Dispatch20 Posted November 8, 2015 Share Posted November 8, 2015 I have the template ready to print in a .doc file. I'll upload it when I get to my home! You can see the template I used a few post back in this post. Oh yeah, I see that now. Thanks for sending along the template! So this afternoon I decided to tackle the motor mounts. I did it on ramps (awful!) and left the headers attached (rusty bolts). I lifted the motor by the oil pan with a block of wood and a floor jack. Holy moly that was a huge pain! I'd rather do a timing belt. The motor mounts took me like 5 hours and it was only 6 bolts! I don't know if the 3rd gen Legacy is a lot harder than an Impreza for some reason, but I don't see how people are able to do this job easily. It took every trick I knew and a lot of different wrenches. The steering rack and subframe really block the rear motor mount bolts. (p.s. don't do motor mounts immediately AFTER undercoating with fluid film). Link to comment Share on other sites More sharing options...
Psycho_TwM Posted November 8, 2015 Share Posted November 8, 2015 Oh yeah, I see that now. Thanks for sending along the template! So this afternoon I decided to tackle the motor mounts. I did it on ramps (awful!) and left the headers attached (rusty bolts). I lifted the motor by the oil pan with a block of wood and a floor jack. Holy moly that was a huge pain! I'd rather do a timing belt. The motor mounts took me like 5 hours and it was only 6 bolts! I don't know if the 3rd gen Legacy is a lot harder than an Impreza for some reason, but I don't see how people are able to do this job easily. It took every trick I knew and a lot of different wrenches. The steering rack and subframe really block the rear motor mount bolts. (p.s. don't do motor mounts immediately AFTER undercoating with fluid film). Here is the link for the template. It's a scan of the original but it's on the right size, ready to print in 2 parts. http://ge.tt/7cOoTPR2/v/0 Link to comment Share on other sites More sharing options...
Dispatch20 Posted November 9, 2015 Share Posted November 9, 2015 Here is the link for the template. It's a scan of the original but it's on the right size, ready to print in 2 parts. http://ge.tt/7cOoTPR2/v/0 I installed my spoiler today! I put up some details here: http://legacygt.com/forums/showthread.php/stock-sedan-spoiler-install-diy-247041.html Link to comment Share on other sites More sharing options...
Dispatch20 Posted November 10, 2015 Share Posted November 10, 2015 Time to install the new arrivals! JDM sidemarkers and B4 mouldings for the sideskirts [ATTACH]217953[/ATTACH] Enviado desde mi Nexus 5 mediante Tapatalk Do you have any pictures of the sideskirt moldings on your sedan? Are they what are commonly called "spats"? Link to comment Share on other sites More sharing options...
Psycho_TwM Posted November 10, 2015 Share Posted November 10, 2015 Do you have any pictures of the sideskirt moldings on your sedan? Are they what are commonly called "spats"? According to SubaruParts.com, it's called "rocker molding". Link: http://subaruparts.com/parts/2002/SUBARU/Legacy/GT?siteid=218240&vehicleid=919&diagram=7522475 Here's a photo with the side skirts installed. It took more clips than SubarParts said (I'm sure I saw another diagram with more clips, but I can't find it), and because there is no template, the most painful part was take the right measure to make the holes. http://images.tapatalk-cdn.com/15/11/10/5d5dfcae1aaaab30518ad88b1dbf0313.jpg Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 11, 2015 Share Posted November 11, 2015 New right front wheel bearing... 92k miles Link to comment Share on other sites More sharing options...
xrayspecs Posted November 16, 2015 Share Posted November 16, 2015 replaced both rear wheel bearings. Link to comment Share on other sites More sharing options...
Zaldon Posted November 18, 2015 Share Posted November 18, 2015 Started doing my lights on the car, didn't do it all today but over the past couple weeks as I got bulbs in. Just have the HVAC left to do on the interior so far. The lights are now LED, the picture does make them seem like they are overly bright, but they aren't that bad, I love how they look. Had some random guy compliment the interior lights haha. http://i64.tinypic.com/2hh18qf.jpg http://i66.tinypic.com/2usjrtl.jpghttp://i67.tinypic.com/6zas68.jpghttp://i66.tinypic.com/28u03r8.jpg http://i63.tinypic.com/2rxg0hy.jpghttp://i68.tinypic.com/29pf7fa.jpg The Door http://i66.tinypic.com/16iduyv.jpg The Dome Light http://i68.tinypic.com/14o23p5.jpg The Map Lights http://i68.tinypic.com/1yalpg.jpg The Trunk Light http://i63.tinypic.com/2ivmz9c.jpg Link to comment Share on other sites More sharing options...
Dispatch20 Posted November 20, 2015 Share Posted November 20, 2015 In an attempt to reduce the severe looseness & bounciness of my drivetrain, I installed a new tranny mount. Sometimes I can just let off the throttle and the drivingtrain starts bucking around. My order of repairs are: 1) New motor mounts - done 2) New tranny mount - done 3) New neutral switch - part in hand, need to install it 4) Rear diff bushing repair - need to research this more I should also probably look at the driveshaft center bearing, if I can figure out how to tell if it's bad or not. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 20, 2015 Share Posted November 20, 2015 Started doing my lights on the car, didn't do it all today but over the past couple weeks as I got bulbs in. Just have the HVAC left to do on the interior so far. The Door The Dome Light The Map Lights The Trunk Light Do you have the part numbers? Link to comment Share on other sites More sharing options...
