hadvw Posted July 14, 2013 Share Posted July 14, 2013 I disagree.. If you're running an aggressive stage 2 map/setup the 16g won't be a huge upgrade in performance. I definitely feel the additional power between 5200 and 6600, but it's not a huge increase and I lost a bit down low as well. I'm regretting not going bigger. I'll agree with both a little. A well tuned vf40 is just so quick to spool, it's fun around town, but man does it run out of steam after 5000.. The 16g is a noticeable increase up top, and not too bad down low. Once in a while, I wish it had more top end, but only once in a while. I know it's not exactly the same, but it's a little like when I went from my '84 Jetta GLI (1.8l 8v) to my '90 GTI (2.0l 16v). The GTI actually felt a little slower than the GLI at first, because it was so linear. The GLI just totally ran out of steam after 5500, so the initial hit felt bigger. I could just barely run it to the 6300 rev limiter in 1st. After that, it struggled to get past 6000, even in 2nd gear. After a rev-limiter-removing chip, the GTI would happily run to 7000 in 2nd and 3rd, and probably 4th, if I'd had a chance to test it. It was faster overall, but actually felt a bit slower. That's kind of how the 16g is - it doesn't hit as quick as the vf40, so it feels laggy, but it just keeps pulling, so overall, it's faster. After 3 years/34K miles with a bnr16g, do I wish I'd gone bigger? Every once in a while, but even on today's road trip of 300-400 miles, I really didn't have more than a handful of cases where an 18g or 20g would have been noticeably more fun. Whereas, in daily driving, the 16g is great because it spools quicker than the others. YMMV - it depends on where you live, how you're able/willing to drive, etc. I spend most of my life these days commuting from home to work and back, and driving kids to school. 20 years ago (can't believe I'm this old!), I would have totally gone 20g or more for the bragging rights. In the end, if it wasn't for the vf40 being a ticking time-bomb, I would have stayed with it, because it was great around town, which is where most of my driving is. However, after upgrading to a 16g + IP&T oil line, I sleep much better at night Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted July 14, 2013 Share Posted July 14, 2013 In the end, if it wasn't for the vf40 being a ticking time-bomb :spin: Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Schrei Wolf Posted July 14, 2013 Share Posted July 14, 2013 However, after upgrading to a 16g + IP&T oil line, I sleep much better at night This so hard. Though If you're doing a 16G you should really at least spend the extra $150 and get the DW65C just to give to you a little more. Link to comment Share on other sites More sharing options...
hadvw Posted July 15, 2013 Share Posted July 15, 2013 This so hard. Though If you're doing a 16G you should really at least spend the extra $150 and get the DW65C just to give to you a little more. Sorry, I was in a hurry and forgot the details. I did 16g + DW650cc + walbro (no 65C 3.5 years ago). I was one of the first people to upgrade to a bnr turbo.. Almost 35K miles later, still happy. Link to comment Share on other sites More sharing options...
JMLegacy Posted July 17, 2013 Share Posted July 17, 2013 Guys, i'm looking for a solution to convert a VF34 to fit to our VF40 style intercooler Would the part below work? http://www.ebay.com/itm/190525216262 http://i.ebayimg.com/t/Turbo-Compressor-Flange-Outlet-Adapter-2-Bolt-/00/$(KGrHqUOKp!E1qimg9(KBNr1jFblzQ~~_12.JPG Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 17, 2013 I Donated Share Posted July 17, 2013 Guys, i'm looking for a solution to convert a VF34 to fit to our VF40 style intercooler Would the part below work? http://www.ebay.com/itm/190525216262 Not sure there is any way to do that. The 02-07 WRX style turbos are clocked wrong, and if you reclock them in such a way that our TMIC will bolt up, I'm pretty sure it won't fit under the hood. Link to comment Share on other sites More sharing options...
JMLegacy Posted July 17, 2013 Share Posted July 17, 2013 I'm told it has been done over and over where I'm from. I seen at least one car first hand, an 05 Spec B Only issue is that the guy who did some of them wants to cut the outlet off my Good VF38, weld a rim to it and use a hose to join the VF34 to the intercooler. I don't want to spoil a good turbo like that :-/ Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 17, 2013 I Donated Share Posted July 17, 2013 Only issue is that the guy who did some of them wants to cut the outlet off my Good VF38, weld a rim to it and use a hose to join the VF34 to the intercooler. Well there you have it. It works... if you cut the outlet off and weld a new piece on. Link to comment Share on other sites More sharing options...
JMLegacy Posted July 17, 2013 Share Posted July 17, 2013 (edited) Lol. In the one that I saw, the mech used a hose to join the sti turbo outlet to the sawed off outlet . I dont wanna do that man. EDIT: Found a guy on here that used it. Here it is, but I'm awaiting his response to the name of the product. Only problem is It would be turned the other way. The flange would face the intercooler and the round side would face the turbo. http://legacygt.com/forums/attachment.php?attachmentid=139528&d=1358643498 So, you saying that with this piece connected it would raise the intercooler by an inch or so and come in contact with the hood? If I remember correctly, the Spec B I saw had his turbo clocked 90 degree facing the the other wheel, and a silicone hose ran under it and back up to the IC. I'm gonna buy the part and figure the rest out. Edited July 17, 2013 by JMLegacy Link to comment Share on other sites More sharing options...
