Giffle Posted December 17, 2015 Share Posted December 17, 2015 Got a Check Engine yesterday with a rough idle. Change the ignition coil on cyl no 2. Running fine now Link to comment Share on other sites More sharing options...
Dispatch20 Posted December 19, 2015 Share Posted December 19, 2015 Fought an epic battle with the rear lower strut bolt, and eventually won. One side came off in 5 seconds with just an impact wrench. The frozen side required pb blaster, MAPP torch, ice cubes, breaker bar, impact wrench and 3 hours. The damn nut was seized onto the bolt. After 176k miles, the rear shocks were completely toast. Oddly, one of my front struts was in excellent condition. I'll do the other front strut later tonight. I HATE doing front struts on Legacys. Spring compressors work pretty terrible on these because only a single compressor can get 3 coils worth inside it. Link to comment Share on other sites More sharing options...
Dispatch20 Posted December 28, 2015 Share Posted December 28, 2015 Today, I drained the manual transmission fluid and put in Redline 75W90ns. It my brief drive out of the garage and back in, the shifts felt buttery smooth. I also installed a set of orange Hella Supertone horns with the Subimods harness and relay. During the horn install, I learned that the 3rd Gen Legacy is well-suited for the standard bracket that comes with the hella horns. The subimods bracket won't fit due to curvature in the sheet metal where the horns bolt on to. Only the 4th Gen Legacy and WRX's really benefit from the relocation bracket. Link to comment Share on other sites More sharing options...
Giffle Posted December 28, 2015 Share Posted December 28, 2015 My Leggy is now waxed and all ready for tomorrow's snowstorm Link to comment Share on other sites More sharing options...
steveo38 Posted December 29, 2015 Share Posted December 29, 2015 did the driver side wheel bearing on my 01 outback and and the ball joint is stuck in the lower control arm but came out of the hub assembly. so I'll have a fun day trying to get that out. Link to comment Share on other sites More sharing options...
Dispatch20 Posted December 29, 2015 Share Posted December 29, 2015 did the driver side wheel bearing on my 01 outback and and the ball joint is stuck in the lower control arm but came out of the hub assembly. so I'll have a fun day trying to get that out. A Pitman puller works well to separate the ball joint from the arm. Link to comment Share on other sites More sharing options...
JaQuan15 Posted January 2, 2016 Share Posted January 2, 2016 Happy New Years everyone live from Connecticut ! https://vimeo.com/150504193 Link to comment Share on other sites More sharing options...
JBisson Posted January 3, 2016 Share Posted January 3, 2016 Took the orange lens out of my headlights and refinished the lenses as well Before the orange lens was removedhttp://images.tapatalk-cdn.com/16/01/02/e7ff294c71701ce2fc97542572c7e665.jpg After the orange lens was removed http://images.tapatalk-cdn.com/16/01/02/52e37a5e8921cde774bdbbbb8d84b84f.jpg Then after the lenses were resurfaced http://images.tapatalk-cdn.com/16/01/02/5e4c7a7ac1f7819c0814e9f9a3949f9d.jpghttp://images.tapatalk-cdn.com/16/01/02/bb39ae19e5d70b6255cf724c72af2faf.jpghttp://images.tapatalk-cdn.com/16/01/02/4adaf5b17a8254256960df684317e747.jpghttp://images.tapatalk-cdn.com/16/01/02/8cc52b3439ea37a1767b5876af1b1cc0.jpg Then finally reinstalled on the car http://images.tapatalk-cdn.com/16/01/02/3442e8e7d5fadacf1d59bafd63abfb8d.jpghttp://images.tapatalk-cdn.com/16/01/02/3d69c6ab0505a197243bd4ec702d3d8e.jpg Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
xrayspecs Posted January 3, 2016 Share Posted January 3, 2016 replaced the front backpads and bleed out the lines. Link to comment Share on other sites More sharing options...
lagwagn Posted January 4, 2016 Share Posted January 4, 2016 Installed clear OEM JDM side markers and a new double din nav deck. It was a good Sunday. Old: http://rbpfuel.com/forumimages/subaru_old_side_markers.jpg New: http://rbpfuel.com/forumimages/subaru_new_side_markers.jpg New Nav Deck: http://rbpfuel.com/forumimages/subaru_new_deck.jpg Link to comment Share on other sites More sharing options...
Dispatch20 Posted January 5, 2016 Share Posted January 5, 2016 New Nav Deck: http://rbpfuel.com/forumimages/subaru_new_deck.jpg Nice! Which double din unit is this? I was thinking of putting one in mine (mostly to add a rear view camera display screen). Link to comment Share on other sites More sharing options...
