Upgraded Brakes - Review & Pics
FJuan
It was time to replace the front rotors and pads. I'm known to be a little hard on the brakes and I tend to glaze the stock pads and rotors often. After reviewing of other brake threads on what's the best rotors and best pads were, I had a better idea on what to buy. Thanks for the reviews everyone!
Pics of my project.
DBA Slotted rotors - Hawk HPS Pads - Dupli-Color Black Caliper Paint
http://www.imagestation.com/picture/sraid225/p5870805dc9bc9041a8918b749f27b729/ea6b9b89.jpg
Difference in stock rotors (top) vs. DBA rotors (bottom)
http://www.imagestation.com/picture/sraid225/p0e59c6a7e034e0ae695de785b23dc9fc/ea6b9b2e.jpg
Before picture of stock rotor and pads
http://www.imagestation.com/picture/sraid225/pcd86a860853d360673b923b6bbb55063/ea6b9ae3.jpg
Cleaning of Caliper - using a toothbrush and caliper cleaner
http://www.imagestation.com/picture/sraid225/p38e546a5657383b8e5be285423876750/ea6b9a81.jpg
Painting of Caliper - The kit includes cleaner, paint and brush. After cleaning, the paint was very easy to apply, just brush it on. What 15 - 30 mins before appling second coat.
http://www.imagestation.com/picture/sraid225/p6750b7279bb1c62efba723c2c9f6c0f8/ea6b9a27.jpg
After Pics - DBA rotors installed after paint dried.
http://www.imagestation.com/picture/sraid225/p38d91f4eb8672ec846e33295806229f8/ea6b97af.jpg
The Final Look
http://www.imagestation.com/picture/sraid225/p4427b51af8a1dd648dad52d854170109/ea6b9732.jpg
After following the instructions for brake-in time and driving for 2 weeks on them now, I found this to be one of the best upgrades I've done. When the brakes are cold they feel good like stock, but after a few stops and they start to warm up that's when I feel the difference. They grab harder without putting more brake pressure down. That's a big plus for me. Another thing I notice are the slotted rotors, the more pressure I put down the more I feel the pads sliding over the slots. It feels like very light tappings on the sterring wheel, to me it's just a good reminder of how much pressure I'm using during braking.
Overall - this was money well spent
DBA rotors - $235
Hawks HPS - $75
Duli-Color Paint - $15
Final cost - $325
My wife's balls are delicious.
almost picked up the dba slotted, but decided to wait. the $700 60k service put a damper on that. would like to get them at a later time.
258k miles - Stock engine/minor suspension upgrades/original shocks/rear struts replaced at 222k/4 passenger side wheel bearings/3 clutches/1 radiator/3 turbos
where did you pick the dba's and hawks up?
DBA's
http://www.autopartswarehouse.com/performance/basket.php?makeid=31&modelid=502&year=2005&partid=78&brandid=3383&page=1
Excellent selections and prices.
Hawks
http://www.jscspeed.com/lgt/lgt_base.html
One of our vendors.
FYI - The DBA's I purchased were the standard slotted, not the 4000 series.
Edit:
One more thing. Stock rotor weighed 22lbs vs. DBA's rotor 20.5lbs.
1.5lbs lighter per front wheel.:)
Nice job, exactly what I want to do.
Just like you I often glazed the pads... The brakes work fine until they are out of their temp range (which is pretty low), then terrible fading and temporary warping.
I was hoping that HPS pads would be OK for me, do you feel that they can handle some hard stops from triple digit speeds?
I haven't tried the "triple digit speeds" yet, but from 85 they work great. :icon_bigg
How important is it to change the break rotor? Is changing the pads more noticable? I am coming up on having to get new pads soon. If I can get much better break perfromance by buying better pads, I will, but if to get much better breaking I need to replace pads and rotors, I won't bother. Suggestions? (for pads, I am not considering changing the rotors)
tires, suspension, pads, rotors, lines, fluid. The last 2 maybe not as important but they are relatively inexpensive mods.
As long as your rotors are in good shape, all you need are just pads then. I added the slotted rotors for looks and to help prevent glazing.
It's all about your driving style.
Pads would make the biggest difference in feel. Rotors would make the biggest difference in looks on the street.
On track however, the DBA 4000 series would provide better cooling as the vanes are specially designed to be better than the stock straight vane.
Note: We carry the 4000 series for LESS than the link above. We also have all kinds of differnt pads depending on your intended use. If you have any question at all, just ask. ;)
Free Sonax Cleaner Deal
http://www.brakeswap.com
Carbotech, Hawk, PFC, DBA Rotors, Motul, Wilwood, Castrol...
Great service. No bumping required :icon_tong!
with today's brake pad compounds, you wont have to worry about glazing... so slotted is no longer needed anymore.. in fact, from my testing, it's better with a blank rotor and run with brake ducts instead.
Keefe
Just curious as how long the stock rotors (or any modern rotors for that matter) would last with 85% daily driving and 15% track time?
Depends on driving style and pad compounds. It's too hard to just throw a general number out there.
You CAN still glaze pads! Depends on the compound. If it isnt the right temperature range, you can and WILL glaze pads. That or if youre using el cheapo pads, they will just fall apart.
I glazed my bobcats.........................on the street!:eek:
Now you tell me!
(I think I should charge for advertising on my thread):p
