posted October 12, 2013 Share Posted October 12, 2013 love my perrin ELH also...its definitely the SOUND of power thats whats important...sounds sexy and beastly Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 14, 2013 Author Share Posted October 14, 2013 http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131014_111503_zpsd9f5e6ee.jpg Ordered new front bumper, headlight and random clips to start fixing the front end... Link to comment Share on other sites More sharing options...
N.Y.X. Posted October 17, 2013 Author Share Posted October 17, 2013 http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131016_175010_633_zps2b23b42a.jpg http://i1063.photobucket.com/albums/t503/childreth13/IMG_20131016_175019_257_zpsdadec9e5.jpg Link to comment Share on other sites More sharing options...