Dispatch20 Posted January 5, 2016 Share Posted January 5, 2016 Smelled gas in the car today. It's super cold (7F) today, so it was the classic hose/clamp leak. I tightened them up, and hopefully it fixes it. Link to comment Share on other sites More sharing options...
lagwagn Posted January 5, 2016 Share Posted January 5, 2016 Nice! Which double din unit is this? I was thinking of putting one in mine (mostly to add a rear view camera display screen). Just a Kenwood. Think it is a DNN770. Its got rear view camera capability though along with a bunch of other nice features. Alberta finally started adding demerits to "distracted driving" tickets, so I was more interested in the Bluetooth for calls and such. Plus, if you have an installer that knows what he is doing, they can enable video on the deck while you are driving without needing an expensive add on kit like other brands. Link to comment Share on other sites More sharing options...
Lwolf25 Posted January 8, 2016 Share Posted January 8, 2016 Smelled gas in the car today. It's super cold (7F) today, so it was the classic hose/clamp leak. I tightened them up, and hopefully it fixes it. Same exact thing here in Pittsburgh. I've been tightening them for 3 years now so I think its time to replace them. Just picked up some new hoses and clamps. Link to comment Share on other sites More sharing options...
allmightyfork Posted January 8, 2016 Share Posted January 8, 2016 dorve it to work...debating on whether i should change out my r/f wheel bearing and upper radiator hose. its hard to get the motivation to work on my car when all i do is fix everyone elses. Link to comment Share on other sites More sharing options...
Chrio Posted January 10, 2016 Share Posted January 10, 2016 Finally installed my Hella Super Tones Link to comment Share on other sites More sharing options...
steveo38 Posted January 11, 2016 Share Posted January 11, 2016 so this will help some of you that have been having the problem i have been having as well with the fuel leaking/smells.. there are about 3-4 small rubber lines on the corners of the motor one drivers side above cly.#4, above cly.#2, and i think last one is above cly#1 but maybe one for cly#3 not sure...anyway these normally go first if you have any fuel smell inside your car... in the picture my finger is on the hose im talking about.. hope this helps and if you need contact me i just had the dealer fix mine cause they did a head gasket for me and they didnt tighten thee clamps so thats why mine where leaking ... lol Link to comment Share on other sites More sharing options...
Lwolf25 Posted January 11, 2016 Share Posted January 11, 2016 Replaced all fuel lines that potential fuel small was coming from along with new fuel hose clamps. changed oil, got the passenger side pads and rotors changed. Started on drivers side and snapped a bolt off inside the caliper bracket because it was too seized up. Picked up a new bracket at autozone and will be trying to finish today. Link to comment Share on other sites More sharing options...
Dispatch20 Posted February 6, 2016 Share Posted February 6, 2016 I finished installing and hardwiring a dash cam. Just like in my 08 Legacy, I went with the A118C / B40. I used a fuse tap, which was a pain for various reasons. http://uploads.tapatalk-cdn.com/20160206/0da1bd2db7104d3f76bc0c7c9aac2312.jpghttp://uploads.tapatalk-cdn.com/20160206/290c36f723b0570a424450466b6bad6e.jpghttp://uploads.tapatalk-cdn.com/20160206/5c646b2a7658324985e6b1272a183f0d.jpg Link to comment Share on other sites More sharing options...
Zaldon Posted February 6, 2016 Share Posted February 6, 2016 http://i68.tinypic.com/11rru41.jpg Mudflaps on and washed it up a bit. Thinking about either new rims with an offset or wheel spacers next. Link to comment Share on other sites More sharing options...
Deacon Posted February 7, 2016 Share Posted February 7, 2016 My '01 legacy developed the head gasket they're known for. Forgot about the additive and was stressing about the cost of replacing it. Then I remembered the research I did before I purchased it. Went to the dealership, picked up two bottles of the coolant system conditioner, poor then in and the leak stopped immediately. $15 is better than $2000. Link to comment Share on other sites More sharing options...
nxmb Posted February 8, 2016 Share Posted February 8, 2016 http://uploads.tapatalk-cdn.com/20160208/aa51d586262bc74dd39dbc8e7d37df43.jpg http://uploads.tapatalk-cdn.com/20160208/4a1a214589f7bf1336954f3b680bd363.jpg Installed new speakers (4 doors) and head unit. Link to comment Share on other sites More sharing options...
xrayspecs Posted February 28, 2016 Share Posted February 28, 2016 Put on the uel headers and changed the oil today. Link to comment Share on other sites More sharing options...
Swannee225 Posted February 28, 2016 Share Posted February 28, 2016 Where'd you get the UEL headers. I have an 03 legacy L Link to comment Share on other sites More sharing options...
xrayspecs Posted February 28, 2016 Share Posted February 28, 2016 From the for sale section on here picked up some borlas. But had been planning on going with ebay knock offs for a while. I have the inline oil cooler that it they normalu list as not fitting. but the combination of a little persuasion from a bfh and going to a 99 miata filter there's no interference issues. I'll be going to a remote filter just to get a larger element in the near future. Link to comment Share on other sites More sharing options...