510Finn Posted July 17, 2013 Share Posted July 17, 2013 Perhaps the flange bolts to the tmic and then a 90 degree elbow silicon hose is then connected to the uncut turbo outlet of the STi style turbo? Sent from my Nexus 4 using Tapatalk 4 Beta 08 Spec B details Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 17, 2013 I Donated Share Posted July 17, 2013 Found a guy on here that used it. Here it is, but I'm awaiting his response to the name of the product. That is the flange from a Process West kit. Different part. Link to comment Share on other sites More sharing options...
JMLegacy Posted July 17, 2013 Share Posted July 17, 2013 Can you find the link and post it please. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 17, 2013 I Donated Share Posted July 17, 2013 Can you find the link and post it please. What link? It's not sold separately AFAIK, if that's what you're asking. You have to buy the $982 intercooler to get it. Link to comment Share on other sites More sharing options...
JMLegacy Posted July 17, 2013 Share Posted July 17, 2013 Well I guess I have to wait and see if it will fit. As far as I see they look quite similar Link to comment Share on other sites More sharing options...
KCwagon Posted July 17, 2013 Share Posted July 17, 2013 Well I guess I have to wait and see if it will fit. As far as I see they look quite similar This should be in the "non-bolt-up" turbocharger upgrade thread. Link to comment Share on other sites More sharing options...
mmmmspecb Posted August 13, 2013 Share Posted August 13, 2013 My 16G is for sale It's still brand new purchased from BNR on 5/1/2013. Check out my FS thread: http://legacygt.com/forums/showthread.php/bnib-bnr-16g-used-avo-tmic-212365.html Link to comment Share on other sites More sharing options...
Moddiction Posted August 18, 2013 Share Posted August 18, 2013 Hmm tempted to go for the 18g turbo instead of 16g now. Was set on 16g but been thinking mor and a little better top end would be nice I think. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
JMLegacy Posted August 18, 2013 Share Posted August 18, 2013 More top end is as useless as a third nipple If you have windy hills that is. For highways, i guess the 18g would be ideal. I went with a vf34 turbo and i'm not sure if i like the turbo lag Link to comment Share on other sites More sharing options...
SBT Posted August 19, 2013 Author Share Posted August 19, 2013 @ JML - Stock exhaust? - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
JMLegacy Posted August 19, 2013 Share Posted August 19, 2013 NO, 3" bellmouth downpipe stock cat-back But I'm 2 liter JDM. the 34 is like the 16G, I think the 18G for your 2.5 would feel like my vf34 on my 2.0 But I'm just assuming ask around Link to comment Share on other sites More sharing options...
SBT Posted August 19, 2013 Author Share Posted August 19, 2013 Even on the 2.0L, it's likely that a properly-sized ELH and improved fueling would move your VF34's boost threshold further to the left. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
JMLegacy Posted August 19, 2013 Share Posted August 19, 2013 I'm untuned now, so i believe you Link to comment Share on other sites More sharing options...
KCwagon Posted August 19, 2013 Share Posted August 19, 2013 More top end is as useless as a third nipple If you have windy hills that is. For highways, i guess the 18g would be ideal. I went with a vf34 turbo and i'm not sure if i like the turbo lag I'm untuned now, so i believe you So you believe the vf34 is laggy and you are untuned ? Maybe you should get tuned before you make too many judgements. Link to comment Share on other sites More sharing options...
JMLegacy Posted August 20, 2013 Share Posted August 20, 2013 I agree with you. But based on my estimation it won't change much. Looking at my spoolup region in my tables it can't get much leaner than that, and dual AVCS...maybe AVCS can take some more pressure. Idk though, leave that to the tuner Link to comment Share on other sites More sharing options...
TheBlackPearl Posted August 20, 2013 Share Posted August 20, 2013 Whoa. I just read thru all 27 pages because I joined the "my turbo blew" club this weekend. ZERO boost when I left the house Saturday morning so turned around, garaged it and grabbed the wifes 'Rolla. No smoke either. Turbine spins, I can't hear or see housing contact (granted it's still in car) but if I push a little axialy the shaft binds and gets resistant. TMIC says I caught it in time and I planned to pull turbo, drain oil and pull oil pan today but I didn't get to it I lost the wind from my sails, haha. BNR 16g appeals to me. I can't do any fueling now. Hell, I can't even afford this right now, damnit. The Cobb OTS stage 2 map would run that turbo just fine wouldn't it? Self proclaimed PNW Craiglist find of the day Champion, April 2014. Link to comment Share on other sites More sharing options...
