Nolmers06LGT Posted May 3, 2013 Share Posted May 3, 2013 (edited) Polishing compound? Just a guess.. Edited May 3, 2013 by Nolmers06LGT Don't want anyone to mistake this as a legitimate explanation Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 3, 2013 Share Posted May 3, 2013 Duh, did you call Bryan yet ? Ask him. Haven't yet but I will. Figured I would ask here first since 100''s of these have been through the community already. Link to comment Share on other sites More sharing options...
Nolmers06LGT Posted May 3, 2013 Share Posted May 3, 2013 Haven't yet but I will. Figured I would ask here first since 100''s of these have been through the community already. Maybe, but don't you think Brian would know what goes into the turbos more than the consumers? People here are just going to guess since they don't actually know what it's even used for. Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 3, 2013 Share Posted May 3, 2013 Maybe, but don't you think Brian would know what goes into the turbos more than the consumers? People here are just going to guess since they don't actually know what it's even used for. Well, yea obviously. However I'm at my desk at work and most likely won't be able to call him today. Oh well. I'll attach a pic later tonight when I get home anyway. Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 3, 2013 Share Posted May 3, 2013 I wonder if I will be able to retain the heatshield bracket and therfore my GS turbo heatshield... I guess I'll find out soon enough. Link to comment Share on other sites More sharing options...
rkhousman Posted May 3, 2013 Share Posted May 3, 2013 (edited) Just looked at my BNR 16g as it is still on the shelf, didn't see any white stuff on any of the blades just what looks like a #2 on one of the inlet blades in sharpie. Edited May 3, 2013 by rkhousman Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 3, 2013 I Donated Share Posted May 3, 2013 I wonder if I will be able to retain the heatshield bracket and therfore my GS turbo heatshield... I guess I'll find out soon enough. Yes, you will be able to retain the bracket. It relies on the top two bolt holes on the turbo, which need to be identical to stock so the turbo mates with existing DPs. Link to comment Share on other sites More sharing options...
SBT Posted May 4, 2013 Author Share Posted May 4, 2013 So it (GS Shield) would work with the new BNR housing I presume is the question? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 4, 2013 I Donated Share Posted May 4, 2013 So it (GS Shield) would work with the new BNR housing I presume is the question? I don't see how it couldn't fit. The housing mounts in the same space as stock... Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 4, 2013 Share Posted May 4, 2013 Yes, you will be able to retain the bracket. It relies on the top two bolt holes on the turbo, which need to be identical to stock so the turbo mates with existing DPs. Good. I hadn't admired it long enough to notice if it did or not. Now to iron out stupid issues that have been bugging me before putting this bad boy in. Link to comment Share on other sites More sharing options...
m sprank Posted May 4, 2013 Share Posted May 4, 2013 No issues with heat shields fitting over the new housings. Link to comment Share on other sites More sharing options...
SBT Posted May 4, 2013 Author Share Posted May 4, 2013 Mike - including the OEM heat shielding (top/bottom, etc.)? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted May 4, 2013 I Donated Share Posted May 4, 2013 Mike - including the OEM heat shielding (top/bottom, etc.)? You need to trim the OEM heatshield anyway if you have an aftermarket DP... Link to comment Share on other sites More sharing options...
SBT Posted May 4, 2013 Author Share Posted May 4, 2013 True. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
fahr_side Posted May 4, 2013 Share Posted May 4, 2013 You need to trim the OEM heatshield anyway if you have an aftermarket DP... ...and there isn't an aftermarket DP out there with the brackets needed to secure the bottom half of the stock turbo heatshield. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 5, 2013 Share Posted May 5, 2013 I'll try and call Bryan tomorrow during lunch or something but here is what I'm referring to as well as a glamor shot Link to comment Share on other sites More sharing options...
Turkeylord Posted May 6, 2013 Share Posted May 6, 2013 My guess is that it's just a mark to help with the balancing process. It'll probably just burn off once you've run it a bit. Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 6, 2013 Share Posted May 6, 2013 I'll try and call Bryan tomorrow during lunch or something but here is what I'm referring to as well as a glamor shot So much want! Who you getting tuned by? Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
BryanBNR Posted May 6, 2013 Share Posted May 6, 2013 My guess is that it's just a mark to help with the balancing process. It'll probably just burn off once you've run it a bit. You are correct. That paint is picked up by a speed sensor on a balancer. Bryan@BNR Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 6, 2013 Share Posted May 6, 2013 You are correct. That paint is picked up by a speed sensor on a balancer. Bryan@BNR Awesome, I figured as much. Thanks Bryan! Link to comment Share on other sites More sharing options...
sjxbrd Posted May 6, 2013 Share Posted May 6, 2013 Just installed my 16G over the weekend. Getting tuned by Airboy on Wednedsay. Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 6, 2013 Share Posted May 6, 2013 So much want! Who you getting tuned by? I was going to go to Precision Tuning but I think I'm going to have Dave tune it again (Cryo). Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 6, 2013 Share Posted May 6, 2013 I was going to go to Precision Tuning but I think I'm going to have Dave tune it again (Cryo). Dang, I would probably use Precision so I was hoping to see what they get out of it for you. Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
mmmmspecb Posted May 6, 2013 Share Posted May 6, 2013 Dang, I would probably use Precision so I was hoping to see what they get out of it for you. IDK At this point I'm looking at $200 vs $500+ for a dyno tune from Precision. I'm not sure it's worth it on a bare bones 16G setup (I'll be running stock fueling). Link to comment Share on other sites More sharing options...
MaStaMooN Posted May 6, 2013 Share Posted May 6, 2013 IDK At this point I'm looking at $200 vs $500+ for a dyno tune from Precision. I'm not sure it's worth it on a bare bones 16G setup (I'll be running stock fueling). Yeah I hear that. Sent from my SCH-I535 using Tapatalk 2 Jon - vBGarage Profile Link to comment Share on other sites More sharing options...
