Chris GTO TT Posted August 14, 2017 Author Share Posted August 14, 2017 Yeah that's why I drive a Ford Speaking of my Ford... http://legacygt.com/forums/showthread.php/07-explorer-255101.html?p=5673027#post5673027 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted August 14, 2017 Share Posted August 14, 2017 My Brother in laws Ford had a $10k rebuild, due to boost of 42 psi damaging the headbolts while towing up a hill. Unsure why it over boosted to 41psi. But, I think the common theme here is that turbos are terrible for longevity. Which Ford? 6.0? The 6.0 Powerstroke has a poor reputation, that IMHO, Ford has never quite shaken. Doesn't help that the newer Fords require cab removal for significant engine work. Sad, since the 7.3 was pretty much bulletproof. Of course we're talking turbo diesels here... The Ford engines with spark plugs don't ever have problems... especially with the spark plugs. Not ever... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 14, 2017 Author Share Posted August 14, 2017 The Ford engines with spark plugs don't ever have problems... especially with the spark plugs. Not ever... Sparkplug extraction is cheaper than ring replacement 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted August 14, 2017 Share Posted August 14, 2017 Sparkplug extraction is cheaper than ring replacement OK, you got me there... Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted August 14, 2017 Moderators Share Posted August 14, 2017 Modern diesels and all the tech that goes he with them scare the piss outta me. Use that warranty up and then time for another new truck! "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Rhitter Posted August 14, 2017 Share Posted August 14, 2017 Which Ford? 6.0? The 6.0 Powerstroke has a poor reputation, that IMHO, Ford has never quite shaken. Doesn't help that the newer Fords require cab removal for significant engine work. Sad, since the 7.3 was pretty much bulletproof. Of course we're talking turbo diesels here... The Ford engines with spark plugs don't ever have problems... especially with the spark plugs. Not ever... Pretty sure it was the 6.0 powerstroke. And it did require Cab removal for the engine work. My OBXT build Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 19, 2017 Author Share Posted August 19, 2017 Threw some LED headlight bulbs in this week... They're a little more blue than I'd like but still looks great! IMG_20170818_201734 by christobal65, on Flickr Also got a picture with the Exploder behind it. IMG_20170818_201845 by christobal65, on Flickr 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 19, 2017 Author Share Posted August 19, 2017 Took it to cars and coffee in Folsom and then drove home via the canyon and back roads. Trip as a whole took me all the way around Folsom Lake. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted August 19, 2017 Share Posted August 19, 2017 (edited) Nice. I really like the NB2 lights... I think when I replace the bumper on our '99 I'm going to swap over to the NB2 bumper cover and lights. Did you polish the lenses? If so, just curious what you used? I tried it on our 'Vette a few years ago, and the results were not very impressive. On the home front, took the new truck out to a CAT scale to get axle weights... and it weighs 8600lbs! 700lbs heavier than the '04. And I just bolted on another 112lbs (I weighed it) of trailer hitch! I also hooked up the trailer (empty) and towed it around for a bit to get some break in miles with light towing. I'm really impressed with the Aisin transmission in this thing. Getting up to highway speed is much smoother, and it doesn't do any hunting... just gets in the right gear and pulls. Combined with the exhaust brake, it also does a great job of maintaining speed downhill as well. I used to be a diehard manual fan for towing, but this thing is already changing my mind. The truck was pretty bored with 5000lbs of trailer. Went up the local radiator busting grade (7 miles of 6%) on cruise at 70... never even pulled max boost. Edited August 19, 2017 by rodan Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 19, 2017 Author Share Posted August 19, 2017 I have polished the lenses a few times. I'm a big fan of wet sanding, and polishing. If they are bad I start with 800ish grit then move to 1000 and finish with 2000 grit. Then I use a plastic polish like Plastix. Next time I plan to put on some clear Lamin-x covers on to help keep them clearer longer. Once the new house is finished I'll be able to park it inside so they shouldn't take as much abuse. Modern autos are truly amazing. The tow haul modes on them really work wonders, they are smarter and faster. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 21, 2017 Author Share Posted August 21, 2017 Hotel reservations made and registered for the track day on the Friday before Miatas @ MRLS. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted August 21, 2017 Share Posted August 21, 2017 Awesome! Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 22, 2017 Author Share Posted August 22, 2017 Awesome! I figured if you were coming from AZ I had better make the 4 hour drive 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted August 22, 2017 Share Posted August 22, 2017 I gotta look and see if we're coming in Thursday or Friday... can't remember. Are you staying for the Saturday events, or just doing the trackday on Friday? Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 22, 2017 Author Share Posted August 22, 2017 My current plan is to drive down Thursday afternoon, do the Friday track day, hang out at the track Saturday till about 2-3 and drive home. We may end up staying a extra day though. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted August 22, 2017 Share Posted August 22, 2017 We're coming in Thursday, so I'll look you up on Friday. We're camping in the Chaparral campground right outside the track. Link to comment Share on other sites More sharing options...
I Donated bucko3the7man Posted August 22, 2017 I Donated Share Posted August 22, 2017 Drove Jerry's miata at autocross this weekend, man I missed miatas. So much fun because of all the WOT. Link to comment Share on other sites More sharing options...
rodan Posted August 29, 2017 Share Posted August 29, 2017 Got my wife signed up for the Friday trackday after some frustration with the lack of communication from Trackmasters... Now I'm trying to find out if I can drop my trailer in the paddock Thursday night. Still haven't got an answer from Trackmasters, and no one at MRLS will pick up a phone... Link to comment Share on other sites More sharing options...
rodan Posted August 31, 2017 Share Posted August 31, 2017 Pro pics are in from Summer Camp... A little rain before the driver's meeting... FMSC17 Thurs 2 by Rodan AZ, on Flickr Wife in her NC... FMSC17 Thurs 5 by Rodan AZ, on Flickr Diving through the chicane... FMSC17 Thurs 1 small by Rodan AZ, on Flickr Yes, that's a little air under the right front... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 31, 2017 Author Share Posted August 31, 2017 I wish my car was half as nice as yours is:redface: 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted August 31, 2017 Share Posted August 31, 2017 Just remember... it's got no carpet, 1/2 a dash, no AC or heat and no stereo... Besides, your NB is definitely nicer than my NB... Yours runs! Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 31, 2017 Author Share Posted August 31, 2017 yeah but your shorty console and dash look great. Mine has AC half the time but then the compressor kicks off and stays off for 5 minutes. I have to cycle the button to get it to work again. I really need to pull the motor, replace a bunch of oil seals, the clutch and motor mounts. I probably also need replace the diff bushings. My transmission likes to stick in reverse on occasion and the exhaust is getting ready blow out the welds on the muffler. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
rodan Posted September 7, 2017 Share Posted September 7, 2017 So today I installed the sway bar in the truck... last equipment upgrade for the new truck to have it ready for camper duty. Here it is compared to a stock NA rear sway... DSC_0989 by Rodan AZ, on Flickr And I made an exhaust tip for MRLS. The Miata weekend is 105dB, but the Trackmasters day on Friday is 92dB. I think I'll make it, but just in case, from what I've seen this should be worth 1-2dB if I need it... DSC_0991 by Rodan AZ, on Flickr DSC_0992 by Rodan AZ, on Flickr And for giggles, I can go to bosuzoku car shows... Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 7, 2017 Author Share Posted September 7, 2017 Gotta love Laguna tips lol 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Chris GTO TT Posted September 8, 2017 Author Share Posted September 8, 2017 I actually drove mine for the first time in weeks lol 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