Zaldon Posted November 22, 2015 Share Posted November 22, 2015 Do you have the part numbers? Map & Courtesy DE3175, this is also the one for the Dome, it's a 31mm bulb, I got a larger led pad for the Dome though. Just stay under 8 Watts for it and it'll work good. You'll need two for the doors (one on each side), two for the map lights (one for each) and one for the Dome. For the Trunk, Cluster, and License plate they all take a 194 bulb. One for the trunk, 4 for the cluster and two for the license plate. For the Lighter Ring, Keyhole Ring and PRND321 and the smaller dash displays (the two small screens) all take a 74 bulb. All of these just take one bulb, the dash screens obviously take one for each. The key ring will just need a slim wedge, if you get a regular one (like I had) just sanded it down a little to fit in. Link to comment Share on other sites More sharing options...
Giffle Posted November 22, 2015 Share Posted November 22, 2015 Krown rust treatment. Almost ready for winter Link to comment Share on other sites More sharing options...
Psycho_TwM Posted November 23, 2015 Share Posted November 23, 2015 Fog lights installed! Bought from eBay with the original switch http://images.tapatalk-cdn.com/15/11/22/e3622b9efed3f36c1201880363b70f1b.jpg Link to comment Share on other sites More sharing options...
JBisson Posted November 23, 2015 Share Posted November 23, 2015 Converted my fog lights and low beams to HID's Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted November 25, 2015 Share Posted November 25, 2015 installing LED tomorrrow Link to comment Share on other sites More sharing options...
Matty2Hotty Posted November 27, 2015 Share Posted November 27, 2015 Found the owner of my old Outback on cardomain.... Douche. Said he got the car stock besides the coilovers. Taking the credit of all the "mods" i have done to it. After I posted comment on his Instagram sayin am the original owner and built the car he deleted all my stuff. http://i264.photobucket.com/albums/ii199/WashHottestPlumber/747E12AB-D2F1-4704-959E-4D22C84B4FB3_zpstyff3jla.png Link to comment Share on other sites More sharing options...
Radials Posted November 27, 2015 Share Posted November 27, 2015 New NGK iridium plugs and wires Just bought a '02 L wagon yesterday! going to be doing the spark plugs. Bought the same plugs as you, any tips? Link to comment Share on other sites More sharing options...
xrayspecs Posted November 27, 2015 Share Posted November 27, 2015 Picked up a screw in the wheel so got it plugged and patched. Link to comment Share on other sites More sharing options...
Matty2Hotty Posted November 30, 2015 Share Posted November 30, 2015 Sneak peak on some goodies coming.... http://i264.photobucket.com/albums/ii199/WashHottestPlumber/Cars/95FE54BC-CF1E-4077-A240-DB31BF109C04_zpsirztqc6d.jpg Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted December 3, 2015 Share Posted December 3, 2015 got the Map lights (9 LED) Dome lights (12 LED) Trunk light (5 LED) License plate (5 LED) lights installed you could easily go 15 LED on the dome light for sure Link to comment Share on other sites More sharing options...
Dylan.Pink Posted December 12, 2015 Share Posted December 12, 2015 What are some good lowering springs for a Gen3 Liberty? Link to comment Share on other sites More sharing options...
patrikman Posted December 12, 2015 Share Posted December 12, 2015 Found the owner of my old Outback on cardomain.... Douche. Said he got the car stock besides the coilovers. Taking the credit of all the "mods" i have done to it. After I posted comment on his Instagram sayin am the original owner and built the car he deleted all my stuff. http://i264.photobucket.com/albums/ii199/WashHottestPlumber/747E12AB-D2F1-4704-959E-4D22C84B4FB3_zpstyff3jla.png I'm down for messing with him lol, that's some lame shit. Link to comment Share on other sites More sharing options...
Matty2Hotty Posted December 12, 2015 Share Posted December 12, 2015 Got another interesting piece from Japan today.... http://i264.photobucket.com/albums/ii199/WashHottestPlumber/Cars/A7B230BC-BA78-4131-821D-30395C2C34A9_zpsoi8xplfp.jpg Link to comment Share on other sites More sharing options...
geeko Posted December 14, 2015 Share Posted December 14, 2015 Today I changed the valve cover gaskets on my driveway in 2 hours. Not as complicated as it sounded Link to comment Share on other sites More sharing options...
Dispatch20 Posted December 16, 2015 Share Posted December 16, 2015 Received two new front KYB struts and two new top hats off EBay. They were unused, open box from APX. Both struts were $60 shipped total ($25 for one, $35 for the other). Top hats were $55 shipped total ($27.50 ea). Good deal!http://images.tapatalk-cdn.com/15/12/15/9e6c89ee150c1a8ddf03c216cac99d42.jpg One strut was the older "GR2" branding with silver paint. Must be 4 years old or older! Identical to the black ExcelG strut in every way except for color. Link to comment Share on other sites More sharing options...
